[MOAB-dev] mixed mesh question
Carlos Breviglieri
carbrevi at gmail.com
Wed Nov 20 04:56:36 CST 2013
Iulian, just to point out that these contributions are by no mean polished
or optimized. If you consider some of the interactions with MOAB API are
not properly done, feel free to adjust and optimize them. It is just a
first version to test the CGNS capability.
Thanks for your attention!
Carlos
On Tue, Nov 19, 2013 at 7:33 PM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
> OK, that was it;
> I made SetStruct a class, initialized those members data properly (in the
> constructor), and it works now.
> That test I was running is fine now.
> Thanks again,
> Iulian
> Hi Carlos and Junior,
> Thank you again for the cgns reader/writer.
> I think I am close to integrate it, at least in 462.
> After I changed the writer hpp file (), it built, but I see some issues
> when I am testing.
> Could be related to my changes, probably I should initialize those members
> in a constructor.
> So this test (reader) that I am doing seems fine:
> ../../../build46/tools/mbsize 2d_naca0012.cgns
> File 2d_naca0012.cgns:
> number of nodes = 3555
> number of elems = 6944
> number of parts = 3
> type count total minimum
> average rms maximum std.dev.
> Edge 166 65 0.0061783
> 0.39047 0.71774 2.0409 0.60223
> Tri 6944 3.1e+02 2.2192e-05
> 0.045078 0.13326 1.4755 0.1254
> 1D Side 20832 3.9e+03 0.0061783
> 0.18654 0.33264 2.0409 0.27542
> Vertex 3555
> But this (reader and writer) has issues. Again, it could be my changes, to
> make it compile.
> ../../../build46/tools/mbconvert 3d_wingbody_mixed_JR.cgns test.cgns
> *** Warning:The file being read is more recent that the CGNS library used
> number of nodes = 285905
> number of elems = 333820
> number of parts = 1
> Read "3d_wingbody_mixed_JR.cgns"
> THE CGNS CONVERSION ONLY WORKS FOR ENTITIES CITED BELOW:
> -MBVERTEX
> -MBEDGE
> -MBTRI
> -MBQUAD
> -MBTET
> -MBPYRAMID
> -MBHEX
> The Number of Vertex is 285905.
> The Number of Edges is 0.
> The Number of Faces is 29782.
> The Number of Cells is 333820.
> test.cgns file is a 3-D mesh.
> The mesh has 5 Tags.
> Tag name= MATERIAL_SET
> Number of MBEDGE = 0
> Number of MBTRI = 0
> Number of MBQUAD = 0
> Number of MBTET = 0
> Number of MBPYRAMID = 0
> Number of MBPRISM = 0
> Number of MBHEX = 0
> Total number of Edges = 0
> Total number of Faces = 0
> Total number of Cells = 0
> Sets[0].CGNSType= 0
> Sets[0].IdSet = 0
> Tag name= NEUMANN_SET
> Number of MBTRI = 0
> Number of MBTET = 0
> Number of MBHEX = 0
> Sets[1].CGNSType= 0
> Sets[1].IdSet = 0
> Tag name= DIRICHLET_SET
> Number of MBTRI = 0
> Number of MBTET = 0
> Number of MBHEX = 0
> Sets[2].CGNSType= 0
> Sets[2].IdSet = 0
> Tag name= GEOM_DIMENSION
> Number of MBTRI = 0
> Number of MBTET = 0
> Number of MBHEX = 0
> Sets[3].CGNSType= 0
> Sets[3].IdSet = 0
> Tag name= GLOBAL_ID
> Number of MBTRI = 0
> Number of MBQUAD = 29782
> Number of MBTET = 72460
> Number of MBPYRAMID = 3836
> Number of MBHEX = 257524
> Total number of Faces = 29782
> Total number of Cells = 333820
> Sets[4].CGNSType= 20
> Sets[4].IdSet = 4
> BeginSetsIndex = 1 EndSetsIndex = 0
> Issue on writing connectivity -- 3-D
> Invalid element range defined for section 'MATERIAL_SET'
> Hi Carlos,
> I rebuilt cgns static, and it configured fine;
> I have though some build errors;
> CXX WriteSLAC.lo
> CXX ReadNC.lo
> CXX ReadGCRM.lo
> CXX ReadCGNS.lo
> ../../../moab46/src/io/ReadCGNS.cpp:59:11: warning: unused parameter
> 'file_set' [-Wunused-parameter]
> ../../../moab46/src/io/ReadCGNS.cpp:551:11: warning: unused parameter
> 'element_type' [-Wunused-parameter]
> 'set_type' [-Wunused-parameter]
> CXX WriteCGNS.lo
> In file included from ../../../moab46/src/io/WriteCGNS.cpp:1:0:
> ../../../moab46/src/io/WriteCGNS.hpp:65:23: error: ISO C++ forbids
> initialization of member 'IdSet' [-fpermissive]
> ../../../moab46/src/io/WriteCGNS.hpp:65:23: error: making 'IdSet' static
> [-fpermissive]
> in-class initialization of non-const static member 'IdSet'
> ../../../moab46/src/io/WriteCGNS.hpp:66:22: error: ISO C++ forbids
> initialization of member 'NbEdges' [-fpermissive]
> ../../../moab46/src/io/WriteCGNS.hpp:66:22: error: making 'NbEdges' static
> [-fpermissive]
> in-class initialization of non-const static member 'NbEdges'
> do you need to initialize these in the struct? I would prefer not to use
> "-fpermissive"
> // A structure to store Set information.
