[MOAB-dev] mixed mesh question
Iulian Grindeanu iulian at mcs.anl.gov
Tue Nov 19 11:42:50 CST 2013
Thanks Carlos,
I have some issues configuring moab with cgns;
I did not rebuild hdf5, we are using version 1.8.8; cgns seems to be built without problems (I used ccmake)
But something is wrong with configuring with cgns.
Do you have any suggestions (besides rebuilding hdf5, cgns, ...)
the symbols needed from hdf5 seem to be there, so I can't really explain the error. Do you use ubuntu 12 or ubuntu 10? Or something else?
/homes/fathom/3rdparty/hdf5-1.8.8-par-mpich2.1.5-gcc/lib> nm libhdf5.so | grep H5T_NATIVE_SCHAR_g
00000000004cc170 D H5T_NATIVE_SCHAR_g
jun/homes/fathom/3rdparty/hdf5-1.8.8-par-mpich2.1.5-gcc/lib> nm libhdf5.so | grep H5Tget_native_type
00000000002424f0 T H5Tget_native_type
configure:32106: result: no
configure:32115: checking for cg_open in -lcgns
configure:32148: /homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/bin/mpicc -o conftest -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -g -I/homes/fathom/3rdparty/cgns/include -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -L/homes/fathom/3rdparty/cgns/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/fathom/3rdparty/hdf5-1.8.8-par-mpich2.1.5-gcc/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/fathom/3rdparty/hdf5-1.8.8-par-mpich2.1.5-gcc/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/fathom/3rdparty/hdf5-1.8.8-par-mpich2.1.5-gcc/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/fathom/3rdparty/hdf5-1.8.8-par-mpich2.1.5-gcc/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/fathom/3rdparty/hdf5-1.8.8-par-mpich2.1.5-gcc/lib conftest.c -lcgns -lhdf5_hl -lhdf5 -lcurl -lm -L/homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lmpich -lopa -lmpl -lrt -lpthread -lgfortran -lm -lquadmath -L/homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lmpichf90 -lmpich -lopa -lmpl -lrt -lpthread -lgfortran -lm -lquadmath >&5
/homes/fathom/3rdparty/cgns/lib/libcgns.so: undefined reference to ` H5T_NATIVE_SCHAR_g '
/homes/fathom/3rdparty/cgns/lib/libcgns.so: undefined reference to `H5Tget_native_type'
/homes/fathom/3rdparty/cgns/lib/libcgns.so: undefined reference to `H5Pset_link_creation_order'
/homes/fathom/3rdparty/cgns/lib/libcgns.so: undefined reference to `H5P_CLS_DATASET_CREATE_g'
/homes/fathom/3rdparty/cgns/lib/libcgns.so: undefined reference to `H5Sget_simple_extent_npoints'
/homes/fathom/3rdparty/cgns/lib/libcgns.so: undefined reference to `H5T_IEEE_F64LE_g'
/homes/fathom/3rdparty/cgns/lib/libcgns.so: undefined reference to `H5P_CLS_FILE_CREATE_g'
/homes/fathom/3rdparty/cgns/lib/libcgns.so: undefined reference to `H5Tcopy'
/homes/fathom/3rdparty/cgns/lib/libcgns.so: undefined reference to `H5Fopen'
----- Original Message -----
| Iulian, here are some data on the supporting libs:
| HDF5 v1.8.11
| I compile the parallel version, but do not use the parallel IO
| capabilities yet in CGNS.
| ./configure \
| CC=%s \
| CXX=%s \
| FC=%s \
| F9X=%s \
| RUNPARALLEL=%s \
| OMPI_MCA_disable_memory_allocator=1 \
| --prefix=%s \
| --enable-largefile \
| --enable-unsupported \
| --enable-shared \
| --disable-static \
| --enable-production=yes \
| --with-pthread=%s,%s \
| --with-zlib=%s,%s \
| --with-default-api-version=v18 \
| --enable-parallel=yes \
| --enable-cxx \
| --disable-sharedlib-rpath"
| hdf5_config.log attached
| CGNS v3.2.1 (Beta)
| We have not considered the parallel IO capabilities as of now. There
| is no clear definition yet how to handle MIXED type element meshes,
| for which you can not specify a fixed record lenght to retrieve with
| hdf5. Although the HDF5 library I linked is mpi-enabled.
| Junior at some point tested with version 3.1.4 release 2 and it
| worked fine, AFAIK.
