[petsc-dev] Help with configure and cmake
Matthew Knepley
knepley at gmail.com
Fri Mar 11 11:20:23 CST 2011
On Fri, Mar 11, 2011 at 11:14 AM, Jed Brown <jed at 59a2.org> wrote:
> On Fri, Mar 11, 2011 at 18:08, Matthew Knepley <knepley at gmail.com> wrote:
>> This does not help AT ALL. How is it bad? I use it all the time just fine,
>> so I was not changing it unless there were complaints.
> If you can just update your scripts to only support petsc-dev, then no big
> deal. But if you have a project that wants to support several versions of
> PETSc, you would need to maintain multiple versions every time an API
> changes. BuildSystem does not have a stable API: try building today's
> petsc-dev using BuildSystem from last year or building last year's petsc
> using today's BuildSystem.
No argument. That is why PETSc only supports a single version of anything.
Doing anything else is untenable.
Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110311/41f53c58/attachment.html>
