[petsc-dev] Test output broken for test sets
Scott Kruger kruger at txcorp.com
Wed Sep 26 10:08:04 CDT 2018
I'll take a look.
Scott
On 9/26/18 8:58 AM, Jed Brown wrote:
> Scott, do you know how to fix this?
> Jakub Kruzik <jakub.kruzik at vsb.cz> writes:
>> Related issues:
>> https://lists.mcs.anl.gov/pipermail/petsc-dev/2018-August/023448.html
>> Jakub
>> On 9/24/18 3:26 PM, Matthew Knepley wrote:
>>> At least on my machine, this does not work correctly
>>>    testset:
>>>      nsize: {{1 2 4}}
>>>      args: -use_generator -faces {{2,2,2  1,3,5  3,4,7}}
>>>      args: -interpolate -distribute -interpolate_after_distribute {{0 1}}
>>>      args: -dm_plex_check_pointsf
>>>      test:
>>>        #TODO some combinations generate wrong SF
>>>        suffix: 6_tet
>>>        requires: ctetgen
>>>        args: -cell_simplex 1 -dm_plex_generator ctetgen
>>>      test:
>>>        suffix: 6_hex
>>>        args: -cell_simplex 0
>>> If I give REPLACE=1, it makes a single output file 6_hex.out and
>>> 6_tet.out for all the test, with the output of the last test in it.
>>>    Thanks,
>>>       Matt
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
Boulder, CO 80303                Fax:   (303) 448-7756
