[mpich-discuss] Excluding c++ compiler from configuration
Sam Pedro
pedro18974 at gmail.com
Sun Oct 14 06:56:46 CDT 2012
I am installing mpich2 version 1.5. Even though I exclude the c++ compiler
from 'configure', it still seems to be checking for c++ compiler and does
not complete configure. This is on a Centos linux box. Here is the command:
configure --prefix=/home/sp/mpi --disable-cxx
These are the last statements on output:
checking for c++... no
checking for g++... no
checking for gcc... gcc
checking whether we are using the GNU C++ compiler... no
checking whether gcc accepts -g... no
checking dependency style of gcc... gcc3
checking how to run the C++ preprocessor... /lib/cpp
configure: error: in `/usr/local/gm363/build':
configure: error: C++ preprocessor "/lib/cpp" fails sanity check
See `config.log' for more details
I am attaching the config.log file
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20121014/7dfd8ca7/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20121014/7dfd8ca7/attachment-0001.obj>
