[MOAB-dev] commit/MOAB: danwu: Do a MPI_Allreduce(collective call) to compute a common maxEdgesPerCell used across all processors. If maxEdgesPerCell is decided locally on each processor, it might have problems when ghosting.
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Wed Oct 9 12:07:10 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/23761f5d3a15/
Changeset:   23761f5d3a15
Branch:      master
User:        danwu
Date:        2013-10-09 19:06:53
Summary:     Do a MPI_Allreduce(collective call) to compute a common maxEdgesPerCell used across all processors. If maxEdgesPerCell is decided locally on each processor, it might have problems when ghosting.
Affected #:  1 file
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index a676dfa..45ce16e 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -14,11 +14,11 @@
 namespace moab {
-const int MAX_EDGES_PER_CELL = 10;
+const int DEFAULT_MAX_EDGES_PER_CELL = 10;
 NCHelperMPAS::NCHelperMPAS(ReadNC* readNC, int fileId, const FileOptions& opts, EntityHandle fileSet)
 : UcdNCHelper(readNC, fileId, opts, fileSet)
-, maxEdgesPerCell(MAX_EDGES_PER_CELL)
+, maxEdgesPerCell(DEFAULT_MAX_EDGES_PER_CELL)
 , numCellGroups(0)
@@ -44,12 +44,12 @@ ErrorCode NCHelperMPAS::init_mesh_vals()
   unsigned int idx;
   std::vector<std::string>::iterator vit;
-  // Get max edges per cell
+  // Get max edges per cell reported in the MPAS file header
   if ((vit = std::find(dimNames.begin(), dimNames.end(), "maxEdges")) != dimNames.end()) {
     idx = vit - dimNames.begin();
     maxEdgesPerCell = dimLens[idx];
-    if (maxEdgesPerCell > MAX_EDGES_PER_CELL) {
-      ERRORR(MB_FAILURE, "maxEdgesPerCell read from MPAS file has exceeded the limit");
+    if (maxEdgesPerCell > DEFAULT_MAX_EDGES_PER_CELL) {
+      ERRORR(MB_FAILURE, "maxEdgesPerCell read from the MPAS file header has exceeded DEFAULT_MAX_EDGES_PER_CELL.");
@@ -311,9 +311,20 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
   success = NCFUNCAG(_vara_int)(_fileId, nEdgesOnCellVarId, tmp_starts_1, tmp_counts_1, &num_edges_on_local_cells[0]);
   ERRORS(success, "Failed to read variable values of nEdgesOnCell.");
-  // Get local maxEdgesPerCell on this proc, to replace the global one reported in the MPAS file
+  // Get local maxEdgesPerCell on this proc
   maxEdgesPerCell = *(std::max_element(num_edges_on_local_cells.begin(), num_edges_on_local_cells.end()));
+  // In parallel, do a MPI_Allreduce to get a common global maxEdgesPerCell used across all procs
+#ifdef USE_MPI
+  if (procs > 1) {
+    int global_max_edges_per_cell;
+    ParallelComm*& myPcomm = _readNC->myPcomm;
+    MPI_Allreduce(&maxEdgesPerCell, &global_max_edges_per_cell, 1, MPI_INTEGER, MPI_MAX, myPcomm->proc_config().proc_comm());
+    assert(maxEdgesPerCell <= global_max_edges_per_cell);
+    maxEdgesPerCell = global_max_edges_per_cell;
+#endif
   // Read vertices on each local cell (connectivity)
   int verticesOnCellVarId;
   success = NCFUNC(inq_varid)(_fileId, "verticesOnCell", &verticesOnCellVarId);
@@ -463,7 +474,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
   } // if (noMixedElements)
   else {
     // Divide local cells into groups based on the number of edges
-    std::vector<int> local_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
+    std::vector<int> local_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
     for (int i = 0; i < nLocalCells; i++) {
       int num_edges = num_edges_on_local_cells[i];
       local_cells_with_n_edges[num_edges].push_back(start_cell_idx + i); // Global cell index
@@ -477,7 +488,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
     numCellGroups = num_edges_on_cell_groups.size();
     // For each non-empty cell group, create cells and set connectivity array with proper local vertices handles
-    EntityHandle* conn_arr_local_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
+    EntityHandle* conn_arr_local_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
     for (int i = 0; i < numCellGroups; i++) {
       int num_edges_per_cell = num_edges_on_cell_groups[i];
       int num_cells = local_cells_with_n_edges[num_edges_per_cell].size();
@@ -635,14 +646,14 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
     else {
       // Divide gather cells into groups based on the number of edges
-      std::vector<int> gather_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
+      std::vector<int> gather_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
       for (int i = 0; i < nCells; i++) {
         int num_edges = num_edges_on_gather_cells[i];
         gather_cells_with_n_edges[num_edges].push_back(i + 1); // 0 based -> 1 based
       // Create gather cells
-      EntityHandle* conn_arr_gather_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
+      EntityHandle* conn_arr_gather_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
       for (int num_edges_per_cell = 3; num_edges_per_cell <= maxEdgesPerCell; num_edges_per_cell++) {
         int num_cells = gather_cells_with_n_edges[num_edges_per_cell].size();
         if (num_cells > 0) {
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
