[petsc-dev] PetscSF in Fortran
Matthew Knepley
knepley at gmail.com
Sun Oct 15 20:14:50 CDT 2017
On Sun, Oct 15, 2017 at 9:13 PM, Adrian Croucher <a.croucher at auckland.ac.nz>
wrote:
> On 16/10/17 13:12, Matthew Knepley wrote:
> Okay, I was wrong about what gets produced. Barry rewrote the Fortran
> bindings last, and I did not understand how everything
> was put together. You will need to make some modifications. Here is the
> idea: we build an F90 module for each class, and your
> stuff will go in the Vec module here:
> https://bitbucket.org/petsc/petsc/src/c99b676fdc4d0978b5621d138ceee2
> e1b7869aa6/src/vec/f90-mod/petscvecmod.F?at=master&
> fileviewer=file-view-default
> You will need to make a module in this file petscsf. It should look about
> like the petscao module. That means making
> a petscsf.h90 with your new interfaces, like this one
> e1b7869aa6/src/vec/f90-mod/petscis.h90?at=master&
> and also a generic petscsf.h, like this one
> e1b7869aa6/src/vec/f90-mod/petscao.h?at=master&
> This last file petscao.h is including a "petsc/finclude/petscao.h", which
> contains various definitions including the definition of AO. Do I need to
> make some sort of similar "petsc/finclude/petscsf.h"?
> It looks like PetscSF is already defined inside petsc/finclude/petscis.h.
> It's not clear to me which bits of the SF interface need to be in their own
> files and which are lumped in with the IS interface.
If SF is already in the IS part then we do not technically need to move it
out. It just seems to me that it would be cleaner to do so.
Matt
> - Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 4611 <+64%209-923%204611>
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171015/578739d2/attachment-0001.html>
