[petsc-dev] download problem p4est on Cori at NERSC
    Mark Adams
    mfadams at lbl.gov
    Thu Feb 16 17:32:50 CST 2017
Hong, do you do this for KNL?  -C knl
On Thu, Feb 16, 2017 at 6:29 PM, Mark Adams <mfadams at lbl.gov> wrote:
> On Thu, Feb 16, 2017 at 4:49 PM, Zhang, Hong <hongzhang at anl.gov> wrote:
>> On cori, I tried to compile PETSc on a compute node in the interactive
>> mode, but it did not work. What worked for me is to do the following:
>> 1. configure with --with-batch=1 to generate a binary
>> 2. submit the binary to the queue: srun -n 1 -c 1 ./conftest-xxx
>> 3. run the reconfigure-xxx script after the submitted job is done
> Humm, I tried this, 1 and 3 on the login node and 2 on a compute node, and
> I seem to get the same error. And I nuked the arch directory before I
> started.
>> Hong (Mr.)
>> On Feb 15, 2017, at 3:38 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> Oh, this is because git does not work on KNL. Maybe I should do
>> with-batch=1,
>> On Wed, Feb 15, 2017 at 4:36 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> I get this error on the KNL partition at NERSC.  P4est works on the
>>> Haswell partition and other downloads seem to work on the KNL partition.
>>> Any ideas?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170216/7b879338/attachment.html>
