[mpich-discuss] Clustering
    bharat gupta
    bharat.85.monu at gmail.com
    Mon Oct 15 18:52:58 CDT 2012
Dear Sir,
I have all the requirements that you mentioned in your last mail. I just
want to know how to cluster them , so that I can utilize the power of both
for single computational work...
On Mon, Oct 15, 2012 at 10:29 PM, Svancara, Randall <rsvancara at wsu.edu>wrote:
>  I would say at a minimum, you need a dedicated gigabit Ethernet between
> the two machines, and an operating system that can support MPICH and
> Gromacs.  Also you will need a compiler to build all the software as well.
>  Lastly, your cluster will need to support SSH or some way to launch all
> the MPI daemons on both systems.
> I would start by learning how to use MPI Software to run on one node and
> then work on expanding to a multinode setup.   Also, you might be better
> served by starting out with one of the many MPI Hello World implementations
> and starting there as a learning platform and working your way up to more
> complex programs like Gromacs.  Once you have a fundamental understanding
> of all the working pieces, you will have a much better user experience.
>  Thanks,
> Randall
> *From:* mpich-discuss-bounces at mcs.anl.gov [
> mpich-discuss-bounces at mcs.anl.gov] on behalf of bharat gupta [
> bharat.85.monu at gmail.com]
> *Sent:* Friday, October 12, 2012 8:51 PM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* Re: [mpich-discuss] Clustering
>  Hi,
>  I have two servers - one is HP Proliant DL580G5 with 32 cores and other
> is Hp server with 24 cores. I want to cluster these two with 32 nodes one
> as the master. Finally I need to use the computational powers of both in
> gromacs (MD simulation software) using mpi. So, what I want to know is how
> can I cluster them. If any could be help me out in this, it will be of
> great help...
>  Regards
> Bharat
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
Bharat
Ph.D. Candidate
Room No. : 7202A, 2nd Floor
Biomolecular Engineering Laboratory
Division of Chemical Engineering and Polymer Science
Pusan National University
Busan -609735
South Korea
Lab phone no. - +82-51-510-3680, +82-51-583-8343
Mobile no. - 010-5818-3680
E-mail : monu46010 at yahoo.com
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20121016/5499d352/attachment.html>
