[petsc-dev] Help with configure and cmake
    Jed Brown
    jed at 59A2.org
    Fri Mar 11 11:14:18 CST 2011
On Fri, Mar 11, 2011 at 18:08, Matthew Knepley <knepley at gmail.com> wrote:
> This does not help AT ALL. How is it bad? I use it all the time just fine,
> so I was not changing it unless there were complaints.
If you can just update your scripts to only support petsc-dev, then no big
deal. But if you have a project that wants to support several versions of
PETSc, you would need to maintain multiple versions every time an API
changes. BuildSystem does not have a stable API: try building today's
petsc-dev using BuildSystem from last year or building last year's petsc
using today's BuildSystem.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110311/08231579/attachment.html>
