[petsc-dev] Matt, please don't put buggy code into PETSc
Matthew Knepley
knepley at gmail.com
Sun Jan 19 18:55:41 CST 2014
On Sun, Jan 19, 2014 at 6:42 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > Yes, I am aware, and as I pointed out, I was checking the complex build,
> You didn't mention "complex" in this thread, just something about C
> typedefs which isn't true because you get warnings like this in C.
> warning: incompatible pointer types passing 'PetscScalar *' (aka '_Complex
> double *') to parameter of type 'PetscReal *' (aka 'double *')
> [-Wincompatible-pointer-types]
> ierr = VecNorm(Z,NORM_2,&dp);CHKERRQ(ierr); /* dp <-
> z'*z = e'*A'*B'*B*A'*e' */
I obviously do not get this warning.
Matt
> but not the examples because it is so noisy.
> Building a single executable for all the tests would make it trivial to
> check that they all compile cleanly. Making the runs completely clean
> brings back the difficulty of comparing output.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140119/9a55693c/attachment.html>
