[petsc-dev] MatAssembly removes all preallocation info
Mon Sep 25 10:43:28 CDT 2017
On Mon, Sep 25, 2017 at 11:39 AM, Kong, Fande <fande.kong at inl.gov> wrote:
> Hi All,
> A matrix is created with the right preallocation, and then MatAssembly is
> called. The preallocation info will be removed. We insert any values then,
> and will encounter an malloc error.
> My question is that we was intending to design like this way? Attached
> simple example demonstrates what I am talking about.
Yes, this is the intent. Why are you assembling? Could you use
MAT_ASSEMBLY_FLUSH?
  Matt
> Fande,
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170925/21ee5062/attachment.html>
