[petsc-dev] tiny issues in test harness
Jakub Kruzik
jakub.kruzik at vsb.cz
Thu Aug 16 10:30:43 CDT 2018
Also, test inside testset overwrites testset nsize with default nsize=1.
E.g.
testset:
nsize: 4
test:
#suffix: 1
is sequential. However, if I uncomment the suffix, it works as expected
with 4 ranks.
Best,
Jakub
On 08/14/2018 12:05 PM, Jakub Kruzik wrote:
> Hi all,
> I started using test harness in PERMON and find out a couple of issues
> with it.
> 1) multiple "args:" keywords in "test:" in "testset:" are ignored
> except for the last "args:" keyword. See attached MWE and check it with
> python2 ${PETSC_DIR}/config/testparse.py -t ex1.c -v 3
> 2) single quotes can't be used in "filter:" keyword. E.g. filter:
> grep 'r =' generates
> petsc_testrun ... 'grep 'r =''
> resulting in filter being "grep r". Might be worth mentioning this in
> dev manual and/or putting guards into parsing/petsc_testrun.
> Best,
> Jakub
