[petsc-dev] Test output broken for test sets
    Matthew Knepley
    knepley at gmail.com
    Mon Sep 24 08:26:35 CDT 2018
At least on my machine, this does not work correctly
  testset:
    nsize: {{1 2 4}}
    args: -use_generator -faces {{2,2,2  1,3,5  3,4,7}}
    args: -interpolate -distribute -interpolate_after_distribute {{0 1}}
    args: -dm_plex_check_pointsf
    test:
      #TODO some combinations generate wrong SF
      suffix: 6_tet
      requires: ctetgen
      args: -cell_simplex 1 -dm_plex_generator ctetgen
    test:
      suffix: 6_hex
      args: -cell_simplex 0
If I give REPLACE=1, it makes a single output file 6_hex.out and 6_tet.out
for all the test, with the output of the last test in it.
     Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180924/c7ead128/attachment.html>
