[petsc-dev] PetscSF in Fortran
Adrian Croucher
a.croucher at auckland.ac.nz
Sun Oct 15 20:52:47 CDT 2017
On 16/10/17 14:14, Matthew Knepley wrote:
> This last file petscao.h is including a "petsc/finclude/petscao.h",
> which contains various definitions including the definition of AO. Do
> I need to make some sort of similar "petsc/finclude/petscsf.h"?
> It looks like PetscSF is already defined inside
> petsc/finclude/petscis.h. It's not clear to me which bits of the
> SF interface need to be in their own files and which are lumped in
> with the IS interface.
> If SF is already in the IS part then we do not technically need to
> move it out. It just seems to me that it would be cleaner to do so.
So do you think the SF stuff in petsc/finclude/petscis.h should be taken
out, and put into a new petsc/finclude/petscsf.h ?
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171016/26315491/attachment.html>
