[petsc-dev] Discussion about time-dependent optimization moved from PR
Jed Brown
jed at jedbrown.org
Sun Oct 15 13:42:05 CDT 2017
Matthew Knepley <knepley at gmail.com> writes:
> I don't think the full space method is of questionable practically in the
> time-independent case.
> This is still important in this discussion because the way we talk about
> the optimization problem,
> and the specification of adjoint problems will inevitably be shared.
Let's simplify a lot. If you want to share the specification for
sensitivities, propose for us a shared specification for just the
forward problem that is amenable to Borzi-type smoothers.
