[MOAB-dev] mixed mesh question
    Carlos Breviglieri
    carbrevi at gmail.com
    Tue Nov 19 15:06:01 CST 2013
Iulian, I am not sure about this... Junior wrote the Writer class.
Junior, could you help us out here?
Carlos
On Tue, Nov 19, 2013 at 5:52 PM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
> Hi Carlos,
> I rebuilt cgns static, and it configured fine;
> I have though some build errors;
>  CXX    WriteSLAC.lo
>   CXX    ReadNC.lo
>   CXX    ReadGCRM.lo
>   CXX    ReadCGNS.lo
> ../../../moab46/src/io/ReadCGNS.cpp:59:11: warning: unused parameter
> 'file_set' [-Wunused-parameter]
> ../../../moab46/src/io/ReadCGNS.cpp:551:11: warning: unused parameter
> 'element_type' [-Wunused-parameter]
> 'set_type' [-Wunused-parameter]
>   CXX    WriteCGNS.lo
> In file included from ../../../moab46/src/io/WriteCGNS.cpp:1:0:
> ../../../moab46/src/io/WriteCGNS.hpp:65:23: error: ISO C++ forbids
> initialization of member 'IdSet' [-fpermissive]
> ../../../moab46/src/io/WriteCGNS.hpp:65:23: error: making 'IdSet' static
> [-fpermissive]
> in-class initialization of non-const static member 'IdSet'
> ../../../moab46/src/io/WriteCGNS.hpp:66:22: error: ISO C++ forbids
> initialization of member 'NbEdges' [-fpermissive]
> ../../../moab46/src/io/WriteCGNS.hpp:66:22: error: making 'NbEdges' static
> [-fpermissive]
> in-class initialization of non-const static member 'NbEdges'
> do you need to initialize these in the struct? I would prefer not to use
> "-fpermissive"
> // A structure to store Set information.
>   struct SetStruct {
>     std::string TagName;      // Tag name
>     cgsize_t IdSet = -1;      // Id of the Set
>     cgsize_t NbEdges=0;       // Number of Edges in the Set
>     cgsize_t NbFaces=0;       // Number of Faces in the Set
>     cgsize_t NbCells=0;       // Number of Cells in the Set
>     // vector with the number of entities in the Sets
>     // 0-MBEDGE | 1-MBTRI | 2-MBQUAD | 3-MBTET | 4-MBPYRAMID | 5-MBPRISM
> | 6-MBHEX
>     std::vector<cgsize_t> NbEntities;
>     ElementType_t CGNSType;
> Iulian,
> I had a similar issue in the past. I recall that I edited the cgns.m4 but
> not exactly which part, probably the section below to link directly with
> hdf5_hl, instead of plain hdf5.
> I use Arch linux but not the system libraries. I compile hdf5 and cgns in
> a local directory and link those.
> I will take a look into the m4 file and see if I can reproduce the problem.
> Regards,
> Carlos
>       # Check if cgns is usable by itself
>   AC_CHECK_LIB( [cgns], [cg_open], [CGNS_LIBS="-lcgns"], [
>       # Check if cgns is usable with HDF5
>     unset ac_cv_lib_cgns
>     unset ac_cv_lib_cgns_cg_open
>       # If we haven't already looked for HDF5 libraries, again now incase
>       # they're in the CGNS lib directory.
>     FATHOM_DETECT_HDF5_LIBS
>     LDFLAGS="$LDFLAGS $HDF5_LDFLAGS"
>     AC_CHECK_LIB( [cgns], [cg_open], [CGNS_LIBS="-lcgns -lhdf5_hl"], [
>       # Try one more time with HDF5 and libcurl
> -lcurl"],
>         [HAVE_CGNS=no], [-lhdf5_hl $HDF5_LIBS -lcurl] )],
>       [-lhdf5_hl $HDF5_LIBS] )],
> On Tue, Nov 19, 2013 at 3:42 PM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
>> Thanks Carlos,
>> I have some issues configuring moab with cgns;
>> I did not rebuild hdf5, we are using version 1.8.8; cgns seems to be
>> built without problems (I used ccmake)
>> But something is wrong with configuring with cgns.
>> Do you have any suggestions (besides rebuilding hdf5, cgns, ...)
>> the symbols needed from hdf5 seem to be there, so I can't really explain
>> the error. Do you use ubuntu 12 or ubuntu 10? Or something else?
