[petsc-dev] download problem p4est on Cori at NERSC
Mark Adams
mfadams at lbl.gov
Thu Feb 16 17:29:41 CST 2017
On Thu, Feb 16, 2017 at 4:49 PM, Zhang, Hong <hongzhang at anl.gov> wrote:
> On cori, I tried to compile PETSc on a compute node in the interactive
> mode, but it did not work. What worked for me is to do the following:
> 1. configure with --with-batch=1 to generate a binary
> 2. submit the binary to the queue: srun -n 1 -c 1 ./conftest-xxx
> 3. run the reconfigure-xxx script after the submitted job is done
Humm, I tried this, 1 and 3 on the login node and 2 on a compute node, and
I seem to get the same error. And I nuked the arch directory before I
started.
> Hong (Mr.)
> On Feb 15, 2017, at 3:38 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Oh, this is because git does not work on KNL. Maybe I should do
> with-batch=1,
> On Wed, Feb 15, 2017 at 4:36 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> I get this error on the KNL partition at NERSC. P4est works on the
>> Haswell partition and other downloads seem to work on the KNL partition.
>> Any ideas?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170216/c42f0c8f/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170216/c42f0c8f/attachment.obj>
