[petsc-dev] Help with configure and cmake
    Matthew Knepley
    knepley at gmail.com
    Fri Mar 11 11:08:24 CST 2011
On Fri, Mar 11, 2011 at 9:41 AM, Jed Brown <jed at 59a2.org> wrote:
> On Fri, Mar 11, 2011 at 13:02, Jose E. Roman <jroman at dsic.upv.es> wrote:
>> I have been adding support for cmake in SLEPc. My simple approach is:
>> 1) generate a SLEPcConfig.cmake file
>> 2) generate CMakeLists.txt with a cmakegen module adapted from petsc-dev
>> 3) run cmake with a cmakeboot module adapted from petsc-dev
>> Step 3 loads RDict and uses 'script' to process all PETSc configuration.
>> The problem comes with prefix-based installations of PETSc, since 'script'
>> is not available.
> Seems to me that necessary script support should be installed with prefix
> installs too. I do not understand why "script" is such a cumbersome beast to
> actually use, but it could be installed. However, exposing it to users turns
> much of BuildSystem into a public API. This does not seem like a good idea,
> especially with Barry's recent "cll" proposal for a much simpler alternative
> to parts of BuildSystem.
This does not help AT ALL. How is it bad? I use it all the time just fine,
so I was not changing it unless there were complaints.
   Matt
> As a long-term solution, I think we should install a pkgconfig file and/or
> a "petsc-config" script that knows about compilers, how to link shared
> versus static, etc.
>>  Can anyone suggest a solution for this? Maybe use Jed's FindPETSc.cmake
>> module?
> If you decide to use it, let me know if you find any problems. Writing
> significant logic in cmake-script is no fun.
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110311/878ebc8d/attachment.html>