>> /homes/fathom/3rdparty/hdf5-1.8.8-par-mpich2.1.5-gcc/lib> nm libhdf5.so |
>> grep H5T_NATIVE_SCHAR_g
>> 00000000004cc170 D H5T_NATIVE_SCHAR_g
>> jun/homes/fathom/3rdparty/hdf5-1.8.8-par-mpich2.1.5-gcc/lib> nm
>> libhdf5.so | grep H5Tget_native_type
>> 00000000002424f0 T H5Tget_native_type
>> configure:32106: result: no
>> configure:32115: checking for cg_open in -lcgns
>> configure:32148: /homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/bin/mpicc
>> -o conftest  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align
>> -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -g
>> -I/homes/fathom/3rdparty/cgns/include  -DVALGRIND
>> -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map
>> -DHAVE_UNORDERED_SET=tr1/unordered_set -L/homes/fathom/3rdparty/cgns/lib
>> -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib
>> -L/homes/fathom/3rdparty/szip/szip-2.1/gcc/lib
>> -L/homes/fathom/3rdparty/hdf5-1.8.8-par-mpich2.1.5-gcc/lib
>> -L/homes/fathom/3rdparty/hdf5-1.8.8-par-mpich2.1.5-gcc/lib conftest.c
>> -lcgns -lhdf5_hl -lhdf5   -lcurl   -lm
>> -L/homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/lib
>> -L/usr/lib/gcc/x86_64-linux-gnu/4.6
>> -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu
>> -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu
>> -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib
>> -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lmpich -lopa -lmpl -lrt
>> -lpthread -lgfortran -lm -lquadmath
>> -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lmpichf90 -lmpich -lopa -lmpl
>> -lrt -lpthread -lgfortran -lm -lquadmath >&5
>> /homes/fathom/3rdparty/cgns/lib/libcgns.so: undefined reference to `
>> H5T_NATIVE_SCHAR_g'
>> `H5Tget_native_type'
>> `H5Pset_link_creation_order'
>> `H5P_CLS_DATASET_CREATE_g'
>> `H5Sget_simple_extent_npoints'
>> `H5T_IEEE_F64LE_g'
>> `H5P_CLS_FILE_CREATE_g'
>> `H5Tcopy'
>> `H5Fopen'
>> Iulian, here are some data on the supporting libs:
>> HDF5 v1.8.11
>> I compile the parallel version, but do not use the parallel IO
>> capabilities yet in CGNS.
>> ./configure \
>>   CC=%s \
>>   CXX=%s \
>>   FC=%s \
>>   F9X=%s \
>>   RUNPARALLEL=%s \
>>   OMPI_MCA_disable_memory_allocator=1 \
>>   --prefix=%s \
>>   --enable-largefile \
>>   --enable-unsupported \
>>   --enable-shared \
>>   --disable-static \
>>   --enable-production=yes \
>>   --with-pthread=%s,%s \
>>   --with-zlib=%s,%s \
>>   --with-default-api-version=v18 \
>>   --enable-parallel=yes \
>>   --enable-cxx \
>>   --disable-sharedlib-rpath"
>> hdf5_config.log attached
>> CGNS v3.2.1 (Beta)
>> We have not considered the parallel IO capabilities as of now. There is
>> no clear definition yet how to handle MIXED type element meshes, for which
>> you can not specify a fixed record lenght to retrieve with hdf5. Although
>> the HDF5 library I linked is mpi-enabled.
>> Junior at some point tested with version 3.1.4 release 2 and it worked
>> fine, AFAIK.
>> The library is transitioning to CMake, I've used:
>> cmake \
>>   -DCGNS_BUILD_SHARED:BOOL=ON \
>>   -DCMAKE_BUILD_TYPE:STRING=Release \
>>   -DCMAKE_INSTALL_PREFIX:PATH=%s \
>>   -DCMAKE_SKIP_RPATH:BOOL=ON \
>>   -DCGNS_BUILD_CGNSTOOLS:BOOL=OFF \
>>   -DCGNS_ENABLE_64BIT:BOOL=ON \
>>   -DCGNS_ENABLE_FORTRAN:BOOL=OFF \
>>   -DCGNS_ENABLE_PARALLEL:BOOL=ON \
>>   -DCGNS_ENABLE_HDF5:BOOL=ON \
>>   -DHDF5_INCLUDE_PATH:PATH=%s \
>>   -DHDF5_LIBRARY:FILEPATH=%s \
>>   -DHDF5_NEED_MPI:BOOL=ON \
>>   -DHDF5_NEED_ZLIB:BOOL=ON \
>>   -DZLIB_LIBRARY:FILEPATH=%s \
>>   -DCGNS_ENABLE_SCOPING:BOOL=OFF \
>>   -DCGNS_ENABLE_TESTS:BOOL=OFF \
>>   -DMPIEXEC:FILEPATH=%s \
>>   -DMPI_C_COMPILER:FILEPATH=%s \
>>   -DMPI_C_INCLUDE_PATH:PATH=\"%s\"
>> cgns321_CMakeCache.txt is attached.
