[MOAB-dev] mixed mesh question
    Carlos Breviglieri
    carbrevi at gmail.com
    Tue Nov 19 10:19:13 CST 2013
Iulian, here are some data on the supporting libs:
HDF5 v1.8.11
I compile the parallel version, but do not use the parallel IO capabilities
yet in CGNS.
./configure \
  CC=%s \
  CXX=%s \
  FC=%s \
  F9X=%s \
  RUNPARALLEL=%s \
  OMPI_MCA_disable_memory_allocator=1 \
  --prefix=%s \
  --enable-largefile \
  --enable-unsupported \
  --enable-shared \
  --disable-static \
  --enable-production=yes \
  --with-pthread=%s,%s \
  --with-zlib=%s,%s \
  --with-default-api-version=v18 \
  --enable-parallel=yes \
  --enable-cxx \
  --disable-sharedlib-rpath"
hdf5_config.log attached
CGNS v3.2.1 (Beta)
We have not considered the parallel IO capabilities as of now. There is no
clear definition yet how to handle MIXED type element meshes, for which you
can not specify a fixed record lenght to retrieve with hdf5. Although the
HDF5 library I linked is mpi-enabled.
Junior at some point tested with version 3.1.4 release 2 and it worked
fine, AFAIK.
The library is transitioning to CMake, I've used:
cmake \
  -DCGNS_BUILD_SHARED:BOOL=ON \
  -DCMAKE_BUILD_TYPE:STRING=Release \
  -DCMAKE_INSTALL_PREFIX:PATH=%s \
  -DCMAKE_SKIP_RPATH:BOOL=ON \
  -DCGNS_BUILD_CGNSTOOLS:BOOL=OFF \
  -DCGNS_ENABLE_64BIT:BOOL=ON \
  -DCGNS_ENABLE_FORTRAN:BOOL=OFF \
  -DCGNS_ENABLE_PARALLEL:BOOL=ON \
  -DCGNS_ENABLE_HDF5:BOOL=ON \
  -DHDF5_INCLUDE_PATH:PATH=%s \
  -DHDF5_LIBRARY:FILEPATH=%s \
  -DHDF5_NEED_MPI:BOOL=ON \
  -DHDF5_NEED_ZLIB:BOOL=ON \
  -DZLIB_LIBRARY:FILEPATH=%s \
  -DCGNS_ENABLE_SCOPING:BOOL=OFF \
  -DCGNS_ENABLE_TESTS:BOOL=OFF \
  -DMPIEXEC:FILEPATH=%s \
  -DMPI_C_COMPILER:FILEPATH=%s \
  -DMPI_C_INCLUDE_PATH:PATH=\"%s\"
 cgns321_CMakeCache.txt is attached.
MOAB v4.6.2
The patch is against the tar file from the website (
http://ftp.mcs.anl.gov/pub/fathom/moab-4.6.2.tar.gz). There is no need from
our side to keep it on 462. Feel free to include it in a latter release. It
was only convenient for me to keep the patch against a fixed release. For
this, I packaged in the previous email a tar.gz with the modified and new
sources and sample cgns files.
The reader and writer are serial only. We tested against homogeneous and
heterogeneous meshes up to 20million elements and it worked. You can read a
CGNS file, convert it to H5M and then convert it back to CGNS.
The modifications to compile moab is just an --with-cgns=DIR flag.
These build use shared libs for now, as I am working on my workstation.
Latter I will experiment with static objects for clusters.
If you need more details, let us know.
Carlos
On Tue, Nov 19, 2013 at 1:30 PM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
> Thank you Carlos and Junior, for your help.
> I will need to build cgns library; you mentioned that you tested 3.2 beta,
> too; I will probably stick with 3.1.4, (release 2?).
>  Also, what version of hdf5 library do you use? Should it work for any
> version greater than 1.8?
> I assume you build statically? Can I also get your config.log files for
> cgns and moab?
> I assume that you are not using any of the parallel io capability, because
> that seems to be available only in beta version.
> So everything is read/written in serial, isn't it?
> I am not sure if we will port the cgns reader / writer  to 4.6.2 also. Is
> your patch against 4.6.2 tar file or against "Version4.6" branch? There
> should not be much difference.
> Tim, what do you suggest? In a way, it should be easier to update 4.6.2.
> But I don't want to merge to the master after that, there are too many
> changes. This patch should work out of the box for 4.6.2, after I build
> cgns.
> Best Regards,
> Iulian
> Iulian,
> Sorry for the delay in getting back to you... I have tested the new
> version and it worked OK for my mesh sample. I will test it latter for
> other cases.
> Also, I am sending you the CGNS reader and writer along with input cgns
> mesh examples. We have worked on top of version 462, so things may look a
> little out of place from the repository.
> The attached patch modifies some autotools files and new files (apply with
> patch -p0 -i moab462_cgns.patch). Moreover, the tar.gz contains sample
> meshes (simple airfoil mesh in 2D and a mixed-mesh discretization of a 3D
> wingbody geometry).
> We have tested the CGNS capability with the latest library vesion 3.1.4
> and 3.2-beta. Furthermore, we sticked with the base CGNS use-case, that is,
> single base/zone. We will also implement latter capability to write out
> user variables.
> Please, feel free to improve the files and if you have any questions, let
> us know. carbrevi at gmail.com and junior.hmg at gmail.com
> Regards,
> Carlos
> On Sat, Nov 16, 2013 at 3:57 AM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
>> Hi Carlos,
>> That ticket is now closed, Tim fixed the bug.
>> Please let us know if it works for you.
>> Thanks for your patience,
>> Iulian
>> Iulian,
>> thanks for checking this out. I will be following the trac ticket. The
>> mesh I used is attached, partitioned for 8 procs (all tri). I noticed that
>> are much simpler sample meshes you created to investigate this issue.
>> Anyway, you can use the airfoil mesh if you find it useful.
>> I use a separate code to compute elements adjacency and then pass those
>> to metis. To write the partitions into h5m I followed the code form
>> mbzoltan tool. The partitioning code is correct (element-based) since I
>> have used this code previously with other applications...
>> I am from Brazil indeed, utc -3h. I'm a PhD candidate from Technological
>> Institute of Aeronautics in Sao Jose dos Campos.
>> Now I am building/adapting parts of my research code (high-order
>> unstructured CFD) to use MOAB. I will stick with 462 for this, working with
>> non-mixed meshes for this transition period. In the near feature I will
>> also look into the structured meshes capability of the library, as well as
>> the high-order elements implementation.
>> The CGNS reader/writer is in the works too and I will submit those as
>> well. My co-worker Junior, cc'ed here, is dealing with the writer part and
>> we are almos done.
>> Regards,
>> Carlos Breviglieri
>> On Sat, Oct 12, 2013 at 5:40 PM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
>>> Hi Carlos,
>>> I am seeing a problem with ghosting, thank you for pointing it out.
>>> Danqing and I messed up with that code :( to fix some other issues we were
>>> seeing.
>>> http://trac.mcs.anl.gov/projects/ITAPS/ticket/284
>>> It may take a while to fix it properly.
>>> Thanks again,
>>> Iulian
>>> Hmmmm,
>>> Can you send me the 2d_naca0012.h5m with your partition?
>>> If you do ghosting after reading, did you get the same results?
>>> The elements/processors should not change ownership after ghosting, but
>>> maybe they do.
>>> It is indeed a work in progress, you may have found another issue :(
>>> Not being able to write is probably the biggest problem.
>>> On what time zone do you work? :) Also, where are you from? The name
>>> looks Brazilian, Portuguese, or Italian ? Or Spanish?
>>> Thanks,
>>> Iulian
>>> Hi Iulian,
>>> I have just ran some tests with the latest clone of the master repo
>>> (saturday morning). Here are my findings with MOAB 470pre:
>>> Now I am able to read partitined mixed meshes without errors. However,
>>> if I plot the owned entitied for a given proc, even for non-mixed meshes,
>>> they are different from the ones obtained by the partitioner, see below
>>> Mesh distribution for 2d_naca0012.h5m (all tri mesh) from partitioner,
>>> over 8 procs:
>>> proc[0] has 866 elements
>>> proc[1] has 863 elements
>>> proc[2] has 866 elements
>>> proc[3] has 869 elements
>>> proc[4] has 872 elements
>>> proc[5] has 869 elements
>>> proc[6] has 862 elements
>>> proc[7] has 877 elements
>>> Mesh distribution seen by MOAB 470pre
>>> ("PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1")
>>> owned_entities[5], size = 864
>>> owned_entities[6], size = 853
>>> owned_entities[7], size = 871
>>> owned_entities[1], size = 859
>>> owned_entities[3], size = 860
>>> owned_entities[4], size = 867
>>> owned_entities[0], size = 866
>>> owned_entities[2], size = 861
>>> besides procs 0, all other report wrong number of entities. Code to
>>> compute such distribution is below (based on example/HelloParMOAB.cpp). The
>>> mixed mesh (2d_naca0012_mixed.h5m) now is read  (does not crash) but the
>>> distribution is off as well. With MOAB 462 the distribution is OK for
>>> homogeneous meshes.
>>> Moreover, with MOAB 470pre, no output is written to disk with
>>> PARALLEL=WRITE_PART, regardless of the mesh type. Using PARALLEL=NONE
>>> works, but only one part of the domain is written, as expected.
>>> I understand that this is a work in progress. If you need more
>>> information, let me know.
>>> Regards,
>>> Carlos Breviglieri
>>>     read_options =
>>> "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1";
>>>     moab::Interface* mb = new Core;
>>>     // Create root sets for each mesh.  Then pass these
>>>     // to the load_file functions to be populated.
>>>     EntityHandle rootset, partnset;
>>>     mb->create_meshset(MESHSET_SET, rootset);
>>>     mb->create_meshset(MESHSET_SET, partnset);
>>>     // Create the parallel communicator object with the partition handle
>>> associated with MOAB
>>>     ParallelComm *pcomm = ParallelComm::get_pcomm(mb, partnset, &myComm);
>>>     // Load the file from disk with given options
>>>     mb->load_file(meshFile.c_str(), &rootset, read_options.c_str());
>>>     // Get all entities of dimension = dim
>>>     Range elemRange, owned_entities;
>>>     int dim = 2;
>>>     mb->get_entities_by_dimension(rootset, dim, elemRange, false);
>>>     pcomm->filter_pstatus(elemRange, // pass entities that we want to
>>> filter
>>>                           PSTATUS_NOT_OWNED, // status we are looking for
>>>                           PSTATUS_NOT, // operation applied ; so it will
>>> return owned entities (!not_owned = owned)
>>>                           -1, // this means all processors
>>>                           &owned_entities);
>>>     std::vector<int> procID(owned_entities.size(), myRank);
>>>     std::cout << "owned_entities[" << myRank << "], size = " <<
>>> owned_entities.size() << std::endl;
>>>     Tag procID_tag;
>>>     mb->tag_get_handle("PROC_ID", 1, MB_TYPE_INTEGER, procID_tag,
>>> MB_TAG_CREAT | MB_TAG_DENSE, &procID[0]);
>>>     mb->tag_set_data(procID_tag, owned_entities, &procID[0]);
>>>     // WRITE_PART writes all partitions to a single output file (only
>>> h5m format supports parallel IO at the moment).
>>>     // One can use the mbconvert tool to convert the output to other
>>> formats.
>>>     mb->write_file(outputFile.c_str(), "H5M", "PARALLEL=WRITE_PART");
>>> On Thu, Oct 10, 2013 at 10:37 AM, Tim Tautges <tautges at mcs.anl.gov>wrote:
>>>> Yeah, too complicated to backport, and latest works for Carlos anyway.
>>>> - tim
>>>> On 10/09/2013 09:41 PM, Iulian Grindeanu wrote:
>>>>>     Both worked for me, with the current code (4.7.0pre)
>>>>>     I don't get your error :(
>>>>>     What version are you using? I will try 4.6.2, but it should be
>>>>> fine there too :(
>>>>>     OK, I got an error with more quads, on 4.6.2 maybe I mixed them up
>>>>> when I saved :(
>>>>>       mpiexec -np 2 /home/iulian/source/MOAB46/tools/mbconvert -O
>>>>> PARALLEL=READ_PART -O PARTITION=PARALLEL_PARTITION -O
>>>>>     PARALLEL_RESOLVE_SHARED_ENTS -O  PARALLEL_GHOSTS=2.0.1  -o
>>>>> PARALLEL=WRITE_PART
>>>>>     /home/iulian/tmp/2d_naca0012_mixed2.h5m 2.h5m
>>>>>     Leaked HDF5 object handle in function at
>>>>> ../../../moab46source/src/io/ReadHDF5.cpp:1523
>>>>>     Open at entrance: 1
>>>>>     Open at exit:     2
>>>>> ../../../moab46source/src/io/ReadHDF5.cpp:827
>>>>>     Open at entrance: 1
>>>>>     Open at exit:     2
>>>>>     Failed to load "/home/iulian/tmp/2d_naca0012_mixed2.h5m".
>>>>>     Error code: MB_INDEX_OUT_OF_RANGE (1)
>>>>>     Error message: Failed in step PARALLEL READ PART
>>>>>     Cannot close file with open handles: 0 file, 1 data, 0 group, 0
>>>>> type, 0 attr
>>>>>     I will look into it.
>>>>> Hi Carlos,
>>>>> It looks like it is a bug in 4.6.2.
>>>>> I don't know if it will be fixed, there are some important changes in
>>>>> ghosting in current version.
>>>>> So for Version4.6 branch, the model with 17 quads works fine if you
>>>>> don't do ghosting:
>>>>> iulian at T520-iuli:~/source/MOAB46$ mpiexec -np 2
>>>>> /home/iulian/source/MOAB46/tools/mbconvert -O PARALLEL=READ_PART -O
>>>>> PARTITION=PARALLEL_PARTITION -O PARALLEL_RESOLVE_SHARED_ENTS  -o
>>>>> PARALLEL=WRITE_PART
>>>>> /home/iulian/tmp/2d_naca0012_mixed_invert.h5m 2.h5m
>>>>> Read "/home/iulian/tmp/2d_naca0012_mixed_invert.h5m"
>>>>> Wrote "2.h5m"
>>>>> I would recommend upgrading to current version.
>>>>> That code is pretty complicated, and I am not sure if we will backport
>>>>> changes to Version4.6 branch.
>>>>> Tim, what do you suggest? Should I try to backport some changes in
>>>>> ParallelComm? I know you are working on that code.
>>>>> Thanks,
>>>>> Iulian
>>>> "You will keep in perfect peace him whose mind is
>>>>   steadfast, because he trusts in you."               Isaiah 26:3
>>>>              Tim Tautges            Argonne National Laboratory
>>>>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>>>>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>>>>             fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131119/fecc6e0e/attachment-0001.html>
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by MOAB configure 4.6.0, which was
generated by GNU Autoconf 2.69.  Invocation command line was
  $ ./configure CC=/usr/bin/mpicc CXX=/usr/bin/mpicxx FC=/usr/bin/mpif90 MPIEXEC=/usr/bin/mpiexec OMPI_MCA_disable_memory_allocator=1 --prefix=/home/carbrevi/opt/lnx_x64/contrib/moab --disable-fortran --enable-shared --enable-optimize --enable-imesh --enable-igeom --disable-mpe --disable-doxygen --disable-tools --with-mpi --with-hdf5=/home/carbrevi/opt/lnx_x64/contrib/hdf5 --with-zoltan=/home/carbrevi/opt/lnx_x64/contrib/trilinos --with-cgns=/home/carbrevi/opt/lnx_x64/contrib/cgns --without-vtk --without-x --without-parmetis --enable-mbsize --enable-mbskin --enable-mbmem --enable-mbcoupler --enable-mbconvert --enable-mbzoltan --enable-refiner --enable-h5mtools --enable-64bit --enable-64bit-handles
## Platform. ##
hostname = ALA_PC180
uname -m = x86_64
uname -r = 3.12.0-1-ARCH
uname -s = Linux
uname -v = #1 SMP PREEMPT Wed Nov 6 09:06:27 CET 2013
/usr/bin/uname -p = unknown
/bin/uname -X     = unknown
/bin/arch              = unknown
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo      = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /home/carbrevi/opt/lnx_x64/bin
PATH: /opt/openmpi/1.6.2/bin
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /opt/intel/bin
PATH: /usr/bin/vendor_perl
PATH: /usr/bin/core_perl
PATH: /home/carbrevi/opt/tecplot/bin
PATH: /home/carbrevi/opt/ansys_inc/v140/icemcfd/linux64_amd/bin
PATH: /opt/CEI/bin
PATH: /home/carbrevi/opt/ParaView-4.0.1/bin
PATH: /home/carbrevi/opt/visit2_7_0/bin
PATH: /home/carbrevi/opt/gmsh-2.8.3-Linux//bin
## Core tests. ##
configure:3261: checking build system type
configure:3275: result: x86_64-unknown-linux-gnu
configure:3295: checking host system type
configure:3308: result: x86_64-unknown-linux-gnu
configure:3328: checking target system type
configure:3341: result: x86_64-unknown-linux-gnu
configure:3384: checking for a BSD-compatible install
configure:3452: result: /usr/bin/install -c
configure:3463: checking whether build environment is sane
configure:3518: result: yes
configure:3669: checking for a thread-safe mkdir -p
configure:3708: result: /usr/bin/mkdir -p
configure:3715: checking for gawk
configure:3731: found /usr/bin/gawk
configure:3742: result: gawk
configure:3753: checking whether make sets $(MAKE)
configure:3775: result: yes
configure:3804: checking whether make supports nested variables
configure:3821: result: yes
configure:3949: checking for sed
configure:3965: found /usr/bin/sed
configure:3977: result: sed
configure:4013: checking for style of include used by make
configure:4041: result: GNU
configure:4170: checking for Fortran 77 compiler version
configure:4179: gfortran --version >&5
GNU Fortran (GCC) 4.8.2
Copyright (C) 2013 Free Software Foundation, Inc.
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
configure:4190: $? = 0
configure:4179: gfortran -v >&5
Using built-in specs.
COLLECT_GCC=gfortran
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.8.2/lto-wrapper
Target: x86_64-unknown-linux-gnu
Configured with: /build/gcc/src/gcc-4.8.2/configure --prefix=/usr --libdir=/usr/lib --libexecdir=/usr/lib --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=https://bugs.archlinux.org/ --enable-languages=c,c++,ada,fortran,go,lto,objc,obj-c++ --enable-shared --enable-threads=posix --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-clocale=gnu --disable-libstdcxx-pch --enable-gnu-unique-object --enable-linker-build-id --enable-cloog-backend=isl --disable-cloog-version-check --enable-lto --enable-gold --enable-ld=default --enable-plugin --with-plugin-ld=ld.gold --with-linker-hash-style=gnu --disable-install-libiberty --disable-multilib --disable-libssp --disable-werror --enable-checking=release
Thread model: posix
gcc version 4.8.2 (GCC)
configure:4179: gfortran -V >&5
gfortran: error: unrecognized command line option '-V'
gfortran: fatal error: no input files
compilation terminated.
configure:4190: $? = 1
configure:4179: gfortran -qversion >&5
gfortran: error: unrecognized command line option '-qversion'
configure:4199: checking whether we are using the GNU Fortran 77 compiler
configure:4212: gfortran -c  conftest.F >&5
configure:4212: $? = 0
configure: failed program was:
|       program main
| #ifndef __GNUC__
|        choke me
| #endif
|       end
configure:4221: result: no
configure:4227: checking whether gfortran accepts -g
configure:4238: gfortran -c -g conftest.f >&5
configure:4238: $? = 0
|       program main
|       end
configure:4246: result: no
configure:4381: checking for Fortran compiler version
configure:4390: /usr/bin/mpif90 --version >&5
configure:4401: $? = 0
configure:4390: /usr/bin/mpif90 -v >&5
COLLECT_GCC=/usr/bin/gfortran
Thread model: posix
configure:4390: /usr/bin/mpif90 -V >&5
configure:4401: $? = 1
configure:4390: /usr/bin/mpif90 -qversion >&5
configure:4410: checking whether we are using the GNU Fortran compiler
configure:4423: /usr/bin/mpif90 -c   conftest.F >&5
configure:4423: $? = 0
|       program main
| #ifndef __GNUC__
|        choke me
| #endif
|       end
configure:4432: result: no
configure:4438: checking whether /usr/bin/mpif90 accepts -g
configure:4449: /usr/bin/mpif90 -c -g  conftest.f >&5
configure:4449: $? = 0
|       program main
|       end
configure:4457: result: no
configure:5092: checking for gcc
configure:5119: result: /usr/bin/mpicc
configure:5348: checking for C compiler version
configure:5357: /usr/bin/mpicc --version >&5
gcc (GCC) 4.8.2
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:5368: $? = 0
configure:5357: /usr/bin/mpicc -v >&5
COLLECT_GCC=/usr/bin/gcc
Thread model: posix
configure:5357: /usr/bin/mpicc -V >&5
gcc: error: unrecognized command line option '-V'
gcc: fatal error: no input files
configure:5368: $? = 1
configure:5357: /usr/bin/mpicc -qversion >&5
gcc: error: unrecognized command line option '-qversion'
configure:5388: checking whether the C compiler works
configure:5410: /usr/bin/mpicc    conftest.c  >&5
configure:5414: $? = 0
configure:5462: result: yes
configure:5465: checking for C compiler default output file name
configure:5467: result: a.out
configure:5473: checking for suffix of executables
configure:5480: /usr/bin/mpicc -o conftest    conftest.c  >&5
configure:5484: $? = 0
configure:5506: result:
configure:5528: checking whether we are cross compiling
configure:5536: /usr/bin/mpicc -o conftest    conftest.c  >&5
configure:5540: $? = 0
configure:5547: ./conftest
configure:5551: $? = 0
configure:5566: result: no
configure:5571: checking for suffix of object files
configure:5593: /usr/bin/mpicc -c   conftest.c >&5
configure:5597: $? = 0
configure:5618: result: o
configure:5622: checking whether we are using the GNU C compiler
configure:5641: /usr/bin/mpicc -c   conftest.c >&5
configure:5641: $? = 0
configure:5650: result: yes
configure:5659: checking whether /usr/bin/mpicc accepts -g
configure:5679: /usr/bin/mpicc -c -g  conftest.c >&5
configure:5679: $? = 0
configure:5720: result: yes
configure:5737: checking for /usr/bin/mpicc option to accept ISO C89
configure:5800: /usr/bin/mpicc  -c -g -O2  conftest.c >&5
configure:5800: $? = 0
configure:5813: result: none needed
configure:5838: checking whether /usr/bin/mpicc understands -c and -o together
configure:5860: /usr/bin/mpicc -c conftest.c -o conftest2.o
configure:5863: $? = 0
configure:5875: result: yes
configure:5894: checking dependency style of /usr/bin/mpicc
configure:6005: result: gcc3
configure:6026: checking how to run the C preprocessor
configure:6057: /usr/bin/mpicc -E  conftest.c
configure:6057: $? = 0
configure:6071: /usr/bin/mpicc -E  conftest.c
conftest.c:11:28: fatal error: ac_nonexistent.h: No such file or directory
 #include <ac_nonexistent.h>
configure:6071: $? = 1
| /* confdefs.h */
| #define PACKAGE_NAME "MOAB"
| #define PACKAGE_TARNAME "moab"
| #define PACKAGE_VERSION "4.6.0"
| #define PACKAGE_STRING "MOAB 4.6.0"
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE_URL ""
| #define PACKAGE "moab"
| #define VERSION "4.6.0"
| /* end confdefs.h.  */
configure:6096: result: /usr/bin/mpicc -E
configure:6116: /usr/bin/mpicc -E  conftest.c
configure:6116: $? = 0
configure:6130: /usr/bin/mpicc -E  conftest.c
configure:6130: $? = 1
| /* confdefs.h */
configure:6271: checking for C++ compiler version
configure:6280: /usr/bin/mpicxx --version >&5
g++ (GCC) 4.8.2
configure:6291: $? = 0
configure:6280: /usr/bin/mpicxx -v >&5
COLLECT_GCC=/usr/bin/g++
Thread model: posix
configure:6280: /usr/bin/mpicxx -V >&5
g++: error: unrecognized command line option '-V'
g++: fatal error: no input files
configure:6291: $? = 1
configure:6280: /usr/bin/mpicxx -qversion >&5
g++: error: unrecognized command line option '-qversion'
configure:6295: checking whether we are using the GNU C++ compiler
configure:6314: /usr/bin/mpicxx -c   conftest.cpp >&5
configure:6314: $? = 0
configure:6323: result: yes
configure:6332: checking whether /usr/bin/mpicxx accepts -g
configure:6352: /usr/bin/mpicxx -c -g  conftest.cpp >&5
configure:6352: $? = 0
configure:6393: result: yes
configure:6418: checking dependency style of /usr/bin/mpicxx
configure:6529: result: gcc3
configure:6549: checking how to run the C++ preprocessor
configure:6576: /usr/bin/mpicxx -E  conftest.cpp
configure:6576: $? = 0
configure:6590: /usr/bin/mpicxx -E  conftest.cpp
conftest.cpp:11:28: fatal error: ac_nonexistent.h: No such file or directory
configure:6590: $? = 1
| /* confdefs.h */
configure:6615: result: /usr/bin/mpicxx -E
configure:6635: /usr/bin/mpicxx -E  conftest.cpp
configure:6635: $? = 0
configure:6649: /usr/bin/mpicxx -E  conftest.cpp
configure:6649: $? = 1
| /* confdefs.h */
configure:7816: checking whether ln -s works
configure:7820: result: yes
configure:7827: checking whether make sets $(MAKE)
configure:7849: result: yes
configure:7935: checking how to print strings
configure:7962: result: printf
configure:7983: checking for a sed that does not truncate output
configure:8047: result: sed
configure:8065: checking for grep that handles long lines and -e
configure:8123: result: /usr/bin/grep
configure:8128: checking for egrep
configure:8190: result: /usr/bin/grep -E
configure:8195: checking for fgrep
configure:8257: result: /usr/bin/grep -F
configure:8292: checking for ld used by /usr/bin/mpicc
configure:8359: result: /usr/bin/ld
configure:8366: checking if the linker (/usr/bin/ld) is GNU ld
configure:8381: result: yes
configure:8393: checking for BSD- or MS-compatible name lister (nm)
configure:8442: result: /usr/bin/nm -B
configure:8572: checking the name lister (/usr/bin/nm -B) interface
configure:8579: /usr/bin/mpicc -c -g -O2  conftest.c >&5
configure:8582: /usr/bin/nm -B "conftest.o"
configure:8585: output
0000000000000000 B some_variable
configure:8592: result: BSD nm
configure:8596: checking the maximum length of command line arguments
configure:8726: result: 1572864
configure:8743: checking whether the shell understands some XSI constructs
configure:8753: result: yes
configure:8757: checking whether the shell understands "+="
configure:8763: result: yes
configure:8798: checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format
configure:8838: result: func_convert_file_noop
configure:8845: checking how to convert x86_64-unknown-linux-gnu file names to toolchain format
configure:8865: result: func_convert_file_noop
configure:8872: checking for /usr/bin/ld option to reload object files
configure:8879: result: -r
configure:8953: checking for objdump
configure:8969: found /usr/bin/objdump
configure:8980: result: objdump
configure:9012: checking how to recognize dependent libraries
configure:9214: result: pass_all
configure:9299: checking for dlltool
configure:9329: result: no
configure:9359: checking how to associate runtime and link libraries
configure:9386: result: printf %s\n
configure:9447: checking for ar
configure:9463: found /usr/bin/ar
configure:9474: result: ar
configure:9511: checking for archiver @FILE support
configure:9528: /usr/bin/mpicc -c -g -O2  conftest.c >&5
configure:9528: $? = 0
configure:9531: ar cru libconftest.a @conftest.lst >&5
configure:9534: $? = 0
configure:9539: ar cru libconftest.a @conftest.lst >&5
ar: conftest.o: No such file or directory
configure:9542: $? = 1
configure:9554: result: @
configure:9612: checking for strip
configure:9628: found /usr/bin/strip
configure:9639: result: strip
configure:9711: checking for ranlib
configure:9727: found /usr/bin/ranlib
configure:9738: result: ranlib
configure:9840: checking command to parse /usr/bin/nm -B output from /usr/bin/mpicc object
configure:9960: /usr/bin/mpicc -c -g -O2  conftest.c >&5
configure:9963: $? = 0
configure:9967: /usr/bin/nm -B conftest.o \| sed -n -e 's/^.*[ ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p' | sed '/ __gnu_lto/d' \> conftest.nm
configure:9970: $? = 0
configure:10036: /usr/bin/mpicc -o conftest -g -O2   conftest.c conftstm.o >&5
configure:10039: $? = 0
configure:10077: result: ok
configure:10114: checking for sysroot
configure:10144: result: no
configure:10221: /usr/bin/mpicc -c -g -O2  conftest.c >&5
configure:10224: $? = 0
configure:10400: checking for mt
configure:10430: result: no
configure:10450: checking if : is a manifest tool
configure:10456: : '-?'
configure:10464: result: no
configure:11102: checking for ANSI C header files
configure:11122: /usr/bin/mpicc -c -g -O2  conftest.c >&5
configure:11122: $? = 0
configure:11195: /usr/bin/mpicc -o conftest -g -O2   conftest.c  -lm >&5
configure:11195: $? = 0
configure:11195: ./conftest
configure:11206: result: yes
configure:11219: checking for sys/types.h
configure:11219: /usr/bin/mpicc -c -g -O2  conftest.c >&5
configure:11219: $? = 0
configure:11219: result: yes
configure:11219: checking for sys/stat.h
configure:11219: checking for stdlib.h
configure:11219: checking for string.h
configure:11219: checking for memory.h
configure:11219: checking for strings.h
configure:11219: checking for inttypes.h
configure:11219: checking for stdint.h
configure:11219: checking for unistd.h
configure:11233: checking for dlfcn.h
configure:11233: /usr/bin/mpicc -c -g -O2  conftest.c >&5
configure:11233: $? = 0
configure:11233: result: yes
configure:11420: checking for objdir
configure:11435: result: .libs
configure:11706: checking if /usr/bin/mpicc supports -fno-rtti -fno-exceptions
configure:11724: /usr/bin/mpicc -c -g -O2  -fno-rtti -fno-exceptions conftest.c >&5
cc1: warning: command line option '-fno-rtti' is valid for C++/ObjC++ but not for C [enabled by default]
configure:11728: $? = 0
configure:11741: result: no
configure:12068: checking for /usr/bin/mpicc option to produce PIC
configure:12075: result: -fPIC -DPIC
configure:12083: checking if /usr/bin/mpicc PIC flag -fPIC -DPIC works
configure:12101: /usr/bin/mpicc -c -g -O2  -fPIC -DPIC -DPIC conftest.c >&5
configure:12105: $? = 0
configure:12118: result: yes
configure:12147: checking if /usr/bin/mpicc static flag -static works
configure:12175: result: no
configure:12190: checking if /usr/bin/mpicc supports -c -o file.o
configure:12211: /usr/bin/mpicc -c -g -O2  -o out/conftest2.o conftest.c >&5
configure:12215: $? = 0
configure:12237: result: yes
configure:12245: checking if /usr/bin/mpicc supports -c -o file.o
configure:12292: result: yes
configure:12325: checking whether the /usr/bin/mpicc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:13478: result: yes
configure:13515: checking whether -lc should be explicitly linked in
configure:13523: /usr/bin/mpicc -c -g -O2  conftest.c >&5
configure:13526: $? = 0
configure:13541: /usr/bin/mpicc -shared  -fPIC -DPIC conftest.o  -v -Wl,-soname -Wl,conftest -o conftest 2\>\&1 \| /usr/bin/grep  -lc  \>/dev/null 2\>\&1
configure:13544: $? = 0
configure:13558: result: no
configure:13718: checking dynamic linker characteristics
configure:14229: /usr/bin/mpicc -o conftest -g -O2   -Wl,-rpath -Wl,/foo conftest.c  -lm >&5
configure:14229: $? = 0
configure:14451: result: GNU/Linux ld.so
configure:14558: checking how to hardcode library paths into programs
configure:14583: result: immediate
configure:15123: checking whether stripping libraries is possible
configure:15128: result: yes
configure:15163: checking if libtool supports shared libraries
configure:15165: result: yes
configure:15168: checking whether to build shared libraries
configure:15189: result: yes
configure:15192: checking whether to build static libraries
configure:15196: result: yes
configure:15219: checking how to run the C++ preprocessor
configure:15285: result: /usr/bin/mpicxx -E
configure:15305: /usr/bin/mpicxx -E  conftest.cpp
configure:15305: $? = 0
configure:15319: /usr/bin/mpicxx -E  conftest.cpp
conftest.cpp:23:28: fatal error: ac_nonexistent.h: No such file or directory
configure:15319: $? = 1
| /* confdefs.h */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_DLFCN_H 1
| #define LT_OBJDIR ".libs/"
configure:15488: checking for ld used by /usr/bin/mpicxx
configure:15555: result: /usr/bin/ld -m elf_x86_64
configure:15562: checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld
configure:15577: result: yes
configure:15632: checking whether the /usr/bin/mpicxx linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:16637: result: yes
configure:16673: /usr/bin/mpicxx -c -g -O2  conftest.cpp >&5
configure:16676: $? = 0
configure:17196: checking for /usr/bin/mpicxx option to produce PIC
configure:17203: result: -fPIC -DPIC
configure:17211: checking if /usr/bin/mpicxx PIC flag -fPIC -DPIC works
configure:17229: /usr/bin/mpicxx -c -g -O2  -fPIC -DPIC -DPIC conftest.cpp >&5
configure:17233: $? = 0
configure:17246: result: yes
configure:17269: checking if /usr/bin/mpicxx static flag -static works
configure:17297: result: no
configure:17309: checking if /usr/bin/mpicxx supports -c -o file.o
configure:17330: /usr/bin/mpicxx -c -g -O2  -o out/conftest2.o conftest.cpp >&5
configure:17334: $? = 0
configure:17356: result: yes
configure:17361: checking if /usr/bin/mpicxx supports -c -o file.o
configure:17408: result: yes
configure:17438: checking whether the /usr/bin/mpicxx linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:17474: result: yes
configure:17615: checking dynamic linker characteristics
configure:18282: result: GNU/Linux ld.so
configure:18335: checking how to hardcode library paths into programs
configure:18360: result: immediate
configure:18508: checking if libtool supports shared libraries
configure:18510: result: yes
configure:18513: checking whether to build shared libraries
configure:18533: result: yes
configure:18536: checking whether to build static libraries
configure:18540: result: yes
configure:18861: checking for gfortran option to produce PIC
configure:18868: result:
configure:18934: checking if gfortran static flag  works
configure:18962: result: yes
configure:18974: checking if gfortran supports -c -o file.o
configure:18995: gfortran -c  -o out/conftest2.o conftest.f >&5
configure:18999: $? = 0
configure:19021: result: yes
configure:19026: checking if gfortran supports -c -o file.o
configure:19073: result: yes
configure:19103: checking whether the gfortran linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:20206: result: yes
configure:20347: checking dynamic linker characteristics
configure:21008: result: GNU/Linux ld.so
configure:21061: checking how to hardcode library paths into programs
configure:21086: result: immediate
configure:21230: checking if libtool supports shared libraries
configure:21232: result: yes
configure:21235: checking whether to build shared libraries
configure:21255: result: yes
configure:21258: checking whether to build static libraries
configure:21262: result: yes
configure:21296: /usr/bin/mpif90 -c   conftest.f >&5
configure:21299: $? = 0
configure:21728: checking for /usr/bin/mpif90 option to produce PIC
configure:21735: result:
configure:21801: checking if /usr/bin/mpif90 static flag  works
configure:21829: result: yes
configure:21841: checking if /usr/bin/mpif90 supports -c -o file.o
configure:21862: /usr/bin/mpif90 -c  -o out/conftest2.o  conftest.f >&5
configure:21866: $? = 0
configure:21888: result: yes
configure:21893: checking if /usr/bin/mpif90 supports -c -o file.o
configure:21940: result: yes
configure:21970: checking whether the /usr/bin/mpif90 linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:23073: result: yes
configure:23214: checking dynamic linker characteristics
configure:23875: result: GNU/Linux ld.so
configure:23928: checking how to hardcode library paths into programs
configure:23953: result: immediate
configure:24017: checking for known C compilers
configure:24038: /usr/bin/mpicc -c -g -O2  conftest.c >&5
conftest.c:25:4: error: unknown type name 'choke'
    choke me
conftest.c:27:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'int'
 int
configure:24038: $? = 1
| /* confdefs.h */
|  #ifndef __INTEL_COMPILER
|    choke me
|  #endif
| int
| main ()
|   return 0;
configure:24410: result: GNU
configure:24418: checking for known compiler/OS combinations
configure:24484: result: GNU:x86_64
configure:24498: checking for known c++ compilers
configure:24519: /usr/bin/mpicxx -c -g -O2  conftest.cpp >&5
conftest.cpp:25:4: error: 'choke' does not name a type
    choke me
configure:24519: $? = 1
| /* confdefs.h */
|    choke me
|  #endif
| int
| main ()
|   return 0;
configure:24914: result: GNU
configure:24922: checking for known compiler/OS combinations
configure:24984: result: GNU:x86_64
configure:25163: checking whether make supports nested variables
configure:25180: result: yes
configure:25195: checking if platform is IBM BlueGene
configure:25212: /usr/bin/mpicc -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  conftest.c >&5
    choke me
 int
configure:25212: $? = 1
| /* confdefs.h */
|  #ifndef __bg__
|    choke me
|  #endif
| int
| main ()
|   return 0;
configure:25217: result: no
configure:25225: checking for gunzip
configure:25241: found /usr/bin/gunzip
configure:25252: result: gunzip -c
configure:25262: checking for gzip
configure:25289: result: gunzip -c
configure:25299: checking for zcat
configure:25326: result: gunzip -c
configure:25349: checking if C++ compiler supports template class specialization
configure:25373: /usr/bin/mpicxx -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  conftest.cpp >&5
conftest.cpp: In function 'int main()':
conftest.cpp:28:12: warning: variable 'one' set but not used [-Wunused-but-set-variable]
 MyTempl<1> one; MyTempl<0> zero; one.data[0] = zero.value = '\0';
configure:25373: $? = 0
configure:25386: result: yes
configure:25396: checking if C++ compiler supports template function specialization
configure:25421: /usr/bin/mpicxx -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  conftest.cpp >&5
configure:25421: $? = 0
configure:25434: result: yes
configure:25452: checking if /usr/bin/mpicxx works
configure:25465: /usr/bin/mpicxx -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  conftest.cpp >&5
configure:25465: $? = 0
configure:25479: /usr/bin/mpicxx -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  conftest.cpp >&5
conftest.cpp:28:4: error: 'choke' was not declared in this scope
    choke me
conftest.cpp:28:10: error: expected ';' before 'me'
    choke me
configure:25479: $? = 1
| /* confdefs.h */
| int
| main ()
| #ifdef __cplusplus
|    choke me
|  #endif
|   return 0;
configure:25483: result: yes
configure:25992: checking for vsnprintf
configure:25992: /usr/bin/mpicc -o conftest  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64   conftest.c  -lm >&5
conftest.c:46:6: warning: conflicting types for built-in function 'vsnprintf' [enabled by default]
 char vsnprintf ();
configure:25992: $? = 0
configure:25992: result: yes
configure:26004: checking if std::vector has templatized insert method
configure:26039: /usr/bin/mpicxx -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  conftest.cpp >&5
configure:26039: $? = 0
configure:26052: result: yes
configure:26060: checking if std::copy must be old SGI format
configure:26091: /usr/bin/mpicxx -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  conftest.cpp >&5
conftest.cpp:35:9: warning: unused variable 'b' [-Wunused-variable]
 int* a, b = std::count(a, a, 5);
conftest.cpp:35:31: warning: 'a' is used uninitialized in this function [-Wuninitialized]
configure:26091: $? = 0
configure:26104: result: no
configure:26137: checking for inttypes.h
configure:26137: result: yes
configure:26145: checking for stdint.h
configure:26145: result: yes
configure:26153: checking for sys/types.h
configure:26153: result: yes
configure:26161: checking stddef.h usability
configure:26161: /usr/bin/mpicc -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  conftest.c >&5
configure:26161: $? = 0
configure:26161: result: yes
configure:26161: checking stddef.h presence
configure:26161: /usr/bin/mpicc -E  conftest.c
configure:26161: checking for stddef.h
configure:26169: checking for stdlib.h
configure:26169: result: yes
configure:26182: checking size of void *
configure:26187: /usr/bin/mpicc -o conftest  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64   conftest.c  -lm >&5
configure:26187: $? = 0
configure:26187: ./conftest
configure:26201: result: 8
configure:26215: checking for uint64_t
configure:26215: /usr/bin/mpicc -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  conftest.c >&5
configure:26215: $? = 0
conftest.c: In function 'main':
conftest.c:73:23: error: expected expression before ')' token
 if (sizeof ((uint64_t)))
configure:26215: $? = 1
| /* confdefs.h */
| #define MOAB_HAVE_INTTYPES_H /**/
| #define MOAB_HAVE_STDINT_H /**/
| #define MOAB_HAVE_SYS_TYPES_H /**/
| #define MOAB_HAVE_STDDEF_H /**/
| #define MOAB_HAVE_STDLIB_H /**/
| #define SIZEOF_VOID_P 8
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| #  include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #ifdef HAVE_UNISTD_H
| # include <unistd.h>
| #endif
| #ifdef FC_DUMMY_MAIN
| #ifndef FC_DUMMY_MAIN_EQ_F77
| #  ifdef __cplusplus
|      extern "C"
| #  endif
|    int FC_DUMMY_MAIN() { return 1; }
| #endif
| #endif
| int
| main ()
| 	    return 0;
|   return 0;
configure:26215: result: yes
configure:26441: checking size of EntityHandle
configure:26443: result: 8
configure:26458: checking if iMesh support is to be built
configure:26460: result: yes
configure:26476: checking if iGeom support is to be built
configure:26478: result: yes
configure:26542: creating ./config.lt
## Running config.lt. ##
config.lt:787: creating libtool
configure:28684: checking ieeefp.h usability
configure:28684: /usr/bin/mpicc -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  conftest.c >&5
conftest.c:68:20: fatal error: ieeefp.h: No such file or directory
 #include <ieeefp.h>
configure:28684: $? = 1
| /* confdefs.h */
| #define MOAB_FORCE_64_BIT_HANDLES /**/
| #define MB_VERSION "4.6.0"
| #define MB_VERSION_MAJOR 4
| #define MB_VERSION_MINOR 6
| #define MB_VERSION_PATCH 0
| #define MB_VERSION_STRING "MOAB 4.6.0"
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <ieeefp.h>
configure:28684: result: no
configure:28684: checking ieeefp.h presence
configure:28684: /usr/bin/mpicc -E  conftest.c
conftest.c:35:20: fatal error: ieeefp.h: No such file or directory
 #include <ieeefp.h>
| /* confdefs.h */
| #include <ieeefp.h>
configure:28684: checking for ieeefp.h
configure:28705: checking for C++ unordered_map
configure:28736: /usr/bin/mpicxx -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  conftest.cpp >&5
In file included from /usr/include/c++/4.8.2/unordered_map:35:0,
                 from conftest.cpp:35:
/usr/include/c++/4.8.2/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
 #error This file requires compiler and library support for the \
conftest.cpp:47:1: error: 'unordered_map' is not a member of 'std'
 std::unordered_map<int,int> map
conftest.cpp:47:20: error: expected primary-expression before 'int'
conftest.cpp:47:20: error: expected ';' before 'int'
configure:28736: $? = 1
| /* confdefs.h */
| #include <unordered_map>
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
|   return 0;
configure:28760: /usr/bin/mpicxx -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  conftest.cpp >&5
configure:28760: $? = 0
configure:28797: result: std::tr1
configure:28821: checking mpi.h usability
configure:28821: /usr/bin/mpicc -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.c >&5
configure:28821: $? = 0
configure:28821: result: yes
configure:28821: checking mpi.h presence
configure:28821: /usr/bin/mpicc -E  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.c
configure:28821: checking for mpi.h
configure:28836: checking If mpi.h conflicts with C headers in C++
configure:28864: /usr/bin/mpicxx -E  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.cpp
configure:28864: $? = 0
configure:28865: result: no
configure:29523: checking for deflate in -lz
configure:29556: /usr/bin/mpicc -o conftest  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set   conftest.c -lz   -lm >&5
configure:29556: $? = 0
configure:29565: result: yes
configure:29601: checking for SZ_Decompress in -lsz
configure:29634: /usr/bin/mpicc -o conftest  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set   conftest.c -lsz   -lm >&5
/usr/bin/ld: cannot find -lsz
collect2: error: ld returned 1 exit status
configure:29634: $? = 1
| /* confdefs.h */
| /* Override any GCC internal prototype to avoid an error.
