[MOAB-dev] commit/MOAB: danwu: For set variables, the memory allocated by read_variable_to_set_allocate() can be deleted after tag_set_by_ptr() is called.
commits-noreply at bitbucket.org
Mon Nov 25 12:15:07 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/6ae4cbbfe96f/
Changeset: 6ae4cbbfe96f
Branch: master
User: danwu
Date: 2013-11-25 19:14:53
Summary: For set variables, the memory allocated by read_variable_to_set_allocate() can be deleted after tag_set_by_ptr() is called.
Affected #: 1 file
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index 6c48d44..44fcdc3 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -409,12 +409,11 @@ ErrorCode NCHelper::read_variable_to_set(std::vector<ReadNC::VarData>& vdatas, s
(double*) data);
ERRORS(success, "Failed to read double data.");
break;
- case NC_FLOAT: {
+ case NC_FLOAT:
success = NCFUNCAG(_vara_float)(_fileId, vdatas[i].varId, &vdatas[i].readStarts[t][0], &vdatas[i].readCounts[t][0],
(float*) data);
ERRORS(success, "Failed to read float data.");
break;
case NC_INT:
success = NCFUNCAG(_vara_int)(_fileId, vdatas[i].varId, &vdatas[i].readStarts[t][0], &vdatas[i].readCounts[t][0],
(int*) data);
@@ -437,9 +436,32 @@ ErrorCode NCHelper::read_variable_to_set(std::vector<ReadNC::VarData>& vdatas, s
ERRORR(rval, "Failed to convert variable.");
dbgOut.tprintf(2, "Setting data for variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t]);
- rval = mbImpl->tag_set_by_ptr(vdatas[i].varTags[t], &_fileSet, 1, &(vdatas[i].varDatas[t]), &vdatas[i].sz);
+ rval = mbImpl->tag_set_by_ptr(vdatas[i].varTags[t], &_fileSet, 1, &data, &vdatas[i].sz);
ERRORR(rval, "Failed to set data for variable.");
+ // Memory pointed by pointer data can be deleted, as tag_set_by_ptr() has already copied the tag values
+ switch (vdatas[i].varDataType) {
+ case NC_BYTE:
+ case NC_CHAR:
+ delete (char*) data;
+ break;
+ case NC_DOUBLE:
+ delete (double*) data;
+ break;
+ case NC_FLOAT:
+ delete (float*) data;
+ break;
+ case NC_INT:
+ delete (int*) data;
+ break;
+ case NC_SHORT:
+ delete (short*) data;
+ break;
+ default:
+ break;
+ vdatas[i].varDatas[t] = NULL;
if (vdatas[i].varDims.size() <= 1 || !vdatas[i].has_t)
break;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