>> MOAB v4.6.2
>> The patch is against the tar file from the website (
>> http://ftp.mcs.anl.gov/pub/fathom/moab-4.6.2.tar.gz). There is no need
>> from our side to keep it on 462. Feel free to include it in a latter
>> release. It was only convenient for me to keep the patch against a fixed
>> release. For this, I packaged in the previous email a tar.gz with the
>> modified and new sources and sample cgns files.
>> The reader and writer are serial only. We tested against homogeneous and
>> heterogeneous meshes up to 20million elements and it worked. You can read a
>> CGNS file, convert it to H5M and then convert it back to CGNS.
>> The modifications to compile moab is just an --with-cgns=DIR flag.
>> These build use shared libs for now, as I am working on my workstation.
>> Latter I will experiment with static objects for clusters.
>> If you need more details, let us know.
>> Regards,
>> Carlos
>> On Tue, Nov 19, 2013 at 1:30 PM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
>>> Thank you Carlos and Junior, for your help.
>>> I will need to build cgns library; you mentioned that you tested 3.2
>>> beta, too; I will probably stick with 3.1.4, (release 2?).
>>>  Also, what version of hdf5 library do you use? Should it work for any
>>> version greater than 1.8?
>>> I assume you build statically? Can I also get your config.log files for
>>> cgns and moab?
>>> I assume that you are not using any of the parallel io capability,
>>> because that seems to be available only in beta version.
>>> So everything is read/written in serial, isn't it?
>>> I am not sure if we will port the cgns reader / writer  to 4.6.2 also.
>>> Is your patch against 4.6.2 tar file or against "Version4.6" branch? There
>>> should not be much difference.
>>> Tim, what do you suggest? In a way, it should be easier to update 4.6.2.
>>> But I don't want to merge to the master after that, there are too many
>>> changes. This patch should work out of the box for 4.6.2, after I build
>>> cgns.
>>> Best Regards,
>>> Iulian
>>> Iulian,
>>> Sorry for the delay in getting back to you... I have tested the new
>>> version and it worked OK for my mesh sample. I will test it latter for
>>> other cases.
>>> Also, I am sending you the CGNS reader and writer along with input cgns
>>> mesh examples. We have worked on top of version 462, so things may look a
>>> little out of place from the repository.
>>> The attached patch modifies some autotools files and new files (apply
>>> with patch -p0 -i moab462_cgns.patch). Moreover, the tar.gz contains sample
>>> meshes (simple airfoil mesh in 2D and a mixed-mesh discretization of a 3D
>>> wingbody geometry).
>>> We have tested the CGNS capability with the latest library vesion 3.1.4
>>> and 3.2-beta. Furthermore, we sticked with the base CGNS use-case, that is,
>>> single base/zone. We will also implement latter capability to write out
>>> user variables.
>>> Please, feel free to improve the files and if you have any questions,
>>> let us know. carbrevi at gmail.com and junior.hmg at gmail.com
>>> Regards,
>>> Carlos
>>> On Sat, Nov 16, 2013 at 3:57 AM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
>>>> Hi Carlos,
>>>> That ticket is now closed, Tim fixed the bug.
>>>> Please let us know if it works for you.
>>>> Thanks for your patience,
>>>> Iulian
>>>> Iulian,
>>>> thanks for checking this out. I will be following the trac ticket. The
>>>> mesh I used is attached, partitioned for 8 procs (all tri). I noticed that
>>>> are much simpler sample meshes you created to investigate this issue.
>>>> Anyway, you can use the airfoil mesh if you find it useful.
>>>> I use a separate code to compute elements adjacency and then pass those
>>>> to metis. To write the partitions into h5m I followed the code form
>>>> mbzoltan tool. The partitioning code is correct (element-based) since I
>>>> have used this code previously with other applications...
>>>> I am from Brazil indeed, utc -3h. I'm a PhD candidate from
>>>> Technological Institute of Aeronautics in Sao Jose dos Campos.
>>>> Now I am building/adapting parts of my research code (high-order
>>>> unstructured CFD) to use MOAB. I will stick with 462 for this, working with
>>>> non-mixed meshes for this transition period. In the near feature I will
>>>> also look into the structured meshes capability of the library, as well as
>>>> the high-order elements implementation.
>>>> The CGNS reader/writer is in the works too and I will submit those as
>>>> well. My co-worker Junior, cc'ed here, is dealing with the writer part and
>>>> we are almos done.
