[petsc-dev] SNES for 2x2 problems
Wed Jan 2 16:19:37 CST 2013
On Wed, Jan 2, 2013 at 4:16 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jan 2, 2013 at 3:21 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> Matt, you know how we always tell people not to use KSP (or even Lapack)
>> for 2x2 problems? Surely the same advice applies to SNES, but your point
>> location code is doing it.
> Yep. The wrapping overhead is far less with some Newton iterations
Bogus
> , and we have no good alternative.
I posit that it's fewer lines of code (and much faster) to just write out
the Newton iteration on the spot. You don't need the full algorithmic
infrastructure for point location.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130102/9572e815/attachment.html>