| The library is transitioning to CMake, I've used:
| cmake \
| -DCGNS_BUILD_SHARED:BOOL=ON \
| -DCMAKE_BUILD_TYPE:STRING=Release \
| -DCMAKE_INSTALL_PREFIX:PATH=%s \
| -DCMAKE_SKIP_RPATH:BOOL=ON \
| -DCGNS_BUILD_CGNSTOOLS:BOOL=OFF \
| -DCGNS_ENABLE_64BIT:BOOL=ON \
| -DCGNS_ENABLE_FORTRAN:BOOL=OFF \
| -DCGNS_ENABLE_PARALLEL:BOOL=ON \
| -DCGNS_ENABLE_HDF5:BOOL=ON \
| -DHDF5_INCLUDE_PATH:PATH=%s \
| -DHDF5_LIBRARY:FILEPATH=%s \
| -DHDF5_NEED_MPI:BOOL=ON \
| -DHDF5_NEED_ZLIB:BOOL=ON \
| -DZLIB_LIBRARY:FILEPATH=%s \
| -DCGNS_ENABLE_SCOPING:BOOL=OFF \
| -DCGNS_ENABLE_TESTS:BOOL=OFF \
| -DMPIEXEC:FILEPATH=%s \
| -DMPI_C_COMPILER:FILEPATH=%s \
| -DMPI_C_INCLUDE_PATH:PATH=\"%s\"
| cgns321_CMakeCache.txt is attached.
| MOAB v4.6.2
| The patch is against the tar file from the website (
| http://ftp.mcs.anl.gov/pub/fathom/moab-4.6.2.tar.gz ). There is no
| need from our side to keep it on 462. Feel free to include it in a
| latter release. It was only convenient for me to keep the patch
| against a fixed release. For this, I packaged in the previous email
| a tar.gz with the modified and new sources and sample cgns files.
| The reader and writer are serial only. We tested against homogeneous
| and heterogeneous meshes up to 20million elements and it worked. You
| can read a CGNS file, convert it to H5M and then convert it back to
| CGNS.
| The modifications to compile moab is just an --with-cgns=DIR flag.
| These build use shared libs for now, as I am working on my
| workstation. Latter I will experiment with static objects for
| clusters.
| If you need more details, let us know.
| Regards,
| Carlos
| On Tue, Nov 19, 2013 at 1:30 PM, Iulian Grindeanu <
| iulian at mcs.anl.gov > wrote:
| | Thank you Carlos and Junior, for your help.
| | I will need to build cgns library; you mentioned that you tested
| | 3.2
| | beta, too; I will probably stick with 3.1.4, (release 2?).
| | Also, what version of hdf5 library do you use? Should it work for
| | any
| | version greater than 1.8?
| | I assume you build statically? Can I also get your config.log files
| | for cgns and moab?
| | I assume that you are not using any of the parallel io capability,
| | because that seems to be available only in beta version.
| | So everything is read/written in serial, isn't it?
| | I am not sure if we will port the cgns reader / writer to 4.6.2
| | also.
| | Is your patch against 4.6.2 tar file or against "Version4.6"
| | branch?
| | There should not be much difference.
| | Tim, what do you suggest? In a way, it should be easier to update
| | 4.6.2. But I don't want to merge to the master after that, there
| | are
| | too many changes. This patch should work out of the box for 4.6.2,
| | after I build cgns.
| | Best Regards,
| | Iulian
| | | Iulian,
| | | Sorry for the delay in getting back to you... I have tested the
| | | new
| | | version and it worked OK for my mesh sample. I will test it
| | | latter
| | | for other cases.
| | | Also, I am sending you the CGNS reader and writer along with
| | | input
| | | cgns mesh examples. We have worked on top of version 462, so
| | | things
| | | may look a little out of place from the repository.
| | | The attached patch modifies some autotools files and new files
| | | (apply
| | | with patch -p0 -i moab462_cgns.patch). Moreover, the tar.gz
| | | contains
| | | sample meshes (simple airfoil mesh in 2D and a mixed-mesh
| | | discretization of a 3D wingbody geometry).
| | | We have tested the CGNS capability with the latest library vesion
| | | 3.1.4 and 3.2-beta. Furthermore, we sticked with the base CGNS
| | | use-case, that is, single base/zone. We will also implement
| | | latter
| | | capability to write out user variables.
| | | Please, feel free to improve the files and if you have any
| | | questions,
| | | let us know. carbrevi at gmail.com and junior.hmg at gmail.com
| | | Regards,
| | | Carlos
| | | On Sat, Nov 16, 2013 at 3:57 AM, Iulian Grindeanu <
| | | | Hi Carlos,
| | | | That ticket is now closed, Tim fixed the bug.