>>>> Regards,
>>>> Carlos Breviglieri
>>>> On Sat, Oct 12, 2013 at 5:40 PM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
>>>>> Hi Carlos,
>>>>> I am seeing a problem with ghosting, thank you for pointing it out.
>>>>> Danqing and I messed up with that code :( to fix some other issues we were
>>>>> seeing.
>>>>> http://trac.mcs.anl.gov/projects/ITAPS/ticket/284
>>>>> It may take a while to fix it properly.
>>>>> Thanks again,
>>>>> Iulian
>>>>> Hmmmm,
>>>>> Can you send me the 2d_naca0012.h5m with your partition?
>>>>> If you do ghosting after reading, did you get the same results?
>>>>> The elements/processors should not change ownership after ghosting,
>>>>> but maybe they do.
>>>>> It is indeed a work in progress, you may have found another issue :(
>>>>> Not being able to write is probably the biggest problem.
>>>>> On what time zone do you work? :) Also, where are you from? The name
>>>>> looks Brazilian, Portuguese, or Italian ? Or Spanish?
>>>>> Thanks,
>>>>> Iulian
>>>>> Hi Iulian,
>>>>> I have just ran some tests with the latest clone of the master repo
>>>>> (saturday morning). Here are my findings with MOAB 470pre:
>>>>> Now I am able to read partitined mixed meshes without errors. However,
>>>>> if I plot the owned entitied for a given proc, even for non-mixed meshes,
>>>>> they are different from the ones obtained by the partitioner, see below
>>>>> Mesh distribution for 2d_naca0012.h5m (all tri mesh) from partitioner,
>>>>> over 8 procs:
>>>>> proc[0] has 866 elements
>>>>> proc[1] has 863 elements
>>>>> proc[2] has 866 elements
>>>>> proc[3] has 869 elements
>>>>> proc[4] has 872 elements
>>>>> proc[5] has 869 elements
>>>>> proc[6] has 862 elements
>>>>> proc[7] has 877 elements
>>>>> Mesh distribution seen by MOAB 470pre
>>>>> ("PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1")
>>>>> owned_entities[5], size = 864
>>>>> owned_entities[6], size = 853
>>>>> owned_entities[7], size = 871
>>>>> owned_entities[1], size = 859
>>>>> owned_entities[3], size = 860
>>>>> owned_entities[4], size = 867
>>>>> owned_entities[0], size = 866
>>>>> owned_entities[2], size = 861
>>>>> besides procs 0, all other report wrong number of entities. Code to
>>>>> compute such distribution is below (based on example/HelloParMOAB.cpp). The
>>>>> mixed mesh (2d_naca0012_mixed.h5m) now is read  (does not crash) but the
>>>>> distribution is off as well. With MOAB 462 the distribution is OK for
>>>>> homogeneous meshes.
>>>>> Moreover, with MOAB 470pre, no output is written to disk with
>>>>> PARALLEL=WRITE_PART, regardless of the mesh type. Using PARALLEL=NONE
>>>>> works, but only one part of the domain is written, as expected.
>>>>> I understand that this is a work in progress. If you need more
>>>>> information, let me know.
>>>>> Regards,
>>>>> Carlos Breviglieri
>>>>>     read_options =
>>>>> "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1";
>>>>>     moab::Interface* mb = new Core;
>>>>>     // Create root sets for each mesh.  Then pass these
>>>>>     // to the load_file functions to be populated.
>>>>>     EntityHandle rootset, partnset;
>>>>>     mb->create_meshset(MESHSET_SET, rootset);
>>>>>     mb->create_meshset(MESHSET_SET, partnset);
>>>>>     // Create the parallel communicator object with the partition
>>>>> handle associated with MOAB
>>>>>     ParallelComm *pcomm = ParallelComm::get_pcomm(mb, partnset,
>>>>> &myComm);
>>>>>     // Load the file from disk with given options
>>>>>     mb->load_file(meshFile.c_str(), &rootset, read_options.c_str());
>>>>>     // Get all entities of dimension = dim
>>>>>     Range elemRange, owned_entities;
>>>>>     int dim = 2;
>>>>>     mb->get_entities_by_dimension(rootset, dim, elemRange, false);
>>>>>     pcomm->filter_pstatus(elemRange, // pass entities that we want to
>>>>> filter
>>>>>                           PSTATUS_NOT_OWNED, // status we are looking
>>>>> for
>>>>>                           PSTATUS_NOT, // operation applied ; so it
>>>>> will return owned entities (!not_owned = owned)
>>>>>                           -1, // this means all processors
>>>>>                           &owned_entities);
>>>>>     std::vector<int> procID(owned_entities.size(), myRank);
>>>>>     std::cout << "owned_entities[" << myRank << "], size = " <<
>>>>> owned_entities.size() << std::endl;
>>>>>     Tag procID_tag;
>>>>>     mb->tag_get_handle("PROC_ID", 1, MB_TYPE_INTEGER, procID_tag,
>>>>> MB_TAG_CREAT | MB_TAG_DENSE, &procID[0]);
>>>>>     mb->tag_set_data(procID_tag, owned_entities, &procID[0]);
>>>>>     // WRITE_PART writes all partitions to a single output file (only
>>>>> h5m format supports parallel IO at the moment).
