[petsc-dev] Discussion about time-dependent optimization moved from PR
Jed Brown
jed at jedbrown.org
Sun Oct 15 13:03:29 CDT 2017
Barry Smith <bsmith at mcs.anl.gov> writes:
>> I don't see how any of the present interfaces work for waveform
>> relaxation. I also think that is rarely a desirable technique -- too
>> many awkward limitations. My recollection is that Borzi only uses it
>> for parabolic problems, for which adaptivity would have given much
>> faster/cheaper solutions of equivalent accuracy. The techniques are
>> theoretically interesting, but have not demonstrated sufficient
>> practicality to worry about. Someone doing research on these full-space
>> methods can just discretize space-time using SNES.
> Yes, but since that is a huge involved process (they need to manage
> time discretization etc themselves) they will NEVER compare with
> reduced methods and that is a huge part of the problem.
Waveform relaxation and related methods intimately couples the temporal
discretization with the spatial discretization. It's a "transposed"
interface.
> People do "research" in one or the other approach and never compare
> the two, leading to bad research. If we can combine them then one
> can actually compare the two approaches.
> Barry
> I'm not saying it is possible to have a nice API that combines them.
If we don't know how to combine them in a nice API and one is very
important/practical while the other is research of questionable
practicality, I'd rather focus on making the important thing work well
rather than constantly hedging to possibly include the questionable
thing.