|    Use char because int might match the return type of a GCC
|    builtin and then its argument prototype would still apply.  */
| #ifdef __cplusplus
| extern "C"
| #endif
| char SZ_Decompress ();
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| return SZ_Decompress ();
|   return 0;
configure:29643: result: no
configure:29679: checking if HDF5 support is enabled
configure:29695: result: yes
configure:29737: checking hdf5.h usability
configure:29737: /usr/bin/mpicc -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  -I/home/carbrevi/opt/lnx_x64/contrib/hdf5/include -isystem /home/carbrevi/opt/lnx_x64/contrib/hdf5/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.c >&5
configure:29737: $? = 0
configure:29737: result: yes
configure:29737: checking hdf5.h presence
configure:29737: /usr/bin/mpicc -E  -I/home/carbrevi/opt/lnx_x64/contrib/hdf5/include -isystem /home/carbrevi/opt/lnx_x64/contrib/hdf5/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.c
configure:29737: checking for hdf5.h
configure:29757: checking for gpfs_stat in -lgpfs
configure:29790: /usr/bin/mpicc -o conftest  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  -I/home/carbrevi/opt/lnx_x64/contrib/hdf5/include -isystem /home/carbrevi/opt/lnx_x64/contrib/hdf5/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib  conftest.c -lgpfs    -lm >&5
/usr/bin/ld: cannot find -lgpfs
configure:29790: $? = 1
| /* confdefs.h */
| #define HAVE_HDF5_H 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char gpfs_stat ();
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| return gpfs_stat ();
|   return 0;
configure:29799: result: no
configure:29815: checking for H5Fopen in -lhdf5
configure:29848: /usr/bin/mpicc -o conftest  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  -I/home/carbrevi/opt/lnx_x64/contrib/hdf5/include -isystem /home/carbrevi/opt/lnx_x64/contrib/hdf5/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib  conftest.c -lhdf5     -lm >&5
configure:29848: $? = 0
configure:29858: result: yes
configure:30260: checking for H5Pset_fapl_mpio in -lhdf5
configure:30294: /usr/bin/mpicc -o conftest  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set    -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib conftest.c -lhdf5 -lhdf5
        -lm >&5
configure:30294: $? = 0
configure:30303: result: yes
configure:30326: checking for H5_MPI_COMPLEX_DERIVED_DATATYPE_WORKS
configure:30352: /usr/bin/mpicc -E  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -I/home/carbrevi/opt/lnx_x64/contrib/hdf5/include -isystem /home/carbrevi/opt/lnx_x64/contrib/hdf5/include conftest.c
configure:30352: $? = 0
configure:30353: result: yes
configure:30371: checking if CCMIO support is enabled
configure:30385: result: yes
configure:30393: checking if CCMIO support available
configure:30395: result:
configure:30427: checking ccmio.h usability
configure:30427: /usr/bin/mpicc -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.c >&5
conftest.c:69:19: fatal error: ccmio.h: No such file or directory
 #include <ccmio.h>
configure:30427: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <ccmio.h>
configure:30427: result: no
configure:30427: checking ccmio.h presence
configure:30427: /usr/bin/mpicc -E   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.c
conftest.c:36:19: fatal error: ccmio.h: No such file or directory
 #include <ccmio.h>
| /* confdefs.h */
| #include <ccmio.h>
configure:30427: checking for ccmio.h
configure:30441: checking ccmioutility.h usability
configure:30441: /usr/bin/mpicc -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.c >&5
conftest.c:69:26: fatal error: ccmioutility.h: No such file or directory
 #include <ccmioutility.h>
configure:30441: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:30441: result: no
configure:30441: checking ccmioutility.h presence
configure:30441: /usr/bin/mpicc -E   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.c
conftest.c:36:26: fatal error: ccmioutility.h: No such file or directory
| /* confdefs.h */
configure:30441: checking for ccmioutility.h
configure:30455: checking ccmiocore.h usability
configure:30455: /usr/bin/mpicc -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.c >&5
conftest.c:69:23: fatal error: ccmiocore.h: No such file or directory
 #include <ccmiocore.h>
configure:30455: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:30455: result: no
configure:30455: checking ccmiocore.h presence
configure:30455: /usr/bin/mpicc -E   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.c
conftest.c:36:23: fatal error: ccmiocore.h: No such file or directory
| /* confdefs.h */
configure:30455: checking for ccmiocore.h
configure:30474: checking unsuccessful, Ccmio support disabled
configure:30476: result:
configure:30512: checking if DAMSEL support is enabled
configure:30529: result: no
configure:30534: checking if DAMSEL support available
configure:30536: result:
configure:30634: checking if NetCDF support is enabled
configure:30648: result: yes
configure:30692: checking netcdf.h usability
configure:30692: /usr/bin/mpicc -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.c >&5
conftest.c:69:20: fatal error: netcdf.h: No such file or directory
 #include <netcdf.h>
configure:30692: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <netcdf.h>
configure:30692: result: no
configure:30692: checking netcdf.h presence
configure:30692: /usr/bin/mpicc -E   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.c
conftest.c:36:20: fatal error: netcdf.h: No such file or directory
 #include <netcdf.h>
| /* confdefs.h */
| #include <netcdf.h>
configure:30692: checking for netcdf.h
configure:30766: WARNING: NetCDF header not found.
configure:30774: checking for nc_create in -lnetcdf
configure:30807: /usr/bin/mpicc -o conftest  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set    -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib    -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib conftest.c -lnetcdf   -lm >&5
/usr/bin/ld: cannot find -lnetcdf
configure:30807: $? = 1
| /* confdefs.h */
| #ifdef __cplusplus
| extern "C"
| #endif
| char nc_create ();
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| return nc_create ();
|   return 0;
configure:30816: result: no
configure:31287: checking for nc_create in -lnetcdf
configure:31320: /usr/bin/mpicc -o conftest  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set    -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib    -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib conftest.c -lnetcdf -lhdf5_hl -lhdf5     -lm >&5
configure:31320: $? = 1
| /* confdefs.h */
| #ifdef __cplusplus
| extern "C"
| #endif
| char nc_create ();
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
|   return 0;
configure:31329: result: no
configure:31338: checking for nc_create in -lnetcdf
configure:31371: /usr/bin/mpicc -o conftest  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set    -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib    -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib conftest.c -lnetcdf -lhdf5_hl -lhdf5   -lcurl   -lm >&5
configure:31371: $? = 1
| /* confdefs.h */
| #ifdef __cplusplus
| extern "C"
| #endif
| char nc_create ();
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
|   return 0;
configure:31380: result: no
configure:31406: WARNING: "NetCDF support disabled"
configure:31456: checking if Pnetcdf support is enabled
configure:31459: result: yes
configure:31503: checking pnetcdf.h usability
configure:31503: /usr/bin/mpicc -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.c >&5
conftest.c:69:21: fatal error: pnetcdf.h: No such file or directory
 #include <pnetcdf.h>
configure:31503: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:31503: result: no
configure:31503: checking pnetcdf.h presence
configure:31503: /usr/bin/mpicc -E   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.c
conftest.c:36:21: fatal error: pnetcdf.h: No such file or directory
| /* confdefs.h */
configure:31503: checking for pnetcdf.h
configure:31583: checking for ncmpi_create in -lpnetcdf
configure:31616: /usr/bin/mpicc -o conftest  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set     -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib conftest.c -lpnetcdf   -lm >&5
/usr/bin/ld: cannot find -lpnetcdf
configure:31616: $? = 1
| /* confdefs.h */
| #ifdef __cplusplus
| extern "C"
| #endif
| char ncmpi_create ();
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| return ncmpi_create ();
|   return 0;
configure:31625: result: no
configure:31677: checking if CGNS support is enabled
configure:31691: result: yes
configure:31734: checking cgnslib.h usability
configure:31734: /usr/bin/mpicc -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64 -I/home/carbrevi/opt/lnx_x64/contrib/cgns/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.c >&5
configure:31734: $? = 0
configure:31734: result: yes
configure:31734: checking cgnslib.h presence
configure:31734: /usr/bin/mpicc -E -I/home/carbrevi/opt/lnx_x64/contrib/cgns/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set conftest.c
configure:31734: checking for cgnslib.h
configure:31745: checking for cg_open in -lcgns
configure:31778: /usr/bin/mpicc -o conftest  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64 -I/home/carbrevi/opt/lnx_x64/contrib/cgns/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -L/home/carbrevi/opt/lnx_x64/contrib/cgns/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib    -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib conftest.c -lcgns   -lm >&5
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5T_NATIVE_INT32_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5P_CLS_FILE_CREATE_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Pcreate'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Tcopy'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5T_NATIVE_UINT32_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Sget_simple_extent_dims'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Eset_auto2'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Sget_simple_extent_ndims'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Aget_type'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Fcreate'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Sclose'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5T_NATIVE_SCHAR_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Aopen_name'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Gunlink'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Lget_val'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Tget_native_type'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Acreate2'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Aclose'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Pset_deflate'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5T_C_S1_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Tset_precision'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Dopen2'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Dget_type'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5T_NATIVE_FLOAT_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Lunpack_elink_val'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Dwrite'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Lcreate_external'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Pset_dxpl_mpio'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Screate_simple'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Aread'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5check_version'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Iget_name'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Lis_registered'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Fget_obj_ids'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5P_CLS_GROUP_CREATE_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Gcreate2'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Giterate'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Tget_size'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Lexists'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5T_NATIVE_UCHAR_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Screate'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5T_IEEE_F32BE_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Literate'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5P_CLS_DATASET_XFER_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Gopen2'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Dset_extent'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5T_IEEE_F64BE_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Dget_space'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Dclose'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5P_CLS_FILE_ACCESS_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5T_NATIVE_UINT64_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Pset_fapl_mpio'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Pset_nlinks'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Pclose'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Fflush'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Pset_link_creation_order'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5P_CLS_LINK_ACCESS_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5T_IEEE_F64LE_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Fis_hdf5'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5T_NATIVE_INT64_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5T_IEEE_F32LE_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Gget_objinfo'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Sselect_hyperslab'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5T_NATIVE_INT_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Gclose'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Ewalk2'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Awrite'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Gmove'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Sget_simple_extent_npoints'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5open'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Dread'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5garbage_collect'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Pset_libver_bounds'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Tget_precision'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Tset_size'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Aiterate2'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Fget_obj_count'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5P_CLS_DATASET_CREATE_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5get_libversion'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Tclose'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Fopen'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Fclose'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Glink'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5T_NATIVE_DOUBLE_g'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Dcreate2'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Tequal'
/home/carbrevi/opt/lnx_x64/contrib/cgns/lib/libcgns.so: undefined reference to `H5Sget_select_npoints'
configure:31778: $? = 1
| /* confdefs.h */
| #ifdef __cplusplus
| extern "C"
| #endif
| char cg_open ();
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| return cg_open ();
|   return 0;
configure:31787: result: no
configure:32258: checking for cg_open in -lcgns
configure:32291: /usr/bin/mpicc -o conftest  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64 -I/home/carbrevi/opt/lnx_x64/contrib/cgns/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -L/home/carbrevi/opt/lnx_x64/contrib/cgns/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib    -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib conftest.c -lcgns -lhdf5_hl -lhdf5     -lm >&5
configure:32291: $? = 0
configure:32300: result: yes
configure:32697: checking if mbconvert is to be built
configure:32699: result: yes
configure:32724: checking if pointsearch is to be built
configure:32726: result: no
configure:32751: checking if hexmodops is to be built
configure:32753: result: no
configure:32778: checking if qvdual is to be built
configure:32780: result: no
configure:32805: checking if vtkMOABReader is to be built
configure:32807: result: no
configure:32832: checking if vtkMOABReaderNew is to be built
configure:32834: result: no
configure:32859: checking if mbsize is to be built
configure:32861: result: yes
configure:32886: checking if mbskin is to be built
configure:32888: result: yes
configure:32913: checking if mbtagprop is to be built
configure:32915: result: no
configure:32940: checking if mbmem is to be built
configure:32942: result: yes
configure:32967: checking if mcnpmit is to be built
configure:32969: result: no
configure:32994: checking if mbcoupler is to be built
configure:32996: result: yes
configure:33021: checking if spheredecomp is to be built
configure:33023: result: no
configure:33048: checking if mbsurfplot is to be built
configure:33050: result: no
configure:33075: checking if mbzoltan is to be built
configure:33077: result: yes
configure:33102: checking if dagmc is to be built
configure:33104: result: no
configure:33129: checking if gsets is to be built
configure:33131: result: no
configure:33156: checking if mbdepth is to be built
configure:33158: result: no
configure:33183: checking if refiner is to be built
configure:33185: result: yes
configure:33210: checking if h5mtools is to be built
configure:33212: result: yes
configure:33237: checking if mbcslam is to be built
configure:33239: result: no
configure:33301: checking for zoltan_cpp.h
configure:33301: /usr/bin/mpicxx -c  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -I/home/carbrevi/opt/lnx_x64/contrib/trilinos/include -DMPICH_IGNORE_CXX_SEEK conftest.cpp >&5
In file included from conftest.cpp:38:0:
/home/carbrevi/opt/lnx_x64/contrib/trilinos/include/zoltan_cpp.h:183:7: warning: unused parameter 'iperm' [-Wunused-parameter]
   int Order    ( int num_gid_entries,
configure:33301: $? = 0
configure:33301: result: yes
configure:33343: checking for Zoltan_LB_Partition in -lzoltan
configure:33376: /usr/bin/mpicc -o conftest  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set    -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib  -L/home/carbrevi/opt/lnx_x64/contrib/trilinos/lib conftest.c -lzoltan   -lm >&5
configure:33376: $? = 0
configure:33385: result: yes
configure:36990: checking that generated files are newer than configure
configure:36996: result: done
configure:37175: creating ./config.status
## Running config.status. ##
This file was extended by MOAB config.status 4.6.0, which was
  CONFIG_FILES    =
  CONFIG_HEADERS  =
  CONFIG_LINKS    =
  CONFIG_COMMANDS =
  $ ./config.status
on ALA_PC180
config.status:1448: creating Makefile
config.status:1448: creating moab.make
config.status:1448: creating MOABConfig.cmake
config.status:1448: creating src/Makefile
config.status:1448: creating src/io/Makefile
config.status:1448: creating src/io/mhdf/Makefile
config.status:1448: creating src/parallel/Makefile
config.status:1448: creating src/oldinc/Makefile
config.status:1448: creating test/Makefile
config.status:1448: creating test/h5file/Makefile
config.status:1448: creating test/dual/Makefile
config.status:1448: creating test/obb/Makefile
config.status:1448: creating test/perf/Makefile
config.status:1448: creating test/io/Makefile
config.status:1448: creating test/parallel/Makefile
config.status:1448: creating test/oldinc/Makefile
config.status:1448: creating itaps/iBase_f.h
config.status:1448: creating itaps/Makefile
config.status:1448: creating itaps/imesh/Makefile
config.status:1448: creating itaps/imesh/iMesh-Defs.inc
config.status:1448: creating itaps/igeom/Makefile
config.status:1448: creating itaps/igeom/FBiGeom-Defs.inc
config.status:1448: creating tools/Makefile
config.status:1448: creating tools/refiner/Makefile
config.status:1448: creating tools/mbcoupler/Makefile
config.status:1448: creating tools/mbcslam/Makefile
config.status:1448: creating tools/mbzoltan/Config.moab
config.status:1448: creating tools/mbzoltan/Makefile
config.status:1448: creating tools/mcnpmit/Makefile
config.status:1448: creating tools/qvdual/Makefile
config.status:1448: creating tools/dagmc/Makefile
config.status:1448: creating tools/vtkMOABReader/CMakeLists.txt
config.status:1448: creating tools/vtkMOABReaderNew/CMakeLists.txt
config.status:1448: creating doc/Makefile
config.status:1448: creating doc/user.dox
config.status:1448: creating doc/dev.dox
config.status:1448: creating doc/config.tex
config.status:1448: creating MeshFiles/Makefile
config.status:1448: creating MeshFiles/unittest/Makefile
config.status:1448: creating MeshFiles/unittest/io/Makefile
config.status:1448: creating config.h
config.status:1448: creating src/moab/Version.h
config.status:1448: creating src/moab/EntityHandle.hpp
config.status:1448: creating src/parallel/moab_mpi_config.h
config.status:1448: creating src/FCDefs.h
config.status:1677: executing depfiles commands
config.status:1677: executing libtool commands
config.status:1677: executing src/MOAB_FCDefs.h commands
configure:40189: result: C:   /usr/bin/mpicc  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set
configure:40191: result: C++: /usr/bin/mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set
configure:40194: result: Fortran: /usr/bin/mpif90   -O2
configure:40198: result: Fortran: gfortran   -O2
configure:40220: WARNING:
*           MOAB has been configured w/out the NetCDF library.
*     Support for ExodusII/Genesis and other file formats is disabled!
## Cache variables. ##
ac_cv_build=x86_64-unknown-linux-gnu
ac_cv_c_compiler_gnu=yes
ac_cv_cxx_compiler_gnu=yes
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=set
ac_cv_env_CC_value=/usr/bin/mpicc
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=set
ac_cv_env_CXX_value=/usr/bin/mpicxx
ac_cv_env_F77_set=set
ac_cv_env_F77_value=gfortran
ac_cv_env_FCFLAGS_set=
ac_cv_env_FCFLAGS_value=
ac_cv_env_FC_set=set
ac_cv_env_FC_value=/usr/bin/mpif90
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_MPIEXEC_NP_set=
ac_cv_env_MPIEXEC_NP_value=
ac_cv_env_MPIEXEC_set=set
ac_cv_env_MPIEXEC_value=/usr/bin/mpiexec
ac_cv_env_NP_set=
ac_cv_env_NP_value=
ac_cv_env_QTDIR_set=
ac_cv_env_QTDIR_value=
ac_cv_env_XMKMF_set=
ac_cv_env_XMKMF_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_f77_compiler_gnu=no
ac_cv_fc_compiler_gnu=no
ac_cv_func_vsnprintf=yes
ac_cv_header_ccmio_h=no
ac_cv_header_ccmiocore_h=no
ac_cv_header_ccmioutility_h=no
ac_cv_header_cgnslib_h=yes
ac_cv_header_dlfcn_h=yes
ac_cv_header_hdf5_h=yes
ac_cv_header_ieeefp_h=no
ac_cv_header_inttypes_h=yes
ac_cv_header_memory_h=yes
ac_cv_header_mpi_h=yes
ac_cv_header_netcdf_h=no
ac_cv_header_pnetcdf_h=no
ac_cv_header_stdc=yes
ac_cv_header_stddef_h=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_unistd_h=yes
ac_cv_header_zoltan_cpp_h=yes
ac_cv_host=x86_64-unknown-linux-gnu
ac_cv_lib_cgns_cg_open=yes
ac_cv_lib_gpfs_gpfs_stat=no
ac_cv_lib_hdf5_H5Pset_fapl_mpio=yes
ac_cv_lib_hdf5___H5Fopen=yes
ac_cv_lib_netcdf_nc_create=no
ac_cv_lib_pnetcdf_ncmpi_create=no
ac_cv_lib_sz_SZ_Decompress=no
ac_cv_lib_z_deflate=yes
ac_cv_lib_zoltan_Zoltan_LB_Partition=yes
ac_cv_objext=o
ac_cv_path_EGREP='/usr/bin/grep -E'
ac_cv_path_FGREP='/usr/bin/grep -F'
ac_cv_path_GREP=/usr/bin/grep
ac_cv_path_SED=sed
ac_cv_path_install='/usr/bin/install -c'
ac_cv_path_mkdir=/usr/bin/mkdir
ac_cv_prog_AWK=gawk
ac_cv_prog_CPP='/usr/bin/mpicc -E'
ac_cv_prog_CXXCPP='/usr/bin/mpicxx -E'
ac_cv_prog_SED=sed
ac_cv_prog_ZCAT='gunzip -c'
ac_cv_prog_ac_ct_AR=ar
ac_cv_prog_ac_ct_CC=/usr/bin/mpicc
ac_cv_prog_ac_ct_OBJDUMP=objdump
ac_cv_prog_ac_ct_RANLIB=ranlib
ac_cv_prog_ac_ct_STRIP=strip
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_f77_g=no
ac_cv_prog_fc_g=no
ac_cv_prog_make_make_set=yes
ac_cv_sizeof_void_p=8
ac_cv_target=x86_64-unknown-linux-gnu
ac_cv_type_uint64_t=yes
am_cv_CC_dependencies_compiler_type=gcc3
am_cv_CXX_dependencies_compiler_type=gcc3
am_cv_make_support_nested_variables=yes
am_cv_prog_cc_c_o=yes
fathom_cv_std_count_old_sgi=no
fathom_cv_std_vector_templatized_insert=yes
lt_cv_ar_at_file=@
lt_cv_archive_cmds_need_lc=no
lt_cv_deplibs_check_method=pass_all
lt_cv_file_magic_cmd='$MAGIC_CMD'
lt_cv_file_magic_test_file=
lt_cv_ld_reload_flag=-r
lt_cv_nm_interface='BSD nm'
lt_cv_objdir=.libs
lt_cv_path_LD=/usr/bin/ld
lt_cv_path_LDCXX='/usr/bin/ld -m elf_x86_64'
lt_cv_path_NM='/usr/bin/nm -B'
lt_cv_path_mainfest_tool=no
lt_cv_prog_compiler_c_o=yes
lt_cv_prog_compiler_c_o_CXX=yes
lt_cv_prog_compiler_c_o_F77=yes
lt_cv_prog_compiler_c_o_FC=yes
lt_cv_prog_compiler_pic='-fPIC -DPIC'
lt_cv_prog_compiler_pic_CXX='-fPIC -DPIC'
lt_cv_prog_compiler_pic_F77=
lt_cv_prog_compiler_pic_FC=
lt_cv_prog_compiler_pic_works=yes
lt_cv_prog_compiler_pic_works_CXX=yes
lt_cv_prog_compiler_rtti_exceptions=no
lt_cv_prog_compiler_static_works=no
lt_cv_prog_compiler_static_works_CXX=no
lt_cv_prog_compiler_static_works_F77=yes
lt_cv_prog_compiler_static_works_FC=yes
lt_cv_prog_gnu_ld=yes
lt_cv_prog_gnu_ldcxx=yes
lt_cv_sharedlib_from_linklib_cmd='printf %s\n'
lt_cv_shlibpath_overrides_runpath=no
lt_cv_sys_global_symbol_pipe='sed -n -e '\''s/^.*[	 ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[	 ][	 ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p'\'' | sed '\''/ __gnu_lto/d'\'''
lt_cv_sys_global_symbol_to_c_name_address='sed -n -e '\''s/^: \([^ ]*\)[ ]*$/  {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/  {"\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_c_name_address_lib_prefix='sed -n -e '\''s/^: \([^ ]*\)[ ]*$/  {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \(lib[^ ]*\)$/  {"\2", (void *) \&\2},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/  {"lib\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_cdecl='sed -n -e '\''s/^T .* \(.*\)$/extern int \1();/p'\'' -e '\''s/^[ABCDGIRSTW]* .* \(.*\)$/extern char \1;/p'\'''
lt_cv_sys_max_cmd_len=1572864
lt_cv_to_host_file_cmd=func_convert_file_noop
lt_cv_to_tool_file_cmd=func_convert_file_noop
mk_cv_cxx_unordered_map=std::tr1
snl_cv_template_func_specialization=yes
snl_cv_template_specialization=yes
## Output variables. ##
ACLOCAL='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/moab_462/config/missing aclocal-1.14'
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='$${TAR-tar}'
AM_BACKSLASH='\'
AM_CFLAGS=''
AM_CPPFLAGS='-I/home/carbrevi/opt/lnx_x64/contrib/cgns/include      -I/home/carbrevi/opt/lnx_x64/contrib/hdf5/include -isystem /home/carbrevi/opt/lnx_x64/contrib/hdf5/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DCGNS_FILE'
AM_CXXFLAGS=''
AM_DEFAULT_V='$(AM_DEFAULT_VERBOSITY)'
AM_DEFAULT_VERBOSITY='1'
AM_FCFLAGS=''
AM_FFLAGS=''
AM_LDFLAGS='  -L/home/carbrevi/opt/lnx_x64/contrib/cgns/lib        -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib'
AM_V='$(V)'
AR='ar'
AUTOCONF='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/moab_462/config/missing autoconf'
AUTOHEADER='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/moab_462/config/missing autoheader'
AUTOMAKE='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/moab_462/config/missing automake-1.14'
AWK='gawk'
CC='/usr/bin/mpicc'
CCDEPMODE='depmode=gcc3'
CCMIO_FILE_FALSE=''
CCMIO_FILE_TRUE='#'
CCMIO_LIBS=''
CFLAGS=' -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64'
CGM_CPPFLAGS=''
CGM_LDFLAGS=''
CGM_LIBS=''
CGM_LTFLAGS=''
CGNS_FILE_FALSE='#'
CGNS_FILE_TRUE=''
CGNS_LIBS='-lcgns -lhdf5_hl'
CPPFLAGS=' -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set'
CXX='/usr/bin/mpicxx'
CXXDEPMODE='depmode=gcc3'
CXXFLAGS=' -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -m64'
CYGPATH_W='echo'
DAMSEL_FILE_FALSE=''
DAMSEL_FILE_TRUE='#'
DAMSEL_LIBS=''
DEFS='-DHAVE_CONFIG_H'
DEPDIR='.deps'
DISTCHECK_CONFIGURE_FLAGS=' --with-mpi="yes" --enable-64bit-handles --with-hdf5="/home/carbrevi/opt/lnx_x64/contrib/hdf5" --with-cgns="/home/carbrevi/opt/lnx_x64/contrib/cgns" --with-zoltan="/home/carbrevi/opt/lnx_x64/contrib/trilinos" --with-vtk="no" --enable-mbconvert="yes" --enable-mbsize="yes" --enable-mbskin="yes" --enable-mbmem="yes" --enable-mbcoupler="yes" --enable-mbzoltan="yes" --enable-refiner="yes" --enable-h5mtools="yes"'
DLLTOOL='false'
DOXYGEN=''
DSYMUTIL=''
DUMPBIN=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
ENABLE_DOXYGEN_FALSE=''
ENABLE_DOXYGEN_TRUE='#'
ENABLE_FORTRAN_FALSE=''
ENABLE_FORTRAN_TRUE='#'
ENABLE_dagmc_FALSE=''
ENABLE_dagmc_TRUE='#'
ENABLE_gsets_FALSE=''
ENABLE_gsets_TRUE='#'
ENABLE_h5mtools_FALSE='#'
ENABLE_h5mtools_TRUE=''
ENABLE_hexmodops_FALSE=''
ENABLE_hexmodops_TRUE='#'
ENABLE_igeom_FALSE='#'
ENABLE_igeom_TRUE=''
ENABLE_imesh_FALSE='#'
ENABLE_imesh_TRUE=''
ENABLE_mbconvert_FALSE='#'
ENABLE_mbconvert_TRUE=''
ENABLE_mbcoupler_FALSE='#'
ENABLE_mbcoupler_TRUE=''
ENABLE_mbcslam_FALSE=''
ENABLE_mbcslam_TRUE='#'
ENABLE_mbdepth_FALSE=''
ENABLE_mbdepth_TRUE='#'
ENABLE_mbmem_FALSE='#'
ENABLE_mbmem_TRUE=''
ENABLE_mbsize_FALSE='#'
ENABLE_mbsize_TRUE=''
ENABLE_mbskin_FALSE='#'
ENABLE_mbskin_TRUE=''
ENABLE_mbsurfplot_FALSE=''
ENABLE_mbsurfplot_TRUE='#'
ENABLE_mbtagprop_FALSE=''
ENABLE_mbtagprop_TRUE='#'
ENABLE_mbzoltan_FALSE='#'
ENABLE_mbzoltan_TRUE=''
ENABLE_mcnpmit_FALSE=''
ENABLE_mcnpmit_TRUE='#'
ENABLE_pointsearch_FALSE=''
ENABLE_pointsearch_TRUE='#'
ENABLE_qvdual_FALSE=''
ENABLE_qvdual_TRUE='#'
ENABLE_refiner_FALSE='#'
ENABLE_refiner_TRUE=''
ENABLE_spheredecomp_FALSE=''
ENABLE_spheredecomp_TRUE='#'
ENABLE_vtkMOABReaderNew_FALSE=''
ENABLE_vtkMOABReaderNew_TRUE='#'
ENABLE_vtkMOABReader_FALSE=''
ENABLE_vtkMOABReader_TRUE='#'
EXEEXT=''
EXPORT_LDFLAGS='-L/home/carbrevi/opt/lnx_x64/contrib/cgns/lib        -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib'
EXPORT_LTFLAGS=''
F77='gfortran'
FC='/usr/bin/mpif90'
FCFLAGS='  -O2'
FCLIBS=''
FFLAGS='  -O2'
FLIBS=''
GREP='/usr/bin/grep'
HAVE_CGM_FALSE=''
HAVE_CGM_TRUE='#'
HAVE_ZCAT_FALSE=''
HAVE_ZCAT_TRUE='#'
HDF5_FILE_FALSE='#'
HDF5_FILE_TRUE=''
HDF5_LIBS='-lhdf5  '
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
LD='/usr/bin/ld -m elf_x86_64'
LDFLAGS='   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib   -L/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib'
LIBOBJS=''
LIBS=' -lm'
LIBTOOL='$(SHELL) $(top_builddir)/libtool'
LIPO=''
LN_S='ln -s'
LTLIBOBJS=''
MAKEINFO='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/moab_462/config/missing makeinfo'
MANIFEST_TOOL=':'
MKDIR_P='/usr/bin/mkdir -p'
MOAB_CGM_DEFINES=''
MOAB_CXX_LIBS=' -lmpi_cxx -lmpi -ldl -lhwloc -lstdc++ -lpthread'
MOAB_CXX_LINKFLAGS='-L/usr/lib/openmpi -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.8.2/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.8.2/../../..'