> struct SetStruct {
> std::string TagName; // Tag name
> cgsize_t IdSet = -1; // Id of the Set
> cgsize_t NbEdges=0; // Number of Edges in the Set
> cgsize_t NbFaces=0; // Number of Faces in the Set
> cgsize_t NbCells=0; // Number of Cells in the Set
> // vector with the number of entities in the Sets
> // 0-MBEDGE | 1-MBTRI | 2-MBQUAD | 3-MBTET | 4-MBPYRAMID | 5-MBPRISM
> | 6-MBHEX
> std::vector<cgsize_t> NbEntities;
> ElementType_t CGNSType;
> Iulian,
> I had a similar issue in the past. I recall that I edited the cgns.m4 but
> not exactly which part, probably the section below to link directly with
> hdf5_hl, instead of plain hdf5.
> I use Arch linux but not the system libraries. I compile hdf5 and cgns in
> a local directory and link those.
> I will take a look into the m4 file and see if I can reproduce the problem.
> Regards,
> Carlos
> # Check if cgns is usable by itself
> AC_CHECK_LIB( [cgns], [cg_open], [CGNS_LIBS="-lcgns"], [
> # Check if cgns is usable with HDF5
> unset ac_cv_lib_cgns
> unset ac_cv_lib_cgns_cg_open
> # If we haven't already looked for HDF5 libraries, again now incase
> # they're in the CGNS lib directory.
> FATHOM_DETECT_HDF5_LIBS
> LDFLAGS="$LDFLAGS $HDF5_LDFLAGS"
> AC_CHECK_LIB( [cgns], [cg_open], [CGNS_LIBS="-lcgns -lhdf5_hl"], [
> # Try one more time with HDF5 and libcurl
> -lcurl"],
> [HAVE_CGNS=no], [-lhdf5_hl $HDF5_LIBS -lcurl] )],
> [-lhdf5_hl $HDF5_LIBS] )],
> On Tue, Nov 19, 2013 at 3:42 PM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
>> Thanks Carlos,
>> I have some issues configuring moab with cgns;
>> I did not rebuild hdf5, we are using version 1.8.8; cgns seems to be
>> built without problems (I used ccmake)
>> But something is wrong with configuring with cgns.
>> Do you have any suggestions (besides rebuilding hdf5, cgns, ...)
>> the symbols needed from hdf5 seem to be there, so I can't really explain
>> the error. Do you use ubuntu 12 or ubuntu 10? Or something else?
