[petsc-dev] MatAssembly removes all preallocation info
    Stefano Zampini
    stefano.zampini at gmail.com
    Mon Sep 25 11:05:02 CDT 2017
If you know the union of the different sparsity patterns, after you
preallocate you can set all zeros to use all the entries. This way PETSc
will not complain about new nonzeros in successive assemblies.
Il 25 Set 2017 7:01 PM, "Kong, Fande" <fande.kong at inl.gov> ha scritto:
> Hi Matt,
> Thanks for your reply.
> The sparsity pattern is slightly different from one Newton iteration to
> another. We preallocate  enough memory at the beginning, and want to use
> that memory for the following iterations.
> Does PETSc accutally free the preallocated (extra) memory? I so cannot use
> it during the second iteration.
> Fande,
> On Mon, Sep 25, 2017 at 9:43 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Sep 25, 2017 at 11:39 AM, Kong, Fande <fande.kong at inl.gov> wrote:
>>> Hi All,
>>> A matrix is created with the right preallocation, and then MatAssembly
>>> is called. The preallocation info will be removed. We insert any values
>>> then, and will encounter an malloc error.
>>> My question is that we was intending to design like this way? Attached
>>> simple example demonstrates what I am talking about.
>> Yes, this is the intent. Why are you assembling? Could you use
>> MAT_ASSEMBLY_FLUSH?
>>   Matt
>>> Fande,
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.caam.rice.edu_-7Emk51_&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=WrDpQnak7wiz1D4Pyx_jvRGpFKeNDwW2WOH8cIlxrP0&s=7NvRav6CET5Eqpsg7MAiCne1LJ1h2RYKf-OgP6trMkE&e=>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170925/36b43844/attachment.html>