MOC=''
MPE_LIBS=''
MPIEXEC='/usr/bin/mpiexec'
MPIEXEC_NP='-np'
NETCDF_FILE_FALSE=''
NETCDF_FILE_TRUE='#'
NETCDF_LIBS=''
NM='/usr/bin/nm -B'
NMEDIT=''
NP='2'
OBJDUMP='objdump'
OBJEXT='o'
OLD_HEADERS_FALSE='#'
OLD_HEADERS_TRUE=''
OTOOL64=''
OTOOL=''
PACKAGE='moab'
PACKAGE_BUGREPORT=''
PACKAGE_NAME='MOAB'
PACKAGE_STRING='MOAB 4.6.0'
PACKAGE_TARNAME='moab'
PACKAGE_URL=''
PACKAGE_VERSION='4.6.0'
PARALLEL_FALSE='#'
PARALLEL_HDF5_FALSE='#'
PARALLEL_HDF5_TRUE=''
PARALLEL_TRUE=''
PATH_SEPARATOR=':'
PNETCDF_FILE_FALSE=''
PNETCDF_FILE_TRUE='#'
PNETCDF_LIBS=''
QTDIR=''
QVDUAL_INCLUDES=''
QVDUAL_LIBS=''
RANLIB='ranlib'
SED='sed'
SET_MAKE=''
SHELL='/bin/sh'
SIZEOF_VOID_P='8'
STRIP='strip'
UIC=''
USE_MPIEXEC_FALSE='#'
USE_MPIEXEC_TRUE=''
USE_MPI_FALSE='#'
USE_MPI_TRUE=''
VERSION='4.6.0'
VTK_INCLUDES=''
VTK_INC_DIR=''
VTK_LIBS=''
VTK_LIB_DIR=''
WITH_MPE='no'
XMKMF=''
X_CFLAGS=''
X_EXTRA_LIBS=''
X_LIBS=''
X_PRE_LIBS=''
ZCAT='gunzip -c'
ZOLTAN_INC_FLAGS='-I/home/carbrevi/opt/lnx_x64/contrib/trilinos/include'
ZOLTAN_LIBS='-lzoltan'
ZOLTAN_LIB_FLAGS=' -L/home/carbrevi/opt/lnx_x64/contrib/trilinos/lib'
ac_ct_AR='ar'
ac_ct_CC='/usr/bin/mpicc'
ac_ct_CXX=''
ac_ct_DUMPBIN=''
ac_ct_F77=''
ac_ct_FC=''
am__EXEEXT_FALSE=''
am__EXEEXT_TRUE='#'
am__fastdepCC_FALSE='#'
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE='#'
am__fastdepCXX_TRUE=''
am__include='include'
am__isrc=''
am__leading_dot='.'
am__nodep='_no'
am__quote=''
am__tar='$${TAR-tar} chof - "$$tardir"'
am__untar='$${TAR-tar} xf -'
bindir='${exec_prefix}/bin'
build='x86_64-unknown-linux-gnu'
build_alias=''
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='unknown'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
dvidir='${docdir}'
exec_prefix='${prefix}'
host='x86_64-unknown-linux-gnu'
host_alias=''
host_cpu='x86_64'
host_os='linux-gnu'
host_vendor='unknown'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/moab_462/config/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
mkdir_p='$(MKDIR_P)'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='/home/carbrevi/opt/lnx_x64/contrib/moab'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target='x86_64-unknown-linux-gnu'
target_alias=''
target_cpu='x86_64'
target_os='linux-gnu'
target_vendor='unknown'
## confdefs.h. ##
/* confdefs.h */
#define PACKAGE_NAME "MOAB"
#define PACKAGE_TARNAME "moab"
#define PACKAGE_VERSION "4.6.0"
#define PACKAGE_STRING "MOAB 4.6.0"
#define PACKAGE_BUGREPORT ""
#define PACKAGE_URL ""
#define PACKAGE "moab"
#define VERSION "4.6.0"
configure: exit 0
# This is the CMakeCache file.
# For build in directory: /home/carbrevi/opt/lnx_x64/contrib/_build/cgnslib_3.2.1
# It was generated by CMake: /usr/bin/cmake
# You can edit this file to change values found and used by cmake.
# If you do not want to change any of the values, simply exit the editor.
# If you do want to change a value, simply edit, save, and exit the editor.
# The syntax for the file is as follows:
# KEY:TYPE=VALUE
# KEY is the name of a variable in the cache.
# TYPE is a hint to GUIs for the type of VALUE, DO NOT EDIT TYPE!.
# VALUE is the current value for the KEY.
# EXTERNAL cache entries
//No help, variable specified on the command line.
CGNS_BUILD_CGNSTOOLS:BOOL=OFF
CGNS_BUILD_SHARED:BOOL=ON
//Enable or disable 64-bit code building
CGNS_ENABLE_64BIT:BOOL=ON
//Enable or disable the use of Fortran
CGNS_ENABLE_FORTRAN:BOOL=OFF
//Enable or disable HDF5 interface
CGNS_ENABLE_HDF5:BOOL=ON
//Enable or disable building legacy code (3.0 compatible)
CGNS_ENABLE_LEGACY:BOOL=OFF
CGNS_ENABLE_PARALLEL:BOOL=ON
//Enable or disable scoping of enumeration values
CGNS_ENABLE_SCOPING:BOOL=OFF
//Enable test programs
CGNS_ENABLE_TESTS:BOOL=OFF
//Link programs to the CGNS shared library
CGNS_USE_SHARED:BOOL=ON
//Path to a program.
CMAKE_AR:FILEPATH=/usr/bin/ar
CMAKE_BUILD_TYPE:STRING=Release
//Enable/Disable color output during build.
CMAKE_COLOR_MAKEFILE:BOOL=ON
//C compiler.
CMAKE_C_COMPILER:FILEPATH=/usr/bin/gcc
//Flags used by the compiler during all build types.
CMAKE_C_FLAGS:STRING=
//Flags used by the compiler during debug builds.
CMAKE_C_FLAGS_DEBUG:STRING=-g
//Flags used by the compiler during release minsize builds.
CMAKE_C_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG
//Flags used by the compiler during release builds (/MD /Ob1 /Oi
// /Ot /Oy /Gs will produce slightly less optimized but smaller
// files).
CMAKE_C_FLAGS_RELEASE:STRING=-O3 -DNDEBUG
//Flags used by the compiler during Release with Debug Info builds.
CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=-O2 -g -DNDEBUG
//Flags used by the linker.
CMAKE_EXE_LINKER_FLAGS:STRING=' '
//Flags used by the linker during debug builds.
CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING=
//Flags used by the linker during release minsize builds.
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING=
//Flags used by the linker during release builds.
CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING=
//Flags used by the linker during Release with Debug Info builds.
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING=
//Enable/Disable output of compile commands during generation.
CMAKE_EXPORT_COMPILE_COMMANDS:BOOL=OFF
CMAKE_INSTALL_PREFIX:PATH=/home/carbrevi/opt/lnx_x64/contrib/cgns
CMAKE_LINKER:FILEPATH=/usr/bin/ld
CMAKE_MAKE_PROGRAM:FILEPATH=/usr/bin/make
//Flags used by the linker during the creation of modules.
CMAKE_MODULE_LINKER_FLAGS:STRING=' '
CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING=
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING=
CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING=
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING=
CMAKE_NM:FILEPATH=/usr/bin/nm
CMAKE_OBJCOPY:FILEPATH=/usr/bin/objcopy
CMAKE_OBJDUMP:FILEPATH=/usr/bin/objdump
//Value Computed by CMake
CMAKE_PROJECT_NAME:STATIC=cgns
CMAKE_RANLIB:FILEPATH=/usr/bin/ranlib
//Flags used by the linker during the creation of dll's.
CMAKE_SHARED_LINKER_FLAGS:STRING=' '
CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING=
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING=
CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING=
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING=
//If set, runtime paths are not added when installing shared libraries,
// but are added when building.
CMAKE_SKIP_INSTALL_RPATH:BOOL=NO
CMAKE_SKIP_RPATH:BOOL=ON
//Flags used by the linker during the creation of static libraries.
CMAKE_STATIC_LINKER_FLAGS:STRING=
CMAKE_STATIC_LINKER_FLAGS_DEBUG:STRING=
CMAKE_STATIC_LINKER_FLAGS_MINSIZEREL:STRING=
CMAKE_STATIC_LINKER_FLAGS_RELEASE:STRING=
CMAKE_STATIC_LINKER_FLAGS_RELWITHDEBINFO:STRING=
CMAKE_STRIP:FILEPATH=/usr/bin/strip
//If true, cmake will use relative paths in makefiles and projects.
CMAKE_USE_RELATIVE_PATHS:BOOL=OFF
//If this value is on, makefiles will be generated without the
// .SILENT directive, and all commands will be echoed to the console
// during the make.  This is useful for debugging only. With Visual
// Studio IDE projects all commands are done without /nologo.
CMAKE_VERBOSE_MAKEFILE:BOOL=FALSE
HDF5_INCLUDE_PATH:PATH=/home/carbrevi/opt/lnx_x64/contrib/hdf5/include
HDF5_LIBRARY:FILEPATH=/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib/libhdf5.so
HDF5_NEED_MPI:BOOL=ON
//Does the HDF5 library require linking to zlib?
HDF5_NEED_SZIP:BOOL=OFF
HDF5_NEED_ZLIB:BOOL=ON
MPIEXEC:FILEPATH=/usr/bin/mpiexec
//Maximum number of processors available to run MPI applications.
MPIEXEC_MAX_NUMPROCS:STRING=2
//Flag used by MPI to specify the number of processes for MPIEXEC;
// the next option will be the number of processes.
MPIEXEC_NUMPROC_FLAG:STRING=-np
//These flags will come after all flags given to MPIEXEC.
MPIEXEC_POSTFLAGS:STRING=
//These flags will be directly before the executable that is being
// run by MPIEXEC.
MPIEXEC_PREFLAGS:STRING=
//Cleared
MPI_C_COMPILER:FILEPATH=/usr/bin/mpicc
//MPI C compilation flags
MPI_C_COMPILE_FLAGS:STRING=
//MPI C include path
MPI_C_INCLUDE_PATH:STRING=/usr/include
//MPI C libraries to link against
MPI_C_LIBRARIES:STRING=/usr/lib64/openmpi/libmpi.so;/usr/lib64/libdl.so;/usr/lib64/libhwloc.so
//MPI C linking flags
MPI_C_LINK_FLAGS:STRING=
//Extra MPI libraries to link against
MPI_EXTRA_LIBRARY:STRING=/usr/lib64/libdl.so;/usr/lib64/libhwloc.so
//MPI library to link against
MPI_LIBRARY:FILEPATH=/usr/lib64/openmpi/libmpi.so
ZLIB_LIBRARY:FILEPATH=/usr/lib64/libz.so
cgns_BINARY_DIR:STATIC=/home/carbrevi/opt/lnx_x64/contrib/_build/cgnslib_3.2.1
cgns_SOURCE_DIR:STATIC=/home/carbrevi/opt/lnx_x64/contrib/_build/cgnslib_3.2.1
//Dependencies for target
cgns_shared_LIB_DEPENDS:STATIC=
cgns_static_LIB_DEPENDS:STATIC=
file_cmd:FILEPATH=/usr/bin/file
# INTERNAL cache entries
//ADVANCED property for variable: CGNS_ENABLE_64BIT
CGNS_ENABLE_64BIT-ADVANCED:INTERNAL=0
//ADVANCED property for variable: CGNS_ENABLE_LEGACY
CGNS_ENABLE_LEGACY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CGNS_ENABLE_PARALLEL
CGNS_ENABLE_PARALLEL-ADVANCED:INTERNAL=0
//ADVANCED property for variable: CGNS_USE_SHARED
CGNS_USE_SHARED-ADVANCED:INTERNAL=0
//ADVANCED property for variable: CMAKE_AR
CMAKE_AR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_BUILD_TOOL
CMAKE_BUILD_TOOL-ADVANCED:INTERNAL=1
//What is the target build tool cmake is generating for.
CMAKE_BUILD_TOOL:INTERNAL=/usr/bin/make
//STRINGS property for variable: CMAKE_BUILD_TYPE
CMAKE_BUILD_TYPE-STRINGS:INTERNAL=Release;Debug;RelWithDebInfo;MinSizeRel
//This is the directory where this CMakeCache.txt was created
CMAKE_CACHEFILE_DIR:INTERNAL=/home/carbrevi/opt/lnx_x64/contrib/_build/cgnslib_3.2.1
//Major version of cmake used to create the current loaded cache
CMAKE_CACHE_MAJOR_VERSION:INTERNAL=2
//Minor version of cmake used to create the current loaded cache
CMAKE_CACHE_MINOR_VERSION:INTERNAL=8
//Patch version of cmake used to create the current loaded cache
CMAKE_CACHE_PATCH_VERSION:INTERNAL=12
//ADVANCED property for variable: CMAKE_COLOR_MAKEFILE
CMAKE_COLOR_MAKEFILE-ADVANCED:INTERNAL=1
//Path to CMake executable.
CMAKE_COMMAND:INTERNAL=/usr/bin/cmake
//Path to cpack program executable.
CMAKE_CPACK_COMMAND:INTERNAL=/usr/bin/cpack
//Path to ctest program executable.
CMAKE_CTEST_COMMAND:INTERNAL=/usr/bin/ctest
//ADVANCED property for variable: CMAKE_C_COMPILER
CMAKE_C_COMPILER-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS
CMAKE_C_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_DEBUG
CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_MINSIZEREL
CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_RELEASE
CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_RELWITHDEBINFO
CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Path to cache edit program executable.
CMAKE_EDIT_COMMAND:INTERNAL=/usr/bin/ccmake
//Executable file format
CMAKE_EXECUTABLE_FORMAT:INTERNAL=ELF
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS
CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG
CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE
CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXPORT_COMPILE_COMMANDS
CMAKE_EXPORT_COMPILE_COMMANDS-ADVANCED:INTERNAL=1
//Name of generator.
CMAKE_GENERATOR:INTERNAL=Unix Makefiles
//Name of generator toolset.
CMAKE_GENERATOR_TOOLSET:INTERNAL=
//Start directory with the top level CMakeLists.txt file for this
// project
CMAKE_HOME_DIRECTORY:INTERNAL=/home/carbrevi/opt/lnx_x64/contrib/_build/cgnslib_3.2.1
//Install .so files without execute permission.
CMAKE_INSTALL_SO_NO_EXE:INTERNAL=0
//ADVANCED property for variable: CMAKE_LINKER
CMAKE_LINKER-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MAKE_PROGRAM
CMAKE_MAKE_PROGRAM-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS
CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG
CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE
CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_NM
CMAKE_NM-ADVANCED:INTERNAL=1
//number of local generators
CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=3
//ADVANCED property for variable: CMAKE_OBJCOPY
CMAKE_OBJCOPY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_OBJDUMP
CMAKE_OBJDUMP-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_RANLIB
CMAKE_RANLIB-ADVANCED:INTERNAL=1
//Path to CMake installation.
CMAKE_ROOT:INTERNAL=/usr/share/cmake-2.8
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS
CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG
CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE
CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SKIP_INSTALL_RPATH
CMAKE_SKIP_INSTALL_RPATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SKIP_RPATH
CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS
CMAKE_STATIC_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS_DEBUG
CMAKE_STATIC_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS_MINSIZEREL
CMAKE_STATIC_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS_RELEASE
CMAKE_STATIC_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_STATIC_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STRIP
CMAKE_STRIP-ADVANCED:INTERNAL=1
//uname command
CMAKE_UNAME:INTERNAL=/usr/bin/uname
//ADVANCED property for variable: CMAKE_USE_RELATIVE_PATHS
CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_VERBOSE_MAKEFILE
CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1
//Details about finding MPI_C
FIND_PACKAGE_MESSAGE_DETAILS_MPI_C:INTERNAL=[/usr/lib64/openmpi/libmpi.so;/usr/lib64/libdl.so;/usr/lib64/libhwloc.so][/usr/include][v()]
//Result of TRY_COMPILE
HAVE_SIZE_OF_LONG:INTERNAL=TRUE
HAVE_SIZE_OF_OFF_T:INTERNAL=TRUE
//Have include stddef.h
HAVE_STDDEF_H:INTERNAL=1
//Have include stdint.h
HAVE_STDINT_H:INTERNAL=1
//Have include sys/types.h
HAVE_SYS_TYPES_H:INTERNAL=1
//ADVANCED property for variable: HDF5_NEED_MPI
HDF5_NEED_MPI-ADVANCED:INTERNAL=0
//ADVANCED property for variable: HDF5_NEED_SZIP
HDF5_NEED_SZIP-ADVANCED:INTERNAL=0
//ADVANCED property for variable: HDF5_NEED_ZLIB
HDF5_NEED_ZLIB-ADVANCED:INTERNAL=0
//ADVANCED property for variable: MPIEXEC
MPIEXEC-ADVANCED:INTERNAL=0
//ADVANCED property for variable: MPIEXEC_MAX_NUMPROCS
MPIEXEC_MAX_NUMPROCS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: MPIEXEC_NUMPROC_FLAG
MPIEXEC_NUMPROC_FLAG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: MPIEXEC_POSTFLAGS
MPIEXEC_POSTFLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: MPIEXEC_PREFLAGS
MPIEXEC_PREFLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: MPI_C_COMPILER
MPI_C_COMPILER-ADVANCED:INTERNAL=0
//ADVANCED property for variable: MPI_C_COMPILE_FLAGS
MPI_C_COMPILE_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: MPI_C_INCLUDE_PATH
MPI_C_INCLUDE_PATH-ADVANCED:INTERNAL=0
//ADVANCED property for variable: MPI_C_LIBRARIES
MPI_C_LIBRARIES-ADVANCED:INTERNAL=0
//ADVANCED property for variable: MPI_C_LINK_FLAGS
MPI_C_LINK_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: MPI_EXTRA_LIBRARY
MPI_EXTRA_LIBRARY-ADVANCED:INTERNAL=1
//Scratch variable for MPI header detection
MPI_HEADER_PATH:INTERNAL=MPI_HEADER_PATH-NOTFOUND
//Scratch variable for MPI lib detection
MPI_LIB:INTERNAL=MPI_LIB-NOTFOUND
//ADVANCED property for variable: MPI_LIBRARY
MPI_LIBRARY-ADVANCED:INTERNAL=1
//CHECK_TYPE_SIZE: sizeof(long)
SIZE_OF_LONG:INTERNAL=8
//CHECK_TYPE_SIZE: sizeof(off_t)
SIZE_OF_OFF_T:INTERNAL=8
//ADVANCED property for variable: ZLIB_LIBRARY
ZLIB_LIBRARY-ADVANCED:INTERNAL=0
//ADVANCED property for variable: file_cmd
file_cmd-ADVANCED:INTERNAL=1
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by HDF5 configure 1.8.11, which was
generated by GNU Autoconf 2.69.  Invocation command line was
  $ ./configure CC=/usr/bin/mpicc CXX=/usr/bin/mpicxx FC= F9X= RUNPARALLEL=/usr/bin/mpiexec OMPI_MCA_disable_memory_allocator=1 --prefix=/home/carbrevi/opt/lnx_x64/contrib/hdf5 --enable-largefile --enable-unsupported --enable-shared --disable-static --enable-production=yes --with-pthread=/usr/include,/usr/lib64/libz.so --with-zlib=/usr/include,/usr/lib64/libpthread.so --with-default-api-version=v18 --enable-parallel=yes --enable-cxx --disable-sharedlib-rpath
## Platform. ##
hostname = ALA_PC180
uname -m = x86_64
uname -r = 3.12.0-1-ARCH
uname -s = Linux
uname -v = #1 SMP PREEMPT Wed Nov 6 09:06:27 CET 2013
/usr/bin/uname -p = unknown
/bin/uname -X     = unknown
/bin/arch              = unknown
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo      = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /home/carbrevi/opt/lnx_x64/bin
PATH: /opt/openmpi/1.6.2/bin
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /opt/intel/bin
PATH: /usr/bin/vendor_perl
PATH: /usr/bin/core_perl
PATH: /home/carbrevi/opt/tecplot/bin
PATH: /home/carbrevi/opt/ansys_inc/v140/icemcfd/linux64_amd/bin
PATH: /opt/CEI/bin
PATH: /home/carbrevi/opt/ParaView-4.0.1/bin
PATH: /home/carbrevi/opt/visit2_7_0/bin
PATH: /home/carbrevi/opt/gmsh-2.8.3-Linux//bin
## Core tests. ##
configure:3254: checking for a BSD-compatible install
configure:3322: result: /usr/bin/install -c
configure:3333: checking whether build environment is sane
configure:3388: result: yes
configure:3539: checking for a thread-safe mkdir -p
configure:3578: result: /usr/bin/mkdir -p
configure:3585: checking for gawk
configure:3601: found /usr/bin/gawk
configure:3612: result: gawk
configure:3623: checking whether make sets $(MAKE)
configure:3645: result: yes
configure:3742: checking whether make supports nested variables
configure:3759: result: yes
configure:3782: checking whether to enable maintainer-specific portions of Makefiles
configure:3791: result: no
configure:3835: checking build system type
configure:3849: result: x86_64-unknown-linux-gnu
configure:3869: checking host system type
configure:3882: result: x86_64-unknown-linux-gnu
configure:3956: checking shell variables initial values
ACLOCAL='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11/bin/missing --run aclocal-1.12'
AMTAR='$${TAR-tar}'
AM_BACKSLASH='\'
AM_CFLAGS=
AM_CPPFLAGS=
AM_CXXFLAGS=
AM_DEFAULT_VERBOSITY=0
AM_FCFLAGS=
AM_LDFLAGS=
AM_V='$(V)'
AUTOCONF='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11/bin/missing --run autoconf'
AUTOHEADER='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11/bin/missing --run autoheader'
AUTOMAKE='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11/bin/missing --run automake-1.12'
AWK=gawk
BASH=/bin/sh
BASHOPTS=cmdhist:extquote:force_fignore:hostcomplete:interactive_comments:progcomp:promptvars:sourcepath
BASH_ALIASES=()
BASH_ARGC=([0]="18")
BASH_ARGV=([0]="--disable-sharedlib-rpath" [1]="--enable-cxx" [2]="--enable-parallel=yes" [3]="--with-default-api-version=v18" [4]="--with-zlib=/usr/include,/usr/lib64/libpthread.so" [5]="--with-pthread=/usr/include,/usr/lib64/libz.so" [6]="--enable-production=yes" [7]="--disable-static" [8]="--enable-shared" [9]="--enable-unsupported" [10]="--enable-largefile" [11]="--prefix=/home/carbrevi/opt/lnx_x64/contrib/hdf5" [12]="OMPI_MCA_disable_memory_allocator=1" [13]="RUNPARALLEL=/usr/bin/mpiexec" [14]="F9X=" [15]="FC=" [16]="CXX=/usr/bin/mpicxx" [17]="CC=/usr/bin/mpicc")
BASH_CMDS=()
BASH_LINENO=([0]="0")
BASH_SOURCE=([0]="./configure")
BASH_VERSINFO=([0]="4" [1]="2" [2]="45" [3]="2" [4]="release" [5]="x86_64-unknown-linux-gnu")
BASH_VERSION='4.2.45(2)-release'
CC=/usr/bin/mpicc
CFLAGS=
COLORFGBG='15;0'
CPPFLAGS=
CXX=/usr/bin/mpicxx
CXXFLAGS=
CYGPATH_W=echo
DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-y2Lb2HeXJS,guid=475c457387543b49d0ae6b75528b89be
DEFAULT_LIBS=
DESKTOP_SESSION=default
DIRSTACK=()
DISPLAY=:0
DM_CONTROL=/var/run/xdmctl
DUALCASE=1
ECHO_C=
ECHO_N=-n
ECHO_T=
EUID=1000
F77=gfortran
F90=gfortran
F9X=
FC=
FCFLAGS=
GPG_AGENT_INFO=/tmp/gpg-uAn984/S.gpg-agent:813:1
GROUPS=()
GS_LIB=/home/carbrevi/.fonts
GTK2_RC_FILES=/etc/gtk-2.0/gtkrc:/home/carbrevi/.gtkrc-2.0:/home/carbrevi/.kde4/share/config/gtkrc-2.0
GTK_MODULES=canberra-gtk-module
GTK_RC_FILES=/etc/gtk/gtkrc:/home/carbrevi/.gtkrc:/home/carbrevi/.kde4/share/config/gtkrc
HOME=/home/carbrevi
HOSTNAME=ALA_PC180
HOSTTYPE=x86_64
IFS='
INSTALL='/usr/bin/install -c'
I_MPI_CC=gcc
I_MPI_CXX=g++
I_MPI_F90=gfortran
JAVA_HOME=/usr/lib/jvm/java-7-openjdk
KDE_FULL_SESSION=true
KDE_MULTIHEAD=false
KDE_SESSION_UID=1000
KDE_SESSION_VERSION=4
KONSOLE_DBUS_SERVICE=:1.79
KONSOLE_DBUS_SESSION=/Sessions/1
KONSOLE_DBUS_WINDOW=/Windows/1
KONSOLE_PROFILE_NAME=Shell
LANG=en_US.UTF-8
LANGUAGE=C
LC_ALL=C
LDFLAGS=
LD_LIBRARY_PATH=/home/carbrevi/opt/lnx_x64/lib:/home/carbrevi/opt/lnx_x64/contrib/hdf5/lib:/home/carbrevi/opt/lnx_x64/contrib/cgns/lib:/home/carbrevi/opt/lnx_x64/contrib/tecio/lib:/home/carbrevi/opt/lnx_x64/contrib/trilinos/lib:/home/carbrevi/opt/lnx_x64/contrib/kmetis/lib:/home/carbrevi/opt/lnx_x64/contrib/scotch/lib:/home/carbrevi/opt/lnx_x64/contrib/osg/lib64:/home/carbrevi/opt/lnx_x64/lib:/opt/openmpi/1.6.2/lib:/opt/intel/lib
LIBOBJS=
LIBRARY_PATH=/opt/openmpi/1.6.2/lib
LINENO=3956
LOADEDMODULES=compilers/gcc-system:mpi/openmpi
LOGNAME=carbrevi
MACHTYPE=x86_64-unknown-linux-gnu
MAINT='#'
MAINTAINER_MODE_FALSE=
MAINTAINER_MODE_TRUE='#'
MAKEFLAGS=
MAKEINFO='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11/bin/missing --run makeinfo'
MANPAGER='/usr/bin/most -s'
MANPATH=/opt/openmpi/1.6.2/share/man:/usr/share/man
MFLAGS=
MISSING='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11/bin/missing'
MODULEPATH=/opt/modules
MODULESHOME=/usr/local/Modules/3.2.9
MODULE_VERSION=3.2.9
MODULE_VERSION_STACK=3.2.9
MOZ_PLUGIN_PATH=/usr/lib/mozilla/plugins
MPI_CC=gcc
MPI_CXX=g++
MPI_F90=gfortran
MPI_FC=gfortran
OMPI_CC=gcc
OMPI_CXX=g++
OMPI_F77=gfortran
OMPI_FC=gfortran
OPTERR=1
OPTIND=1
OSTYPE=linux-gnu
PACKAGE=hdf5
PACKAGE_BUGREPORT=help at hdfgroup.org
PACKAGE_NAME=HDF5
PACKAGE_STRING='HDF5 1.8.11'
PACKAGE_TARNAME=hdf5
PACKAGE_URL=
PACKAGE_VERSION=1.8.11
PATH=/home/carbrevi/opt/lnx_x64/bin:/opt/openmpi/1.6.2/bin:/usr/local/sbin:/usr/local/bin:/usr/bin:/opt/intel/bin:/usr/bin/vendor_perl:/usr/bin/core_perl:/home/carbrevi/opt/tecplot/bin:/home/carbrevi/opt/ansys_inc/v140/icemcfd/linux64_amd/bin:/opt/CEI/bin:/home/carbrevi/opt/ParaView-4.0.1/bin:/home/carbrevi/opt/visit2_7_0/bin:/home/carbrevi/opt/gmsh-2.8.3-Linux//bin
PATH_SEPARATOR=:
PIPESTATUS=([0]="0")
POSIXLY_CORRECT=y
PPID=1582
PROFILEHOME=
PS1='$ '
PS2='> '
PS4='+ '
PWD=/home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11
QT_PLUGIN_PATH=/home/carbrevi/.kde4/lib/kde4/plugins/:/usr/lib/kde4/plugins/
SESSION_MANAGER=local/ALA_PC180:@/tmp/.ICE-unix/913,unix/ALA_PC180:/tmp/.ICE-unix/913
SET_MAKE=
SHELL=/bin/sh
SHELLOPTS=braceexpand:hashall:interactive-comments:posix
SHELL_SESSION_ID=527db53a5eb1400082fb9978d51dddcb
SHLVL=4
SSH_AGENT_PID=816
SSH_AUTH_SOCK=/tmp/ssh-D6vdxw1pfiFc/agent.815
TECHOME=/home/carbrevi/opt/tecplot
TERM=xterm-256color
UID=1000
USER=carbrevi
USE_MAINTAINER_MODE=no
VERSION=1.8.11
WINDOWID=20971547
WINDOWPATH=7
XCURSOR_SIZE=0
XCURSOR_THEME=Oxygen_Black
XDG_CURRENT_DESKTOP=KDE
XDG_DATA_DIRS=/usr/share:/usr/share:/usr/local/share
XDG_RUNTIME_DIR=/run/user/1000
XDG_SEAT=seat0
XDG_SESSION_ID=1
XDG_VTNR=7
XDM_MANAGED=method=classic
_='checking shell variables initial values... '
_LMFILES_=/opt/modules/compilers/gcc-system:/opt/modules/mpi/openmpi
ac_abs_confdir=/home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11
ac_arg=CXX=/usr/bin/mpicxx
ac_aux_dir=bin
ac_build_alias=x86_64-unknown-linux-gnu
ac_cache_corrupted=false
ac_clean_files=
ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
ac_compiler_gnu=
ac_confdir=.
ac_config_commands=' pubconf'
ac_config_guess='/bin/sh bin/config.guess'
ac_config_headers=' src/H5config.h'
ac_config_libobj_dir=.
ac_config_sub='/bin/sh bin/config.sub'
ac_configure='/bin/sh bin/configure'
ac_configure_args=' '\''CC=/usr/bin/mpicc'\'' '\''CXX=/usr/bin/mpicxx'\'' '\''FC='\'' '\''F9X='\'' '\''RUNPARALLEL=/usr/bin/mpiexec'\'' '\''OMPI_MCA_disable_memory_allocator=1'\'' '\''--prefix=/home/carbrevi/opt/lnx_x64/contrib/hdf5'\'' '\''--enable-largefile'\'' '\''--enable-unsupported'\'' '\''--enable-shared'\'' '\''--disable-static'\'' '\''--enable-production=yes'\'' '\''--with-pthread=/usr/include,/usr/lib64/libz.so'\'' '\''--with-zlib=/usr/include,/usr/lib64/libpthread.so'\'' '\''--with-default-api-version=v18'\'' '\''--enable-parallel=yes'\'' '\''--enable-cxx'\'' '\''--disable-sharedlib-rpath'\'''
ac_cpp='$CPP $CPPFLAGS'
ac_cv_env_CCC_set=
ac_cv_env_CPP_set=
ac_cv_env_FC_value=
ac_cv_env_LIBS_set=
ac_cv_prog_AWK=gawk
ac_dashdash=
ac_default_prefix=/home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11/hdf5
ac_dir=bin
ac_env_CCC_set=
ac_env_CCC_value=
ac_env_CC_set=set
ac_env_CC_value=/usr/bin/mpicc
ac_env_CFLAGS_set=
ac_env_CFLAGS_value=
ac_env_CPPFLAGS_set=
ac_env_CPPFLAGS_value=
ac_env_CPP_set=
ac_env_CPP_value=
ac_env_CXXCPP_set=
ac_env_CXXCPP_value=
ac_env_CXXFLAGS_set=
ac_env_CXXFLAGS_value=
ac_env_CXX_set=set
ac_env_CXX_value=/usr/bin/mpicxx
ac_env_FCFLAGS_set=
ac_env_FCFLAGS_value=
ac_env_FC_set=set
ac_env_FC_value=
ac_env_LDFLAGS_set=
ac_env_LDFLAGS_value=
ac_env_LIBS_set=
ac_env_LIBS_value=
ac_env_build_alias_set=
ac_env_build_alias_value=
ac_env_host_alias_set=
ac_env_host_alias_value=
ac_env_target_alias_set=
ac_env_target_alias_value=
ac_envvar=OMPI_MCA_disable_memory_allocator
ac_exec_ext=
ac_ext=c
ac_hostname=ALA_PC180
ac_includes_default='#include <stdio.h>
#ifdef HAVE_SYS_TYPES_H
# include <sys/types.h>
#endif
#ifdef HAVE_SYS_STAT_H
# include <sys/stat.h>
#endif
#ifdef STDC_HEADERS
# include <stdlib.h>
# include <stddef.h>
#else
# ifdef HAVE_STDLIB_H
# endif
#endif
#ifdef HAVE_STRING_H
# if !defined STDC_HEADERS && defined HAVE_MEMORY_H
#  include <memory.h>
# endif
# include <string.h>
#endif
#ifdef HAVE_STRINGS_H
# include <strings.h>
#endif
#ifdef HAVE_INTTYPES_H
# include <inttypes.h>
#endif
#ifdef HAVE_STDINT_H
# include <stdint.h>
#endif
#ifdef HAVE_UNISTD_H
# include <unistd.h>
#endif'
ac_init_help=
ac_init_version=false
ac_install_sh='bin/install-sh -c'
ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
ac_ls_di='15728732 .'
ac_make=make
ac_msg='sources are in ., but `cd .'\'' does not work'
ac_must_keep_next=false
ac_new_set=
ac_new_val=
ac_old_set=
ac_old_val=
ac_optarg=yes
ac_option=--disable-sharedlib-rpath
ac_pass=2
ac_precious_vars='build_alias
host_alias
target_alias
CC
CFLAGS
LDFLAGS
LIBS
CPPFLAGS
FC
FCFLAGS
CXX
CXXFLAGS
CCC
CXXCPP
CPP'
ac_prev=
ac_prog=gawk
ac_pwd=/home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11
ac_pwd_ls_di='15728732 .'
ac_save_IFS='
ac_script='s/[\\$]/&&/g;s/;s,x,x,$//'
ac_signal=0
ac_site_file=/home/carbrevi/opt/lnx_x64/contrib/hdf5/etc/config.site
ac_site_file1=/home/carbrevi/opt/lnx_x64/contrib/hdf5/share/config.site
ac_site_file2=/home/carbrevi/opt/lnx_x64/contrib/hdf5/etc/config.site
ac_srcdir_defaulted=yes
ac_subst_files=
ac_subst_vars='am__EXEEXT_FALSE
am__EXEEXT_TRUE
LTLIBOBJS
LIBOBJS
HAVE_SHARED_CONDITIONAL_FALSE
HAVE_SHARED_CONDITIONAL_TRUE
SETX
SEARCH
BUILD_HDF5_HL_CONDITIONAL_FALSE
BUILD_HDF5_HL_CONDITIONAL_TRUE
BUILD_FORTRAN_CONDITIONAL_FALSE
BUILD_FORTRAN_CONDITIONAL_TRUE
BUILD_PARALLEL_CONDITIONAL_FALSE
BUILD_PARALLEL_CONDITIONAL_TRUE
BUILD_CXX_CONDITIONAL_FALSE
BUILD_CXX_CONDITIONAL_TRUE
STRICT_FORMAT_CHECKS
DEFAULT_API_VERSION
DEPRECATED_SYMBOLS
BUILD_ALL_CONDITIONAL_FALSE
BUILD_ALL_CONDITIONAL_TRUE
HL_FOR
HL
DYNAMIC_DIRS
ROOT
CXX_VERSION
FC_VERSION
CC_VERSION
WORDS_BIGENDIAN
BYTESEX
CONFIG_MODE
CONFIG_USER
CONFIG_DATE
H5_VERSION
DIRECT_VFD_CONDITIONAL_FALSE
DIRECT_VFD_CONDITIONAL_TRUE
USE_FILTER_SCALEOFFSET
USE_FILTER_NBIT
USE_FILTER_FLETCHER32
USE_FILTER_SHUFFLE
FILTERS
MPI_GET_SIZE
ADD_PARALLEL_FILES
USINGMEMCHECKER
CLEARFILEBUF
INSTRUMENT_LIBRARY
TRACE_API
DEBUG_PKG
H5_LONE_COLON
HAVE_PTHREAD
BUILD_SHARED_SZIP_CONDITIONAL_FALSE
BUILD_SHARED_SZIP_CONDITIONAL_TRUE
LL_PATH
USE_FILTER_SZIP
USE_FILTER_DEFLATE
AM_MAKEFLAGS
LT_STATIC_EXEC
CPP
OTOOL64
OTOOL
LIPO
NMEDIT
DSYMUTIL
MANIFEST_TOOL
RANLIB
ac_ct_AR
LN_S
NM
ac_ct_DUMPBIN
DUMPBIN
LD
FGREP
EGREP
GREP
SED
LIBTOOL
OBJDUMP
DLLTOOL
AS
CXX_SHARED_CONDITIONAL_FALSE
CXX_SHARED_CONDITIONAL_TRUE
H5_CXX_SHARED
FORTRAN_SHARED_CONDITIONAL_FALSE
FORTRAN_SHARED_CONDITIONAL_TRUE
H5_FORTRAN_SHARED
TESTPARALLEL
RUNPARALLEL
RUNSERIAL
PARALLEL
TIME
TR
AR
PERL
CXXCPP
am__fastdepCXX_TRUE
CXXDEPMODE
ac_ct_CXX
CXXFLAGS
FORTRAN_DEFAULT_REALisDBLE_F_FALSE
FORTRAN_DEFAULT_REALisDBLE_F_TRUE
FORTRAN_2003_CONDITIONAL_F_FALSE
FORTRAN_2003_CONDITIONAL_F_TRUE
FORTRAN_HAVE_SIZEOF_FALSE
FORTRAN_HAVE_SIZEOF_TRUE
FCLIBS
F9XMODEXT
F9XMODFLAG
FSEARCH_DIRS
F9XSUFFIXFLAG
FCFLAGS_f90
ac_ct_FC
FCFLAGS
OBJECT_NAMELEN_DEFAULT_F
SIZE_T
HID_T
HSSIZE_T
HSIZE_T
HADDR_T
R_INTEGER
R_LARGE
HAVE_FORTRAN_2003
HDF5_INTERFACES
am__fastdepCC_FALSE
am__fastdepCC_TRUE
CCDEPMODE
am__nodep
AMDEPBACKSLASH
AMDEP_FALSE
AMDEP_TRUE
am__quote
am__include
DEPDIR
OBJEXT
EXEEXT
ac_ct_CC
LDFLAGS
CFLAGS
CC
UNAME_INFO
enable_static
enable_shared
STATIC_SHARED
THREADSAFE
DIRECT_VFD
HAVE_DMALLOC
CODESTACK
INSTRUMENT
LARGEFILE
GPFS
HDF5_HL
CXX
HDF_CXX
FC2003
FC
HDF_FORTRAN2003
HDF_FORTRAN
STATIC_EXEC
MPE
EXTERNAL_FILTERS
AM_LDFLAGS
AM_CPPFLAGS
AM_CXXFLAGS
AM_FCFLAGS
AM_CFLAGS
H5_LDFLAGS
H5_CXXFLAGS
H5_FCFLAGS
H5_CPPFLAGS
H5_CFLAGS
CPPFLAGS
host_os
host_vendor
host_cpu
host
build_os
build_vendor
build_cpu
build
MAINT
AM_BACKSLASH
AM_DEFAULT_V
AM_V
am__untar
am__tar
AMTAR
am__leading_dot
SET_MAKE
AWK
mkdir_p
MKDIR_P
STRIP
install_sh
MAKEINFO
AUTOHEADER
AUTOMAKE
AUTOCONF
ACLOCAL
VERSION
PACKAGE
CYGPATH_W
am__isrc
INSTALL_DATA
INSTALL_SCRIPT
INSTALL_PROGRAM
target_alias
host_alias
build_alias
LIBS
ECHO_T
ECHO_N
ECHO_C
DEFS
mandir
localedir
libdir
psdir
pdfdir
dvidir
htmldir
infodir
docdir
oldincludedir
includedir
localstatedir
sharedstatedir
sysconfdir
datadir
datarootdir
libexecdir
sbindir
bindir
prefix
exec_prefix
PACKAGE_URL
PACKAGE_BUGREPORT
PACKAGE_STRING
PACKAGE_VERSION
PACKAGE_TARNAME
PACKAGE_NAME
PATH_SEPARATOR
SHELL'
ac_tool_prefix=
ac_unique_file=src/H5.c
ac_unrecognized_opts=
ac_unrecognized_sep=
ac_user_opts='
enable_option_checking
enable_silent_rules
enable_maintainer_mode
enable_dependency_tracking
enable_unsupported
enable_fortran
enable_fortran2003
enable_cxx
enable_shared
enable_static
with_pic
enable_fast_install
with_gnu_ld
with_sysroot
enable_libtool_lock
enable_static_exec
enable_sharedlib_rpath
enable_production
enable_largefile
enable_linux_lfs
with_fnord
with_dmalloc
with_zlib
with_szlib
with_pthread
enable_threadsafe
enable_gpfs
enable_debug
enable_codestack
enable_metadata_trace_file
enable_trace
enable_instrument
enable_clear_file_buffers
enable_using_memchecker
enable_parallel
with_mpe
enable_mpi_size
enable_filters
with_default_vfd
enable_direct_vfd
enable_dconv_exception
enable_dconv_accuracy
enable_hl
enable_build_all
enable_deprecated_symbols
with_default_api_version
enable_strict_format_checks
enable_embedded_libinfo
ac_useropt=sharedlib_rpath
ac_useropt_orig=sharedlib-rpath
ac_val='${datarootdir}/man'
ac_var=CPP
ac_word=gawk
am__api_version=1.12
am__leading_dot=.