>> /homes/fathom/3rdparty/hdf5-1.8.8-par-mpich2.1.5-gcc/lib> nm libhdf5.so |
>> grep H5T_NATIVE_SCHAR_g
>> 00000000004cc170 D H5T_NATIVE_SCHAR_g
>> jun/homes/fathom/3rdparty/hdf5-1.8.8-par-mpich2.1.5-gcc/lib> nm
>> libhdf5.so | grep H5Tget_native_type
>> 00000000002424f0 T H5Tget_native_type
>> configure:32106: result: no
>> configure:32115: checking for cg_open in -lcgns
>> configure:32148: /homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/bin/mpicc
>> -o conftest -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align
>> -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -g
>> -I/homes/fathom/3rdparty/cgns/include -DVALGRIND
>> -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map
>> -DHAVE_UNORDERED_SET=tr1/unordered_set -L/homes/fathom/3rdparty/cgns/lib
>> -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib
>> -L/homes/fathom/3rdparty/szip/szip-2.1/gcc/lib
>> -L/homes/fathom/3rdparty/hdf5-1.8.8-par-mpich2.1.5-gcc/lib
>> -L/homes/fathom/3rdparty/hdf5-1.8.8-par-mpich2.1.5-gcc/lib conftest.c
>> -lcgns -lhdf5_hl -lhdf5 -lcurl -lm
>> -L/homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/lib
>> -L/usr/lib/gcc/x86_64-linux-gnu/4.6
>> -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu
>> -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu
>> -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib
>> -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lmpich -lopa -lmpl -lrt
>> -lpthread -lgfortran -lm -lquadmath
>> -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lmpichf90 -lmpich -lopa -lmpl
>> -lrt -lpthread -lgfortran -lm -lquadmath >&5
>> /homes/fathom/3rdparty/cgns/lib/libcgns.so: undefined reference to `
>> H5T_NATIVE_SCHAR_g'
>> `H5Tget_native_type'
>> `H5Pset_link_creation_order'
>> `H5P_CLS_DATASET_CREATE_g'
>> `H5Sget_simple_extent_npoints'
>> `H5T_IEEE_F64LE_g'
>> `H5P_CLS_FILE_CREATE_g'
>> `H5Tcopy'
>> `H5Fopen'
>> Iulian, here are some data on the supporting libs:
>> HDF5 v1.8.11
>> I compile the parallel version, but do not use the parallel IO
>> capabilities yet in CGNS.
>> ./configure \
>> CC=%s \
>> CXX=%s \
>> FC=%s \
>> F9X=%s \
>> RUNPARALLEL=%s \
>> OMPI_MCA_disable_memory_allocator=1 \
>> --prefix=%s \
>> --enable-largefile \
>> --enable-unsupported \
>> --enable-shared \
>> --disable-static \
>> --enable-production=yes \
>> --with-pthread=%s,%s \
>> --with-zlib=%s,%s \
>> --with-default-api-version=v18 \
>> --enable-parallel=yes \
>> --enable-cxx \
>> --disable-sharedlib-rpath"
>> hdf5_config.log attached
>> CGNS v3.2.1 (Beta)
>> We have not considered the parallel IO capabilities as of now. There is
>> no clear definition yet how to handle MIXED type element meshes, for which
>> you can not specify a fixed record lenght to retrieve with hdf5. Although
>> the HDF5 library I linked is mpi-enabled.
>> Junior at some point tested with version 3.1.4 release 2 and it worked
>> fine, AFAIK.
>> The library is transitioning to CMake, I've used:
>> cmake \
>> -DCGNS_BUILD_SHARED:BOOL=ON \
>> -DCMAKE_BUILD_TYPE:STRING=Release \
>> -DCMAKE_INSTALL_PREFIX:PATH=%s \
>> -DCMAKE_SKIP_RPATH:BOOL=ON \
>> -DCGNS_BUILD_CGNSTOOLS:BOOL=OFF \
>> -DCGNS_ENABLE_64BIT:BOOL=ON \
>> -DCGNS_ENABLE_FORTRAN:BOOL=OFF \
>> -DCGNS_ENABLE_PARALLEL:BOOL=ON \
>> -DCGNS_ENABLE_HDF5:BOOL=ON \
>> -DHDF5_INCLUDE_PATH:PATH=%s \
>> -DHDF5_LIBRARY:FILEPATH=%s \
>> -DHDF5_NEED_MPI:BOOL=ON \
>> -DHDF5_NEED_ZLIB:BOOL=ON \
>> -DZLIB_LIBRARY:FILEPATH=%s \
>> -DCGNS_ENABLE_SCOPING:BOOL=OFF \
>> -DCGNS_ENABLE_TESTS:BOOL=OFF \
>> -DMPIEXEC:FILEPATH=%s \
>> -DMPI_C_COMPILER:FILEPATH=%s \
>> -DMPI_C_INCLUDE_PATH:PATH=\"%s\"
>> cgns321_CMakeCache.txt is attached.
>> MOAB v4.6.2
>> The patch is against the tar file from the website (
>> http://ftp.mcs.anl.gov/pub/fathom/moab-4.6.2.tar.gz). There is no need
>> from our side to keep it on 462. Feel free to include it in a latter
>> release. It was only convenient for me to keep the patch against a fixed
>> release. For this, I packaged in the previous email a tar.gz with the
>> modified and new sources and sample cgns files.
