[petsc-dev] Okay, petscmath.h is a complete piece of crap and now its breaking my build
    Matthew Knepley
    knepley at gmail.com
    Tue Mar 15 13:51:46 CDT 2011
On Tue, Mar 15, 2011 at 1:49 PM, Jed Brown <jed at 59a2.org> wrote:
> On Tue, Mar 15, 2011 at 19:44, Matthew Knepley <knepley at gmail.com> wrote:
>> Verification of preprocess code is exactly as intensive, since you have to
>> compile each version. What is your point here?
> You can see all possible variants using a widely used and standardized
> language with editor support, the turn-around time for a correctness check
> is less because you don't have to reconfigure.
Again, I could say exactly the same thing. I can jsut look at the Python and
see all possible variants. This is not an argument.
>> The code I had would have continued to work, rather than break.
> Why did you bother pulling/updating if you wanted to work with an old
> version? This sounds more like a problem of you/the build system not knowing
> when to reconfigure.
In my scenario, it would have been easy to tell what was going on. Here it
was hard.
  Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110315/c2197e09/attachment.html>
