[MOAB-dev] FileOptions
    Tim Tautges (ANL)
    tautges at mcs.anl.gov
    Fri Dec 20 13:02:02 CST 2013
Aha, good question.  Yes, they look similar to what's in section 5.2 of the user's manual,
http://www.mcs.anl.gov/~fathom/moab-docs/html/contents.html#fivetwo.  I'll make a ticket to document this, now that it's
in the public API.
- tim
On 12/20/2013 12:26 PM, Patrick Shriwise wrote:
> Hello,
> Can anyone help me with the format for FileOptions? Are the same set of options available as in 4.6.2? And when one
> would like to set an option, should it be set as "...;Option1;SPLITS_PER_DIR1;Option3;..."?
> Thank you,
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
