[petsc-dev] PetscFEM routines missing user data arguments
Geoffrey Irving
irving at naml.us
Thu Nov 14 20:14:26 CST 2013
On Thu, Nov 14, 2013 at 6:03 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Nov 14, 2013 at 7:43 PM, Geoffrey Irving <irving at naml.us> wrote:
>> It doesn't look like there's currently a way to pass user data down to
>> the various fields in PetscFEM. Can I add an extra argument to each
>> function, or is that part of the API going to change in a way that
>> would obviate the extra argument?
> That is by design. Here is the rationale. I want to be able to use CUDA or OpenCL
> to evaluate these low-level FEM integration routines, so you can't pass in arbitrary context.
> I really don't think we should need arbitrary information at the lowest level integration.
> Right now you can pass in information using auxiliary fields. How would you use
> other stuff?
Well, you're probably not going to like application 1, which is
passing around PyObject*'s so I can write little FEM explorations in
numpy. Is the field support the right thing to do for constant
fields, or integer valued constant fields?
Geoffrey
