[petsc-dev] PETSc statistics
Jed Brown jed at jedbrown.org
Thu Jun 8 22:34:15 CDT 2017
Sean Farley <sean at farley.io> writes:
> Jed Brown <jed at jedbrown.org> writes:
>>>> Andrew McRae <A.T.T.McRae at bath.ac.uk> writes:
>>>>> But we clone from our fork (formerly Bitbucket firedrake/petsc, now Github
>>>>> firedrakeproject/petsc), not from Bitbucket petsc/petsc.
>>>> Yeah, the stats won't be perfect, of course. Hopefully, useful enough
>>>> for some general idea of the numbers.
>>> Also, there are harder questions to answer: does a pull count? If so,
>>> what about a no-op pull? A pull of one commit? etc.
>> It would be fascinating to know how often people issue pulls.  For
>> example, we really have no idea how many people track 'master' or
>> 'next', but daily pulls, particularly those not at exactly the same time
>> each day (e.g., cron/nightly testing versus issued by a human) would
>> help give a picture.
> Fair enough. Attached is a new PDF with that data. As you mention,
> though, there's no good way to tell a pull is from a bot.
Unique IP?  Doesn't help for on-demand CI systems, but would be relevant
to institutional machines.
> I've modded out the more obvious on-the-hour / half-hour / etc. but
> still, you take this with a grain of salt.
Cool, thanks.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170608/ce8df536/attachment.sig>