>> The reader and writer are serial only. We tested against homogeneous and
>> heterogeneous meshes up to 20million elements and it worked. You can read a
>> CGNS file, convert it to H5M and then convert it back to CGNS.
>> The modifications to compile moab is just an --with-cgns=DIR flag.
>> These build use shared libs for now, as I am working on my workstation.
>> Latter I will experiment with static objects for clusters.
>> If you need more details, let us know.
>> Regards,
>> Carlos
>> On Tue, Nov 19, 2013 at 1:30 PM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
>>> Thank you Carlos and Junior, for your help.
>>> I will need to build cgns library; you mentioned that you tested 3.2
>>> beta, too; I will probably stick with 3.1.4, (release 2?).
>>> Also, what version of hdf5 library do you use? Should it work for any
>>> version greater than 1.8?
>>> I assume you build statically? Can I also get your config.log files for
>>> cgns and moab?
>>> I assume that you are not using any of the parallel io capability,
>>> because that seems to be available only in beta version.
>>> So everything is read/written in serial, isn't it?
>>> I am not sure if we will port the cgns reader / writer to 4.6.2 also.
>>> Is your patch against 4.6.2 tar file or against "Version4.6" branch? There
>>> should not be much difference.
>>> Tim, what do you suggest? In a way, it should be easier to update 4.6.2.
>>> But I don't want to merge to the master after that, there are too many
>>> changes. This patch should work out of the box for 4.6.2, after I build
>>> cgns.
>>> Best Regards,
>>> Iulian
>>> Iulian,
>>> Sorry for the delay in getting back to you... I have tested the new
>>> version and it worked OK for my mesh sample. I will test it latter for
>>> other cases.
>>> Also, I am sending you the CGNS reader and writer along with input cgns
>>> mesh examples. We have worked on top of version 462, so things may look a
>>> little out of place from the repository.
>>> The attached patch modifies some autotools files and new files (apply
>>> with patch -p0 -i moab462_cgns.patch). Moreover, the tar.gz contains sample
>>> meshes (simple airfoil mesh in 2D and a mixed-mesh discretization of a 3D
>>> wingbody geometry).
>>> We have tested the CGNS capability with the latest library vesion 3.1.4
>>> and 3.2-beta. Furthermore, we sticked with the base CGNS use-case, that is,
>>> single base/zone. We will also implement latter capability to write out
>>> user variables.
>>> Please, feel free to improve the files and if you have any questions,
>>> let us know. carbrevi at gmail.com and junior.hmg at gmail.com
>>> Regards,
>>> Carlos
>>> On Sat, Nov 16, 2013 at 3:57 AM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
>>>> Hi Carlos,
>>>> That ticket is now closed, Tim fixed the bug.
>>>> Please let us know if it works for you.
>>>> Thanks for your patience,
>>>> Iulian
>>>> Iulian,
>>>> thanks for checking this out. I will be following the trac ticket. The
>>>> mesh I used is attached, partitioned for 8 procs (all tri). I noticed that
>>>> are much simpler sample meshes you created to investigate this issue.
>>>> Anyway, you can use the airfoil mesh if you find it useful.
>>>> I use a separate code to compute elements adjacency and then pass those
>>>> to metis. To write the partitions into h5m I followed the code form
>>>> mbzoltan tool. The partitioning code is correct (element-based) since I
>>>> have used this code previously with other applications...
>>>> I am from Brazil indeed, utc -3h. I'm a PhD candidate from
>>>> Technological Institute of Aeronautics in Sao Jose dos Campos.
>>>> Now I am building/adapting parts of my research code (high-order
>>>> unstructured CFD) to use MOAB. I will stick with 462 for this, working with
>>>> non-mixed meshes for this transition period. In the near feature I will
>>>> also look into the structured meshes capability of the library, as well as
>>>> the high-order elements implementation.
>>>> The CGNS reader/writer is in the works too and I will submit those as
>>>> well. My co-worker Junior, cc'ed here, is dealing with the writer part and
>>>> we are almos done.
>>>> Regards,
>>>> Carlos Breviglieri
>>>> On Sat, Oct 12, 2013 at 5:40 PM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
>>>>> Hi Carlos,
>>>>> I am seeing a problem with ghosting, thank you for pointing it out.
>>>>> Danqing and I messed up with that code :( to fix some other issues we were
>>>>> seeing.
