[petsc-dev] MatAssembly removes all preallocation info
Kong, Fande fande.kong at inl.gov
Mon Sep 25 11:00:54 CDT 2017
Hi Matt,
Thanks for your reply.
The sparsity pattern is slightly different from one Newton iteration to
another. We preallocate  enough memory at the beginning, and want to use
that memory for the following iterations.
Does PETSc accutally free the preallocated (extra) memory? I so cannot use
it during the second iteration.
Fande,
On Mon, Sep 25, 2017 at 9:43 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Sep 25, 2017 at 11:39 AM, Kong, Fande <fande.kong at inl.gov> wrote:
>> Hi All,
>> A matrix is created with the right preallocation, and then MatAssembly is
>> called. The preallocation info will be removed. We insert any values then,
>> and will encounter an malloc error.
>> My question is that we was intending to design like this way? Attached
>> simple example demonstrates what I am talking about.
> Yes, this is the intent. Why are you assembling? Could you use
> MAT_ASSEMBLY_FLUSH?
>   Matt
>> Fande,
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.caam.rice.edu_-7Emk51_&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=WrDpQnak7wiz1D4Pyx_jvRGpFKeNDwW2WOH8cIlxrP0&s=7NvRav6CET5Eqpsg7MAiCne1LJ1h2RYKf-OgP6trMkE&e=>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170925/a2ba28c5/attachment-0001.html>