am_aux_dir=/home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11/bin
am_lf='
am_make=make
am_missing_run='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11/bin/missing --run '
am_sleep_pid=1764
as_basename=basename
as_bourne_compatible='if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
  emulate sh
  NULLCMD=:
  # Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
  # is contrary to our usage.  Disable this feature.
  alias -g '\''${1+"$@"}'\''='\''"$@"'\''
  setopt NO_GLOB_SUBST
else
  case `(set -o) 2>/dev/null` in #(
  *posix*) :
    set -o posix ;; #(
esac
fi
as_cr_LETTERS=ABCDEFGHIJKLMNOPQRSTUVWXYZ
as_cr_Letters=abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ
as_cr_alnum=abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789
as_cr_digits=0123456789
as_cr_letters=abcdefghijklmnopqrstuvwxyz
as_dir=/usr/bin
as_dirname=dirname
as_echo='printf %s\n'
as_echo_n='printf %s'
as_executable_p=as_fn_executable_p
as_expr=expr
as_have_required=yes
as_lineno_1=477
as_lineno_1a=477
as_lineno_2=478
as_lineno_2a=478
as_ln_s='ln -s'
as_me=configure
as_mkdir_p='mkdir -p "$as_dir"'
as_myself=./configure
as_nl='
as_required='as_fn_return () { (exit $1); }
as_fn_success () { as_fn_return 0; }
as_fn_failure () { as_fn_return 1; }
as_fn_ret_success () { return 0; }
as_fn_ret_failure () { return 1; }
exitcode=0
as_fn_success || { exitcode=1; echo as_fn_success failed.; }
as_fn_failure && { exitcode=1; echo as_fn_failure succeeded.; }
as_fn_ret_success || { exitcode=1; echo as_fn_ret_success failed.; }
as_fn_ret_failure && { exitcode=1; echo as_fn_ret_failure succeeded.; }
if ( set x; as_fn_ret_success y && test x = "$1" ); then :
else
  exitcode=1; echo positional parameters were not saved.
fi
test x$exitcode = x0 || exit 1
test -x / || exit 1'
as_save_IFS='
as_suggested='  as_lineno_1=198 as_lineno_1a=$LINENO
  as_lineno_2=199 as_lineno_2a=$LINENO
  eval '\''test "x$as_lineno_1'\''$as_run'\''" != "x$as_lineno_2'\''$as_run'\''" &&
  test "x`expr $as_lineno_1'\''$as_run'\'' + 1`" = "x$as_lineno_2'\''$as_run'\''"'\'' || exit 1
  test -n "${ZSH_VERSION+set}${BASH_VERSION+set}" || (
    ECHO='\''\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'\''
    ECHO=$ECHO$ECHO$ECHO$ECHO$ECHO
    ECHO=$ECHO$ECHO$ECHO$ECHO$ECHO$ECHO
    PATH=/empty FPATH=/empty; export PATH FPATH
    test "X`printf %s $ECHO`" = "X$ECHO" \
      || test "X`print -r -- $ECHO`" = "X$ECHO" ) || exit 1
test $(( 1 + 1 )) = 2 || exit 1'
as_test_x='test -x'
as_tr_cpp='eval sed '\''y%*abcdefghijklmnopqrstuvwxyz%PABCDEFGHIJKLMNOPQRSTUVWXYZ%;s%[^_abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789]%_%g'\'''
as_tr_sh='eval sed '\''y%*+%pp%;s%[^_abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789]%_%g'\'''
as_unset=as_fn_unset
as_var=MAILPATH
build_cpu=x86_64
build_os=linux-gnu
build_vendor=unknown
cache_file=/dev/null
cross_compiling=no
dvidir='${docdir}'
enable_cxx=yes
enable_largefile=yes
enable_parallel=yes
enable_production=yes
enable_shared=yes
enable_sharedlib_rpath=no
enable_static=no
enable_unsupported=yes
exec_prefix=NONE
host_cpu=x86_64
host_os=linux-gnu
host_vendor=unknown
htmldir='${docdir}'
install_sh='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11/bin/install-sh'
no_create=
no_recursion=
oldincludedir=/usr/include
pdfdir='${docdir}'
program_prefix=NONE
program_suffix=NONE
program_transform_name=s,x,x,
psdir='${docdir}'
saved_user_CFLAGS=
saved_user_CPPFLAGS=
saved_user_CXXFLAGS=
saved_user_FCFLAGS=
saved_user_LDFLAGS=
silent=
site=
srcdir=.
subdirs=
target=
verbose=
with_default_api_version=v18
with_pthread=/usr/include,/usr/lib64/libz.so
with_zlib=/usr/include,/usr/lib64/libpthread.so
x_includes=NONE
x_libraries=NONE
configure:3959: result: done
configure:4018: checking if basename works
configure:4024: result: yes
configure:4028: checking if xargs works
configure:4034: result: yes
configure:4042: checking for cached host
configure:4049: result: none
configure:4115: checking for config x86_64-unknown-linux-gnu
configure:4123: result: no
configure:4115: checking for config unknown-linux-gnu
configure:4115: checking for config x86_64-linux-gnu
configure:4115: checking for config linux-gnu
configure:4119: result: found
configure:4135: checking for config ./config/site-specific/host-ALA_PC180
configure:4143: result: no
configure:4220: checking for gcc
configure:4247: result: /usr/bin/mpicc
configure:4476: checking for C compiler version
configure:4485: /usr/bin/mpicc --version >&5
gcc (GCC) 4.8.2
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:4496: $? = 0
configure:4485: /usr/bin/mpicc -v >&5
Using built-in specs.
COLLECT_GCC=/usr/bin/gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.8.2/lto-wrapper
Target: x86_64-unknown-linux-gnu
Configured with: /build/gcc/src/gcc-4.8.2/configure --prefix=/usr --libdir=/usr/lib --libexecdir=/usr/lib --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=https://bugs.archlinux.org/ --enable-languages=c,c++,ada,fortran,go,lto,objc,obj-c++ --enable-shared --enable-threads=posix --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-clocale=gnu --disable-libstdcxx-pch --enable-gnu-unique-object --enable-linker-build-id --enable-cloog-backend=isl --disable-cloog-version-check --enable-lto --enable-gold --enable-ld=default --enable-plugin --with-plugin-ld=ld.gold --with-linker-hash-style=gnu --disable-install-libiberty --disable-multilib --disable-libssp --disable-werror --enable-checking=release
Thread model: posix
gcc version 4.8.2 (GCC)
configure:4485: /usr/bin/mpicc -V >&5
gcc: error: unrecognized command line option '-V'
gcc: fatal error: no input files
compilation terminated.
configure:4496: $? = 1
configure:4485: /usr/bin/mpicc -qversion >&5
gcc: error: unrecognized command line option '-qversion'
configure:4516: checking whether the C compiler works
configure:4538: /usr/bin/mpicc       conftest.c  >&5
configure:4542: $? = 0
configure:4590: result: yes
configure:4593: checking for C compiler default output file name
configure:4595: result: a.out
configure:4601: checking for suffix of executables
configure:4608: /usr/bin/mpicc -o conftest       conftest.c  >&5
configure:4612: $? = 0
configure:4634: result:
configure:4656: checking whether we are cross compiling
configure:4664: /usr/bin/mpicc -o conftest       conftest.c  >&5
configure:4668: $? = 0
configure:4675: ./conftest
configure:4679: $? = 0
configure:4694: result: no
configure:4699: checking for suffix of object files
configure:4721: /usr/bin/mpicc -c     conftest.c >&5
configure:4725: $? = 0
configure:4746: result: o
configure:4750: checking whether we are using the GNU C compiler
configure:4769: /usr/bin/mpicc -c     conftest.c >&5
configure:4769: $? = 0
configure:4778: result: yes
configure:4787: checking whether /usr/bin/mpicc accepts -g
configure:4807: /usr/bin/mpicc -c -g   conftest.c >&5
configure:4807: $? = 0
configure:4848: result: yes
configure:4865: checking for /usr/bin/mpicc option to accept ISO C89
configure:4928: /usr/bin/mpicc  -c     conftest.c >&5
configure:4928: $? = 0
configure:4941: result: none needed
configure:4972: checking for style of include used by make
configure:5000: result: GNU
configure:5026: checking dependency style of /usr/bin/mpicc
configure:5137: result: gcc3
configure:5159: checking if unsupported combinations of configure options are allowed
configure:5173: result: yes
configure:5184: checking if Fortran interface enabled
configure:5202: checking if Fortran 2003 interface enabled
configure:6814: checking for C++ compiler version
configure:6823: /usr/bin/mpicxx --version >&5
g++ (GCC) 4.8.2
configure:6834: $? = 0
configure:6823: /usr/bin/mpicxx -v >&5
COLLECT_GCC=/usr/bin/g++
Thread model: posix
configure:6823: /usr/bin/mpicxx -V >&5
g++: error: unrecognized command line option '-V'
g++: fatal error: no input files
configure:6834: $? = 1
configure:6823: /usr/bin/mpicxx -qversion >&5
g++: error: unrecognized command line option '-qversion'
configure:6838: checking whether we are using the GNU C++ compiler
configure:6865: /usr/bin/mpicxx -c     conftest.cpp >&5
configure:6865: $? = 0
configure:6874: result: yes
configure:6883: checking whether /usr/bin/mpicxx accepts -g
configure:6911: /usr/bin/mpicxx -c -g   conftest.cpp >&5
configure:6911: $? = 0
configure:6968: result: yes
configure:6993: checking dependency style of /usr/bin/mpicxx
configure:7104: result: gcc3
configure:7124: checking how to run the C++ preprocessor
configure:7151: /usr/bin/mpicxx -E   conftest.cpp
configure:7151: $? = 0
configure:7165: /usr/bin/mpicxx -E   conftest.cpp
conftest.cpp:11:28: fatal error: ac_nonexistent.h: No such file or directory
 #include <ac_nonexistent.h>
configure:7165: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "HDF5"
| #define PACKAGE_TARNAME "hdf5"
| #define PACKAGE_VERSION "1.8.11"
| #define PACKAGE_STRING "HDF5 1.8.11"
| #define PACKAGE_BUGREPORT "help at hdfgroup.org"
| #define PACKAGE "hdf5"
| #define VERSION "1.8.11"
| /* end confdefs.h.  */
configure:7190: result: /usr/bin/mpicxx -E
configure:7210: /usr/bin/mpicxx -E   conftest.cpp
configure:7210: $? = 0
configure:7224: /usr/bin/mpicxx -E   conftest.cpp
configure:7224: $? = 1
| /* confdefs.h */
configure:7253: checking if c++ interface enabled
configure:7274: checking if /usr/bin/mpicxx needs old style header files in includes
configure:7291: /usr/bin/mpicxx -o conftest       conftest.cpp  >&5
configure:7291: $? = 0
configure:7291: ./conftest
configure:7307: checking if /usr/bin/mpicxx can handle namespaces
configure:7329: /usr/bin/mpicxx -o conftest       conftest.cpp  >&5
configure:7329: $? = 0
configure:7329: ./conftest
configure:7345: checking if /usr/bin/mpicxx supports std
configure:7366: /usr/bin/mpicxx -o conftest       conftest.cpp  >&5
configure:7366: $? = 0
configure:7366: ./conftest
configure:7382: checking if /usr/bin/mpicxx supports bool types
configure:7399: /usr/bin/mpicxx -o conftest       conftest.cpp  >&5
configure:7399: $? = 0
configure:7399: ./conftest
configure:7415: checking if /usr/bin/mpicxx has offsetof extension
configure:7450: /usr/bin/mpicxx -c     conftest.cpp >&5
configure:7450: $? = 0
configure:7454: result: yes
configure:7462: checking if /usr/bin/mpicxx can handle static cast
configure:7482: /usr/bin/mpicxx -o conftest       conftest.cpp  >&5
configure:7482: $? = 0
configure:7482: ./conftest
configure:7520: checking for perl
configure:7536: found /usr/bin/perl
configure:7547: result: perl
configure:7571: checking for ar
configure:7587: found /usr/bin/ar
configure:7598: result: ar
configure:7617: checking whether make sets $(MAKE)
configure:7639: result: yes
configure:7656: checking for tr
configure:7674: found /usr/bin/tr
configure:7686: result: /usr/bin/tr
configure:7705: checking if srcdir= and time commands work together
configure:7716: result: no
configure:7775: checking for mpiexec
configure:7792: result: /usr/bin/mpiexec
configure:7964: checking if shared C++ libraries are supported
configure:7995: result: yes
configure:8408: checking how to print strings
configure:8435: result: printf
configure:8456: checking for a sed that does not truncate output
configure:8520: result: /usr/bin/sed
configure:8538: checking for grep that handles long lines and -e
configure:8596: result: /usr/bin/grep
configure:8601: checking for egrep
configure:8663: result: /usr/bin/grep -E
configure:8668: checking for fgrep
configure:8730: result: /usr/bin/grep -F
configure:8765: checking for ld used by /usr/bin/mpicc
configure:8832: result: /usr/bin/ld
configure:8839: checking if the linker (/usr/bin/ld) is GNU ld
configure:8854: result: yes
configure:8866: checking for BSD- or MS-compatible name lister (nm)
configure:8915: result: /usr/bin/nm -B
configure:9045: checking the name lister (/usr/bin/nm -B) interface
configure:9052: /usr/bin/mpicc -c     conftest.c >&5
configure:9055: /usr/bin/nm -B "conftest.o"
configure:9058: output
0000000000000000 B some_variable
configure:9065: result: BSD nm
configure:9068: checking whether ln -s works
configure:9072: result: yes
configure:9080: checking the maximum length of command line arguments
configure:9210: result: 1572864
configure:9227: checking whether the shell understands some XSI constructs
configure:9237: result: yes
configure:9241: checking whether the shell understands "+="
configure:9247: result: yes
configure:9282: checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format
configure:9322: result: func_convert_file_noop
configure:9329: checking how to convert x86_64-unknown-linux-gnu file names to toolchain format
configure:9349: result: func_convert_file_noop
configure:9356: checking for /usr/bin/ld option to reload object files
configure:9363: result: -r
configure:9437: checking for objdump
configure:9464: result: objdump
configure:9493: checking how to recognize dependent libraries
configure:9695: result: pass_all
configure:9780: checking for dlltool
configure:9807: result: dlltool
configure:9837: checking how to associate runtime and link libraries
configure:9864: result: printf %s\n
configure:9988: checking for archiver @FILE support
configure:10013: /usr/bin/mpicc -c     conftest.c >&5
configure:10013: $? = 0
configure:10016: ar cru libconftest.a @conftest.lst >&5
configure:10019: $? = 0
configure:10024: ar cru libconftest.a @conftest.lst >&5
ar: conftest.o: No such file or directory
configure:10027: $? = 1
configure:10039: result: @
configure:10097: checking for strip
configure:10113: found /usr/bin/strip
configure:10124: result: strip
configure:10196: checking for ranlib
configure:10212: found /usr/bin/ranlib
configure:10223: result: ranlib
configure:10325: checking command to parse /usr/bin/nm -B output from /usr/bin/mpicc object
configure:10445: /usr/bin/mpicc -c     conftest.c >&5
configure:10448: $? = 0
configure:10452: /usr/bin/nm -B conftest.o \| sed -n -e 's/^.*[ ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p' | sed '/ __gnu_lto/d' \> conftest.nm
configure:10455: $? = 0
configure:10521: /usr/bin/mpicc -o conftest       conftest.c conftstm.o >&5
configure:10524: $? = 0
configure:10562: result: ok
configure:10599: checking for sysroot
configure:10629: result: no
configure:10706: /usr/bin/mpicc -c     conftest.c >&5
configure:10709: $? = 0
configure:10893: checking for mt
configure:10923: result: no
configure:10943: checking if : is a manifest tool
configure:10949: : '-?'
configure:10957: result: no
configure:11607: checking how to run the C preprocessor
configure:11638: /usr/bin/mpicc -E   conftest.c
configure:11638: $? = 0
configure:11652: /usr/bin/mpicc -E   conftest.c
conftest.c:12:28: fatal error: ac_nonexistent.h: No such file or directory
configure:11652: $? = 1
| /* confdefs.h */
| #define CXX_HAVE_OFFSETOF 1
configure:11677: result: /usr/bin/mpicc -E
configure:11697: /usr/bin/mpicc -E   conftest.c
configure:11697: $? = 0
configure:11711: /usr/bin/mpicc -E   conftest.c
configure:11711: $? = 1
| /* confdefs.h */
configure:11740: checking for ANSI C header files
configure:11768: /usr/bin/mpicc -c     conftest.c >&5
configure:11768: $? = 0
configure:11841: /usr/bin/mpicc -o conftest       conftest.c  >&5
configure:11841: $? = 0
configure:11841: ./conftest
configure:11852: result: yes
configure:11865: checking for sys/types.h
configure:11865: /usr/bin/mpicc -c     conftest.c >&5
configure:11865: $? = 0
configure:11865: result: yes
configure:11865: checking for sys/stat.h
configure:11865: checking for stdlib.h
configure:11865: checking for string.h
configure:11865: checking for memory.h
configure:11865: checking for strings.h
configure:11865: checking for inttypes.h
configure:11865: checking for stdint.h
configure:11865: checking for unistd.h
configure:11879: checking for dlfcn.h
configure:11879: /usr/bin/mpicc -c     conftest.c >&5
configure:11879: $? = 0
configure:11879: result: yes
configure:12092: checking for objdir
configure:12107: result: .libs
configure:12374: checking if /usr/bin/mpicc supports -fno-rtti -fno-exceptions
configure:12392: /usr/bin/mpicc -c     -fno-rtti -fno-exceptions conftest.c >&5
cc1: warning: command line option '-fno-rtti' is valid for C++/ObjC++ but not for C [enabled by default]
configure:12396: $? = 0
configure:12409: result: no
configure:12736: checking for /usr/bin/mpicc option to produce PIC
configure:12743: result: -fPIC -DPIC
configure:12751: checking if /usr/bin/mpicc PIC flag -fPIC -DPIC works
configure:12769: /usr/bin/mpicc -c     -fPIC -DPIC -DPIC conftest.c >&5
configure:12773: $? = 0
configure:12786: result: yes
configure:12815: checking if /usr/bin/mpicc static flag -static works
configure:12843: result: no
configure:12858: checking if /usr/bin/mpicc supports -c -o file.o
configure:12879: /usr/bin/mpicc -c     -o out/conftest2.o conftest.c >&5
configure:12883: $? = 0
configure:12905: result: yes
configure:12913: checking if /usr/bin/mpicc supports -c -o file.o
configure:12960: result: yes
configure:12993: checking whether the /usr/bin/mpicc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:14162: result: yes
configure:14199: checking whether -lc should be explicitly linked in
configure:14207: /usr/bin/mpicc -c     conftest.c >&5
configure:14210: $? = 0
configure:14225: /usr/bin/mpicc -shared  -fPIC -DPIC conftest.o  -v -Wl,-soname -Wl,conftest -o conftest 2\>\&1 \| /usr/bin/grep  -lc  \>/dev/null 2\>\&1
configure:14228: $? = 0
configure:14242: result: no
configure:14402: checking dynamic linker characteristics
configure:14921: /usr/bin/mpicc -o conftest       -Wl,-rpath -Wl,/foo conftest.c  >&5
configure:14921: $? = 0
configure:15143: result: GNU/Linux ld.so
configure:15250: checking how to hardcode library paths into programs
configure:15275: result: immediate
configure:15377: checking for shl_load
configure:15377: /usr/bin/mpicc -o conftest       conftest.c  >&5
/tmp/ccMw0ul7.o: In function `main':
conftest.c:(.text+0xa): undefined reference to `shl_load'
collect2: error: ld returned 1 exit status
configure:15377: $? = 1
| /* confdefs.h */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_DLFCN_H 1
| #define LT_OBJDIR ".libs/"
| /* Define shl_load to an innocuous variant, in case <limits.h> declares shl_load.
|    For example, HP-UX 11i <limits.h> declares gettimeofday.  */
| #define shl_load innocuous_shl_load
| /* System header to define __stub macros and hopefully few prototypes,
|     which can conflict with char shl_load (); below.
|     Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
|     <limits.h> exists even on freestanding compilers.  */
| #ifdef __STDC__
| # include <limits.h>
| #else
| # include <assert.h>
| #endif
| #undef shl_load
| /* Override any GCC internal prototype to avoid an error.
|    Use char because int might match the return type of a GCC
|    builtin and then its argument prototype would still apply.  */
| #ifdef __cplusplus
| extern "C"
| #endif
| char shl_load ();
| /* The GNU C library defines this for functions which it implements
|     to always fail with ENOSYS.  Some functions are actually named
|     something starting with __ and the normal name is an alias.  */
| #if defined __stub_shl_load || defined __stub___shl_load
| choke me
| #endif
| #ifdef FC_DUMMY_MAIN
| #ifndef FC_DUMMY_MAIN_EQ_F77
| #  ifdef __cplusplus
|      extern "C"
| #  endif
|    int FC_DUMMY_MAIN() { return 1; }
| #endif
| #endif
| int
| main ()
| return shl_load ();
|   return 0;
configure:15377: result: no
configure:15381: checking for shl_load in -ldld
configure:15414: /usr/bin/mpicc -o conftest       conftest.c -ldld   >&5
/usr/bin/ld: cannot find -ldld
configure:15414: $? = 1
| /* confdefs.h */
| #ifdef __cplusplus
| extern "C"
| #endif
| char shl_load ();
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| return shl_load ();
|   return 0;
configure:15423: result: no
configure:15428: checking for dlopen
configure:15428: /usr/bin/mpicc -o conftest       conftest.c  >&5
configure:15428: $? = 0
configure:15428: result: yes
configure:15609: checking whether a program can dlopen itself
configure:15689: /usr/bin/mpicc -o conftest     -DHAVE_DLFCN_H   -Wl,--export-dynamic conftest.c   >&5
configure:15692: $? = 0
configure:15710: result: yes
configure:15715: checking whether a statically linked program can dlopen itself
configure:15795: /usr/bin/mpicc -o conftest     -DHAVE_DLFCN_H   -Wl,--export-dynamic  conftest.c   >&5
configure:15798: $? = 0
configure:15816: result: yes
configure:15855: checking whether stripping libraries is possible
configure:15860: result: yes
configure:15895: checking if libtool supports shared libraries
configure:15897: result: yes
configure:15900: checking whether to build shared libraries
configure:15921: result: yes
configure:15924: checking whether to build static libraries
configure:15928: result: no
configure:15951: checking how to run the C++ preprocessor
configure:16017: result: /usr/bin/mpicxx -E
configure:16037: /usr/bin/mpicxx -E   conftest.cpp
configure:16037: $? = 0
configure:16051: /usr/bin/mpicxx -E   conftest.cpp
conftest.cpp:24:28: fatal error: ac_nonexistent.h: No such file or directory
configure:16051: $? = 1
| /* confdefs.h */
configure:16220: checking for ld used by /usr/bin/mpicxx
configure:16287: result: /usr/bin/ld -m elf_x86_64
configure:16294: checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld
configure:16309: result: yes
configure:16364: checking whether the /usr/bin/mpicxx linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:17385: result: yes
configure:17421: /usr/bin/mpicxx -c     conftest.cpp >&5
configure:17424: $? = 0
configure:17944: checking for /usr/bin/mpicxx option to produce PIC
configure:17951: result: -fPIC -DPIC
configure:17959: checking if /usr/bin/mpicxx PIC flag -fPIC -DPIC works
configure:17977: /usr/bin/mpicxx -c     -fPIC -DPIC -DPIC conftest.cpp >&5
configure:17981: $? = 0
configure:17994: result: yes
configure:18017: checking if /usr/bin/mpicxx static flag -static works
configure:18045: result: no
configure:18057: checking if /usr/bin/mpicxx supports -c -o file.o
configure:18078: /usr/bin/mpicxx -c     -o out/conftest2.o conftest.cpp >&5
configure:18082: $? = 0
configure:18104: result: yes
configure:18109: checking if /usr/bin/mpicxx supports -c -o file.o
configure:18156: result: yes
configure:18186: checking whether the /usr/bin/mpicxx linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:18222: result: yes
configure:18363: checking dynamic linker characteristics
configure:19038: result: GNU/Linux ld.so
configure:19091: checking how to hardcode library paths into programs
configure:19116: result: immediate
configure:22048: checking if we should install only statically linked executables
configure:22083: checking if -Wl,-rpath should be used to link shared libs in nondefault directories
configure:22093: result: no
configure:22110: checking make
configure:22118: checking how make searches directories
configure:22135: result: VPATH=DIR1 DIR2 ...
configure:22200: checking whether make will build with undefined variables
configure:22209: result: yes
configure:22224: checking for production mode
configure:22235: result: production
configure:22274: checking for ceil in -lm
configure:22307: /usr/bin/mpicc -o conftest       conftest.c -lm   >&5
conftest.c:31:6: warning: conflicting types for built-in function 'ceil' [enabled by default]
 char ceil ();
configure:22307: $? = 0
configure:22316: result: yes
configure:22327: checking for dlopen in -ldl
configure:22360: /usr/bin/mpicc -o conftest       conftest.c -ldl  -lm  >&5
configure:22360: $? = 0
configure:22369: result: yes
configure:22495: checking for ANSI C header files
configure:22607: result: yes
configure:22615: checking whether time.h and sys/time.h may both be included
configure:22643: /usr/bin/mpicc -c     conftest.c >&5
configure:22643: $? = 0
configure:22650: result: yes
configure:22666: checking for difftime
configure:22666: /usr/bin/mpicc -o conftest       conftest.c -ldl -lm  >&5
configure:22666: $? = 0
configure:22666: result: yes
configure:22677: checking for gettimeofday
configure:22677: /usr/bin/mpicc -o conftest       conftest.c -ldl -lm  >&5
configure:22677: $? = 0
configure:22677: result: yes
configure:22688: checking for library containing clock_gettime
configure:22727: /usr/bin/mpicc -o conftest       conftest.c -ldl -lm  >&5
configure:22727: $? = 0
configure:22744: result: none required
configure:22754: checking for clock_gettime
configure:22754: /usr/bin/mpicc -o conftest       conftest.c -ldl -lm  >&5
configure:22754: $? = 0
configure:22754: result: yes
configure:22770: checking sys/resource.h usability
configure:22770: /usr/bin/mpicc -c     conftest.c >&5
configure:22770: $? = 0
configure:22770: result: yes
configure:22770: checking sys/resource.h presence
configure:22770: /usr/bin/mpicc -E   conftest.c
configure:22770: checking for sys/resource.h
configure:22770: checking sys/time.h usability
configure:22770: checking sys/time.h presence
configure:22770: checking for sys/time.h
configure:22770: checking for unistd.h
configure:22770: checking sys/ioctl.h usability
configure:22770: checking sys/ioctl.h presence
configure:22770: checking for sys/ioctl.h
configure:22770: checking for sys/stat.h
configure:22783: checking sys/socket.h usability
configure:22783: /usr/bin/mpicc -c     conftest.c >&5
configure:22783: $? = 0
configure:22783: result: yes
configure:22783: checking sys/socket.h presence
configure:22783: /usr/bin/mpicc -E   conftest.c
configure:22783: checking for sys/socket.h
configure:22783: checking for sys/types.h
configure:22796: checking stddef.h usability
configure:22796: /usr/bin/mpicc -c     conftest.c >&5
configure:22796: $? = 0
configure:22796: result: yes
configure:22796: checking stddef.h presence
configure:22796: /usr/bin/mpicc -E   conftest.c
configure:22796: checking for stddef.h
configure:22796: checking setjmp.h usability
configure:22796: checking setjmp.h presence
configure:22796: checking for setjmp.h
configure:22796: checking features.h usability
configure:22796: checking features.h presence
configure:22796: checking for features.h
configure:22808: checking dirent.h usability
configure:22808: /usr/bin/mpicc -c     conftest.c >&5
configure:22808: $? = 0
configure:22808: result: yes
configure:22808: checking dirent.h presence
configure:22808: /usr/bin/mpicc -E   conftest.c
configure:22808: checking for dirent.h
configure:22820: checking for stdint.h
configure:22820: result: yes
configure:22834: checking mach/mach_time.h usability
configure:22834: /usr/bin/mpicc -c     conftest.c >&5
conftest.c:76:28: fatal error: mach/mach_time.h: No such file or directory
 #include <mach/mach_time.h>
configure:22834: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_LIBDL 1
| #define TIME_WITH_SYS_TIME 1
| #define HAVE_DIFFTIME 1
| #define HAVE_GETTIMEOFDAY 1
| #define HAVE_CLOCK_GETTIME 1
| #define HAVE_SYS_RESOURCE_H 1
| #define HAVE_SYS_TIME_H 1
| #define HAVE_SYS_IOCTL_H 1
| #define HAVE_SYS_SOCKET_H 1
| #define HAVE_STDDEF_H 1
| #define HAVE_SETJMP_H 1
| #define HAVE_FEATURES_H 1
| #define HAVE_DIRENT_H 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:22834: result: no
configure:22834: checking mach/mach_time.h presence
configure:22834: /usr/bin/mpicc -E   conftest.c
conftest.c:43:28: fatal error: mach/mach_time.h: No such file or directory
| /* confdefs.h */
| #define HAVE_LIBM 1
configure:22834: checking for mach/mach_time.h
configure:22937: checking io.h usability
configure:22937: /usr/bin/mpicc -c     conftest.c >&5
conftest.c:76:16: fatal error: io.h: No such file or directory
 #include <io.h>
configure:22937: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <io.h>
configure:22937: result: no
configure:22937: checking io.h presence
configure:22937: /usr/bin/mpicc -E   conftest.c
conftest.c:43:16: fatal error: io.h: No such file or directory
 #include <io.h>
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <io.h>
configure:22937: checking for io.h
configure:22937: checking winsock2.h usability
conftest.c:76:22: fatal error: winsock2.h: No such file or directory
 #include <winsock2.h>
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:22937: checking winsock2.h presence
conftest.c:43:22: fatal error: winsock2.h: No such file or directory
| /* confdefs.h */
| #define HAVE_LIBM 1
configure:22937: checking for winsock2.h
configure:22937: checking sys/timeb.h usability
configure:22937: $? = 0
configure:22937: result: yes
configure:22937: checking sys/timeb.h presence
configure:22937: checking for sys/timeb.h
configure:23008: checking if libtool needs -no-undefined flag to build shared libraries
configure:23019: result: no
configure:23028: checking if configure should try to set up large file support
configure:23058: result: yes
configure:23063: checking for special C compiler options needed for large files
configure:23116: result: no
configure:23130: checking for _FILE_OFFSET_BITS value needed for large files
configure:23163: /usr/bin/mpicc -c     conftest.c >&5
configure:23163: $? = 0
configure:23203: result: no
configure:23307: checking if large (64-bit) files are supported on this system.
