[petsc-dev] Discussion about time-dependent optimization moved from PR
Sun Oct 15 13:25:40 CDT 2017
On Sun, Oct 15, 2017 at 2:03 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
> >> I don't see how any of the present interfaces work for waveform
> >> relaxation.  I also think that is rarely a desirable technique -- too
> >> many awkward limitations.  My recollection is that Borzi only uses it
> >> for parabolic problems, for which adaptivity would have given much
> >> faster/cheaper solutions of equivalent accuracy.  The techniques are
> >> theoretically interesting, but have not demonstrated sufficient
> >> practicality to worry about.  Someone doing research on these full-space
> >> methods can just discretize space-time using SNES.
> >    Yes, but since that is a huge involved process (they need to manage
> >    time discretization etc themselves) they will NEVER compare with
> >    reduced methods and that is a huge part of the problem.
> Waveform relaxation and related methods intimately couples the temporal
> discretization with the spatial discretization.  It's a "transposed"
> interface.
> >    People do "research" in one or the other approach and never compare
> >    the two, leading to bad research. If we can combine them then one
> >    can actually compare the two approaches.
> >    Barry
> > I'm not saying it is possible to have a nice API that combines them.
> If we don't know how to combine them in a nice API and one is very
> important/practical while the other is research of questionable
> practicality, I'd rather focus on making the important thing work well
> rather than constantly hedging to possibly include the questionable
> thing.
I don't think the full space method is of questionable practically in the
time-independent case.
This is still important in this discussion because the way we talk about
the optimization problem,
and the specification of adjoint problems will inevitably be shared.
   Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171015/17f3c670/attachment.html>
