[petsc-dev] download problem p4est on Cori at NERSC
    Zhang, Hong
    hongzhang at anl.gov
    Thu Feb 16 19:38:47 CST 2017
Yes, I do it for KNL. But I just noticed that your problem is caused by p4est. I have not tried p4est. Sorry for not being helpful.
Hong (Mr.)
On Feb 16, 2017, at 5:32 PM, Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>> wrote:
Hong, do you do this for KNL?  -C knl
On Thu, Feb 16, 2017 at 6:29 PM, Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>> wrote:
On Thu, Feb 16, 2017 at 4:49 PM, Zhang, Hong <hongzhang at anl.gov<mailto:hongzhang at anl.gov>> wrote:
On cori, I tried to compile PETSc on a compute node in the interactive mode, but it did not work. What worked for me is to do the following:
1. configure with --with-batch=1 to generate a binary
2. submit the binary to the queue: srun -n 1 -c 1 ./conftest-xxx
3. run the reconfigure-xxx script after the submitted job is done
Humm, I tried this, 1 and 3 on the login node and 2 on a compute node, and I seem to get the same error. And I nuked the arch directory before I started.
Hong (Mr.)
On Feb 15, 2017, at 3:38 PM, Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>> wrote:
Oh, this is because git does not work on KNL. Maybe I should do with-batch=1,
On Wed, Feb 15, 2017 at 4:36 PM, Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>> wrote:
I get this error on the KNL partition at NERSC.  P4est works on the Haswell partition and other downloads seem to work on the KNL partition. Any ideas?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170217/d43e9376/attachment.html>
