[petsc-dev] PetscFEM routines missing user data arguments
Matthew Knepley
knepley at gmail.com
Thu Nov 14 20:03:29 CST 2013
On Thu, Nov 14, 2013 at 7:43 PM, Geoffrey Irving <irving at naml.us> wrote:
> It doesn't look like there's currently a way to pass user data down to
> the various fields in PetscFEM. Can I add an extra argument to each
> function, or is that part of the API going to change in a way that
> would obviate the extra argument?
That is by design. Here is the rationale. I want to be able to use CUDA or
OpenCL
to evaluate these low-level FEM integration routines, so you can't pass in
arbitrary
context.
I really don't think we should need arbitrary information at the lowest
level integration.
Right now you can pass in information using auxiliary fields. How would you
use
other stuff?
Matt
> Geoffrey
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131114/235ef0dd/attachment.html>