>>>>>     // One can use the mbconvert tool to convert the output to other
>>>>> formats.
>>>>>     mb->write_file(outputFile.c_str(), "H5M", "PARALLEL=WRITE_PART");
>>>>> On Thu, Oct 10, 2013 at 10:37 AM, Tim Tautges <tautges at mcs.anl.gov>wrote:
>>>>>> Yeah, too complicated to backport, and latest works for Carlos anyway.
>>>>>> - tim
>>>>>> On 10/09/2013 09:41 PM, Iulian Grindeanu wrote:
>>>>>>>     Both worked for me, with the current code (4.7.0pre)
>>>>>>>     I don't get your error :(
>>>>>>>     What version are you using? I will try 4.6.2, but it should be
>>>>>>> fine there too :(
>>>>>>>     OK, I got an error with more quads, on 4.6.2 maybe I mixed them
>>>>>>> up when I saved :(
>>>>>>>       mpiexec -np 2 /home/iulian/source/MOAB46/tools/mbconvert -O
>>>>>>> PARALLEL=READ_PART -O PARTITION=PARALLEL_PARTITION -O
>>>>>>>     PARALLEL_RESOLVE_SHARED_ENTS -O  PARALLEL_GHOSTS=2.0.1  -o
>>>>>>> PARALLEL=WRITE_PART
>>>>>>>     /home/iulian/tmp/2d_naca0012_mixed2.h5m 2.h5m
>>>>>>>     Leaked HDF5 object handle in function at
>>>>>>> ../../../moab46source/src/io/ReadHDF5.cpp:1523
>>>>>>>     Open at entrance: 1
>>>>>>>     Open at exit:     2
>>>>>>> ../../../moab46source/src/io/ReadHDF5.cpp:827
>>>>>>>     Open at entrance: 1
>>>>>>>     Open at exit:     2
>>>>>>>     Failed to load "/home/iulian/tmp/2d_naca0012_mixed2.h5m".
>>>>>>>     Error code: MB_INDEX_OUT_OF_RANGE (1)
>>>>>>>     Error message: Failed in step PARALLEL READ PART
>>>>>>>     Cannot close file with open handles: 0 file, 1 data, 0 group, 0
>>>>>>> type, 0 attr
>>>>>>>     I will look into it.
>>>>>>> Hi Carlos,
>>>>>>> It looks like it is a bug in 4.6.2.
>>>>>>> I don't know if it will be fixed, there are some important changes
>>>>>>> in ghosting in current version.
>>>>>>> So for Version4.6 branch, the model with 17 quads works fine if you
>>>>>>> don't do ghosting:
>>>>>>> iulian at T520-iuli:~/source/MOAB46$ mpiexec -np 2
>>>>>>> /home/iulian/source/MOAB46/tools/mbconvert -O PARALLEL=READ_PART -O
>>>>>>> PARTITION=PARALLEL_PARTITION -O PARALLEL_RESOLVE_SHARED_ENTS  -o
>>>>>>> PARALLEL=WRITE_PART
>>>>>>> /home/iulian/tmp/2d_naca0012_mixed_invert.h5m 2.h5m
>>>>>>> Read "/home/iulian/tmp/2d_naca0012_mixed_invert.h5m"
>>>>>>> Wrote "2.h5m"
>>>>>>> I would recommend upgrading to current version.
>>>>>>> That code is pretty complicated, and I am not sure if we will
>>>>>>> backport changes to Version4.6 branch.
>>>>>>> Tim, what do you suggest? Should I try to backport some changes in
>>>>>>> ParallelComm? I know you are working on that code.
>>>>>>> Thanks,
>>>>>>> Iulian
>>>>>> "You will keep in perfect peace him whose mind is
>>>>>>   steadfast, because he trusts in you."               Isaiah 26:3
>>>>>>              Tim Tautges            Argonne National Laboratory
>>>>>>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>>>>>>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>>>>>>             fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131119/38803e4d/attachment-0001.html>
