[petsc-dev] PetscSF in Fortran
Jed Brown jed at jedbrown.org
Sun Oct 15 21:16:43 CDT 2017
Adrian Croucher <a.croucher at auckland.ac.nz> writes:
> On 16/10/17 14:14, Matthew Knepley wrote:
>> This last file petscao.h is including a "petsc/finclude/petscao.h",
>> which contains various definitions including the definition of AO. Do
>> I need to make some sort of similar "petsc/finclude/petscsf.h"?
>>     It looks like PetscSF is already defined inside
>>     petsc/finclude/petscis.h. It's not clear to me which bits of the
>>     SF interface need to be in their own files and which are lumped in
>>     with the IS interface.
>> If SF is already in the IS part then we do not technically need to
>> move it out. It just seems to me that it would be cleaner to do so.
> So do you think the SF stuff in petsc/finclude/petscis.h should be taken
> out, and put into a new petsc/finclude/petscsf.h ?
I think that's desirable for symmetry with include/petscsf.h, but it
isn't important for your contribution.