configure:23338: /usr/bin/mpicc -o conftest       conftest.c -ldl -lm  >&5
configure:23338: $? = 0
configure:23338: ./conftest
configure:23351: result: yes
configure:23432: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
conftest.c:11:0: warning: macro "STDC_HEADERS" is not used [-Wunused-macros]
conftest.c:20:0: warning: macro "HAVE_UNISTD_H" is not used [-Wunused-macros]
conftest.c:13:0: warning: macro "HAVE_SYS_STAT_H" is not used [-Wunused-macros]
conftest.c:12:0: warning: macro "HAVE_SYS_TYPES_H" is not used [-Wunused-macros]
conftest.c:19:0: warning: macro "HAVE_STDINT_H" is not used [-Wunused-macros]
conftest.c:54:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c: In function 'main':
conftest.c:54:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:56:9: warning: unused variable 'n' [-Wunused-variable]
 off64_t n = 0;
conftest.c:54:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
 main ()
conftest.c: At top level:
conftest.c:15:0: warning: macro "HAVE_STRING_H" is not used [-Wunused-macros]
conftest.c:27:0: warning: macro "HAVE_DIFFTIME" is not used [-Wunused-macros]
conftest.c:5:0: warning: macro "PACKAGE_STRING" is not used [-Wunused-macros]
conftest.c:16:0: warning: macro "HAVE_MEMORY_H" is not used [-Wunused-macros]
conftest.c:41:0: warning: macro "HAVE_STDINT_H" is not used [-Wunused-macros]
conftest.c:40:0: warning: macro "HAVE_DIRENT_H" is not used [-Wunused-macros]
conftest.c:18:0: warning: macro "HAVE_INTTYPES_H" is not used [-Wunused-macros]
conftest.c:3:0: warning: macro "PACKAGE_TARNAME" is not used [-Wunused-macros]
conftest.c:28:0: warning: macro "HAVE_GETTIMEOFDAY" is not used [-Wunused-macros]
conftest.c:14:0: warning: macro "HAVE_STDLIB_H" is not used [-Wunused-macros]
conftest.c:36:0: warning: macro "HAVE_SYS_TYPES_H" is not used [-Wunused-macros]
conftest.c:35:0: warning: macro "HAVE_SYS_SOCKET_H" is not used [-Wunused-macros]
conftest.c:42:0: warning: macro "HAVE_SYS_TIMEB_H" is not used [-Wunused-macros]
 #define HAVE_SYS_TIMEB_H 1
conftest.c:33:0: warning: macro "HAVE_SYS_IOCTL_H" is not used [-Wunused-macros]
conftest.c:6:0: warning: macro "PACKAGE_BUGREPORT" is not used [-Wunused-macros]
conftest.c:32:0: warning: macro "HAVE_UNISTD_H" is not used [-Wunused-macros]
conftest.c:30:0: warning: macro "HAVE_SYS_RESOURCE_H" is not used [-Wunused-macros]
conftest.c:17:0: warning: macro "HAVE_STRINGS_H" is not used [-Wunused-macros]
conftest.c:37:0: warning: macro "HAVE_STDDEF_H" is not used [-Wunused-macros]
conftest.c:34:0: warning: macro "HAVE_SYS_STAT_H" is not used [-Wunused-macros]
conftest.c:25:0: warning: macro "STDC_HEADERS" is not used [-Wunused-macros]
conftest.c:4:0: warning: macro "PACKAGE_VERSION" is not used [-Wunused-macros]
conftest.c:2:0: warning: macro "PACKAGE_NAME" is not used [-Wunused-macros]
conftest.c:31:0: warning: macro "HAVE_SYS_TIME_H" is not used [-Wunused-macros]
conftest.c:8:0: warning: macro "PACKAGE" is not used [-Wunused-macros]
conftest.c:22:0: warning: macro "LT_OBJDIR" is not used [-Wunused-macros]
conftest.c:23:0: warning: macro "HAVE_LIBM" is not used [-Wunused-macros]
 #define HAVE_LIBM 1
conftest.c:21:0: warning: macro "HAVE_DLFCN_H" is not used [-Wunused-macros]
conftest.c:29:0: warning: macro "HAVE_CLOCK_GETTIME" is not used [-Wunused-macros]
conftest.c:39:0: warning: macro "HAVE_FEATURES_H" is not used [-Wunused-macros]
conftest.c:38:0: warning: macro "HAVE_SETJMP_H" is not used [-Wunused-macros]
conftest.c:10:0: warning: macro "CXX_HAVE_OFFSETOF" is not used [-Wunused-macros]
conftest.c:26:0: warning: macro "TIME_WITH_SYS_TIME" is not used [-Wunused-macros]
conftest.c:24:0: warning: macro "HAVE_LIBDL" is not used [-Wunused-macros]
conftest.c:9:0: warning: macro "VERSION" is not used [-Wunused-macros]
conftest.c:7:0: warning: macro "PACKAGE_URL" is not used [-Wunused-macros]
 #define PACKAGE_URL ""
configure:23432: $? = 0
configure:23436: checking for lseek64
configure:23436: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:46:0: warning: macro "lseek64" is not used [-Wunused-macros]
 #define lseek64 innocuous_lseek64
conftest.c:67:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char lseek64 ();
conftest.c:84:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:84:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_LIBM 1
configure:23436: $? = 0
configure:23436: result: yes
configure:23436: checking for fseeko64
conftest.c:47:0: warning: macro "fseeko64" is not used [-Wunused-macros]
 #define fseeko64 innocuous_fseeko64
conftest.c:68:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char fseeko64 ();
conftest.c:85:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:85:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_LIBM 1
conftest.c:43:0: warning: macro "HAVE_LSEEK64" is not used [-Wunused-macros]
 #define HAVE_LSEEK64 1
configure:23436: checking for ftello64
conftest.c:48:0: warning: macro "ftello64" is not used [-Wunused-macros]
 #define ftello64 innocuous_ftello64
conftest.c:69:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char ftello64 ();
conftest.c:86:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:86:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_LIBM 1
conftest.c:44:0: warning: macro "HAVE_FSEEKO64" is not used [-Wunused-macros]
 #define HAVE_FSEEKO64 1
configure:23436: checking for ftruncate64
conftest.c:49:0: warning: macro "ftruncate64" is not used [-Wunused-macros]
 #define ftruncate64 innocuous_ftruncate64
conftest.c:70:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char ftruncate64 ();
conftest.c:87:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:87:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:45:0: warning: macro "HAVE_FTELLO64" is not used [-Wunused-macros]
 #define HAVE_FTELLO64 1
 #define HAVE_LIBM 1
configure:23453: checking for fseeko
configure:23453: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:50:0: warning: macro "fseeko" is not used [-Wunused-macros]
 #define fseeko innocuous_fseeko
conftest.c:71:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char fseeko ();
conftest.c:88:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:88:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:46:0: warning: macro "HAVE_FTRUNCATE64" is not used [-Wunused-macros]
 #define HAVE_FTRUNCATE64 1
 #define HAVE_LIBM 1
configure:23453: $? = 0
configure:23453: result: yes
configure:23453: checking for ftello
conftest.c:51:0: warning: macro "ftello" is not used [-Wunused-macros]
 #define ftello innocuous_ftello
conftest.c:72:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char ftello ();
conftest.c:89:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:89:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:47:0: warning: macro "HAVE_FSEEKO" is not used [-Wunused-macros]
 #define HAVE_FSEEKO 1
 #define HAVE_LIBM 1
configure:23483: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
conftest.c:62:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:62:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:64:15: warning: unused variable 'sb' [-Wunused-variable]
 struct stat64 sb;
conftest.c:62:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
 main ()
conftest.c:48:0: warning: macro "HAVE_FTELLO" is not used [-Wunused-macros]
 #define HAVE_FTELLO 1
 #define HAVE_LIBM 1
configure:23483: $? = 0
configure:23487: checking for stat64
configure:23487: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:52:0: warning: macro "stat64" is not used [-Wunused-macros]
 #define stat64 innocuous_stat64
conftest.c:73:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char stat64 ();
conftest.c:90:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:90:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_LIBM 1
configure:23487: $? = 0
configure:23487: result: yes
configure:23487: checking for fstat64
conftest.c:53:0: warning: macro "fstat64" is not used [-Wunused-macros]
 #define fstat64 innocuous_fstat64
conftest.c:74:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char fstat64 ();
conftest.c:91:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:91:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:49:0: warning: macro "HAVE_STAT64" is not used [-Wunused-macros]
 #define HAVE_STAT64 1
 #define HAVE_LIBM 1
configure:23505: checking for off_t
configure:23505: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
conftest.c:94:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:94:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:94:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
conftest.c:50:0: warning: macro "HAVE_FSTAT64" is not used [-Wunused-macros]
 #define HAVE_FSTAT64 1
 #define HAVE_LIBM 1
configure:23505: $? = 0
 main ()
conftest.c:96:20: error: expected expression before ')' token
 if (sizeof ((off_t)))
 #define HAVE_LIBM 1
configure:23505: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| 	    return 0;
|   return 0;
configure:23505: result: yes
configure:23516: checking for size_t
configure:23516: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 main ()
 #define HAVE_LIBM 1
configure:23516: $? = 0
 main ()
conftest.c:96:21: error: expected expression before ')' token
 if (sizeof ((size_t)))
 #define HAVE_LIBM 1
configure:23516: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| 	    return 0;
|   return 0;
configure:23516: result: yes
configure:23527: checking for ssize_t
configure:23527: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 main ()
 #define HAVE_LIBM 1
configure:23527: $? = 0
 main ()
conftest.c:96:22: error: expected expression before ')' token
 if (sizeof ((ssize_t)))
 #define HAVE_LIBM 1
configure:23527: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| 	    return 0;
|   return 0;
configure:23527: result: yes
configure:23538: checking for ptrdiff_t
configure:23538: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 main ()
 #define HAVE_LIBM 1
configure:23538: $? = 0
 main ()
conftest.c:96:24: error: expected expression before ')' token
 if (sizeof ((ptrdiff_t)))
 #define HAVE_LIBM 1
configure:23538: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| 	    return 0;
|   return 0;
configure:23538: result: yes
configure:23549: checking whether byte ordering is bigendian
configure:23564: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
conftest.c:53:9: warning: identifier "not" is a special operator name in C++ [-Wc++-compat]
         not a universal capable compiler
conftest.c:53:9: error: unknown type name 'not'
conftest.c:53:15: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'universal'
conftest.c:53:15: error: unknown type name 'universal'
 #define HAVE_LIBM 1
configure:23564: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #ifndef __APPLE_CC__
| 	     #endif
| 	     typedef int dummy;
configure:23617: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
conftest.c:64:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:64:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:64:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
 #define HAVE_LIBM 1
configure:23617: $? = 0
configure:23643: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 main ()
conftest.c:67:4: warning: identifier "not" is a special operator name in C++ [-Wc++-compat]
    not big endian
conftest.c:67:4: error: unknown type name 'not'
conftest.c:67:12: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'endian'
    not big endian
 #define HAVE_LIBM 1
configure:23643: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <sys/types.h>
| 		#include <sys/param.h>
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| #if BYTE_ORDER != BIG_ENDIAN
| 		 not big endian
| 		#endif
|   return 0;
configure:23803: result: no
configure:23825: checking size of char
configure:23830: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:85:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (char)); }
conftest.c: In function 'longval':
conftest.c:85:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:86:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (char)); }
conftest.c: In function 'ulongval':
conftest.c:86:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:98:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:98:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_LIBM 1
configure:23830: $? = 0
configure:23830: ./conftest
configure:23844: result: 1
configure:23858: checking size of short
configure:23863: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:86:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (short)); }
conftest.c:86:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:87:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (short)); }
conftest.c:87:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:99:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:99:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:51:0: warning: macro "SIZEOF_CHAR" is not used [-Wunused-macros]
 #define SIZEOF_CHAR 1
 #define HAVE_LIBM 1
configure:23863: $? = 0
configure:23863: ./conftest
configure:23877: result: 2
configure:23891: checking size of int
configure:23896: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:87:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (int)); }
conftest.c:87:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:88:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (int)); }
conftest.c:88:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:100:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:100:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:52:0: warning: macro "SIZEOF_SHORT" is not used [-Wunused-macros]
 #define SIZEOF_SHORT 2
 #define HAVE_LIBM 1
configure:23896: $? = 0
configure:23896: ./conftest
configure:23910: result: 4
configure:23924: checking size of unsigned
configure:23929: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:88:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (unsigned)); }
conftest.c:88:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:89:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (unsigned)); }
conftest.c:89:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:101:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:101:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:53:0: warning: macro "SIZEOF_INT" is not used [-Wunused-macros]
 #define SIZEOF_INT 4
 #define HAVE_LIBM 1
configure:23929: $? = 0
configure:23929: ./conftest
configure:23943: result: 4
configure:23957: checking size of long
configure:23962: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:89:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (long)); }
conftest.c:89:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:90:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (long)); }
conftest.c:90:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:102:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:102:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:54:0: warning: macro "SIZEOF_UNSIGNED" is not used [-Wunused-macros]
 #define SIZEOF_UNSIGNED 4
 #define HAVE_LIBM 1
configure:23962: $? = 0
configure:23962: ./conftest
configure:23976: result: 8
configure:23990: checking size of long long
configure:23995: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:90:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (long long)); }
conftest.c:90:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:91:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (long long)); }
conftest.c:91:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:103:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:103:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:55:0: warning: macro "SIZEOF_LONG" is not used [-Wunused-macros]
 #define SIZEOF_LONG 8
 #define HAVE_LIBM 1
configure:23995: $? = 0
configure:23995: ./conftest
configure:24009: result: 8
configure:24023: checking size of __int64
configure:24028: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:91:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (__int64)); }
conftest.c:91:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:91:57: error: '__int64' undeclared (first use in this function)
conftest.c:91:57: note: each undeclared identifier is reported only once for each function it appears in
conftest.c:92:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (__int64)); }
conftest.c:92:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:92:67: error: '__int64' undeclared (first use in this function)
conftest.c:104:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:104:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:110:28: error: '__int64' undeclared (first use in this function)
   if (((long int) (sizeof (__int64))) < 0)
conftest.c:56:0: warning: macro "SIZEOF_LONG_LONG" is not used [-Wunused-macros]
 #define SIZEOF_LONG_LONG 8
 #define HAVE_LIBM 1
configure:24028: $? = 1
configure: program exited with status 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "HDF5"
| #define PACKAGE_TARNAME "hdf5"
| #define PACKAGE_VERSION "1.8.11"
| #define PACKAGE_STRING "HDF5 1.8.11"
| #define PACKAGE_BUGREPORT "help at hdfgroup.org"
| #define PACKAGE "hdf5"
| #define VERSION "1.8.11"
| #define HAVE_LIBM 1
| /* end confdefs.h.  */
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| #  include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #ifdef HAVE_UNISTD_H
| # include <unistd.h>
| #endif
| #include <stdio.h>
| #include <stdlib.h>
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
|   FILE *f = fopen ("conftest.val", "w");
|   if (! f)
|     return 1;
|       long int i = longval ();
|       if (i != ((long int) (sizeof (__int64))))
| 	return 1;
|       fprintf (f, "%ld", i);
|   else
|       unsigned long int i = ulongval ();
| 	return 1;
|       fprintf (f, "%lu", i);
|   /* Do not output a trailing newline, as this causes \r\n confusion
|      on some platforms.  */
|   return ferror (f) || fclose (f) != 0;
|   return 0;
configure:24042: result: 0
configure:24056: checking size of float
configure:24061: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:92:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (float)); }
conftest.c:92:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:93:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (float)); }
conftest.c:93:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:105:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:105:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_LIBM 1
conftest.c:57:0: warning: macro "SIZEOF___INT64" is not used [-Wunused-macros]
 #define SIZEOF___INT64 0
configure:24061: $? = 0
configure:24061: ./conftest
configure:24075: result: 4
configure:24089: checking size of double
configure:24094: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:93:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (double)); }
conftest.c:93:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:94:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (double)); }
conftest.c:94:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:106:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:106:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:58:0: warning: macro "SIZEOF_FLOAT" is not used [-Wunused-macros]
 #define SIZEOF_FLOAT 4
 #define HAVE_LIBM 1
configure:24094: $? = 0
configure:24094: ./conftest
configure:24108: result: 8
configure:24122: checking size of long double
configure:24127: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:94:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (long double)); }
conftest.c:94:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:95:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (long double)); }
conftest.c:95:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:107:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:107:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:59:0: warning: macro "SIZEOF_DOUBLE" is not used [-Wunused-macros]
 #define SIZEOF_DOUBLE 8
 #define HAVE_LIBM 1
 #define CXX_HAVE_OFFSETOF 1
configure:24127: $? = 0
configure:24127: ./conftest
configure:24141: result: 16
configure:24254: checking size of int8_t
configure:24259: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:97:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (int8_t)); }
conftest.c:97:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:98:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (int8_t)); }
conftest.c:98:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:110:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:110:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:60:0: warning: macro "SIZEOF_LONG_DOUBLE" is not used [-Wunused-macros]
 #define SIZEOF_LONG_DOUBLE 16
 #define HAVE_STDLIB_H 1
 #define HAVE_LIBM 1
configure:24259: $? = 0
configure:24259: ./conftest
configure:24273: result: 1
configure:24287: checking size of uint8_t
configure:24292: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
 #define STDC_HEADERS 1
 #define HAVE_UNISTD_H 1
 #define HAVE_SYS_STAT_H 1
 #define HAVE_SYS_TYPES_H 1
 #define HAVE_STDINT_H 1
conftest.c:98:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (uint8_t)); }
conftest.c:98:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:99:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (uint8_t)); }
conftest.c:99:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:111:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:111:1: warning: old-style function definition [-Wold-style-definition]
 #define LT_OBJDIR ".libs/"
 #define HAVE_LIBM 1
 #define HAVE_DLFCN_H 1
conftest.c:63:0: warning: macro "SIZEOF_INT8_T" is not used [-Wunused-macros]
 #define SIZEOF_INT8_T 1
configure:24292: $? = 0
configure:24292: ./conftest
configure:24306: result: 1
configure:24320: checking size of int_least8_t
configure:24325: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:99:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (int_least8_t)); }
conftest.c:99:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:100:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (int_least8_t)); }
conftest.c:100:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:112:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:112:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:64:0: warning: macro "SIZEOF_UINT8_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT8_T 1
 #define HAVE_LIBM 1
configure:24325: $? = 0
configure:24325: ./conftest
configure:24339: result: 1
configure:24353: checking size of uint_least8_t
configure:24358: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:100:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (uint_least8_t)); }
conftest.c:100:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:101:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (uint_least8_t)); }
conftest.c:101:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:113:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:113:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:65:0: warning: macro "SIZEOF_INT_LEAST8_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_LEAST8_T 1
 #define HAVE_LIBM 1
configure:24358: $? = 0
configure:24358: ./conftest
configure:24372: result: 1
configure:24386: checking size of int_fast8_t
configure:24391: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:101:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (int_fast8_t)); }
conftest.c:101:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:102:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (int_fast8_t)); }
conftest.c:102:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:114:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:114:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:66:0: warning: macro "SIZEOF_UINT_LEAST8_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_LEAST8_T 1
 #define HAVE_LIBM 1
configure:24391: $? = 0
configure:24391: ./conftest
configure:24405: result: 1
configure:24419: checking size of uint_fast8_t
configure:24424: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:102:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (uint_fast8_t)); }
conftest.c:102:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:103:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (uint_fast8_t)); }
conftest.c:103:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:115:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:115:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_DIFFTIME 1
 #define HAVE_DIRENT_H 1
 #define HAVE_GETTIMEOFDAY 1
 #define HAVE_SYS_SOCKET_H 1
 #define HAVE_SYS_IOCTL_H 1
 #define HAVE_SYS_RESOURCE_H 1
 #define HAVE_STDDEF_H 1
 #define HAVE_SYS_TIME_H 1
 #define HAVE_LIBM 1
 #define HAVE_CLOCK_GETTIME 1
 #define HAVE_FEATURES_H 1
 #define HAVE_SETJMP_H 1
conftest.c:67:0: warning: macro "SIZEOF_INT_FAST8_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_FAST8_T 1
 #define TIME_WITH_SYS_TIME 1
 #define HAVE_LIBDL 1
configure:24424: $? = 0
configure:24424: ./conftest
configure:24438: result: 1
configure:24453: checking size of int16_t
configure:24458: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:103:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (int16_t)); }
conftest.c:103:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:104:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (int16_t)); }
conftest.c:104:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:116:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:116:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_LIBM 1
conftest.c:68:0: warning: macro "SIZEOF_UINT_FAST8_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_FAST8_T 1
configure:24458: $? = 0
configure:24458: ./conftest
configure:24472: result: 2
configure:24486: checking size of uint16_t
configure:24491: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:11:0: warning: macro "STDC_HEADERS" is not used [-Wunused-macros]
conftest.c:20:0: warning: macro "HAVE_UNISTD_H" is not used [-Wunused-macros]
conftest.c:13:0: warning: macro "HAVE_SYS_STAT_H" is not used [-Wunused-macros]
conftest.c:12:0: warning: macro "HAVE_SYS_TYPES_H" is not used [-Wunused-macros]
conftest.c:19:0: warning: macro "HAVE_STDINT_H" is not used [-Wunused-macros]
conftest.c:104:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (uint16_t)); }
conftest.c:104:17: warning: old-style function definition [-Wold-style-definition]
conftest.c: At top level:
conftest.c:105:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (uint16_t)); }
conftest.c:105:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:117:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c: In function 'main':
conftest.c:117:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:27:0: warning: macro "HAVE_DIFFTIME" is not used [-Wunused-macros]
conftest.c:5:0: warning: macro "PACKAGE_STRING" is not used [-Wunused-macros]
conftest.c:40:0: warning: macro "HAVE_DIRENT_H" is not used [-Wunused-macros]
conftest.c:3:0: warning: macro "PACKAGE_TARNAME" is not used [-Wunused-macros]
conftest.c:28:0: warning: macro "HAVE_GETTIMEOFDAY" is not used [-Wunused-macros]
conftest.c:14:0: warning: macro "HAVE_STDLIB_H" is not used [-Wunused-macros]
conftest.c:35:0: warning: macro "HAVE_SYS_SOCKET_H" is not used [-Wunused-macros]
conftest.c:42:0: warning: macro "HAVE_SYS_TIMEB_H" is not used [-Wunused-macros]
 #define HAVE_SYS_TIMEB_H 1
conftest.c:33:0: warning: macro "HAVE_SYS_IOCTL_H" is not used [-Wunused-macros]
conftest.c:69:0: warning: macro "SIZEOF_INT16_T" is not used [-Wunused-macros]
 #define SIZEOF_INT16_T 2
conftest.c:6:0: warning: macro "PACKAGE_BUGREPORT" is not used [-Wunused-macros]
conftest.c:30:0: warning: macro "HAVE_SYS_RESOURCE_H" is not used [-Wunused-macros]
conftest.c:37:0: warning: macro "HAVE_STDDEF_H" is not used [-Wunused-macros]
conftest.c:4:0: warning: macro "PACKAGE_VERSION" is not used [-Wunused-macros]
conftest.c:2:0: warning: macro "PACKAGE_NAME" is not used [-Wunused-macros]
conftest.c:31:0: warning: macro "HAVE_SYS_TIME_H" is not used [-Wunused-macros]
conftest.c:8:0: warning: macro "PACKAGE" is not used [-Wunused-macros]
conftest.c:22:0: warning: macro "LT_OBJDIR" is not used [-Wunused-macros]
conftest.c:23:0: warning: macro "HAVE_LIBM" is not used [-Wunused-macros]
 #define HAVE_LIBM 1
conftest.c:21:0: warning: macro "HAVE_DLFCN_H" is not used [-Wunused-macros]
conftest.c:29:0: warning: macro "HAVE_CLOCK_GETTIME" is not used [-Wunused-macros]
conftest.c:39:0: warning: macro "HAVE_FEATURES_H" is not used [-Wunused-macros]
conftest.c:38:0: warning: macro "HAVE_SETJMP_H" is not used [-Wunused-macros]
conftest.c:10:0: warning: macro "CXX_HAVE_OFFSETOF" is not used [-Wunused-macros]
conftest.c:26:0: warning: macro "TIME_WITH_SYS_TIME" is not used [-Wunused-macros]
conftest.c:24:0: warning: macro "HAVE_LIBDL" is not used [-Wunused-macros]
conftest.c:9:0: warning: macro "VERSION" is not used [-Wunused-macros]
conftest.c:7:0: warning: macro "PACKAGE_URL" is not used [-Wunused-macros]
 #define PACKAGE_URL ""
configure:24491: $? = 0
configure:24491: ./conftest
configure:24505: result: 2
configure:24519: checking size of int_least16_t
configure:24524: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:105:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (int_least16_t)); }
conftest.c:105:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:106:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (int_least16_t)); }
conftest.c:106:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:118:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:118:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:70:0: warning: macro "SIZEOF_UINT16_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT16_T 2
 #define HAVE_LIBM 1
conftest.c:43:0: warning: macro "HAVE_LSEEK64" is not used [-Wunused-macros]
 #define HAVE_LSEEK64 1
conftest.c:44:0: warning: macro "HAVE_FSEEKO64" is not used [-Wunused-macros]
 #define HAVE_FSEEKO64 1
configure:24524: $? = 0
configure:24524: ./conftest
configure:24538: result: 2
configure:24552: checking size of uint_least16_t
configure:24557: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:106:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (uint_least16_t)); }
conftest.c:106:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:107:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (uint_least16_t)); }
conftest.c:107:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:119:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:119:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:45:0: warning: macro "HAVE_FTELLO64" is not used [-Wunused-macros]
 #define HAVE_FTELLO64 1
conftest.c:47:0: warning: macro "HAVE_FSEEKO" is not used [-Wunused-macros]
 #define HAVE_FSEEKO 1
conftest.c:71:0: warning: macro "SIZEOF_INT_LEAST16_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_LEAST16_T 2
conftest.c:46:0: warning: macro "HAVE_FTRUNCATE64" is not used [-Wunused-macros]
 #define HAVE_FTRUNCATE64 1
 #define HAVE_LIBM 1
configure:24557: $? = 0
configure:24557: ./conftest
configure:24571: result: 2
configure:24585: checking size of int_fast16_t
configure:24590: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:107:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (int_fast16_t)); }
conftest.c:107:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:108:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (int_fast16_t)); }
conftest.c:108:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:120:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:120:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:48:0: warning: macro "HAVE_FTELLO" is not used [-Wunused-macros]
 #define HAVE_FTELLO 1
 #define HAVE_LIBM 1
conftest.c:72:0: warning: macro "SIZEOF_UINT_LEAST16_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_LEAST16_T 2
configure:24590: $? = 0
configure:24590: ./conftest
configure:24604: result: 8
configure:24618: checking size of uint_fast16_t
configure:24623: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:108:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (uint_fast16_t)); }
conftest.c:108:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:109:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (uint_fast16_t)); }
conftest.c:109:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:121:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:121:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:49:0: warning: macro "HAVE_STAT64" is not used [-Wunused-macros]
 #define HAVE_STAT64 1
 #define HAVE_LIBM 1
conftest.c:73:0: warning: macro "SIZEOF_INT_FAST16_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_FAST16_T 8
configure:24623: $? = 0
configure:24623: ./conftest
configure:24637: result: 8
configure:24652: checking size of int32_t
configure:24657: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:109:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (int32_t)); }
conftest.c:109:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:110:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (int32_t)); }
conftest.c:110:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:122:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:122:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:50:0: warning: macro "HAVE_FSTAT64" is not used [-Wunused-macros]
 #define HAVE_FSTAT64 1
conftest.c:74:0: warning: macro "SIZEOF_UINT_FAST16_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_FAST16_T 8
 #define HAVE_LIBM 1
configure:24657: $? = 0
configure:24657: ./conftest
configure:24671: result: 4
configure:24685: checking size of uint32_t
configure:24690: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:110:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (uint32_t)); }
conftest.c:110:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:111:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (uint32_t)); }
conftest.c:111:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:123:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:123:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_LIBM 1
conftest.c:75:0: warning: macro "SIZEOF_INT32_T" is not used [-Wunused-macros]
 #define SIZEOF_INT32_T 4
configure:24690: $? = 0
configure:24690: ./conftest
configure:24704: result: 4
configure:24718: checking size of int_least32_t
configure:24723: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:111:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (int_least32_t)); }
conftest.c:111:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:112:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (int_least32_t)); }
conftest.c:112:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:124:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:124:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:76:0: warning: macro "SIZEOF_UINT32_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT32_T 4
 #define HAVE_LIBM 1
configure:24723: $? = 0
configure:24723: ./conftest
configure:24737: result: 4
configure:24751: checking size of uint_least32_t
configure:24756: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:112:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (uint_least32_t)); }
conftest.c:112:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:113:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (uint_least32_t)); }
conftest.c:113:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:125:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:125:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:77:0: warning: macro "SIZEOF_INT_LEAST32_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_LEAST32_T 4
 #define HAVE_LIBM 1
configure:24756: $? = 0
configure:24756: ./conftest
configure:24770: result: 4
configure:24784: checking size of int_fast32_t
configure:24789: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:113:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (int_fast32_t)); }
conftest.c:113:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:114:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (int_fast32_t)); }
conftest.c:114:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:126:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:126:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:78:0: warning: macro "SIZEOF_UINT_LEAST32_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_LEAST32_T 4
 #define HAVE_LIBM 1
configure:24789: $? = 0
configure:24789: ./conftest
configure:24803: result: 8
configure:24817: checking size of uint_fast32_t
configure:24822: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:114:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (uint_fast32_t)); }
conftest.c:114:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:115:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (uint_fast32_t)); }
conftest.c:115:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:127:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:127:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:79:0: warning: macro "SIZEOF_INT_FAST32_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_FAST32_T 8
 #define HAVE_LIBM 1
configure:24822: $? = 0
configure:24822: ./conftest
configure:24836: result: 8
configure:24851: checking size of int64_t
configure:24856: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:115:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (int64_t)); }
conftest.c: In function 'longval':
conftest.c:115:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:116:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (int64_t)); }
conftest.c: In function 'ulongval':
conftest.c:116:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:128:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:128:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:80:0: warning: macro "SIZEOF_UINT_FAST32_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_FAST32_T 8
conftest.c:51:0: warning: macro "SIZEOF_CHAR" is not used [-Wunused-macros]
 #define SIZEOF_CHAR 1
 #define HAVE_LIBM 1
configure:24856: $? = 0
configure:24856: ./conftest
configure:24870: result: 8
configure:24884: checking size of uint64_t
configure:24889: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:116:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (uint64_t)); }
conftest.c:116:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:117:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (uint64_t)); }
conftest.c:117:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:129:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:129:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:52:0: warning: macro "SIZEOF_SHORT" is not used [-Wunused-macros]
 #define SIZEOF_SHORT 2
conftest.c:81:0: warning: macro "SIZEOF_INT64_T" is not used [-Wunused-macros]
 #define SIZEOF_INT64_T 8
 #define HAVE_LIBM 1
configure:24889: $? = 0
configure:24889: ./conftest
configure:24903: result: 8
configure:24917: checking size of int_least64_t
configure:24922: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:117:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (int_least64_t)); }
conftest.c:117:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:118:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (int_least64_t)); }
conftest.c:118:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:130:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:130:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:53:0: warning: macro "SIZEOF_INT" is not used [-Wunused-macros]
 #define SIZEOF_INT 4
conftest.c:82:0: warning: macro "SIZEOF_UINT64_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT64_T 8
 #define HAVE_LIBM 1
configure:24922: $? = 0
configure:24922: ./conftest
configure:24936: result: 8
configure:24950: checking size of uint_least64_t
configure:24955: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:118:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (uint_least64_t)); }
conftest.c:118:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:119:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (uint_least64_t)); }
conftest.c:119:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:131:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:131:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:54:0: warning: macro "SIZEOF_UNSIGNED" is not used [-Wunused-macros]
 #define SIZEOF_UNSIGNED 4
 #define HAVE_LIBM 1
conftest.c:83:0: warning: macro "SIZEOF_INT_LEAST64_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_LEAST64_T 8
configure:24955: $? = 0
configure:24955: ./conftest
configure:24969: result: 8
configure:24983: checking size of int_fast64_t
configure:24988: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:119:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (int_fast64_t)); }
conftest.c:119:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:120:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (int_fast64_t)); }
conftest.c:120:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:132:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:132:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:55:0: warning: macro "SIZEOF_LONG" is not used [-Wunused-macros]
 #define SIZEOF_LONG 8
 #define HAVE_LIBM 1
conftest.c:84:0: warning: macro "SIZEOF_UINT_LEAST64_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_LEAST64_T 8
configure:24988: $? = 0
configure:24988: ./conftest
configure:25002: result: 8
configure:25016: checking size of uint_fast64_t
configure:25021: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:120:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (uint_fast64_t)); }
conftest.c:120:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:121:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (uint_fast64_t)); }
conftest.c:121:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:133:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:133:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:56:0: warning: macro "SIZEOF_LONG_LONG" is not used [-Wunused-macros]
 #define SIZEOF_LONG_LONG 8
conftest.c:85:0: warning: macro "SIZEOF_INT_FAST64_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_FAST64_T 8
 #define PACKAGE_STRING "HDF5 1.8.11"
 #define PACKAGE_TARNAME "hdf5"
 #define PACKAGE_BUGREPORT "help at hdfgroup.org"
 #define PACKAGE_VERSION "1.8.11"
 #define PACKAGE_NAME "HDF5"
 #define PACKAGE "hdf5"
 #define HAVE_LIBM 1
 #define VERSION "1.8.11"
configure:25021: $? = 0
configure:25021: ./conftest
configure:25035: result: 8
configure:25050: checking size of size_t
configure:25055: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:121:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (size_t)); }
conftest.c:121:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:122:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (size_t)); }
conftest.c:122:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:134:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:134:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:86:0: warning: macro "SIZEOF_UINT_FAST64_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_FAST64_T 8
 #define HAVE_LIBM 1
configure:25055: $? = 0
configure:25055: ./conftest
configure:25069: result: 8
configure:25083: checking size of ssize_t
configure:25088: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:122:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (ssize_t)); }
conftest.c:122:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:123:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (ssize_t)); }
conftest.c:123:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:135:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:135:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_LIBM 1
conftest.c:87:0: warning: macro "SIZEOF_SIZE_T" is not used [-Wunused-macros]
 #define SIZEOF_SIZE_T 8
conftest.c:57:0: warning: macro "SIZEOF___INT64" is not used [-Wunused-macros]
 #define SIZEOF___INT64 0
configure:25088: $? = 0
configure:25088: ./conftest
configure:25102: result: 8
configure:25116: checking size of ptrdiff_t
configure:25121: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:123:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (ptrdiff_t)); }
conftest.c:123:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:124:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (ptrdiff_t)); }
conftest.c:124:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:136:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:136:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:88:0: warning: macro "SIZEOF_SSIZE_T" is not used [-Wunused-macros]
 #define SIZEOF_SSIZE_T 8
conftest.c:58:0: warning: macro "SIZEOF_FLOAT" is not used [-Wunused-macros]
 #define SIZEOF_FLOAT 4
 #define HAVE_LIBM 1
configure:25121: $? = 0
configure:25121: ./conftest
configure:25135: result: 8
configure:25153: checking size of off_t
configure:25158: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:125:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (off_t)); }
conftest.c:125:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:126:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (off_t)); }
conftest.c:126:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:138:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:138:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:59:0: warning: macro "SIZEOF_DOUBLE" is not used [-Wunused-macros]
 #define SIZEOF_DOUBLE 8
 #define HAVE_LIBM 1
conftest.c:89:0: warning: macro "SIZEOF_PTRDIFF_T" is not used [-Wunused-macros]
 #define SIZEOF_PTRDIFF_T 8
 #define CXX_HAVE_OFFSETOF 1
configure:25158: $? = 0
configure:25158: ./conftest
configure:25172: result: 8
configure:25186: checking size of off64_t
configure:25191: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      conftest.c -ldl -lm  >&5
conftest.c:126:17: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static long int longval () { return (long int) (sizeof (off64_t)); }
conftest.c:126:17: warning: old-style function definition [-Wold-style-definition]
conftest.c:127:26: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static unsigned long int ulongval () { return (long int) (sizeof (off64_t)); }
conftest.c:127:26: warning: old-style function definition [-Wold-style-definition]
conftest.c:139:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:139:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:60:0: warning: macro "SIZEOF_LONG_DOUBLE" is not used [-Wunused-macros]
 #define SIZEOF_LONG_DOUBLE 16
 #define HAVE_STDLIB_H 1
conftest.c:91:0: warning: macro "SIZEOF_OFF_T" is not used [-Wunused-macros]
 #define SIZEOF_OFF_T 8
 #define HAVE_LIBM 1
configure:25191: $? = 0
configure:25191: ./conftest
configure:25205: result: 8
configure:25306: checking if dev_t is scalar
configure:25331: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 #define STDC_HEADERS 1
 #define HAVE_UNISTD_H 1
 #define HAVE_SYS_STAT_H 1
 #define HAVE_SYS_TYPES_H 1
 #define HAVE_STDINT_H 1
conftest.c:108:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:108:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:110:17: warning: 'd1' is used uninitialized in this function [-Wuninitialized]
 dev_t d1, d2; if(d1==d2) return 0;
conftest.c:110:17: warning: 'd2' is used uninitialized in this function [-Wuninitialized]
conftest.c:108:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
 main ()
conftest.c:15:0: warning: macro "HAVE_STRING_H" is not used [-Wunused-macros]
 #define HAVE_STRING_H 1
conftest.c:16:0: warning: macro "HAVE_MEMORY_H" is not used [-Wunused-macros]
 #define HAVE_MEMORY_H 1
conftest.c:41:0: warning: macro "HAVE_STDINT_H" is not used [-Wunused-macros]
conftest.c:18:0: warning: macro "HAVE_INTTYPES_H" is not used [-Wunused-macros]
 #define HAVE_INTTYPES_H 1
conftest.c:32:0: warning: macro "HAVE_UNISTD_H" is not used [-Wunused-macros]
conftest.c:17:0: warning: macro "HAVE_STRINGS_H" is not used [-Wunused-macros]
 #define HAVE_STRINGS_H 1
conftest.c:34:0: warning: macro "HAVE_SYS_STAT_H" is not used [-Wunused-macros]
conftest.c:25:0: warning: macro "STDC_HEADERS" is not used [-Wunused-macros]
 #define LT_OBJDIR ".libs/"
 #define HAVE_LIBM 1
conftest.c:92:0: warning: macro "SIZEOF_OFF64_T" is not used [-Wunused-macros]
 #define SIZEOF_OFF64_T 8
 #define HAVE_DLFCN_H 1
conftest.c:63:0: warning: macro "SIZEOF_INT8_T" is not used [-Wunused-macros]
 #define SIZEOF_INT8_T 1
configure:25331: $? = 0
configure:25335: result: yes
configure:25451: checking for dmalloc library
configure:25453: result: suppressed
configure:25719: checking zlib.h usability
configure:25719: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
conftest.c:64:0: warning: macro "SIZEOF_UINT8_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT8_T 1
conftest.c:93:0: warning: macro "DEV_T_IS_SCALAR" is not used [-Wunused-macros]
 #define DEV_T_IS_SCALAR 1
 #define HAVE_LIBM 1
configure:25719: $? = 0
configure:25719: result: yes
configure:25719: checking zlib.h presence
configure:25719: /usr/bin/mpicc -E -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c
configure:25719: checking for zlib.h
configure:25738: checking for compress2 in -lz
configure:25771: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so conftest.c -lz  -ldl -lm  >&5
conftest.c:103:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char compress2 ();
conftest.c:113:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:113:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:65:0: warning: macro "SIZEOF_INT_LEAST8_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_LEAST8_T 1
conftest.c:36:0: warning: macro "HAVE_SYS_TYPES_H" is not used [-Wunused-macros]
conftest.c:94:0: warning: macro "HAVE_ZLIB_H" is not used [-Wunused-macros]
 #define HAVE_ZLIB_H 1
 #define HAVE_LIBM 1
configure:25771: $? = 0
configure:25780: result: yes
configure:25800: checking for compress2
configure:25800: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so conftest.c -lz -ldl -lm  >&5
conftest.c:99:0: warning: macro "compress2" is not used [-Wunused-macros]
 #define compress2 innocuous_compress2
 char compress2 ();
conftest.c:137:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:137:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:66:0: warning: macro "SIZEOF_UINT_LEAST8_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_LEAST8_T 1
 #define HAVE_LIBM 1
conftest.c:95:0: warning: macro "HAVE_LIBZ" is not used [-Wunused-macros]
 #define HAVE_LIBZ 1
configure:25800: $? = 0
configure:25800: result: yes
configure:25919: checking for szlib
configure:25921: result: suppressed
configure:26362: checking pthread.h usability
configure:26362: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 #define HAVE_DIFFTIME 1
 #define HAVE_DIRENT_H 1
conftest.c:96:0: warning: macro "HAVE_FILTER_DEFLATE" is not used [-Wunused-macros]
 #define HAVE_FILTER_DEFLATE 1
 #define HAVE_GETTIMEOFDAY 1
 #define HAVE_SYS_SOCKET_H 1
 #define HAVE_SYS_IOCTL_H 1
 #define HAVE_SYS_RESOURCE_H 1
 #define HAVE_STDDEF_H 1
 #define HAVE_SYS_TIME_H 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
 #define HAVE_CLOCK_GETTIME 1
 #define HAVE_FEATURES_H 1
 #define HAVE_SETJMP_H 1
conftest.c:67:0: warning: macro "SIZEOF_INT_FAST8_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_FAST8_T 1
 #define TIME_WITH_SYS_TIME 1
 #define HAVE_LIBDL 1
configure:26362: $? = 0
configure:26362: result: yes
configure:26362: checking pthread.h presence
configure:26362: /usr/bin/mpicc -E -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c
configure:26362: checking for pthread.h
configure:26382: checking for pthread_self in -lpthread
configure:26415: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread  -lz -ldl -lm  >&5
conftest.c:106:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char pthread_self ();
conftest.c:116:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:116:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:97:0: warning: macro "HAVE_PTHREAD_H" is not used [-Wunused-macros]
 #define HAVE_PTHREAD_H 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:68:0: warning: macro "SIZEOF_UINT_FAST8_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_FAST8_T 1
configure:26415: $? = 0
configure:26424: result: yes
configure:26501: checking for thread safe support
configure:26528: result: no
configure:26578: checking whether CLOCK_MONOTONIC is declared
configure:26578: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
conftest.c:11:0: warning: macro "STDC_HEADERS" is not used [-Wunused-macros]
conftest.c:20:0: warning: macro "HAVE_UNISTD_H" is not used [-Wunused-macros]
conftest.c:13:0: warning: macro "HAVE_SYS_STAT_H" is not used [-Wunused-macros]
conftest.c:12:0: warning: macro "HAVE_SYS_TYPES_H" is not used [-Wunused-macros]
conftest.c:19:0: warning: macro "HAVE_STDINT_H" is not used [-Wunused-macros]
conftest.c:111:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c: In function 'main':
conftest.c:111:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:111:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
conftest.c: At top level:
conftest.c:27:0: warning: macro "HAVE_DIFFTIME" is not used [-Wunused-macros]
conftest.c:5:0: warning: macro "PACKAGE_STRING" is not used [-Wunused-macros]
conftest.c:98:0: warning: macro "HAVE_LIBPTHREAD" is not used [-Wunused-macros]
 #define HAVE_LIBPTHREAD 1
conftest.c:40:0: warning: macro "HAVE_DIRENT_H" is not used [-Wunused-macros]
conftest.c:3:0: warning: macro "PACKAGE_TARNAME" is not used [-Wunused-macros]
conftest.c:28:0: warning: macro "HAVE_GETTIMEOFDAY" is not used [-Wunused-macros]
conftest.c:14:0: warning: macro "HAVE_STDLIB_H" is not used [-Wunused-macros]
conftest.c:35:0: warning: macro "HAVE_SYS_SOCKET_H" is not used [-Wunused-macros]
conftest.c:42:0: warning: macro "HAVE_SYS_TIMEB_H" is not used [-Wunused-macros]
 #define HAVE_SYS_TIMEB_H 1
conftest.c:33:0: warning: macro "HAVE_SYS_IOCTL_H" is not used [-Wunused-macros]
conftest.c:69:0: warning: macro "SIZEOF_INT16_T" is not used [-Wunused-macros]
 #define SIZEOF_INT16_T 2
conftest.c:6:0: warning: macro "PACKAGE_BUGREPORT" is not used [-Wunused-macros]
conftest.c:30:0: warning: macro "HAVE_SYS_RESOURCE_H" is not used [-Wunused-macros]
conftest.c:37:0: warning: macro "HAVE_STDDEF_H" is not used [-Wunused-macros]
conftest.c:4:0: warning: macro "PACKAGE_VERSION" is not used [-Wunused-macros]
conftest.c:2:0: warning: macro "PACKAGE_NAME" is not used [-Wunused-macros]
conftest.c:31:0: warning: macro "HAVE_SYS_TIME_H" is not used [-Wunused-macros]
conftest.c:8:0: warning: macro "PACKAGE" is not used [-Wunused-macros]
conftest.c:22:0: warning: macro "LT_OBJDIR" is not used [-Wunused-macros]
conftest.c:23:0: warning: macro "HAVE_LIBM" is not used [-Wunused-macros]
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:21:0: warning: macro "HAVE_DLFCN_H" is not used [-Wunused-macros]
conftest.c:29:0: warning: macro "HAVE_CLOCK_GETTIME" is not used [-Wunused-macros]
conftest.c:39:0: warning: macro "HAVE_FEATURES_H" is not used [-Wunused-macros]
conftest.c:38:0: warning: macro "HAVE_SETJMP_H" is not used [-Wunused-macros]
conftest.c:10:0: warning: macro "CXX_HAVE_OFFSETOF" is not used [-Wunused-macros]
conftest.c:26:0: warning: macro "TIME_WITH_SYS_TIME" is not used [-Wunused-macros]
conftest.c:24:0: warning: macro "HAVE_LIBDL" is not used [-Wunused-macros]
conftest.c:9:0: warning: macro "VERSION" is not used [-Wunused-macros]
conftest.c:7:0: warning: macro "PACKAGE_URL" is not used [-Wunused-macros]
 #define PACKAGE_URL ""
configure:26578: $? = 0
configure:26578: result: yes
configure:26593: checking for tm_gmtoff in struct tm
configure:26616: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
conftest.c:112:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:112:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:114:11: warning: variable 'tm' set but not used [-Wunused-but-set-variable]
 struct tm tm; tm.tm_gmtoff=0;
conftest.c:112:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
 main ()
conftest.c:70:0: warning: macro "SIZEOF_UINT16_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT16_T 2
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:43:0: warning: macro "HAVE_LSEEK64" is not used [-Wunused-macros]
 #define HAVE_LSEEK64 1
conftest.c:44:0: warning: macro "HAVE_FSEEKO64" is not used [-Wunused-macros]
 #define HAVE_FSEEKO64 1
configure:26616: $? = 0
configure:26620: result: yes
configure:26629: checking for __tm_gmtoff in struct tm
configure:26652: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 main ()
conftest.c:115:17: error: 'struct tm' has no member named '__tm_gmtoff'
 struct tm tm; tm.__tm_gmtoff=0;
conftest.c:115:11: warning: variable 'tm' set but not used [-Wunused-but-set-variable]
conftest.c:45:0: warning: macro "HAVE_FTELLO64" is not used [-Wunused-macros]
 #define HAVE_FTELLO64 1
conftest.c:99:0: warning: macro "HAVE_TM_GMTOFF" is not used [-Wunused-macros]
 #define HAVE_TM_GMTOFF 1
conftest.c:47:0: warning: macro "HAVE_FSEEKO" is not used [-Wunused-macros]
 #define HAVE_FSEEKO 1
conftest.c:71:0: warning: macro "SIZEOF_INT_LEAST16_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_LEAST16_T 2
conftest.c:46:0: warning: macro "HAVE_FTRUNCATE64" is not used [-Wunused-macros]
 #define HAVE_FTRUNCATE64 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:26652: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <sys/types.h>
| #include <stdint.h>
| #include <sys/types.h> /*for off_t definition*/
| #define HAVE_LIBZ 1
| /* end confdefs.h.  */
|   #include <sys/time.h>
|   #include <time.h>
| #ifdef FC_DUMMY_MAIN
| #ifndef FC_DUMMY_MAIN_EQ_F77
| #  ifdef __cplusplus
|      extern "C"
| #  endif
|    int FC_DUMMY_MAIN() { return 1; }
| #endif
| #endif
| int
| main ()
|   return 0;
configure:26659: result: no
configure:26665: checking for global timezone variable
configure:26695: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
 main ()
conftest.c:115:1: error: 'timezone' undeclared (first use in this function)
 timezone=0;
conftest.c:115:1: note: each undeclared identifier is reported only once for each function it appears in
conftest.c:48:0: warning: macro "HAVE_FTELLO" is not used [-Wunused-macros]
 #define HAVE_FTELLO 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:72:0: warning: macro "SIZEOF_UINT_LEAST16_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_LEAST16_T 2
configure:26695: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdint.h>
| #define HAVE_LIBZ 1
|     #include <time.h>
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| timezone=0;
|   return 0;
configure:26702: result: no
configure:26711: checking whether struct tm is in sys/time.h or time.h
configure:26739: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 main ()
conftest.c:113:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:26739: $? = 0
configure:26746: result: time.h
configure:26754: checking for struct tm.tm_zone
configure:26754: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
conftest.c:114:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:114:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:114:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
conftest.c:49:0: warning: macro "HAVE_STAT64" is not used [-Wunused-macros]
 #define HAVE_STAT64 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:73:0: warning: macro "SIZEOF_INT_FAST16_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_FAST16_T 8
configure:26754: $? = 0
configure:26754: result: yes
configure:26829: checking for struct timezone
configure:26853: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 main ()
conftest.c:118:17: warning: variable 'tz' set but not used [-Wunused-but-set-variable]
 struct timezone tz; tz.tz_minuteswest=0;
conftest.c:116:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
 main ()
conftest.c:50:0: warning: macro "HAVE_FSTAT64" is not used [-Wunused-macros]
 #define HAVE_FSTAT64 1
conftest.c:101:0: warning: macro "HAVE_TM_ZONE" is not used [-Wunused-macros]
 #define HAVE_TM_ZONE 1
conftest.c:74:0: warning: macro "SIZEOF_UINT_FAST16_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_FAST16_T 8
conftest.c:100:0: warning: macro "HAVE_STRUCT_TM_TM_ZONE" is not used [-Wunused-macros]
 #define HAVE_STRUCT_TM_TM_ZONE 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:26853: $? = 0
configure:26858: result: yes
configure:26869: checking whether gettimeofday() gives timezone
configure:26898: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:116:17: warning: implicit declaration of function 'exit' [-Wimplicit-function-declaration]
                 exit(1);
conftest.c:116:17: warning: incompatible implicit declaration of built-in function 'exit' [enabled by default]
conftest.c:117:19: warning: incompatible implicit declaration of built-in function 'exit' [enabled by default]
              else exit (0);
conftest.c:102:0: warning: macro "HAVE_STRUCT_TIMEZONE" is not used [-Wunused-macros]
 #define HAVE_STRUCT_TIMEZONE 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:75:0: warning: macro "SIZEOF_INT32_T" is not used [-Wunused-macros]
 #define SIZEOF_INT32_T 4
configure:26898: $? = 0
configure:26898: ./conftest
configure:26911: result: yes
configure:26925: checking for st_blocks in struct stat
configure:26947: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 main ()
conftest.c:118:13: warning: variable 'sb' set but not used [-Wunused-but-set-variable]
 struct stat sb; sb.st_blocks=0;
 main ()
conftest.c:76:0: warning: macro "SIZEOF_UINT32_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT32_T 4
conftest.c:103:0: warning: macro "GETTIMEOFDAY_GIVES_TZ" is not used [-Wunused-macros]
 #define GETTIMEOFDAY_GIVES_TZ 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:26947: $? = 0
configure:26951: result: yes
configure:26965: checking for _getvideoconfig
configure:26965: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:108:0: warning: macro "_getvideoconfig" is not used [-Wunused-macros]
 #define _getvideoconfig innocuous__getvideoconfig
 char _getvideoconfig ();
conftest.c:146:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:146:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:77:0: warning: macro "SIZEOF_INT_LEAST32_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_LEAST32_T 4
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:104:0: warning: macro "HAVE_STAT_ST_BLOCKS" is not used [-Wunused-macros]
 #define HAVE_STAT_ST_BLOCKS 1
/tmp/ccD0D97l.o: In function `main':
conftest.c:(.text.startup+0x7): undefined reference to `_getvideoconfig'
collect2: error: ld returned 1 exit status
configure:26965: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdint.h>
| #define HAVE_LIBZ 1
| /* Define _getvideoconfig to an innocuous variant, in case <limits.h> declares _getvideoconfig.
