[petsc-dev] SNES for 2x2 problems
Matthew Knepley
knepley at gmail.com
Wed Jan 2 16:33:12 CST 2013
On Wed, Jan 2, 2013 at 4:19 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Wed, Jan 2, 2013 at 4:16 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Jan 2, 2013 at 3:21 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> Matt, you know how we always tell people not to use KSP (or even Lapack)
>>> for 2x2 problems? Surely the same advice applies to SNES, but your point
>>> location code is doing it.
>> Yep. The wrapping overhead is far less with some Newton iterations
> Bogus
>> , and we have no good alternative.
> I posit that it's fewer lines of code (and much faster) to just write out
> the Newton iteration on the spot. You don't need the full algorithmic
> infrastructure for point location.
And if it does not converge with fixed step? It will eventually morph nto
SNES.
I think your approach is bogus unless you can prove that your simple thing
is sufficient.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130102/8e2a8563/attachment.html>