>>>>> http://trac.mcs.anl.gov/projects/ITAPS/ticket/284
>>>>> It may take a while to fix it properly.
>>>>> Thanks again,
>>>>> Iulian
>>>>> Hmmmm,
>>>>> Can you send me the 2d_naca0012.h5m with your partition?
>>>>> If you do ghosting after reading, did you get the same results?
>>>>> The elements/processors should not change ownership after ghosting,
>>>>> but maybe they do.
>>>>> It is indeed a work in progress, you may have found another issue :(
>>>>> Not being able to write is probably the biggest problem.
>>>>> On what time zone do you work? :) Also, where are you from? The name
>>>>> looks Brazilian, Portuguese, or Italian ? Or Spanish?
>>>>> Thanks,
>>>>> Iulian
>>>>> Hi Iulian,
>>>>> I have just ran some tests with the latest clone of the master repo
>>>>> (saturday morning). Here are my findings with MOAB 470pre:
>>>>> Now I am able to read partitined mixed meshes without errors. However,
>>>>> if I plot the owned entitied for a given proc, even for non-mixed meshes,
>>>>> they are different from the ones obtained by the partitioner, see below
>>>>> Mesh distribution for 2d_naca0012.h5m (all tri mesh) from partitioner,
>>>>> over 8 procs:
>>>>> proc[0] has 866 elements
>>>>> proc[1] has 863 elements
>>>>> proc[2] has 866 elements
>>>>> proc[3] has 869 elements
>>>>> proc[4] has 872 elements
>>>>> proc[5] has 869 elements
>>>>> proc[6] has 862 elements
>>>>> proc[7] has 877 elements
>>>>> Mesh distribution seen by MOAB 470pre
>>>>> ("PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1")
>>>>> owned_entities[5], size = 864
>>>>> owned_entities[6], size = 853
>>>>> owned_entities[7], size = 871
>>>>> owned_entities[1], size = 859
>>>>> owned_entities[3], size = 860
>>>>> owned_entities[4], size = 867
>>>>> owned_entities[0], size = 866
>>>>> owned_entities[2], size = 861
>>>>> besides procs 0, all other report wrong number of entities. Code to
>>>>> compute such distribution is below (based on example/HelloParMOAB.cpp). The
>>>>> mixed mesh (2d_naca0012_mixed.h5m) now is read (does not crash) but the
>>>>> distribution is off as well. With MOAB 462 the distribution is OK for
>>>>> homogeneous meshes.
>>>>> Moreover, with MOAB 470pre, no output is written to disk with
>>>>> PARALLEL=WRITE_PART, regardless of the mesh type. Using PARALLEL=NONE
>>>>> works, but only one part of the domain is written, as expected.
>>>>> I understand that this is a work in progress. If you need more
>>>>> information, let me know.
>>>>> Regards,
>>>>> Carlos Breviglieri
>>>>> read_options =
>>>>> "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1";
>>>>> moab::Interface* mb = new Core;
>>>>> // Create root sets for each mesh. Then pass these
>>>>> // to the load_file functions to be populated.
>>>>> EntityHandle rootset, partnset;
>>>>> mb->create_meshset(MESHSET_SET, rootset);
>>>>> mb->create_meshset(MESHSET_SET, partnset);
>>>>> // Create the parallel communicator object with the partition
>>>>> handle associated with MOAB
>>>>> ParallelComm *pcomm = ParallelComm::get_pcomm(mb, partnset,
>>>>> &myComm);
>>>>> // Load the file from disk with given options
>>>>> mb->load_file(meshFile.c_str(), &rootset, read_options.c_str());
>>>>> // Get all entities of dimension = dim
>>>>> Range elemRange, owned_entities;
>>>>> int dim = 2;
>>>>> mb->get_entities_by_dimension(rootset, dim, elemRange, false);
>>>>> pcomm->filter_pstatus(elemRange, // pass entities that we want to
>>>>> filter
>>>>> PSTATUS_NOT_OWNED, // status we are looking
>>>>> for
>>>>> PSTATUS_NOT, // operation applied ; so it
>>>>> will return owned entities (!not_owned = owned)
>>>>> -1, // this means all processors
>>>>> &owned_entities);
>>>>> std::vector<int> procID(owned_entities.size(), myRank);
>>>>> std::cout << "owned_entities[" << myRank << "], size = " <<
>>>>> owned_entities.size() << std::endl;
>>>>> Tag procID_tag;
>>>>> mb->tag_get_handle("PROC_ID", 1, MB_TYPE_INTEGER, procID_tag,
>>>>> MB_TAG_CREAT | MB_TAG_DENSE, &procID[0]);
>>>>> mb->tag_set_data(procID_tag, owned_entities, &procID[0]);
>>>>> // WRITE_PART writes all partitions to a single output file (only
>>>>> h5m format supports parallel IO at the moment).
