[MOAB-dev] commit/MOAB: danwu: To delete the memory allocated by read_variable_to_set_allocate(), data types should be consistent with new.
commits-noreply at bitbucket.org
Mon Nov 25 12:51:19 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/600c90a34f29/
Changeset: 600c90a34f29
Branch: master
User: danwu
Date: 2013-11-25 19:51:07
Summary: To delete the memory allocated by read_variable_to_set_allocate(), data types should be consistent with new.
Affected #: 1 file
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index 89245a4..0f8a7fa 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -446,16 +446,12 @@ ErrorCode NCHelper::read_variable_to_set(std::vector<ReadNC::VarData>& vdatas, s
delete[] (char*) data;
break;
case NC_DOUBLE:
- delete[] (double*) data;
- break;
case NC_FLOAT:
- delete[] (float*) data;
+ delete[] (double*) data;
break;
case NC_INT:
- delete[] (int*) data;
- break;
case NC_SHORT:
- delete[] (short*) data;
+ delete[] (int*) data;
break;
default:
break;
@@ -860,7 +856,7 @@ ErrorCode NCHelper::read_variable_to_set_allocate(std::vector<ReadNC::VarData>&
vdatas[i].varDatas[t] = new int[sz];
break;
default:
- std::cerr << "Unrecognized data type for tag " << std::endl;
+ std::cerr << "Unrecognized data type for set variable tag values" << std::endl;
rval = MB_FAILURE;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