|    For example, HP-UX 11i <limits.h> declares gettimeofday.  */
| /* System header to define __stub macros and hopefully few prototypes,
|     which can conflict with char _getvideoconfig (); below.
|     Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
|     <limits.h> exists even on freestanding compilers.  */
| #ifdef __STDC__
| # include <limits.h>
| #else
| # include <assert.h>
| #endif
| #undef _getvideoconfig
| /* Override any GCC internal prototype to avoid an error.
|    Use char because int might match the return type of a GCC
|    builtin and then its argument prototype would still apply.  */
| #ifdef __cplusplus
| extern "C"
| #endif
| /* The GNU C library defines this for functions which it implements
|     to always fail with ENOSYS.  Some functions are actually named
|     something starting with __ and the normal name is an alias.  */
| #if defined __stub__getvideoconfig || defined __stub____getvideoconfig
| choke me
| #endif
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| return _getvideoconfig ();
|   return 0;
configure:26965: result: no
configure:26965: checking for gettextinfo
conftest.c:108:0: warning: macro "gettextinfo" is not used [-Wunused-macros]
 #define gettextinfo innocuous_gettextinfo
 char gettextinfo ();
 main ()
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
/tmp/ccytUSJq.o: In function `main':
conftest.c:(.text.startup+0x7): undefined reference to `gettextinfo'
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdint.h>
| #define SIZEOF_UINT_LEAST32_T 4
| #define HAVE_LIBZ 1
| /* Define gettextinfo to an innocuous variant, in case <limits.h> declares gettextinfo.
|     which can conflict with char gettextinfo (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef gettextinfo
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_gettextinfo || defined __stub___gettextinfo
| choke me
| #endif
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| return gettextinfo ();
|   return 0;
configure:26965: checking for GetConsoleScreenBufferInfo
conftest.c:108:0: warning: macro "GetConsoleScreenBufferInfo" is not used [-Wunused-macros]
 #define GetConsoleScreenBufferInfo innocuous_GetConsoleScreenBufferInfo
 char GetConsoleScreenBufferInfo ();
 main ()
conftest.c:78:0: warning: macro "SIZEOF_UINT_LEAST32_T" is not used [-Wunused-macros]
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
/tmp/cc9rSsBs.o: In function `main':
conftest.c:(.text.startup+0x7): undefined reference to `GetConsoleScreenBufferInfo'
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdint.h>
| #define HAVE_LIBZ 1
| /* Define GetConsoleScreenBufferInfo to an innocuous variant, in case <limits.h> declares GetConsoleScreenBufferInfo.
|     which can conflict with char GetConsoleScreenBufferInfo (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef GetConsoleScreenBufferInfo
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_GetConsoleScreenBufferInfo || defined __stub___GetConsoleScreenBufferInfo
| choke me
| #endif
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| return GetConsoleScreenBufferInfo ();
|   return 0;
configure:26977: checking for _scrsize
configure:26977: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:108:0: warning: macro "_scrsize" is not used [-Wunused-macros]
 #define _scrsize innocuous__scrsize
 char _scrsize ();
 main ()
conftest.c:79:0: warning: macro "SIZEOF_INT_FAST32_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_FAST32_T 8
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
/tmp/ccL0zNTx.o: In function `main':
conftest.c:(.text.startup+0x7): undefined reference to `_scrsize'
configure:26977: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdint.h>
| #define HAVE_LIBZ 1
| /* Define _scrsize to an innocuous variant, in case <limits.h> declares _scrsize.
|     which can conflict with char _scrsize (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef _scrsize
| #ifdef __cplusplus
| extern "C"
| #endif
| char _scrsize ();
| #if defined __stub__scrsize || defined __stub____scrsize
| choke me
| #endif
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| return _scrsize ();
|   return 0;
configure:26977: result: no
configure:26977: checking for ioctl
conftest.c:108:0: warning: macro "ioctl" is not used [-Wunused-macros]
 #define ioctl innocuous_ioctl
 char ioctl ();
 main ()
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:26977: $? = 0
configure:26977: result: yes
configure:26987: checking for struct videoconfig
configure:27008: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
conftest.c:117:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:117:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:119:20: error: storage size of 'w' isn't known
 struct videoconfig w; w.numtextcols=0;
conftest.c:119:20: warning: unused variable 'w' [-Wunused-variable]
conftest.c:80:0: warning: macro "SIZEOF_UINT_FAST32_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_FAST32_T 8
conftest.c:51:0: warning: macro "SIZEOF_CHAR" is not used [-Wunused-macros]
 #define SIZEOF_CHAR 1
conftest.c:105:0: warning: macro "HAVE_IOCTL" is not used [-Wunused-macros]
 #define HAVE_IOCTL 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27008: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdint.h>
| #define HAVE_LIBZ 1
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
|   return 0;
configure:27015: result: no
configure:27020: checking for struct text_info
configure:27041: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 main ()
conftest.c:119:18: error: storage size of 'w' isn't known
 struct text_info w; w.screenwidth=0;
conftest.c:119:18: warning: unused variable 'w' [-Wunused-variable]
conftest.c:52:0: warning: macro "SIZEOF_SHORT" is not used [-Wunused-macros]
 #define SIZEOF_SHORT 2
conftest.c:81:0: warning: macro "SIZEOF_INT64_T" is not used [-Wunused-macros]
 #define SIZEOF_INT64_T 8
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27041: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdint.h>
| #define HAVE_LIBZ 1
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
|   return 0;
configure:27048: result: no
configure:27053: checking for TIOCGWINSZ
configure:27074: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 main ()
conftest.c:119:5: warning: unused variable 'w' [-Wunused-variable]
 int w=TIOCGWINSZ;
conftest.c:117:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
 main ()
conftest.c:53:0: warning: macro "SIZEOF_INT" is not used [-Wunused-macros]
 #define SIZEOF_INT 4
conftest.c:82:0: warning: macro "SIZEOF_UINT64_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT64_T 8
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27074: $? = 0
configure:27078: result: yes
configure:27086: checking for TIOCGETD
configure:27107: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
conftest.c:118:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:118:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:120:5: warning: unused variable 'w' [-Wunused-variable]
 int w=TIOCGETD;
conftest.c:118:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
 main ()
conftest.c:106:0: warning: macro "HAVE_TIOCGWINSZ" is not used [-Wunused-macros]
 #define HAVE_TIOCGWINSZ 1
conftest.c:54:0: warning: macro "SIZEOF_UNSIGNED" is not used [-Wunused-macros]
 #define SIZEOF_UNSIGNED 4
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:83:0: warning: macro "SIZEOF_INT_LEAST64_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_LEAST64_T 8
configure:27107: $? = 0
configure:27111: result: yes
configure:27126: checking for alarm
configure:27126: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:111:0: warning: macro "alarm" is not used [-Wunused-macros]
 #define alarm innocuous_alarm
conftest.c:132:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char alarm ();
conftest.c:149:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:149:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:107:0: warning: macro "HAVE_TIOCGETD" is not used [-Wunused-macros]
 #define HAVE_TIOCGETD 1
conftest.c:55:0: warning: macro "SIZEOF_LONG" is not used [-Wunused-macros]
 #define SIZEOF_LONG 8
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:84:0: warning: macro "SIZEOF_UINT_LEAST64_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_LEAST64_T 8
configure:27126: $? = 0
configure:27126: result: yes
configure:27126: checking for BSDgettimeofday
conftest.c:112:0: warning: macro "BSDgettimeofday" is not used [-Wunused-macros]
 #define BSDgettimeofday innocuous_BSDgettimeofday
 char BSDgettimeofday ();
conftest.c:150:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:150:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:108:0: warning: macro "HAVE_ALARM" is not used [-Wunused-macros]
 #define HAVE_ALARM 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
/tmp/ccY05s1U.o: In function `main':
conftest.c:(.text.startup+0x7): undefined reference to `BSDgettimeofday'
configure:27126: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdint.h>
| #define HAVE_LIBZ 1
| /* Define BSDgettimeofday to an innocuous variant, in case <limits.h> declares BSDgettimeofday.
|     which can conflict with char BSDgettimeofday (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef BSDgettimeofday
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_BSDgettimeofday || defined __stub___BSDgettimeofday
| choke me
| #endif
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| return BSDgettimeofday ();
|   return 0;
configure:27126: result: no
configure:27126: checking for fork
conftest.c:112:0: warning: macro "fork" is not used [-Wunused-macros]
 #define fork innocuous_fork
conftest.c:133:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char fork ();
 main ()
conftest.c:56:0: warning: macro "SIZEOF_LONG_LONG" is not used [-Wunused-macros]
 #define SIZEOF_LONG_LONG 8
conftest.c:85:0: warning: macro "SIZEOF_INT_FAST64_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_FAST64_T 8
 #define PACKAGE_STRING "HDF5 1.8.11"
 #define PACKAGE_TARNAME "hdf5"
 #define PACKAGE_BUGREPORT "help at hdfgroup.org"
 #define PACKAGE_VERSION "1.8.11"
 #define PACKAGE_NAME "HDF5"
 #define PACKAGE "hdf5"
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
 #define VERSION "1.8.11"
configure:27126: checking for frexpf
conftest.c:113:0: warning: macro "frexpf" is not used [-Wunused-macros]
 #define frexpf innocuous_frexpf
 char frexpf ();
conftest.c:134:6: warning: conflicting types for built-in function 'frexpf' [enabled by default]
 char frexpf ();
conftest.c:151:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:151:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:109:0: warning: macro "HAVE_FORK" is not used [-Wunused-macros]
 #define HAVE_FORK 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27126: checking for frexpl
conftest.c:114:0: warning: macro "frexpl" is not used [-Wunused-macros]
 #define frexpl innocuous_frexpl
 char frexpl ();
conftest.c:135:6: warning: conflicting types for built-in function 'frexpl' [enabled by default]
 char frexpl ();
conftest.c:152:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:152:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:110:0: warning: macro "HAVE_FREXPF" is not used [-Wunused-macros]
 #define HAVE_FREXPF 1
 #define HAVE_FORK 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27138: checking for gethostname
configure:27138: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:115:0: warning: macro "gethostname" is not used [-Wunused-macros]
 #define gethostname innocuous_gethostname
 char gethostname ();
conftest.c:153:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:153:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_FORK 1
conftest.c:111:0: warning: macro "HAVE_FREXPL" is not used [-Wunused-macros]
 #define HAVE_FREXPL 1
conftest.c:86:0: warning: macro "SIZEOF_UINT_FAST64_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_FAST64_T 8
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27138: $? = 0
configure:27138: result: yes
configure:27138: checking for getpwuid
conftest.c:116:0: warning: macro "getpwuid" is not used [-Wunused-macros]
 #define getpwuid innocuous_getpwuid
 char getpwuid ();
conftest.c:154:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:154:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:112:0: warning: macro "HAVE_GETHOSTNAME" is not used [-Wunused-macros]
 #define HAVE_GETHOSTNAME 1
 #define HAVE_FORK 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27138: checking for getrusage
conftest.c:117:0: warning: macro "getrusage" is not used [-Wunused-macros]
 #define getrusage innocuous_getrusage
 char getrusage ();
conftest.c:155:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:155:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:113:0: warning: macro "HAVE_GETPWUID" is not used [-Wunused-macros]
 #define HAVE_GETPWUID 1
 #define HAVE_FORK 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:87:0: warning: macro "SIZEOF_SIZE_T" is not used [-Wunused-macros]
 #define SIZEOF_SIZE_T 8
conftest.c:57:0: warning: macro "SIZEOF___INT64" is not used [-Wunused-macros]
 #define SIZEOF___INT64 0
configure:27138: checking for lstat
conftest.c:118:0: warning: macro "lstat" is not used [-Wunused-macros]
 #define lstat innocuous_lstat
 char lstat ();
conftest.c:156:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:156:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_FORK 1
conftest.c:114:0: warning: macro "HAVE_GETRUSAGE" is not used [-Wunused-macros]
 #define HAVE_GETRUSAGE 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27150: checking for rand_r
configure:27150: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:119:0: warning: macro "rand_r" is not used [-Wunused-macros]
 #define rand_r innocuous_rand_r
conftest.c:140:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char rand_r ();
conftest.c:157:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:157:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:88:0: warning: macro "SIZEOF_SSIZE_T" is not used [-Wunused-macros]
 #define SIZEOF_SSIZE_T 8
 #define HAVE_FORK 1
conftest.c:115:0: warning: macro "HAVE_LSTAT" is not used [-Wunused-macros]
 #define HAVE_LSTAT 1
conftest.c:58:0: warning: macro "SIZEOF_FLOAT" is not used [-Wunused-macros]
 #define SIZEOF_FLOAT 4
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27150: $? = 0
configure:27150: result: yes
configure:27150: checking for random
conftest.c:120:0: warning: macro "random" is not used [-Wunused-macros]
 #define random innocuous_random
conftest.c:141:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char random ();
conftest.c:158:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:158:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_FORK 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:116:0: warning: macro "HAVE_RAND_R" is not used [-Wunused-macros]
 #define HAVE_RAND_R 1
configure:27150: checking for setsysinfo
conftest.c:121:0: warning: macro "setsysinfo" is not used [-Wunused-macros]
 #define setsysinfo innocuous_setsysinfo
conftest.c:142:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char setsysinfo ();
conftest.c:159:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:159:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_FORK 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:117:0: warning: macro "HAVE_RANDOM" is not used [-Wunused-macros]
 #define HAVE_RANDOM 1
/tmp/ccEPixXG.o: In function `main':
conftest.c:(.text.startup+0x7): undefined reference to `setsysinfo'
configure:27150: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdint.h>
| #define HAVE_LIBZ 1
| #define HAVE_FORK 1
| /* Define setsysinfo to an innocuous variant, in case <limits.h> declares setsysinfo.
|     which can conflict with char setsysinfo (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef setsysinfo
| #ifdef __cplusplus
| extern "C"
| #endif
| char setsysinfo ();
| #if defined __stub_setsysinfo || defined __stub___setsysinfo
| choke me
| #endif
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| return setsysinfo ();
|   return 0;
configure:27150: result: no
configure:27162: checking for signal
configure:27162: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:121:0: warning: macro "signal" is not used [-Wunused-macros]
 #define signal innocuous_signal
 char signal ();
 main ()
 #define HAVE_FORK 1
conftest.c:59:0: warning: macro "SIZEOF_DOUBLE" is not used [-Wunused-macros]
 #define SIZEOF_DOUBLE 8
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:89:0: warning: macro "SIZEOF_PTRDIFF_T" is not used [-Wunused-macros]
 #define SIZEOF_PTRDIFF_T 8
 #define CXX_HAVE_OFFSETOF 1
configure:27162: $? = 0
configure:27162: result: yes
configure:27162: checking for longjmp
conftest.c:122:0: warning: macro "longjmp" is not used [-Wunused-macros]
 #define longjmp innocuous_longjmp
conftest.c:143:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char longjmp ();
conftest.c:160:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:160:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:60:0: warning: macro "SIZEOF_LONG_DOUBLE" is not used [-Wunused-macros]
 #define SIZEOF_LONG_DOUBLE 16
 #define HAVE_STDLIB_H 1
 #define HAVE_FORK 1
conftest.c:118:0: warning: macro "HAVE_SIGNAL" is not used [-Wunused-macros]
 #define HAVE_SIGNAL 1
conftest.c:91:0: warning: macro "SIZEOF_OFF_T" is not used [-Wunused-macros]
 #define SIZEOF_OFF_T 8
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27162: checking for setjmp
conftest.c:123:0: warning: macro "setjmp" is not used [-Wunused-macros]
 #define setjmp innocuous_setjmp
conftest.c:144:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char setjmp ();
conftest.c:161:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:161:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_FORK 1
conftest.c:119:0: warning: macro "HAVE_LONGJMP" is not used [-Wunused-macros]
 #define HAVE_LONGJMP 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27162: checking for siglongjmp
 #define STDC_HEADERS 1
 #define HAVE_UNISTD_H 1
 #define HAVE_SYS_STAT_H 1
 #define HAVE_SYS_TYPES_H 1
 #define HAVE_STDINT_H 1
conftest.c:124:0: warning: macro "siglongjmp" is not used [-Wunused-macros]
 #define siglongjmp innocuous_siglongjmp
conftest.c:145:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char siglongjmp ();
conftest.c:162:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:162:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_FORK 1
conftest.c:120:0: warning: macro "HAVE_SETJMP" is not used [-Wunused-macros]
 #define HAVE_SETJMP 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27162: checking for sigsetjmp
conftest.c:125:0: warning: macro "sigsetjmp" is not used [-Wunused-macros]
 #define sigsetjmp innocuous_sigsetjmp
 char sigsetjmp ();
conftest.c:163:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:163:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:15:0: warning: macro "HAVE_STRING_H" is not used [-Wunused-macros]
 #define HAVE_STRING_H 1
conftest.c:16:0: warning: macro "HAVE_MEMORY_H" is not used [-Wunused-macros]
 #define HAVE_MEMORY_H 1
conftest.c:41:0: warning: macro "HAVE_STDINT_H" is not used [-Wunused-macros]
conftest.c:18:0: warning: macro "HAVE_INTTYPES_H" is not used [-Wunused-macros]
 #define HAVE_INTTYPES_H 1
 #define HAVE_FORK 1
conftest.c:32:0: warning: macro "HAVE_UNISTD_H" is not used [-Wunused-macros]
conftest.c:17:0: warning: macro "HAVE_STRINGS_H" is not used [-Wunused-macros]
 #define HAVE_STRINGS_H 1
conftest.c:34:0: warning: macro "HAVE_SYS_STAT_H" is not used [-Wunused-macros]
conftest.c:25:0: warning: macro "STDC_HEADERS" is not used [-Wunused-macros]
 #define LT_OBJDIR ".libs/"
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:92:0: warning: macro "SIZEOF_OFF64_T" is not used [-Wunused-macros]
 #define SIZEOF_OFF64_T 8
 #define HAVE_DLFCN_H 1
conftest.c:63:0: warning: macro "SIZEOF_INT8_T" is not used [-Wunused-macros]
 #define SIZEOF_INT8_T 1
conftest.c:121:0: warning: macro "HAVE_SIGLONGJMP" is not used [-Wunused-macros]
 #define HAVE_SIGLONGJMP 1
/tmp/ccD6CX75.o: In function `main':
conftest.c:(.text.startup+0x7): undefined reference to `sigsetjmp'
configure:27162: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdint.h>
| #define HAVE_LIBZ 1
| #define HAVE_FORK 1
| /* Define sigsetjmp to an innocuous variant, in case <limits.h> declares sigsetjmp.
|     which can conflict with char sigsetjmp (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef sigsetjmp
| #ifdef __cplusplus
| extern "C"
| #endif
| char sigsetjmp ();
| #if defined __stub_sigsetjmp || defined __stub___sigsetjmp
| choke me
| #endif
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| #endif
| int
| main ()
| return sigsetjmp ();
|   return 0;
configure:27162: result: no
configure:27162: checking for sigprocmask
conftest.c:125:0: warning: macro "sigprocmask" is not used [-Wunused-macros]
 #define sigprocmask innocuous_sigprocmask
 char sigprocmask ();
 main ()
conftest.c:64:0: warning: macro "SIZEOF_UINT8_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT8_T 1
conftest.c:93:0: warning: macro "DEV_T_IS_SCALAR" is not used [-Wunused-macros]
 #define DEV_T_IS_SCALAR 1
 #define HAVE_FORK 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27174: checking for snprintf
configure:27174: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:126:0: warning: macro "snprintf" is not used [-Wunused-macros]
 #define snprintf innocuous_snprintf
conftest.c:147:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char snprintf ();
conftest.c:147:6: warning: conflicting types for built-in function 'snprintf' [enabled by default]
 char snprintf ();
conftest.c:164:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:164:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:65:0: warning: macro "SIZEOF_INT_LEAST8_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_LEAST8_T 1
conftest.c:122:0: warning: macro "HAVE_SIGPROCMASK" is not used [-Wunused-macros]
 #define HAVE_SIGPROCMASK 1
conftest.c:36:0: warning: macro "HAVE_SYS_TYPES_H" is not used [-Wunused-macros]
 #define HAVE_FORK 1
conftest.c:94:0: warning: macro "HAVE_ZLIB_H" is not used [-Wunused-macros]
 #define HAVE_ZLIB_H 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27174: $? = 0
configure:27174: result: yes
configure:27174: checking for srandom
conftest.c:127:0: warning: macro "srandom" is not used [-Wunused-macros]
 #define srandom innocuous_srandom
conftest.c:148:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 char srandom ();
conftest.c:165:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:165:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_FORK 1
conftest.c:123:0: warning: macro "HAVE_SNPRINTF" is not used [-Wunused-macros]
 #define HAVE_SNPRINTF 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27174: checking for strdup
conftest.c:128:0: warning: macro "strdup" is not used [-Wunused-macros]
 #define strdup innocuous_strdup
 char strdup ();
conftest.c:166:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:166:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:124:0: warning: macro "HAVE_SRANDOM" is not used [-Wunused-macros]
 #define HAVE_SRANDOM 1
 #define HAVE_FORK 1
conftest.c:66:0: warning: macro "SIZEOF_UINT_LEAST8_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_LEAST8_T 1
 #define HAVE_LIBM 1
conftest.c:95:0: warning: macro "HAVE_LIBZ" is not used [-Wunused-macros]
 #define HAVE_LIBZ 1
configure:27174: checking for symlink
conftest.c:129:0: warning: macro "symlink" is not used [-Wunused-macros]
 #define symlink innocuous_symlink
 char symlink ();
conftest.c:167:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:167:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_FORK 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:125:0: warning: macro "HAVE_STRDUP" is not used [-Wunused-macros]
 #define HAVE_STRDUP 1
configure:27174: checking for system
conftest.c:130:0: warning: macro "system" is not used [-Wunused-macros]
 #define system innocuous_system
 char system ();
conftest.c:168:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:168:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_FORK 1
conftest.c:126:0: warning: macro "HAVE_SYMLINK" is not used [-Wunused-macros]
 #define HAVE_SYMLINK 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27186: checking for tmpfile
configure:27186: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:131:0: warning: macro "tmpfile" is not used [-Wunused-macros]
 #define tmpfile innocuous_tmpfile
 char tmpfile ();
conftest.c:169:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:169:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_DIFFTIME 1
conftest.c:127:0: warning: macro "HAVE_SYSTEM" is not used [-Wunused-macros]
 #define HAVE_SYSTEM 1
 #define HAVE_DIRENT_H 1
conftest.c:96:0: warning: macro "HAVE_FILTER_DEFLATE" is not used [-Wunused-macros]
 #define HAVE_FILTER_DEFLATE 1
 #define HAVE_GETTIMEOFDAY 1
 #define HAVE_FORK 1
 #define HAVE_SYS_SOCKET_H 1
 #define HAVE_SYS_IOCTL_H 1
 #define HAVE_SYS_RESOURCE_H 1
 #define HAVE_STDDEF_H 1
 #define HAVE_SYS_TIME_H 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
 #define HAVE_CLOCK_GETTIME 1
 #define HAVE_FEATURES_H 1
 #define HAVE_SETJMP_H 1
conftest.c:67:0: warning: macro "SIZEOF_INT_FAST8_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_FAST8_T 1
 #define TIME_WITH_SYS_TIME 1
 #define HAVE_LIBDL 1
configure:27186: $? = 0
configure:27186: result: yes
configure:27186: checking for vasprintf
conftest.c:132:0: warning: macro "vasprintf" is not used [-Wunused-macros]
 #define vasprintf innocuous_vasprintf
 char vasprintf ();
conftest.c:170:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:170:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_FORK 1
conftest.c:128:0: warning: macro "HAVE_TMPFILE" is not used [-Wunused-macros]
 #define HAVE_TMPFILE 1
conftest.c:97:0: warning: macro "HAVE_PTHREAD_H" is not used [-Wunused-macros]
 #define HAVE_PTHREAD_H 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:68:0: warning: macro "SIZEOF_UINT_FAST8_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_FAST8_T 1
configure:27186: checking for waitpid
conftest.c:133:0: warning: macro "waitpid" is not used [-Wunused-macros]
 #define waitpid innocuous_waitpid
 char waitpid ();
conftest.c:171:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:171:1: warning: old-style function definition [-Wold-style-definition]
 #define HAVE_FORK 1
conftest.c:129:0: warning: macro "HAVE_VASPRINTF" is not used [-Wunused-macros]
 #define HAVE_VASPRINTF 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27201: checking for vsnprintf
configure:27201: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:11:0: warning: macro "STDC_HEADERS" is not used [-Wunused-macros]
conftest.c:20:0: warning: macro "HAVE_UNISTD_H" is not used [-Wunused-macros]
conftest.c:13:0: warning: macro "HAVE_SYS_STAT_H" is not used [-Wunused-macros]
conftest.c:12:0: warning: macro "HAVE_SYS_TYPES_H" is not used [-Wunused-macros]
conftest.c:19:0: warning: macro "HAVE_STDINT_H" is not used [-Wunused-macros]
conftest.c:134:0: warning: macro "vsnprintf" is not used [-Wunused-macros]
 #define vsnprintf innocuous_vsnprintf
 char vsnprintf ();
conftest.c:155:6: warning: conflicting types for built-in function 'vsnprintf' [enabled by default]
 char vsnprintf ();
conftest.c:172:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c: In function 'main':
conftest.c:172:1: warning: old-style function definition [-Wold-style-definition]
conftest.c: At top level:
conftest.c:27:0: warning: macro "HAVE_DIFFTIME" is not used [-Wunused-macros]
conftest.c:5:0: warning: macro "PACKAGE_STRING" is not used [-Wunused-macros]
conftest.c:98:0: warning: macro "HAVE_LIBPTHREAD" is not used [-Wunused-macros]
 #define HAVE_LIBPTHREAD 1
conftest.c:40:0: warning: macro "HAVE_DIRENT_H" is not used [-Wunused-macros]
conftest.c:3:0: warning: macro "PACKAGE_TARNAME" is not used [-Wunused-macros]
conftest.c:28:0: warning: macro "HAVE_GETTIMEOFDAY" is not used [-Wunused-macros]
conftest.c:14:0: warning: macro "HAVE_STDLIB_H" is not used [-Wunused-macros]
 #define HAVE_FORK 1
conftest.c:35:0: warning: macro "HAVE_SYS_SOCKET_H" is not used [-Wunused-macros]
conftest.c:42:0: warning: macro "HAVE_SYS_TIMEB_H" is not used [-Wunused-macros]
 #define HAVE_SYS_TIMEB_H 1
conftest.c:33:0: warning: macro "HAVE_SYS_IOCTL_H" is not used [-Wunused-macros]
conftest.c:69:0: warning: macro "SIZEOF_INT16_T" is not used [-Wunused-macros]
 #define SIZEOF_INT16_T 2
conftest.c:6:0: warning: macro "PACKAGE_BUGREPORT" is not used [-Wunused-macros]
conftest.c:30:0: warning: macro "HAVE_SYS_RESOURCE_H" is not used [-Wunused-macros]
conftest.c:37:0: warning: macro "HAVE_STDDEF_H" is not used [-Wunused-macros]
conftest.c:130:0: warning: macro "HAVE_WAITPID" is not used [-Wunused-macros]
 #define HAVE_WAITPID 1
conftest.c:4:0: warning: macro "PACKAGE_VERSION" is not used [-Wunused-macros]
conftest.c:2:0: warning: macro "PACKAGE_NAME" is not used [-Wunused-macros]
conftest.c:31:0: warning: macro "HAVE_SYS_TIME_H" is not used [-Wunused-macros]
conftest.c:8:0: warning: macro "PACKAGE" is not used [-Wunused-macros]
conftest.c:22:0: warning: macro "LT_OBJDIR" is not used [-Wunused-macros]
conftest.c:23:0: warning: macro "HAVE_LIBM" is not used [-Wunused-macros]
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:21:0: warning: macro "HAVE_DLFCN_H" is not used [-Wunused-macros]
conftest.c:29:0: warning: macro "HAVE_CLOCK_GETTIME" is not used [-Wunused-macros]
conftest.c:39:0: warning: macro "HAVE_FEATURES_H" is not used [-Wunused-macros]
conftest.c:38:0: warning: macro "HAVE_SETJMP_H" is not used [-Wunused-macros]
conftest.c:10:0: warning: macro "CXX_HAVE_OFFSETOF" is not used [-Wunused-macros]
conftest.c:26:0: warning: macro "TIME_WITH_SYS_TIME" is not used [-Wunused-macros]
conftest.c:24:0: warning: macro "HAVE_LIBDL" is not used [-Wunused-macros]
conftest.c:9:0: warning: macro "VERSION" is not used [-Wunused-macros]
conftest.c:7:0: warning: macro "PACKAGE_URL" is not used [-Wunused-macros]
 #define PACKAGE_URL ""
configure:27201: $? = 0
configure:27201: result: yes
configure:27217: checking if vsnprintf returns correct value
configure:27255: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:138:5: warning: no previous prototype for 'test_vsnprintf' [-Wmissing-prototypes]
 int test_vsnprintf(const char *fmt,...)