>>>>> // One can use the mbconvert tool to convert the output to other
>>>>> formats.
>>>>> mb->write_file(outputFile.c_str(), "H5M", "PARALLEL=WRITE_PART");
>>>>> On Thu, Oct 10, 2013 at 10:37 AM, Tim Tautges <tautges at mcs.anl.gov>wrote:
>>>>>> Yeah, too complicated to backport, and latest works for Carlos anyway.
>>>>>> - tim
>>>>>> On 10/09/2013 09:41 PM, Iulian Grindeanu wrote:
>>>>>>> Both worked for me, with the current code (4.7.0pre)
>>>>>>> I don't get your error :(
>>>>>>> What version are you using? I will try 4.6.2, but it should be
>>>>>>> fine there too :(
>>>>>>> OK, I got an error with more quads, on 4.6.2 maybe I mixed them
>>>>>>> up when I saved :(
>>>>>>> mpiexec -np 2 /home/iulian/source/MOAB46/tools/mbconvert -O
>>>>>>> PARALLEL=READ_PART -O PARTITION=PARALLEL_PARTITION -O
>>>>>>> PARALLEL_RESOLVE_SHARED_ENTS -O PARALLEL_GHOSTS=2.0.1 -o
>>>>>>> PARALLEL=WRITE_PART
>>>>>>> /home/iulian/tmp/2d_naca0012_mixed2.h5m 2.h5m
>>>>>>> Leaked HDF5 object handle in function at
>>>>>>> ../../../moab46source/src/io/ReadHDF5.cpp:1523
>>>>>>> Open at entrance: 1
>>>>>>> Open at exit: 2
>>>>>>> ../../../moab46source/src/io/ReadHDF5.cpp:827
>>>>>>> Open at entrance: 1
>>>>>>> Open at exit: 2
>>>>>>> Failed to load "/home/iulian/tmp/2d_naca0012_mixed2.h5m".
>>>>>>> Error code: MB_INDEX_OUT_OF_RANGE (1)
>>>>>>> Error message: Failed in step PARALLEL READ PART
>>>>>>> Cannot close file with open handles: 0 file, 1 data, 0 group, 0
>>>>>>> type, 0 attr
>>>>>>> I will look into it.
>>>>>>> Hi Carlos,
>>>>>>> It looks like it is a bug in 4.6.2.
>>>>>>> I don't know if it will be fixed, there are some important changes
>>>>>>> in ghosting in current version.
>>>>>>> So for Version4.6 branch, the model with 17 quads works fine if you
>>>>>>> don't do ghosting:
>>>>>>> iulian at T520-iuli:~/source/MOAB46$ mpiexec -np 2
>>>>>>> /home/iulian/source/MOAB46/tools/mbconvert -O PARALLEL=READ_PART -O
>>>>>>> PARTITION=PARALLEL_PARTITION -O PARALLEL_RESOLVE_SHARED_ENTS -o
>>>>>>> PARALLEL=WRITE_PART
>>>>>>> /home/iulian/tmp/2d_naca0012_mixed_invert.h5m 2.h5m
>>>>>>> Read "/home/iulian/tmp/2d_naca0012_mixed_invert.h5m"
>>>>>>> Wrote "2.h5m"
>>>>>>> I would recommend upgrading to current version.
>>>>>>> That code is pretty complicated, and I am not sure if we will
>>>>>>> backport changes to Version4.6 branch.
>>>>>>> Tim, what do you suggest? Should I try to backport some changes in
>>>>>>> ParallelComm? I know you are working on that code.
>>>>>>> Thanks,
>>>>>>> Iulian
>>>>>> "You will keep in perfect peace him whose mind is
>>>>>> steadfast, because he trusts in you." Isaiah 26:3
>>>>>> Tim Tautges Argonne National Laboratory
>>>>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>>>>> phone (gvoice): (608) 354-1459 1500 Engineering Dr.
>>>>>> fax: (608) 263-4499 Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131120/94aa00a5/attachment-0001.html>
