[MOAB-dev] FileOptions
Patrick Shriwise shriwise at wisc.edu
Fri Dec 20 12:26:51 CST 2013
Hello,
Can anyone help me with the format for FileOptions? Are the same set of
options available as in 4.6.2? And when one would like to set an option,
should it be set as "...;Option1;SPLITS_PER_DIR1;Option3;..."?
Thank you,
Patrick C. Shriwise
Research Assistant
University of Wisconsin - Madison
Engineering Research Building - Rm. 428
1500 Engineering Drive
Madison, WI 53706
(608) 446-8173