conftest.c: In function 'test_vsnprintf':
conftest.c:141:15: warning: request for implicit conversion from 'void *' to 'char *' not permitted in C++ [-Wc++-compat]
     char *s = malloc(16);
conftest.c:145:5: warning: function might be possible candidate for 'gnu_printf' format attribute [-Wsuggest-attribute=format]
     ret=vsnprintf(s,16,"%s",ap);
 #define HAVE_FORK 1
conftest.c:70:0: warning: macro "SIZEOF_UINT16_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT16_T 2
conftest.c:131:0: warning: macro "HAVE_VSNPRINTF" is not used [-Wunused-macros]
 #define HAVE_VSNPRINTF 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:43:0: warning: macro "HAVE_LSEEK64" is not used [-Wunused-macros]
 #define HAVE_LSEEK64 1
conftest.c:44:0: warning: macro "HAVE_FSEEKO64" is not used [-Wunused-macros]
 #define HAVE_FSEEKO64 1
configure:27255: $? = 0
configure:27255: ./conftest
configure:27268: result: yes
configure:27287: checking if lone colon can be used as an argument
configure:27309: result: yes
configure:27317: checking for an ANSI C-conforming const
configure:27391: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 main ()
conftest.c:144:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:165:9: warning: cast discards '__attribute__((const))' qualifier from pointer target type [-Wcast-qual]
   ppc = (char**) pcpcc;
conftest.c:144:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
 main ()
conftest.c:132:0: warning: macro "VSNPRINTF_WORKS" is not used [-Wunused-macros]
 #define VSNPRINTF_WORKS 1
conftest.c:45:0: warning: macro "HAVE_FTELLO64" is not used [-Wunused-macros]
 #define HAVE_FTELLO64 1
conftest.c:99:0: warning: macro "HAVE_TM_GMTOFF" is not used [-Wunused-macros]
 #define HAVE_TM_GMTOFF 1
 #define HAVE_FORK 1
conftest.c:47:0: warning: macro "HAVE_FSEEKO" is not used [-Wunused-macros]
 #define HAVE_FSEEKO 1
conftest.c:71:0: warning: macro "SIZEOF_INT_LEAST16_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_LEAST16_T 2
conftest.c:46:0: warning: macro "HAVE_FTRUNCATE64" is not used [-Wunused-macros]
 #define HAVE_FTRUNCATE64 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27391: $? = 0
configure:27398: result: yes
configure:27406: checking for inline
configure:27422: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
conftest.c:136:21: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 static inline foo_t static_foo () {return 0; }
conftest.c: In function 'static_foo':
conftest.c:136:21: warning: old-style function definition [-Wold-style-definition]
conftest.c:137:14: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 inline foo_t foo () {return 0; }
conftest.c: In function 'foo':
conftest.c:137:14: warning: old-style function definition [-Wold-style-definition]
conftest.c:48:0: warning: macro "HAVE_FTELLO" is not used [-Wunused-macros]
 #define HAVE_FTELLO 1
 #define HAVE_FORK 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:72:0: warning: macro "SIZEOF_UINT_LEAST16_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_LEAST16_T 2
configure:27422: $? = 0
configure:27430: result: inline
configure:27449: checking for __attribute__ extension
configure:27470: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 main ()
 #define HAVE_FORK 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27470: $? = 0
configure:27474: result: yes
configure:27482: checking for __func__ extension
configure:27503: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 main ()
conftest.c:145:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:147:14: warning: unused variable 'fname' [-Wunused-variable]
  const char *fname = __func__;
conftest.c:145:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
 main ()
conftest.c:133:0: warning: macro "HAVE_ATTRIBUTE" is not used [-Wunused-macros]
 #define HAVE_ATTRIBUTE 1
conftest.c:49:0: warning: macro "HAVE_STAT64" is not used [-Wunused-macros]
 #define HAVE_STAT64 1
 #define HAVE_FORK 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:73:0: warning: macro "SIZEOF_INT_FAST16_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_FAST16_T 8
configure:27503: $? = 0
configure:27507: result: yes
configure:27514: checking for __FUNCTION__ extension
configure:27535: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 main ()
conftest.c:148:14: warning: unused variable 'fname' [-Wunused-variable]
  const char *fname = __FUNCTION__;
conftest.c:146:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
 main ()
conftest.c:50:0: warning: macro "HAVE_FSTAT64" is not used [-Wunused-macros]
 #define HAVE_FSTAT64 1
 #define HAVE_FORK 1
conftest.c:101:0: warning: macro "HAVE_TM_ZONE" is not used [-Wunused-macros]
 #define HAVE_TM_ZONE 1
conftest.c:74:0: warning: macro "SIZEOF_UINT_FAST16_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_FAST16_T 8
conftest.c:100:0: warning: macro "HAVE_STRUCT_TM_TM_ZONE" is not used [-Wunused-macros]
 #define HAVE_STRUCT_TM_TM_ZONE 1
conftest.c:134:0: warning: macro "HAVE_C99_FUNC" is not used [-Wunused-macros]
 #define HAVE_C99_FUNC 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27535: $? = 0
configure:27539: result: yes
configure:27546: checking for C99 designated initialization support
configure:27575: /usr/bin/mpicc -c -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE    conftest.c >&5
 main ()
conftest.c:147:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:157:17: warning: unsuffixed float constant [-Wunsuffixed-float-constants]
                 di_struct_t x = {0, { .d = 0.0}};
conftest.c:157:29: warning: unused variable 'x' [-Wunused-variable]
conftest.c:147:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
 main ()
conftest.c:102:0: warning: macro "HAVE_STRUCT_TIMEZONE" is not used [-Wunused-macros]
 #define HAVE_STRUCT_TIMEZONE 1
 #define HAVE_FORK 1
conftest.c:135:0: warning: macro "HAVE_FUNCTION" is not used [-Wunused-macros]
 #define HAVE_FUNCTION 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:75:0: warning: macro "SIZEOF_INT32_T" is not used [-Wunused-macros]
 #define SIZEOF_INT32_T 4
configure:27575: $? = 0
configure:27579: result: yes
configure:27595: checking how to print long long
configure:27624: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:145:12: warning: request for implicit conversion from 'void *' to 'char *' not permitted in C++ [-Wc++-compat]
  char *s = malloc(128);
conftest.c:147:2: warning: format '%ld' expects argument of type 'long int', but argument 3 has type 'long long int' [-Wformat=]
  sprintf(s,"%ld",x);
conftest.c:76:0: warning: macro "SIZEOF_UINT32_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT32_T 4
conftest.c:136:0: warning: macro "HAVE_C99_DESIGNATED_INITIALIZER" is not used [-Wunused-macros]
 #define HAVE_C99_DESIGNATED_INITIALIZER 1
 #define HAVE_FORK 1
conftest.c:77:0: warning: macro "SIZEOF_INT_LEAST32_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_LEAST32_T 4
conftest.c:103:0: warning: macro "GETTIMEOFDAY_GIVES_TZ" is not used [-Wunused-macros]
 #define GETTIMEOFDAY_GIVES_TZ 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:104:0: warning: macro "HAVE_STAT_ST_BLOCKS" is not used [-Wunused-macros]
 #define HAVE_STAT_ST_BLOCKS 1
configure:27624: $? = 0
configure:27624: ./conftest
configure:27635: result: %ld and %lu
configure:27647: checking Threads support system scope
configure:27677: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
 #define HAVE_FORK 1
conftest.c:137:0: warning: macro "PRINTF_LL_WIDTH" is not used [-Wunused-macros]
 #define PRINTF_LL_WIDTH "l"
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:27677: $? = 0
configure:27677: ./conftest
configure:27693: result: yes
configure:27761: checking for gpfs
configure:27763: result: suppressed
configure:27772: checking for debug flags
configure:27805: result: none
configure:27825: checking whether function stack tracking is enabled
configure:27844: result: no
configure:27852: checking whether metadata trace file code is enabled
configure:27871: result: no
configure:27881: checking for API tracing
configure:27906: result: no
configure:27918: checking for instrumented library
configure:27945: result: no
configure:27956: checking whether to clear file buffers
configure:27967: result: yes
configure:27987: checking whether a memory checking tool will be used
configure:28006: result: no
configure:28141: checking for parallel support files
configure:28155: result: provided by compiler
configure:28180: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
 main ()
conftest.c:153:1: warning: implicit declaration of function 'MPI_Init' [-Wimplicit-function-declaration]
 MPI_Init()
conftest.c:153:1: warning: nested extern declaration of 'MPI_Init' [-Wnested-externs]
 #define HAVE_FORK 1
conftest.c:139:0: warning: macro "CLEAR_MEMORY" is not used [-Wunused-macros]
 #define CLEAR_MEMORY 1
conftest.c:78:0: warning: macro "SIZEOF_UINT_LEAST32_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_LEAST32_T 4
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:138:0: warning: macro "SYSTEM_SCOPE_THREADS" is not used [-Wunused-macros]
 #define SYSTEM_SCOPE_THREADS 1
configure:28180: $? = 0
configure:28318: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
 main ()
conftest.c:153:1: warning: implicit declaration of function 'MPI_File_open' [-Wimplicit-function-declaration]
 MPI_File_open()
conftest.c:153:1: warning: nested extern declaration of 'MPI_File_open' [-Wnested-externs]
 #define HAVE_FORK 1
conftest.c:79:0: warning: macro "SIZEOF_INT_FAST32_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_FAST32_T 8
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:28318: $? = 0
configure:28570: checking prefix for running on one processor
configure:28572: result: none
configure:28574: checking prefix for running in parallel
configure:28576: result: /usr/bin/mpiexec
configure:28580: checking whether a simple MPI-IO program can be linked
configure:28601: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
 main ()
conftest.c:154:1: warning: implicit declaration of function 'MPI_Init' [-Wimplicit-function-declaration]
 MPI_Init(); MPI_File_open();
conftest.c:154:1: warning: nested extern declaration of 'MPI_Init' [-Wnested-externs]
conftest.c:154:1: warning: implicit declaration of function 'MPI_File_open' [-Wimplicit-function-declaration]
conftest.c:154:1: warning: nested extern declaration of 'MPI_File_open' [-Wnested-externs]
conftest.c:80:0: warning: macro "SIZEOF_UINT_FAST32_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_FAST32_T 8
 #define HAVE_FORK 1
conftest.c:140:0: warning: macro "HAVE_PARALLEL" is not used [-Wunused-macros]
 #define HAVE_PARALLEL 1
conftest.c:51:0: warning: macro "SIZEOF_CHAR" is not used [-Wunused-macros]
 #define SIZEOF_CHAR 1
conftest.c:105:0: warning: macro "HAVE_IOCTL" is not used [-Wunused-macros]
 #define HAVE_IOCTL 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:28601: $? = 0
configure:28602: result: yes
configure:28719: checking for MPE
configure:28721: result: suppressed
configure:29153: checking if MPI_File_set_size works for files over 2GB
configure:29166: result: yes
configure:29186: checking if MPI_File_get_size is enabled
configure:29197: result: yes
configure:29220: checking for I/O filters
configure:29233: result: all (shuffle,fletcher32,nbit,scaleoffset)
configure:29294: checking for Default Virtual File Driver definition
configure:29306: result: yes
configure:29333: checking for Direct Virtual File Driver support
configure:29370: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:156:59: error: 'O_DIRECT' undeclared (first use in this function)
              if((fid=open("tst_file", O_CREAT | O_TRUNC | O_DIRECT, 0755))<0)
conftest.c:156:59: note: each undeclared identifier is reported only once for each function it appears in
conftest.c:157:3: warning: implicit declaration of function 'exit' [-Wimplicit-function-declaration]
   exit(1);
conftest.c:157:3: warning: incompatible implicit declaration of built-in function 'exit' [enabled by default]
conftest.c:158:14: warning: implicit declaration of function 'close' [-Wimplicit-function-declaration]
              close(fid);
conftest.c:158:14: warning: nested extern declaration of 'close' [-Wnested-externs]
conftest.c:159:14: warning: implicit declaration of function 'remove' [-Wimplicit-function-declaration]
              remove("tst_file");
conftest.c:159:14: warning: nested extern declaration of 'remove' [-Wnested-externs]
conftest.c:160:14: warning: incompatible implicit declaration of built-in function 'exit' [enabled by default]
              exit (0);
conftest.c:144:0: warning: macro "HAVE_FILTER_FLETCHER32" is not used [-Wunused-macros]
 #define HAVE_FILTER_FLETCHER32 1
conftest.c:147:0: warning: macro "DEFAULT_VFD" is not used [-Wunused-macros]
 #define DEFAULT_VFD H5FD_SEC2
conftest.c:145:0: warning: macro "HAVE_FILTER_NBIT" is not used [-Wunused-macros]
 #define HAVE_FILTER_NBIT 1
 #define HAVE_FORK 1
conftest.c:53:0: warning: macro "SIZEOF_INT" is not used [-Wunused-macros]
 #define SIZEOF_INT 4
conftest.c:52:0: warning: macro "SIZEOF_SHORT" is not used [-Wunused-macros]
 #define SIZEOF_SHORT 2
conftest.c:143:0: warning: macro "HAVE_FILTER_SHUFFLE" is not used [-Wunused-macros]
 #define HAVE_FILTER_SHUFFLE 1
conftest.c:142:0: warning: macro "HAVE_MPI_GET_SIZE" is not used [-Wunused-macros]
 #define HAVE_MPI_GET_SIZE 1
conftest.c:82:0: warning: macro "SIZEOF_UINT64_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT64_T 8
conftest.c:81:0: warning: macro "SIZEOF_INT64_T" is not used [-Wunused-macros]
 #define SIZEOF_INT64_T 8
conftest.c:141:0: warning: macro "MPI_FILE_SET_SIZE_BIG" is not used [-Wunused-macros]
 #define MPI_FILE_SET_SIZE_BIG 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:146:0: warning: macro "HAVE_FILTER_SCALEOFFSET" is not used [-Wunused-macros]
 #define HAVE_FILTER_SCALEOFFSET 1
configure:29370: $? = 1
configure: program exited with status 1
configure: failed program was:
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <sys/types.h>
| #include <stdint.h>
| #include <sys/types.h> /*for off_t definition*/
| #define HAVE_LIBZ 1
| #define HAVE_FORK 1
| /* end confdefs.h.  */
| 	  #include <sys/stat.h>
| 	  #include <fcntl.h>
|           int main(void)
|              int fid;
| 		exit(1);
|              close(fid);
|              remove("tst_file");
|              exit (0);
configure:29414: result: no
configure:29438: checking whether exception handling functions is checked during data conversions
configure:29449: result: yes
configure:29465: checking whether data accuracy is guaranteed during data conversions
configure:29476: result: yes
configure:29492: checking if converting denormalized floating-point values is possible
configure:29505: result: yes
configure:29518: checking if converting floating-point values to long long is not working
configure:29534: result: false
configure:29544: checking if the machine has window style path name
configure:29556: result: no
configure:29568: checking if converting from long double to integers is accurate
configure:29586: result: yes
configure:29601: checking if converting from long double to integers works
configure:29642: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:163:13: warning: implicit declaration of function 'malloc' [-Wimplicit-function-declaration]
             align = (void*)malloc(sizeof(long double));
conftest.c:163:28: warning: incompatible implicit declaration of built-in function 'malloc' [enabled by default]
conftest.c:164:13: warning: implicit declaration of function 'memcpy' [-Wimplicit-function-declaration]
             memcpy(align, &ld, sizeof(long double));
conftest.c:164:13: warning: incompatible implicit declaration of built-in function 'memcpy' [enabled by default]
conftest.c:173:13: warning: implicit declaration of function 'exit' [-Wimplicit-function-declaration]
             exit(ret);
conftest.c:173:13: warning: incompatible implicit declaration of built-in function 'exit' [enabled by default]
conftest.c:172:5: warning: label 'done' defined but not used [-Wunused-label]
     done:
conftest.c:160:26: warning: variable 'v3' set but not used [-Wunused-but-set-variable]
             unsigned int v3;
conftest.c:159:19: warning: variable 'v2' set but not used [-Wunused-but-set-variable]
             short v2;
conftest.c:158:27: warning: variable 'v1' set but not used [-Wunused-but-set-variable]
             unsigned char v1;
conftest.c:150:0: warning: macro "CONVERT_DENORMAL_FLOAT" is not used [-Wunused-macros]
 #define CONVERT_DENORMAL_FLOAT 1
conftest.c:151:0: warning: macro "LDOUBLE_TO_INTEGER_ACCURATE" is not used [-Wunused-macros]
 #define LDOUBLE_TO_INTEGER_ACCURATE 1
conftest.c:108:0: warning: macro "HAVE_ALARM" is not used [-Wunused-macros]
 #define HAVE_ALARM 1
conftest.c:148:0: warning: macro "WANT_DCONV_EXCEPTION" is not used [-Wunused-macros]
 #define WANT_DCONV_EXCEPTION 1
 #define HAVE_FORK 1
conftest.c:106:0: warning: macro "HAVE_TIOCGWINSZ" is not used [-Wunused-macros]
 #define HAVE_TIOCGWINSZ 1
conftest.c:54:0: warning: macro "SIZEOF_UNSIGNED" is not used [-Wunused-macros]
 #define SIZEOF_UNSIGNED 4
conftest.c:107:0: warning: macro "HAVE_TIOCGETD" is not used [-Wunused-macros]
 #define HAVE_TIOCGETD 1
conftest.c:55:0: warning: macro "SIZEOF_LONG" is not used [-Wunused-macros]
 #define SIZEOF_LONG 8
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:149:0: warning: macro "WANT_DATA_ACCURACY" is not used [-Wunused-macros]
 #define WANT_DATA_ACCURACY 1
conftest.c:83:0: warning: macro "SIZEOF_INT_LEAST64_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_LEAST64_T 8
conftest.c:84:0: warning: macro "SIZEOF_UINT_LEAST64_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_LEAST64_T 8
configure:29642: $? = 0
configure:29642: ./conftest
configure:29659: result: yes
configure:29673: checking if accurately converting from integers to long double
configure:29691: result: yes
configure:29706: checking if accurately converting unsigned long to float values
configure:29750: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:181:9: warning: implicit declaration of function 'exit' [-Wimplicit-function-declaration]
         exit(ret);
conftest.c:181:9: warning: incompatible implicit declaration of built-in function 'exit' [enabled by default]
conftest.c:180:1: warning: label 'done' defined but not used [-Wunused-label]
 done:
conftest.c:56:0: warning: macro "SIZEOF_LONG_LONG" is not used [-Wunused-macros]
 #define SIZEOF_LONG_LONG 8
conftest.c:110:0: warning: macro "HAVE_FREXPF" is not used [-Wunused-macros]
 #define HAVE_FREXPF 1
conftest.c:85:0: warning: macro "SIZEOF_INT_FAST64_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_FAST64_T 8
 #define PACKAGE_STRING "HDF5 1.8.11"
 #define PACKAGE_TARNAME "hdf5"
conftest.c:109:0: warning: macro "HAVE_FORK" is not used [-Wunused-macros]
 #define HAVE_FORK 1
 #define PACKAGE_BUGREPORT "help at hdfgroup.org"
conftest.c:153:0: warning: macro "INTEGER_TO_LDOUBLE_ACCURATE" is not used [-Wunused-macros]
 #define INTEGER_TO_LDOUBLE_ACCURATE 1
 #define PACKAGE_VERSION "1.8.11"
 #define PACKAGE_NAME "HDF5"
 #define PACKAGE "hdf5"
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:152:0: warning: macro "LDOUBLE_TO_INTEGER_WORKS" is not used [-Wunused-macros]
 #define LDOUBLE_TO_INTEGER_WORKS 1
 #define VERSION "1.8.11"
configure:29750: $? = 0
configure:29750: ./conftest
configure:29766: result: yes
configure:29782: checking if accurately converting unsigned long long to floating-point values
configure:29882: result: yes
configure:29896: checking if accurately roundup converting floating-point to unsigned long long values
configure:29929: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:161:9: warning: conversion to 'double' alters 'long double' constant value [-Wconversion]
         double d = 222.55L;
conftest.c:172:9: warning: implicit declaration of function 'exit' [-Wimplicit-function-declaration]
         exit(ret);
conftest.c:172:9: warning: incompatible implicit declaration of built-in function 'exit' [enabled by default]
conftest.c:171:1: warning: label 'done' defined but not used [-Wunused-label]
 done:
conftest.c:113:0: warning: macro "HAVE_GETPWUID" is not used [-Wunused-macros]
 #define HAVE_GETPWUID 1
conftest.c:112:0: warning: macro "HAVE_GETHOSTNAME" is not used [-Wunused-macros]
 #define HAVE_GETHOSTNAME 1
 #define HAVE_FORK 1
conftest.c:111:0: warning: macro "HAVE_FREXPL" is not used [-Wunused-macros]
 #define HAVE_FREXPL 1
conftest.c:114:0: warning: macro "HAVE_GETRUSAGE" is not used [-Wunused-macros]
 #define HAVE_GETRUSAGE 1
conftest.c:86:0: warning: macro "SIZEOF_UINT_FAST64_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_FAST64_T 8
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:155:0: warning: macro "ULONG_TO_FP_BOTTOM_BIT_ACCURATE" is not used [-Wunused-macros]
 #define ULONG_TO_FP_BOTTOM_BIT_ACCURATE 1
conftest.c:154:0: warning: macro "ULONG_TO_FLOAT_ACCURATE" is not used [-Wunused-macros]
 #define ULONG_TO_FLOAT_ACCURATE 1
conftest.c:87:0: warning: macro "SIZEOF_SIZE_T" is not used [-Wunused-macros]
 #define SIZEOF_SIZE_T 8
conftest.c:57:0: warning: macro "SIZEOF___INT64" is not used [-Wunused-macros]
 #define SIZEOF___INT64 0
configure:29929: $? = 0
configure:29929: ./conftest
configure:29945: result: yes
configure:29959: checking if right maximum converting floating-point to unsigned long long values
configure:29999: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:164:9: warning: conversion to 'double' alters 'long double' constant value [-Wconversion]
         double d3 = 2e40L;
conftest.c:180:9: warning: implicit declaration of function 'exit' [-Wimplicit-function-declaration]
         exit(ret);
conftest.c:180:9: warning: incompatible implicit declaration of built-in function 'exit' [enabled by default]
conftest.c:179:1: warning: label 'done' defined but not used [-Wunused-label]
 done:
conftest.c:156:0: warning: macro "FP_TO_ULLONG_ACCURATE" is not used [-Wunused-macros]
 #define FP_TO_ULLONG_ACCURATE 1
conftest.c:88:0: warning: macro "SIZEOF_SSIZE_T" is not used [-Wunused-macros]
 #define SIZEOF_SSIZE_T 8
 #define HAVE_FORK 1
conftest.c:115:0: warning: macro "HAVE_LSTAT" is not used [-Wunused-macros]
 #define HAVE_LSTAT 1
conftest.c:58:0: warning: macro "SIZEOF_FLOAT" is not used [-Wunused-macros]
 #define SIZEOF_FLOAT 4
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:117:0: warning: macro "HAVE_RANDOM" is not used [-Wunused-macros]
 #define HAVE_RANDOM 1
conftest.c:116:0: warning: macro "HAVE_RAND_R" is not used [-Wunused-macros]
 #define HAVE_RAND_R 1
configure:29999: $? = 0
configure:29999: ./conftest
configure:30015: result: yes
configure:30027: checking if correctly converting long double to unsigned int values
configure:30060: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:171:13: warning: implicit declaration of function 'exit' [-Wimplicit-function-declaration]
             exit(ret);
conftest.c:171:13: warning: incompatible implicit declaration of built-in function 'exit' [enabled by default]
conftest.c:170:5: warning: label 'done' defined but not used [-Wunused-label]
     done:
 #define HAVE_FORK 1
conftest.c:157:0: warning: macro "FP_TO_ULLONG_RIGHT_MAXIMUM" is not used [-Wunused-macros]
 #define FP_TO_ULLONG_RIGHT_MAXIMUM 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
configure:30060: $? = 0
configure:30060: ./conftest
configure:30077: result: yes
configure:30091: checking if compiling unsigned long long to floating-point typecasts work
configure:30104: result: yes
configure:30118: checking if compiling long long to floating-point typecasts work
configure:30131: result: yes
configure:30145: checking if converting unsigned long long to long double with precision
configure:30238: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:233:21: warning: 'c2_cyg' may be used uninitialized in this function [-Wmaybe-uninitialized]
                 free(c2_cyg);
conftest.c:60:0: warning: macro "SIZEOF_LONG_DOUBLE" is not used [-Wunused-macros]
 #define SIZEOF_LONG_DOUBLE 16
 #define HAVE_STDLIB_H 1
 #define HAVE_FORK 1
conftest.c:59:0: warning: macro "SIZEOF_DOUBLE" is not used [-Wunused-macros]
 #define SIZEOF_DOUBLE 8
 #define HAVE_UNISTD_H 1
conftest.c:118:0: warning: macro "HAVE_SIGNAL" is not used [-Wunused-macros]
 #define HAVE_SIGNAL 1
conftest.c:159:0: warning: macro "ULLONG_TO_FP_CAST_WORKS" is not used [-Wunused-macros]
 #define ULLONG_TO_FP_CAST_WORKS 1
conftest.c:91:0: warning: macro "SIZEOF_OFF_T" is not used [-Wunused-macros]
 #define SIZEOF_OFF_T 8
 #define HAVE_SYS_STAT_H 1
 #define STDC_HEADERS 1
conftest.c:119:0: warning: macro "HAVE_LONGJMP" is not used [-Wunused-macros]
 #define HAVE_LONGJMP 1
conftest.c:160:0: warning: macro "LLONG_TO_FP_CAST_WORKS" is not used [-Wunused-macros]
 #define LLONG_TO_FP_CAST_WORKS 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:89:0: warning: macro "SIZEOF_PTRDIFF_T" is not used [-Wunused-macros]
 #define SIZEOF_PTRDIFF_T 8
conftest.c:158:0: warning: macro "LDOUBLE_TO_UINT_ACCURATE" is not used [-Wunused-macros]
 #define LDOUBLE_TO_UINT_ACCURATE 1
 #define CXX_HAVE_OFFSETOF 1
configure:30238: $? = 0
configure:30238: ./conftest
configure:30255: result: yes
configure:30269: checking if overflows normally converting floating-point to integer values
configure:30296: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
 #define HAVE_SYS_TYPES_H 1
 #define HAVE_STDINT_H 1
         exit(0);
 done:
conftest.c:167:16: warning: variable 'i' set but not used [-Wunused-but-set-variable]
         int    i;
conftest.c:15:0: warning: macro "HAVE_STRING_H" is not used [-Wunused-macros]
 #define HAVE_STRING_H 1
conftest.c:16:0: warning: macro "HAVE_MEMORY_H" is not used [-Wunused-macros]
 #define HAVE_MEMORY_H 1
conftest.c:41:0: warning: macro "HAVE_STDINT_H" is not used [-Wunused-macros]
conftest.c:18:0: warning: macro "HAVE_INTTYPES_H" is not used [-Wunused-macros]
 #define HAVE_INTTYPES_H 1
 #define HAVE_FORK 1
conftest.c:120:0: warning: macro "HAVE_SETJMP" is not used [-Wunused-macros]
 #define HAVE_SETJMP 1
conftest.c:32:0: warning: macro "HAVE_UNISTD_H" is not used [-Wunused-macros]
conftest.c:17:0: warning: macro "HAVE_STRINGS_H" is not used [-Wunused-macros]
 #define HAVE_STRINGS_H 1
conftest.c:34:0: warning: macro "HAVE_SYS_STAT_H" is not used [-Wunused-macros]
conftest.c:25:0: warning: macro "STDC_HEADERS" is not used [-Wunused-macros]
 #define LT_OBJDIR ".libs/"
conftest.c:161:0: warning: macro "ULLONG_TO_LDOUBLE_PRECISION" is not used [-Wunused-macros]
 #define ULLONG_TO_LDOUBLE_PRECISION 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:92:0: warning: macro "SIZEOF_OFF64_T" is not used [-Wunused-macros]
 #define SIZEOF_OFF64_T 8
 #define HAVE_DLFCN_H 1
conftest.c:63:0: warning: macro "SIZEOF_INT8_T" is not used [-Wunused-macros]
 #define SIZEOF_INT8_T 1
conftest.c:121:0: warning: macro "HAVE_SIGLONGJMP" is not used [-Wunused-macros]
 #define HAVE_SIGLONGJMP 1
configure:30296: $? = 0
configure:30296: ./conftest
configure:30312: result: yes
configure:30328: checking if using special algorithm to convert long double to (unsigned) long values
configure:30401: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:179:17: warning: implicit declaration of function 'memcpy' [-Wimplicit-function-declaration]
                 memcpy(s, &ld, 16);
conftest.c:179:17: warning: incompatible implicit declaration of built-in function 'memcpy' [enabled by default]
conftest.c:216:13: warning: implicit declaration of function 'exit' [-Wimplicit-function-declaration]
             exit(ret);
conftest.c:216:13: warning: incompatible implicit declaration of built-in function 'exit' [enabled by default]
conftest.c:215:5: warning: label 'done' defined but not used [-Wunused-label]
     done:
conftest.c:65:0: warning: macro "SIZEOF_INT_LEAST8_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_LEAST8_T 1
conftest.c:122:0: warning: macro "HAVE_SIGPROCMASK" is not used [-Wunused-macros]
 #define HAVE_SIGPROCMASK 1
conftest.c:64:0: warning: macro "SIZEOF_UINT8_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT8_T 1
conftest.c:93:0: warning: macro "DEV_T_IS_SCALAR" is not used [-Wunused-macros]
 #define DEV_T_IS_SCALAR 1
conftest.c:36:0: warning: macro "HAVE_SYS_TYPES_H" is not used [-Wunused-macros]
 #define HAVE_FORK 1
conftest.c:94:0: warning: macro "HAVE_ZLIB_H" is not used [-Wunused-macros]
 #define HAVE_ZLIB_H 1
conftest.c:123:0: warning: macro "HAVE_SNPRINTF" is not used [-Wunused-macros]
 #define HAVE_SNPRINTF 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:162:0: warning: macro "FP_TO_INTEGER_OVERFLOW_WORKS" is not used [-Wunused-macros]
 #define FP_TO_INTEGER_OVERFLOW_WORKS 1
configure:30401: $? = 0
configure:30401: ./conftest
configure:30401: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdint.h>
| #define SIZEOF_UINT_LEAST8_T 1
| #define HAVE_LIBZ 1
| #define HAVE_FORK 1
| #define HAVE_SRANDOM 1
|         int main(void)
|             long double         ld = 20041683600089727.779961L;
|             long                ll;
|             unsigned long       ull;
|             unsigned char       s[16];
|             unsigned char       s2[8];
|             int                 ret = 1;
|             if(sizeof(long double) == 16 && sizeof(long) == 8) {
|                 /*make sure the long double type has 16 bytes in size and
|                  * 11 bits of exponent.  If it is,
|                  *the bit sequence should be like below.  It's not
|                  *a decent way to check but this info isn't available. */
|                 memcpy(s, &ld, 16);
|                 if(s[0]==0x43 && s[1]==0x51 && s[2]==0xcc && s[3]==0xf3 &&
|                     s[4]==0x85 && s[5]==0xeb && s[6]==0xc8 && s[7]==0xa0 &&
|                     s[8]==0xbf && s[9]==0xcc && s[10]==0x2a && s[11]==0x3c) {
|                     /* Assign the hexadecimal value of long double type. */
|                     s[0]=0x43; s[1]=0x51; s[2]=0xcc; s[3]=0xf3;
|                     s[4]=0x85; s[5]=0xeb; s[6]=0xc8; s[7]=0xa0;
|                     s[8]=0xbf; s[9]=0xcc; s[10]=0x2a; s[11]=0x3c;
|                     s[12]=0x3d; s[13]=0x85; s[14]=0x56; s[15]=0x20;
|                     memcpy(&ld, s, 16);
|                     ll = (long)ld;
|                     memcpy(s2, &ll, 8);
|                     /* The library's algorithm converts it to 0x 00 47 33 ce 17 af 22 82
|                      * and gets wrong value 20041683600089730 on the IBM Power6 Linux.
|                      * But the IBM Power6 Linux converts it to 0x00 47 33 ce 17 af 22 7f
|                      * and gets the correct value 20041683600089727.  It uses some special
|                      * algorithm.  We're going to define the macro and skip the test until
|                      * we can figure out how they do it. */
|                     if(s2[0]==0x00 && s2[1]==0x47 && s2[2]==0x33 && s2[3]==0xce &&
|                        s2[4]==0x17 && s2[5]==0xaf && s2[6]==0x22 && s2[7]==0x7f)
|                         ret = 0;
|                     ull = (unsigned long)ld;
|                     memcpy(s2, &ull, 8);
|                     /* The unsigned long is the same as signed long. */
|                         ret = 0;
|     done:
|             exit(ret);
configure:30421: result: no
configure:30433: checking if using special algorithm to convert (unsigned) long to long double values
configure:30508: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:177:17: warning: implicit declaration of function 'memcpy' [-Wimplicit-function-declaration]
                 memcpy(s, &ld, 16);
conftest.c:177:17: warning: incompatible implicit declaration of built-in function 'memcpy' [enabled by default]
conftest.c:186:17: warning: incompatible implicit declaration of built-in function 'memcpy' [enabled by default]
                 memcpy(s, &ld, 16);
conftest.c:202:17: warning: incompatible implicit declaration of built-in function 'memcpy' [enabled by default]
                 memcpy(s, &ld, 16);
conftest.c:218:13: warning: implicit declaration of function 'exit' [-Wimplicit-function-declaration]
             exit(ret);
conftest.c:218:13: warning: incompatible implicit declaration of built-in function 'exit' [enabled by default]
conftest.c:217:5: warning: label 'done' defined but not used [-Wunused-label]
     done:
 #define HAVE_DIFFTIME 1
conftest.c:127:0: warning: macro "HAVE_SYSTEM" is not used [-Wunused-macros]
 #define HAVE_SYSTEM 1
 #define HAVE_DIRENT_H 1
conftest.c:124:0: warning: macro "HAVE_SRANDOM" is not used [-Wunused-macros]
conftest.c:96:0: warning: macro "HAVE_FILTER_DEFLATE" is not used [-Wunused-macros]
 #define HAVE_FILTER_DEFLATE 1
 #define HAVE_GETTIMEOFDAY 1
 #define HAVE_FORK 1
 #define HAVE_SYS_SOCKET_H 1
 #define HAVE_SYS_IOCTL_H 1
 #define HAVE_SYS_RESOURCE_H 1
 #define HAVE_STDDEF_H 1
conftest.c:128:0: warning: macro "HAVE_TMPFILE" is not used [-Wunused-macros]
 #define HAVE_TMPFILE 1
 #define HAVE_SYS_TIME_H 1
conftest.c:97:0: warning: macro "HAVE_PTHREAD_H" is not used [-Wunused-macros]
 #define HAVE_PTHREAD_H 1
conftest.c:126:0: warning: macro "HAVE_SYMLINK" is not used [-Wunused-macros]
 #define HAVE_SYMLINK 1
conftest.c:66:0: warning: macro "SIZEOF_UINT_LEAST8_T" is not used [-Wunused-macros]
 #define HAVE_LIBM 1
conftest.c:95:0: warning: macro "HAVE_LIBZ" is not used [-Wunused-macros]
 #define HAVE_LIBZ 1
 #define HAVE_CLOCK_GETTIME 1
 #define HAVE_FEATURES_H 1
 #define HAVE_SETJMP_H 1
conftest.c:67:0: warning: macro "SIZEOF_INT_FAST8_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_FAST8_T 1
conftest.c:125:0: warning: macro "HAVE_STRDUP" is not used [-Wunused-macros]
 #define HAVE_STRDUP 1
 #define TIME_WITH_SYS_TIME 1
 #define HAVE_LIBDL 1
conftest.c:68:0: warning: macro "SIZEOF_UINT_FAST8_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_FAST8_T 1
configure:30508: $? = 0
configure:30508: ./conftest
configure:30508: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdint.h>
| #define HAVE_LIBZ 1
| #define HAVE_FORK 1
| #define HAVE_VASPRINTF 1
|         int main(void)
|             long double         ld;
|             long                ll;
|             unsigned long       ull;
|             int                 flag=0, ret=1;
|             /*Determine if long double has 16 byte in size, 11 bit exponent, and
|              *the bias is 0x3ff */
|             if(sizeof(long double) == 16) {
|                 ld = 1.0L;
|                 memcpy(s, &ld, 16);
|                 if(s[0]==0x3f && s[1]==0xf0 && s[2]==0x00 && s[3]==0x00 &&
|                     s[4]==0x00 && s[5]==0x00 && s[6]==0x00 && s[7]==0x00)
|                     flag = 1;
|             if(flag==1 && sizeof(long)==8) {
|                 ll = 0x003fffffffffffffL;
|                 ld = (long double)ll;
|                 memcpy(s, &ld, 16);
|                 /* The library converts the value to 0x434fffffffffffff8000000000000000.
|                  * In decimal it is 18014398509481982.000000, one value short of the original.
|                  * The IBM Power6 Linux converts it to 0x4350000000000000bff0000000000000.
|                  * The value is correct in decimal. It uses some special
|                 if(s[0]==0x43 && s[1]==0x50 && s[2]==0x00 && s[3]==0x00 &&
|                     s[4]==0x00 && s[5]==0x00 && s[6]==0x00 && s[7]==0x00 &&
|                     s[8]==0xbf && s[9]==0xf0 && s[10]==0x00 && s[11]==0x00 &&
|                     s[12]==0x00 && s[13]==0x00 && s[14]==0x00 && s[15]==0x00)
|                     ret = 0;
|             if(flag==1 && sizeof(unsigned long)==8) {
|                 ull = 0xffffffffffffffffUL;
|                 ld = (long double)ull;
|                 memcpy(s, &ld, 16);
|                 /* Use a different value from signed long to test. The problem is the same
|                  * for both long and unsigned long. The value is 18446744073709551615.
