[mpich-discuss] mpich2-1.3.2-install
    silenceWE
    silencewe at foxmail.com
    Tue Mar  1 06:28:56 CST 2011
You r right,the permissions-related disappear when i log on as a regular user。But root's permission higher than regular user‘s,why operation not permitted?
 Although ./configure  executed correctly,make has one error(m.txt).
  ------------------ Original ------------------
 Date:  Tue, Mar 1, 2011 02:21 PM
 To:  "mpich-discuss"<mpich-discuss at mcs.anl.gov>;
 Cc:  "silenceWE"<silencewe at foxmail.com>;
 Subject:  Re: [mpich-discuss] mpich2-1.3.2-install
Just guessing, but perhaps worth a shot while you wait for a more
experienced answer:
Your config log shows a bunch of failed chmod attempts (`Operation not
permitted'). Try to ensure a correct ./configure before attempting to
run make. Rather than start by tweaking permissions, I'd retry from
scratch somewhere else.
Since MPICH2 can be configured and built in user space, you don't need
root for such a preliminary test: Just log on as a regular user,
create a fresh subdir in your $HOME (or wherever you have unrestricted
rights, enough space, and ideally a local, non-networked filesystem),
unpack a fresh copy of the tarball there (as that user), cd into it
and ./configure. If the permissions-related problems disappear (and
they should), then run make. Any better?
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110301/e522ecad/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110301/e522ecad/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110301/e522ecad/attachment-0003.obj>
