[MOAB-dev] commit/MOAB: danwu: Use delete[] to free the memory allocated by read_variable_to_set_allocate().
commits-noreply at bitbucket.org
Mon Nov 25 12:33:34 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/4cdfdf8163b7/
Changeset: 4cdfdf8163b7
Branch: master
User: danwu
Date: 2013-11-25 19:33:24
Summary: Use delete[] to free the memory allocated by read_variable_to_set_allocate().
Affected #: 1 file
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index 44fcdc3..89245a4 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -443,19 +443,19 @@ ErrorCode NCHelper::read_variable_to_set(std::vector<ReadNC::VarData>& vdatas, s
switch (vdatas[i].varDataType) {
case NC_BYTE:
case NC_CHAR:
- delete (char*) data;
+ delete[] (char*) data;
break;
case NC_DOUBLE:
- delete (double*) data;
+ delete[] (double*) data;
break;
case NC_FLOAT:
- delete (float*) data;
+ delete[] (float*) data;
break;
case NC_INT:
- delete (int*) data;
+ delete[] (int*) data;
break;
case NC_SHORT:
- delete (short*) data;
+ delete[] (short*) data;
break;
default:
break;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