|                  * The library converts the value to 0x43effffffffffffffe000000000000000.
|                  * In decimal it's 18446744073709548544.000000, very different from the original.
|                  * The IBM Power6 Linux converts it to 0x43f0000000000000bff0000000000000.
|                 if(s[0]==0x43 && s[1]==0xf0 && s[2]==0x00 && s[3]==0x00 &&
|                     ret = 0;
|     done:
|             exit(ret);
configure:30528: result: no
configure:30541: checking if correctly converting long double to (unsigned) long long values
configure:30597: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
conftest.c:11:0: warning: macro "STDC_HEADERS" is not used [-Wunused-macros]
conftest.c:20:0: warning: macro "HAVE_UNISTD_H" is not used [-Wunused-macros]
conftest.c:13:0: warning: macro "HAVE_SYS_STAT_H" is not used [-Wunused-macros]
conftest.c:12:0: warning: macro "HAVE_SYS_TYPES_H" is not used [-Wunused-macros]
conftest.c:19:0: warning: macro "HAVE_STDINT_H" is not used [-Wunused-macros]
conftest.c: In function 'main':
conftest.c:178:17: warning: implicit declaration of function 'memcpy' [-Wimplicit-function-declaration]
                 memcpy(s, &ld, 16);
conftest.c:178:17: warning: incompatible implicit declaration of built-in function 'memcpy' [enabled by default]
conftest.c:199:13: warning: implicit declaration of function 'exit' [-Wimplicit-function-declaration]
             exit(ret);
conftest.c:199:13: warning: incompatible implicit declaration of built-in function 'exit' [enabled by default]
conftest.c:198:5: warning: label 'done' defined but not used [-Wunused-label]
     done:
conftest.c: At top level:
conftest.c:27:0: warning: macro "HAVE_DIFFTIME" is not used [-Wunused-macros]
conftest.c:5:0: warning: macro "PACKAGE_STRING" is not used [-Wunused-macros]
conftest.c:98:0: warning: macro "HAVE_LIBPTHREAD" is not used [-Wunused-macros]
 #define HAVE_LIBPTHREAD 1
conftest.c:40:0: warning: macro "HAVE_DIRENT_H" is not used [-Wunused-macros]
conftest.c:3:0: warning: macro "PACKAGE_TARNAME" is not used [-Wunused-macros]
conftest.c:28:0: warning: macro "HAVE_GETTIMEOFDAY" is not used [-Wunused-macros]
conftest.c:14:0: warning: macro "HAVE_STDLIB_H" is not used [-Wunused-macros]
 #define HAVE_FORK 1
conftest.c:35:0: warning: macro "HAVE_SYS_SOCKET_H" is not used [-Wunused-macros]
conftest.c:42:0: warning: macro "HAVE_SYS_TIMEB_H" is not used [-Wunused-macros]
 #define HAVE_SYS_TIMEB_H 1
conftest.c:33:0: warning: macro "HAVE_SYS_IOCTL_H" is not used [-Wunused-macros]
conftest.c:69:0: warning: macro "SIZEOF_INT16_T" is not used [-Wunused-macros]
 #define SIZEOF_INT16_T 2
conftest.c:6:0: warning: macro "PACKAGE_BUGREPORT" is not used [-Wunused-macros]
conftest.c:129:0: warning: macro "HAVE_VASPRINTF" is not used [-Wunused-macros]
conftest.c:30:0: warning: macro "HAVE_SYS_RESOURCE_H" is not used [-Wunused-macros]
conftest.c:37:0: warning: macro "HAVE_STDDEF_H" is not used [-Wunused-macros]
conftest.c:130:0: warning: macro "HAVE_WAITPID" is not used [-Wunused-macros]
 #define HAVE_WAITPID 1
conftest.c:4:0: warning: macro "PACKAGE_VERSION" is not used [-Wunused-macros]
conftest.c:2:0: warning: macro "PACKAGE_NAME" is not used [-Wunused-macros]
conftest.c:31:0: warning: macro "HAVE_SYS_TIME_H" is not used [-Wunused-macros]
conftest.c:8:0: warning: macro "PACKAGE" is not used [-Wunused-macros]
conftest.c:22:0: warning: macro "LT_OBJDIR" is not used [-Wunused-macros]
conftest.c:23:0: warning: macro "HAVE_LIBM" is not used [-Wunused-macros]
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:21:0: warning: macro "HAVE_DLFCN_H" is not used [-Wunused-macros]
conftest.c:29:0: warning: macro "HAVE_CLOCK_GETTIME" is not used [-Wunused-macros]
conftest.c:39:0: warning: macro "HAVE_FEATURES_H" is not used [-Wunused-macros]
conftest.c:44:0: warning: macro "HAVE_FSEEKO64" is not used [-Wunused-macros]
 #define HAVE_FSEEKO64 1
conftest.c:38:0: warning: macro "HAVE_SETJMP_H" is not used [-Wunused-macros]
conftest.c:10:0: warning: macro "CXX_HAVE_OFFSETOF" is not used [-Wunused-macros]
conftest.c:26:0: warning: macro "TIME_WITH_SYS_TIME" is not used [-Wunused-macros]
conftest.c:24:0: warning: macro "HAVE_LIBDL" is not used [-Wunused-macros]
conftest.c:9:0: warning: macro "VERSION" is not used [-Wunused-macros]
conftest.c:7:0: warning: macro "PACKAGE_URL" is not used [-Wunused-macros]
 #define PACKAGE_URL ""
configure:30597: $? = 0
configure:30597: ./conftest
configure:30614: result: yes
configure:30629: checking if correctly converting (unsigned) long long to long double values
configure:30689: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c -lpthread -lz -ldl -lm  >&5
                 memcpy(s, &ld, 16);
conftest.c:187:17: warning: incompatible implicit declaration of built-in function 'memcpy' [enabled by default]
                 memcpy(s, &ld, 16);
conftest.c:197:17: warning: incompatible implicit declaration of built-in function 'memcpy' [enabled by default]
                 memcpy(s, &ld, 16);
conftest.c:204:13: warning: implicit declaration of function 'exit' [-Wimplicit-function-declaration]
             exit(ret);
conftest.c:204:13: warning: incompatible implicit declaration of built-in function 'exit' [enabled by default]
conftest.c:203:5: warning: label 'done' defined but not used [-Wunused-label]
     done:
conftest.c:132:0: warning: macro "VSNPRINTF_WORKS" is not used [-Wunused-macros]
 #define VSNPRINTF_WORKS 1
conftest.c:45:0: warning: macro "HAVE_FTELLO64" is not used [-Wunused-macros]
 #define HAVE_FTELLO64 1
conftest.c:99:0: warning: macro "HAVE_TM_GMTOFF" is not used [-Wunused-macros]
 #define HAVE_TM_GMTOFF 1
 #define HAVE_FORK 1
conftest.c:47:0: warning: macro "HAVE_FSEEKO" is not used [-Wunused-macros]
 #define HAVE_FSEEKO 1
conftest.c:70:0: warning: macro "SIZEOF_UINT16_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT16_T 2
conftest.c:163:0: warning: macro "LDOUBLE_TO_LLONG_ACCURATE" is not used [-Wunused-macros]
 #define LDOUBLE_TO_LLONG_ACCURATE 1
conftest.c:71:0: warning: macro "SIZEOF_INT_LEAST16_T" is not used [-Wunused-macros]
 #define SIZEOF_INT_LEAST16_T 2
conftest.c:46:0: warning: macro "HAVE_FTRUNCATE64" is not used [-Wunused-macros]
 #define HAVE_FTRUNCATE64 1
conftest.c:131:0: warning: macro "HAVE_VSNPRINTF" is not used [-Wunused-macros]
 #define HAVE_VSNPRINTF 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:43:0: warning: macro "HAVE_LSEEK64" is not used [-Wunused-macros]
 #define HAVE_LSEEK64 1
configure:30689: $? = 0
configure:30689: ./conftest
configure:30706: result: yes
configure:30719: checking if bad code for log2 routine is generated
configure:30735: result: no
configure:30904: checking if high level library is enabled
configure:30929: checking additional programs should be built
configure:30957: checking if deprecated public symbols are available
configure:30969: result: yes
configure:30988: checking which version of public symbols to use by default
configure:31007: result: v18
configure:31028: checking Whether to perform strict file format checks
configure:31055: result: no
configure:31065: checking Whether to have library information embedded in the executables
configure:31076: result: yes
configure:31090: checking if alignment restrictions are strictly enforced
configure:31151: /usr/bin/mpicc -o conftest -std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions    -D_POSIX_C_SOURCE=199506L   -D_BSD_SOURCE -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE      -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so conftest.c  -lpthread -lz -ldl -lm  >&5
conftest.c:187:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
 main ()
conftest.c:187:1: warning: old-style function definition [-Wold-style-definition]
conftest.c:190:21: warning: initialization discards 'const' qualifier from pointer target type [enabled by default]
         char *chp = "beefs";
conftest.c:191:23: warning: request for implicit conversion from 'void *' to 'char **' not permitted in C++ [-Wc++-compat]
         char **chpp = malloc (2 * sizeof (char *));
conftest.c:205:13: warning: request for implicit conversion from 'void *' to 'struct hvl_t *' not permitted in C++ [-Wc++-compat]
         vlp = malloc (2 * sizeof (hvl_t));
conftest.c:187:1: warning: function might be candidate for attribute 'const' [-Wsuggest-attribute=const]
 main ()
conftest.c:48:0: warning: macro "HAVE_FTELLO" is not used [-Wunused-macros]
 #define HAVE_FTELLO 1
 #define HAVE_FORK 1
conftest.c:164:0: warning: macro "LLONG_TO_LDOUBLE_CORRECT" is not used [-Wunused-macros]
 #define LLONG_TO_LDOUBLE_CORRECT 1
conftest.c:165:0: warning: macro "INCLUDE_HL" is not used [-Wunused-macros]
 #define INCLUDE_HL 1
 #define HAVE_LIBM 1
 #define HAVE_LIBZ 1
conftest.c:72:0: warning: macro "SIZEOF_UINT_LEAST16_T" is not used [-Wunused-macros]
 #define SIZEOF_UINT_LEAST16_T 2
conftest.c:166:0: warning: macro "HAVE_EMBEDDED_LIBINFO" is not used [-Wunused-macros]
 #define HAVE_EMBEDDED_LIBINFO 1
configure:31151: $? = 0
configure:31151: ./conftest
configure:31156: result: no
configure:31263: creating ./config.lt
## Running config.lt. ##
config.lt:732: creating libtool
configure:33316: checking that generated files are newer than configure
configure:33322: result: done
configure:33406: creating ./config.status
## Running config.status. ##
This file was extended by HDF5 config.status 1.8.11, which was
generated by GNU Autoconf 2.69.  Invocation command line was
  CONFIG_FILES    =
  CONFIG_HEADERS  =
  CONFIG_LINKS    =
  CONFIG_COMMANDS =
  $ ./config.status
on ALA_PC180
config.status:1544: creating src/libhdf5.settings
config.status:1544: creating Makefile
config.status:1544: creating src/Makefile
config.status:1544: creating test/Makefile
config.status:1544: creating test/testcheck_version.sh
config.status:1544: creating test/testerror.sh
config.status:1544: creating test/H5srcdir_str.h
config.status:1544: creating test/testlibinfo.sh
config.status:1544: creating test/testlinks_env.sh
config.status:1544: creating test/test_plugin.sh
config.status:1544: creating testpar/Makefile
config.status:1544: creating testpar/testph5.sh
config.status:1544: creating perform/Makefile
config.status:1544: creating tools/Makefile
config.status:1544: creating tools/h5dump/Makefile
config.status:1544: creating tools/h5dump/testh5dump.sh
config.status:1544: creating tools/h5dump/testh5dumppbits.sh
config.status:1544: creating tools/h5dump/testh5dumpxml.sh
config.status:1544: creating tools/h5ls/testh5ls.sh
config.status:1544: creating tools/h5import/Makefile
config.status:1544: creating tools/h5import/h5importtestutil.sh
config.status:1544: creating tools/h5diff/Makefile
config.status:1544: creating tools/h5diff/testh5diff.sh
config.status:1544: creating tools/h5diff/testph5diff.sh
config.status:1544: creating tools/h5jam/Makefile
config.status:1544: creating tools/h5jam/testh5jam.sh
config.status:1544: creating tools/h5repack/Makefile
config.status:1544: creating tools/h5repack/h5repack.sh
config.status:1544: creating tools/h5ls/Makefile
config.status:1544: creating tools/h5copy/Makefile
config.status:1544: creating tools/h5copy/testh5copy.sh
config.status:1544: creating tools/lib/Makefile
config.status:1544: creating tools/misc/Makefile
config.status:1544: creating tools/misc/h5cc
config.status:1544: creating tools/misc/testh5mkgrp.sh
config.status:1544: creating tools/misc/testh5repart.sh
config.status:1544: creating tools/h5stat/testh5stat.sh
config.status:1544: creating tools/h5stat/Makefile
config.status:1544: creating examples/Makefile
config.status:1544: creating examples/run-c-ex.sh
config.status:1544: creating examples/testh5cc.sh
config.status:1544: creating c++/Makefile
config.status:1544: creating c++/src/Makefile
config.status:1544: creating c++/src/h5c++
config.status:1544: creating c++/test/Makefile
config.status:1544: creating c++/test/H5srcdir_str.h
config.status:1544: creating c++/examples/Makefile
config.status:1544: creating c++/examples/run-c++-ex.sh
config.status:1544: creating c++/examples/testh5c++.sh
config.status:1544: creating fortran/Makefile
config.status:1544: creating fortran/src/h5fc
config.status:1544: creating fortran/src/Makefile
config.status:1544: creating fortran/test/Makefile
config.status:1544: creating fortran/testpar/Makefile
config.status:1544: creating fortran/examples/Makefile
config.status:1544: creating fortran/examples/run-fortran-ex.sh
config.status:1544: creating fortran/examples/testh5fc.sh
config.status:1544: creating hl/Makefile
config.status:1544: creating hl/src/Makefile
config.status:1544: creating hl/test/Makefile
config.status:1544: creating hl/test/H5srcdir_str.h
config.status:1544: creating hl/tools/Makefile
config.status:1544: creating hl/tools/gif2h5/Makefile
config.status:1544: creating hl/tools/gif2h5/h52giftest.sh
config.status:1544: creating hl/examples/Makefile
config.status:1544: creating hl/examples/run-hlc-ex.sh
config.status:1544: creating hl/c++/Makefile
config.status:1544: creating hl/c++/src/Makefile
config.status:1544: creating hl/c++/test/Makefile
config.status:1544: creating hl/c++/examples/Makefile
config.status:1544: creating hl/c++/examples/run-hlc++-ex.sh
config.status:1544: creating hl/fortran/Makefile
config.status:1544: creating hl/fortran/src/Makefile
config.status:1544: creating hl/fortran/test/Makefile
config.status:1544: creating hl/fortran/examples/Makefile
config.status:1544: creating hl/fortran/examples/run-hlfortran-ex.sh
config.status:1544: creating src/H5config.h
config.status:1773: executing pubconf commands
config.status:1773: executing depfiles commands
config.status:1773: executing libtool commands
## Cache variables. ##
ac_cv_build=x86_64-unknown-linux-gnu
ac_cv_c_bigendian=no
ac_cv_c_compiler_gnu=yes
ac_cv_c_const=yes
ac_cv_c_inline=inline
ac_cv_cxx_compiler_gnu=yes
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=set
ac_cv_env_CC_value=/usr/bin/mpicc
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=set
ac_cv_env_CXX_value=/usr/bin/mpicxx
ac_cv_env_FCFLAGS_set=
ac_cv_env_FCFLAGS_value=
ac_cv_env_FC_set=set
ac_cv_env_FC_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_func_BSDgettimeofday=no
ac_cv_func_GetConsoleScreenBufferInfo=no
ac_cv_func__getvideoconfig=no
ac_cv_func__scrsize=no
ac_cv_func_alarm=yes
ac_cv_func_clock_gettime=yes
ac_cv_func_compress2=yes
ac_cv_func_difftime=yes
ac_cv_func_dlopen=yes
ac_cv_func_fork=yes
ac_cv_func_frexpf=yes
ac_cv_func_frexpl=yes
ac_cv_func_fseeko64=yes
ac_cv_func_fseeko=yes
ac_cv_func_fstat64=yes
ac_cv_func_ftello64=yes
ac_cv_func_ftello=yes
ac_cv_func_ftruncate64=yes
ac_cv_func_gethostname=yes
ac_cv_func_getpwuid=yes
ac_cv_func_getrusage=yes
ac_cv_func_gettextinfo=no
ac_cv_func_gettimeofday=yes
ac_cv_func_ioctl=yes
ac_cv_func_longjmp=yes
ac_cv_func_lseek64=yes
ac_cv_func_lstat=yes
ac_cv_func_rand_r=yes
ac_cv_func_random=yes
ac_cv_func_setjmp=yes
ac_cv_func_setsysinfo=no
ac_cv_func_shl_load=no
ac_cv_func_siglongjmp=yes
ac_cv_func_signal=yes
ac_cv_func_sigprocmask=yes
ac_cv_func_sigsetjmp=no
ac_cv_func_snprintf=yes
ac_cv_func_srandom=yes
ac_cv_func_stat64=yes
ac_cv_func_strdup=yes
ac_cv_func_symlink=yes
ac_cv_func_system=yes
ac_cv_func_tmpfile=yes
ac_cv_func_vasprintf=yes
ac_cv_func_vsnprintf=yes
ac_cv_func_waitpid=yes
ac_cv_have_decl_CLOCK_MONOTONIC=yes
ac_cv_header_dirent_h=yes
ac_cv_header_dlfcn_h=yes
ac_cv_header_features_h=yes
ac_cv_header_inttypes_h=yes
ac_cv_header_io_h=no
ac_cv_header_mach_mach_time_h=no
ac_cv_header_memory_h=yes
ac_cv_header_pthread_h=yes
ac_cv_header_setjmp_h=yes
ac_cv_header_stdc=yes
ac_cv_header_stddef_h=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_sys_ioctl_h=yes
ac_cv_header_sys_resource_h=yes
ac_cv_header_sys_socket_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_time_h=yes
ac_cv_header_sys_timeb_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_time=yes
ac_cv_header_unistd_h=yes
ac_cv_header_winsock2_h=no
ac_cv_header_zlib_h=yes
ac_cv_host=x86_64-unknown-linux-gnu
ac_cv_lib_dl_dlopen=yes
ac_cv_lib_dld_shl_load=no
ac_cv_lib_m_ceil=yes
ac_cv_lib_pthread_pthread_self=yes
ac_cv_lib_z_compress2=yes
ac_cv_member_struct_tm_tm_zone=yes
ac_cv_objext=o
ac_cv_path_EGREP='/usr/bin/grep -E'
ac_cv_path_FGREP='/usr/bin/grep -F'
ac_cv_path_GREP=/usr/bin/grep
ac_cv_path_SED=/usr/bin/sed
ac_cv_path_TR=/usr/bin/tr
ac_cv_path_install='/usr/bin/install -c'
ac_cv_path_mkdir=/usr/bin/mkdir
ac_cv_prog_AR=ar
ac_cv_prog_AWK=gawk
ac_cv_prog_CPP='/usr/bin/mpicc -E'
ac_cv_prog_CXXCPP='/usr/bin/mpicxx -E'
ac_cv_prog_PERL=perl
ac_cv_prog_ac_ct_CC=/usr/bin/mpicc
ac_cv_prog_ac_ct_DLLTOOL=dlltool
ac_cv_prog_ac_ct_OBJDUMP=objdump
ac_cv_prog_ac_ct_RANLIB=ranlib
ac_cv_prog_ac_ct_STRIP=strip
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_make_make_set=yes
ac_cv_search_clock_gettime='none required'
ac_cv_sizeof___int64=0
ac_cv_sizeof_char=1
ac_cv_sizeof_double=8
ac_cv_sizeof_float=4
ac_cv_sizeof_int16_t=2
ac_cv_sizeof_int32_t=4
ac_cv_sizeof_int64_t=8
ac_cv_sizeof_int8_t=1
ac_cv_sizeof_int=4
ac_cv_sizeof_int_fast16_t=8
ac_cv_sizeof_int_fast32_t=8
ac_cv_sizeof_int_fast64_t=8
ac_cv_sizeof_int_fast8_t=1
ac_cv_sizeof_int_least16_t=2
ac_cv_sizeof_int_least32_t=4
ac_cv_sizeof_int_least64_t=8
ac_cv_sizeof_int_least8_t=1
ac_cv_sizeof_long=8
ac_cv_sizeof_long_double=16
ac_cv_sizeof_long_long=8
ac_cv_sizeof_off64_t=8
ac_cv_sizeof_off_t=8
ac_cv_sizeof_ptrdiff_t=8
ac_cv_sizeof_short=2
ac_cv_sizeof_size_t=8
ac_cv_sizeof_ssize_t=8
ac_cv_sizeof_uint16_t=2
ac_cv_sizeof_uint32_t=4
ac_cv_sizeof_uint64_t=8
ac_cv_sizeof_uint8_t=1
ac_cv_sizeof_uint_fast16_t=8
ac_cv_sizeof_uint_fast32_t=8
ac_cv_sizeof_uint_fast64_t=8
ac_cv_sizeof_uint_fast8_t=1
ac_cv_sizeof_uint_least16_t=2
ac_cv_sizeof_uint_least32_t=4
ac_cv_sizeof_uint_least64_t=8
ac_cv_sizeof_uint_least8_t=1
ac_cv_sizeof_unsigned=4
ac_cv_struct_tm=time.h
ac_cv_sys_file_offset_bits=no
ac_cv_sys_largefile_CC=no
ac_cv_type_off_t=yes
ac_cv_type_ptrdiff_t=yes
ac_cv_type_size_t=yes
ac_cv_type_ssize_t=yes
am_cv_CC_dependencies_compiler_type=gcc3
am_cv_CXX_dependencies_compiler_type=gcc3
am_cv_make_support_nested_variables=yes
hdf5_cv_bad_log2_code_generated=no
hdf5_cv_convert_denormal_float=yes
hdf5_cv_convert_float_llong_not_works=no
hdf5_cv_direct_io=no
hdf5_cv_fp_to_integer_overflow_works=yes
hdf5_cv_fp_to_ullong_accurate=yes
hdf5_cv_fp_to_ullong_right_maximum=yes
hdf5_cv_gettimeofday_tz=yes
hdf5_cv_have_lfs=yes
hdf5_cv_host=x86_64-unknown-linux-gnu
hdf5_cv_integer_to_ldouble_accurate=yes
hdf5_cv_ldouble_to_integer_accurate=yes
hdf5_cv_ldouble_to_integer_works=yes
hdf5_cv_ldouble_to_llong_accurate=yes
hdf5_cv_ldouble_to_long_special=no
hdf5_cv_ldouble_to_uint_accurate=yes
hdf5_cv_llong_to_fp_cast_works=yes
hdf5_cv_llong_to_ldouble_correct=yes
hdf5_cv_lone_colon=yes
hdf5_cv_long_to_ldouble_special=no
hdf5_cv_mpi_file_set_size_big=yes
hdf5_cv_printf_ll=l
hdf5_cv_system_scope_threads=yes
hdf5_cv_ullong_to_fp_cast_works=yes
hdf5_cv_ullong_to_ldouble_precision=yes
hdf5_cv_ulong_to_float_accurate=yes
hdf5_cv_ulong_to_fp_bottom_bit_accurate=yes
hdf5_cv_vsnprintf_works=yes
lt_cv_ar_at_file=@
lt_cv_archive_cmds_need_lc=no
lt_cv_deplibs_check_method=pass_all
lt_cv_dlopen=dlopen
lt_cv_dlopen_libs=
lt_cv_dlopen_self=yes
lt_cv_dlopen_self_static=yes
lt_cv_file_magic_cmd='$MAGIC_CMD'
lt_cv_file_magic_test_file=
lt_cv_ld_reload_flag=-r
lt_cv_nm_interface='BSD nm'
lt_cv_objdir=.libs
lt_cv_path_LD=/usr/bin/ld
lt_cv_path_LDCXX='/usr/bin/ld -m elf_x86_64'
lt_cv_path_NM='/usr/bin/nm -B'
lt_cv_path_mainfest_tool=no
lt_cv_prog_compiler_c_o=yes
lt_cv_prog_compiler_c_o_CXX=yes
lt_cv_prog_compiler_pic='-fPIC -DPIC'
lt_cv_prog_compiler_pic_CXX='-fPIC -DPIC'
lt_cv_prog_compiler_pic_works=yes
lt_cv_prog_compiler_pic_works_CXX=yes
lt_cv_prog_compiler_rtti_exceptions=no
lt_cv_prog_compiler_static_works=no
lt_cv_prog_compiler_static_works_CXX=no
lt_cv_prog_gnu_ld=yes
lt_cv_prog_gnu_ldcxx=yes
lt_cv_sharedlib_from_linklib_cmd='printf %s\n'
lt_cv_shlibpath_overrides_runpath=no
lt_cv_sys_global_symbol_pipe='sed -n -e '\''s/^.*[	 ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[	 ][	 ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p'\'' | sed '\''/ __gnu_lto/d'\'''
lt_cv_sys_global_symbol_to_c_name_address='sed -n -e '\''s/^: \([^ ]*\)[ ]*$/  {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/  {"\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_c_name_address_lib_prefix='sed -n -e '\''s/^: \([^ ]*\)[ ]*$/  {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \(lib[^ ]*\)$/  {"\2", (void *) \&\2},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/  {"lib\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_cdecl='sed -n -e '\''s/^T .* \(.*\)$/extern int \1();/p'\'' -e '\''s/^[ABCDGIRSTW]* .* \(.*\)$/extern char \1;/p'\'''
lt_cv_sys_max_cmd_len=1572864
lt_cv_to_host_file_cmd=func_convert_file_noop
lt_cv_to_tool_file_cmd=func_convert_file_noop
## Output variables. ##
ACLOCAL='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11/bin/missing --run aclocal-1.12'
ADD_PARALLEL_FILES='no'
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='$${TAR-tar}'
AM_BACKSLASH='\'
AM_CFLAGS=''
AM_CPPFLAGS='-D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_BSD_SOURCE '
AM_CXXFLAGS=''
AM_DEFAULT_V='$(AM_DEFAULT_VERBOSITY)'
AM_DEFAULT_VERBOSITY='0'
AM_FCFLAGS=''
AM_LDFLAGS=' -L/usr/lib64/libpthread.so -L/usr/lib64/libz.so'
AM_MAKEFLAGS=''
AM_V='$(V)'
AR='ar'
AS='as'
AUTOCONF='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11/bin/missing --run autoconf'
AUTOHEADER='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11/bin/missing --run autoheader'
AUTOMAKE='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11/bin/missing --run automake-1.12'
AWK='gawk'
BUILD_ALL_CONDITIONAL_FALSE=''
BUILD_ALL_CONDITIONAL_TRUE='#'
BUILD_CXX_CONDITIONAL_FALSE='#'
BUILD_CXX_CONDITIONAL_TRUE=''
BUILD_FORTRAN_CONDITIONAL_FALSE=''
BUILD_FORTRAN_CONDITIONAL_TRUE='#'
BUILD_HDF5_HL_CONDITIONAL_FALSE='#'
BUILD_HDF5_HL_CONDITIONAL_TRUE=''
BUILD_PARALLEL_CONDITIONAL_FALSE='#'
BUILD_PARALLEL_CONDITIONAL_TRUE=''
BUILD_SHARED_SZIP_CONDITIONAL_FALSE=''
BUILD_SHARED_SZIP_CONDITIONAL_TRUE='#'
BYTESEX='little-endian'
CC='/usr/bin/mpicc'
CCDEPMODE='depmode=gcc3'
CC_VERSION='/usr/bin/mpicc'
CFLAGS=''
CLEARFILEBUF='yes'
CODESTACK='no'
CONFIG_DATE='Tue Nov 19 13:59:17 BRST 2013'
CONFIG_MODE='production'
CONFIG_USER='carbrevi at ALA_PC180'
CPPFLAGS=''
CXX='/usr/bin/mpicxx'
CXXDEPMODE='depmode=gcc3'
CXXFLAGS=''
CXX_SHARED_CONDITIONAL_FALSE='#'
CXX_SHARED_CONDITIONAL_TRUE=''
CXX_VERSION='/usr/bin/mpicxx'
CYGPATH_W='echo'
DEBUG_PKG=''
DEFAULT_API_VERSION='v18'
DEFS='-DHAVE_CONFIG_H'
DEPDIR='.deps'
DEPRECATED_SYMBOLS='yes'
DIRECT_VFD='no'
DIRECT_VFD_CONDITIONAL_FALSE=''
DIRECT_VFD_CONDITIONAL_TRUE='#'
DLLTOOL='dlltool'
DSYMUTIL=''
DUMPBIN=''
DYNAMIC_DIRS='-R/usr/lib64/libz.so -R/usr/lib64/libpthread.so -R/usr/lib64/libz.so -R/usr/lib64/libpthread.so '
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EXEEXT=''
EXTERNAL_FILTERS='deflate(zlib)'
F9XMODEXT=''
F9XMODFLAG=''
F9XSUFFIXFLAG=''
FC2003=''
FC='no'
FCFLAGS=''
FCFLAGS_f90=''
FCLIBS=''
FC_VERSION='no'
FILTERS='shuffle,fletcher32,nbit,scaleoffset'
FORTRAN_2003_CONDITIONAL_F_FALSE=''
FORTRAN_2003_CONDITIONAL_F_TRUE='#'
FORTRAN_DEFAULT_REALisDBLE_F_FALSE=''
FORTRAN_DEFAULT_REALisDBLE_F_TRUE='#'
FORTRAN_HAVE_SIZEOF_FALSE=''
FORTRAN_HAVE_SIZEOF_TRUE='#'
FORTRAN_SHARED_CONDITIONAL_FALSE=''
FORTRAN_SHARED_CONDITIONAL_TRUE='#'
FSEARCH_DIRS=''
GPFS='no'
GREP='/usr/bin/grep'
H5_CFLAGS='-std=c99 -pedantic -Wall -Wextra -Wundef -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-qual -Wcast-align -Wwrite-strings -Wconversion -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wnested-externs -Winline -Wfloat-equal -Wmissing-format-attribute -Wmissing-noreturn -Wpacked -Wdisabled-optimization -Wformat=2 -Wendif-labels -Wdeclaration-after-statement -Wold-style-definition -Winvalid-pch -Wvariadic-macros -Winit-self -Wmissing-include-dirs -Wswitch-default -Wswitch-enum -Wunused-macros -Wunsafe-loop-optimizations -Wc++-compat -Wstrict-overflow -Wlogical-op -Wlarger-than=2048 -Wvla -Wsync-nand -Wframe-larger-than=16384 -Wpacked-bitfield-compat -Wstrict-overflow=5 -Wjump-misses-init -Wunsuffixed-float-constants -Wdouble-promotion -Wsuggest-attribute=const -Wtrampolines -Wstack-usage=8192 -Wvector-operation-performance -O3 -fomit-frame-pointer -finline-functions'
H5_CPPFLAGS='-D_POSIX_C_SOURCE=199506L   -DNDEBUG -UH5_DEBUG_API'
H5_CXXFLAGS=' '
H5_CXX_SHARED='yes'
H5_FCFLAGS=' '
H5_FORTRAN_SHARED='no'
H5_LDFLAGS=''
H5_LONE_COLON='yes'
H5_VERSION='1.8.11'
HADDR_T=''
HAVE_DMALLOC='no'
HAVE_FORTRAN_2003=''
HAVE_PTHREAD='yes'
HAVE_SHARED_CONDITIONAL_FALSE='#'
HAVE_SHARED_CONDITIONAL_TRUE=''
HDF5_HL='yes'
HDF5_INTERFACES=' c++'
HDF_CXX='yes'
HDF_FORTRAN2003='no'
HDF_FORTRAN='no'
HID_T=''
HL='hl'
HL_FOR=''
HSIZE_T=''
HSSIZE_T=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
INSTRUMENT='no'
INSTRUMENT_LIBRARY='no'
LARGEFILE='yes'
LD='/usr/bin/ld -m elf_x86_64'
LDFLAGS=''
LIBOBJS=''
LIBS=' -lpthread -lz -ldl -lm '
LIBTOOL='$(SHELL) $(top_builddir)/libtool'
LIPO=''
LL_PATH=''
LN_S='ln -s'
LTLIBOBJS=''
LT_STATIC_EXEC=''
MAINT='#'
MAINTAINER_MODE_FALSE=''
MAINTAINER_MODE_TRUE='#'
MAKEINFO='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11/bin/missing --run makeinfo'
MANIFEST_TOOL=':'
MKDIR_P='/usr/bin/mkdir -p'
MPE=''
MPI_GET_SIZE='yes'
NM='/usr/bin/nm -B'
NMEDIT=''
OBJDUMP='objdump'
OBJECT_NAMELEN_DEFAULT_F=''
OBJEXT='o'
OTOOL64=''
OTOOL=''
PACKAGE='hdf5'
PACKAGE_BUGREPORT='help at hdfgroup.org'
PACKAGE_NAME='HDF5'
PACKAGE_STRING='HDF5 1.8.11'
PACKAGE_TARNAME='hdf5'
PACKAGE_URL=''
PACKAGE_VERSION='1.8.11'
PARALLEL='yes'
PATH_SEPARATOR=':'
PERL='perl'
RANLIB='ranlib'
ROOT='/home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11'
RUNPARALLEL='/usr/bin/mpiexec'
RUNSERIAL=''
R_INTEGER=''
R_LARGE=''
SEARCH='VPATH=$(srcdir) $(top_builddir)/src $(top_srcdir)/src'
SED='/usr/bin/sed'
SETX='set -x'
SET_MAKE=''
SHELL='/bin/sh'
SIZE_T=''
STATIC_EXEC='no'
STATIC_SHARED='shared'
STRICT_FORMAT_CHECKS='no'
STRIP='strip'
TESTPARALLEL='testpar'
THREADSAFE='no'
TIME=''
TR='/usr/bin/tr'
TRACE_API='no'
UNAME_INFO='Linux ALA_PC180 3.12.0-1-ARCH #1 SMP PREEMPT Wed Nov 6 09:06:27 CET 2013 x86_64 GNU/Linux'
USE_FILTER_DEFLATE='yes'
USE_FILTER_FLETCHER32='yes'
USE_FILTER_NBIT='yes'
USE_FILTER_SCALEOFFSET='yes'
USE_FILTER_SHUFFLE='yes'
USE_FILTER_SZIP='no'
USINGMEMCHECKER='no'
VERSION='1.8.11'
WORDS_BIGENDIAN='no'
ac_ct_AR=''
ac_ct_CC='/usr/bin/mpicc'
ac_ct_CXX=''
ac_ct_DUMPBIN=''
ac_ct_FC=''
am__EXEEXT_FALSE=''
am__EXEEXT_TRUE='#'
am__fastdepCC_FALSE='#'
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE='#'
am__fastdepCXX_TRUE=''
am__include='include'
am__isrc=''
am__leading_dot='.'
am__nodep='_no'
am__quote=''
am__tar='$${TAR-tar} chof - "$$tardir"'
am__untar='$${TAR-tar} xf -'
bindir='${exec_prefix}/bin'
build='x86_64-unknown-linux-gnu'
build_alias=''
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='unknown'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
dvidir='${docdir}'
enable_shared='yes'
enable_static='no'
exec_prefix='${prefix}'
host='x86_64-unknown-linux-gnu'
host_alias=''
host_cpu='x86_64'
host_os='linux-gnu'
host_vendor='unknown'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='${SHELL} /home/carbrevi/opt/lnx_x64/contrib/_build/hdf5-1.8.11/bin/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
mkdir_p='$(MKDIR_P)'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='/home/carbrevi/opt/lnx_x64/contrib/hdf5'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
/* confdefs.h */
#define HAVE_LIBM 1
#define HAVE_STAT64 1
#define HAVE_FSTAT64 1
#define SIZEOF_CHAR 1
#define SIZEOF_SHORT 2
#define SIZEOF_INT 4
#include <sys/types.h>
#include <stdint.h>
#define SIZEOF_INT_FAST16_T 8
#define SIZEOF_UINT_FAST16_T 8
#define SIZEOF_INT32_T 4
#define SIZEOF_UINT32_T 4
#define SIZEOF_INT_LEAST32_T 4
#define SIZEOF_UINT_LEAST32_T 4
#define SIZEOF_INT_FAST32_T 8
#define SIZEOF_UINT_FAST32_T 8
#define SIZEOF_INT64_T 8
#define SIZEOF_UINT64_T 8
#include <sys/types.h> /*for off_t definition*/
#define HAVE_LIBZ 1
#define HAVE_STRUCT_TM_TM_ZONE 1
#define HAVE_TM_ZONE 1
#define HAVE_STRUCT_TIMEZONE 1
#define GETTIMEOFDAY_GIVES_TZ 1
#define HAVE_STAT_ST_BLOCKS 1
#define HAVE_IOCTL 1
#define HAVE_FORK 1
#define HAVE_ATTRIBUTE 1
#define HAVE_C99_FUNC 1
#define HAVE_FUNCTION 1
#define HAVE_C99_DESIGNATED_INITIALIZER 1
#define PRINTF_LL_WIDTH "l"
#define SYSTEM_SCOPE_THREADS 1
#define CLEAR_MEMORY 1
#define HAVE_PARALLEL 1
#define MPI_FILE_SET_SIZE_BIG 1
#define HAVE_MPI_GET_SIZE 1
#define HAVE_FILTER_SHUFFLE 1
#define HAVE_FILTER_FLETCHER32 1
#define HAVE_FILTER_NBIT 1
#define HAVE_FILTER_SCALEOFFSET 1
#define DEFAULT_VFD H5FD_SEC2
#define NO_ALIGNMENT_RESTRICTIONS 1
configure: exit 0
