[petsc-dev] PETSc statistics
Sean Farley
sean at farley.io
Thu Jun 8 22:29:16 CDT 2017
Jed Brown <jed at jedbrown.org> writes:
> Sean Farley <sean at farley.io> writes:
>>> Andrew McRae <A.T.T.McRae at bath.ac.uk> writes:
>>>> But we clone from our fork (formerly Bitbucket firedrake/petsc, now Github
>>>> firedrakeproject/petsc), not from Bitbucket petsc/petsc.
>>> Yeah, the stats won't be perfect, of course. Hopefully, useful enough
>>> for some general idea of the numbers.
>> Also, there are harder questions to answer: does a pull count? If so,
>> what about a no-op pull? A pull of one commit? etc.
> It would be fascinating to know how often people issue pulls. For
> example, we really have no idea how many people track 'master' or
> 'next', but daily pulls, particularly those not at exactly the same time
> each day (e.g., cron/nightly testing versus issued by a human) would
> help give a picture.
Fair enough. Attached is a new PDF with that data. As you mention,
though, there's no good way to tell a pull is from a bot. I've modded
out the more obvious on-the-hour / half-hour / etc. but still, you take
this with a grain of salt.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170608/239aa1b3/attachment.sig>
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170608/239aa1b3/attachment.pdf>