| | | | Please let us know if it works for you.
| | | | Thanks for your patience,
| | | | Iulian
| | | | | Iulian,
| | | | | thanks for checking this out. I will be following the trac
| | | | | ticket.
| | | | | The mesh I used is attached, partitioned for 8 procs (all
| | | | | tri).
| | | | | I
| | | | | noticed that are much simpler sample meshes you created to
| | | | | investigate this issue. Anyway, you can use the airfoil mesh
| | | | | if
| | | | | you
| | | | | find it useful.
| | | | | I use a separate code to compute elements adjacency and then
| | | | | pass
| | | | | those to metis. To write the partitions into h5m I followed
| | | | | the
| | | | | code
| | | | | form mbzoltan tool. The partitioning code is correct
| | | | | (element-based)
| | | | | since I have used this code previously with other
| | | | | applications...
| | | | | I am from Brazil indeed, utc -3h. I'm a PhD candidate from
| | | | | Technological Institute of Aeronautics in Sao Jose dos
| | | | | Campos.
| | | | | Now I am building/adapting parts of my research code
| | | | | (high-order
| | | | | unstructured CFD) to use MOAB. I will stick with 462 for
| | | | | this,
| | | | | working with non-mixed meshes for this transition period. In
| | | | | the
| | | | | near feature I will also look into the structured meshes
| | | | | capability
| | | | | of the library, as well as the high-order elements
| | | | | implementation.
| | | | | The CGNS reader/writer is in the works too and I will submit
| | | | | those
| | | | | as
| | | | | well. My co-worker Junior, cc'ed here, is dealing with the
| | | | | writer
| | | | | part and we are almos done.
| | | | | Regards,
| | | | | Carlos Breviglieri
| | | | | On Sat, Oct 12, 2013 at 5:40 PM, Iulian Grindeanu <
| | | | | | Hi Carlos,
| | | | | | I am seeing a problem with ghosting, thank you for pointing
| | | | | | it
| | | | | | out.
| | | | | | Danqing and I messed up with that code :( to fix some other
| | | | | | issues
| | | | | | we were seeing.
| | | | | | http://trac.mcs.anl.gov/projects/ITAPS/ticket/284
| | | | | | It may take a while to fix it properly.
| | | | | | Thanks again,
| | | | | | Iulian
| | | | | | | Hmmmm,
| | | | | | | Can you send me the 2d_naca0012.h5m with your partition?
| | | | | | | If you do ghosting after reading, did you get the same
| | | | | | | results?
| | | | | | | The elements/processors should not change ownership after
| | | | | | | ghosting,
| | | | | | | but maybe they do.
| | | | | | | It is indeed a work in progress, you may have found
| | | | | | | another
| | | | | | | issue
| | | | | | | Not being able to write is probably the biggest problem.
| | | | | | | On what time zone do you work? :) Also, where are you
| | | | | | | from?
| | | | | | | The
| | | | | | | name
| | | | | | | looks Brazilian, Portuguese, or Italian ? Or Spanish?
| | | | | | | Thanks,
| | | | | | | Iulian
| | | | | | | | Hi Iulian,
| | | | | | | | I have just ran some tests with the latest clone of the
| | | | | | | | master
| | | | | | | | repo
| | | | | | | | (saturday morning). Here are my findings with MOAB
| | | | | | | | 470pre:
| | | | | | | | Now I am able to read partitined mixed meshes without
| | | | | | | | errors.
| | | | | | | | However, if I plot the owned entitied for a given proc,
| | | | | | | | even
| | | | | | | | for
| | | | | | | | non-mixed meshes, they are different from the ones
| | | | | | | | obtained
| | | | | | | | by
| | | | | | | | the
| | | | | | | | partitioner, see below
| | | | | | | | Mesh distribution for 2d_naca0012.h5m (all tri mesh)
| | | | | | | | from
| | | | | | | | partitioner, over 8 procs:
| | | | | | | | proc[0] has 866 elements
| | | | | | | | proc[1] has 863 elements
| | | | | | | | proc[2] has 866 elements
| | | | | | | | proc[3] has 869 elements
| | | | | | | | proc[4] has 872 elements
| | | | | | | | proc[5] has 869 elements
| | | | | | | | proc[6] has 862 elements
| | | | | | | | proc[7] has 877 elements
| | | | | | | | Mesh distribution seen by MOAB 470pre
| | | | | | | | ("PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1")
| | | | | | | | owned_entities[5], size = 864
| | | | | | | | owned_entities[6], size = 853
| | | | | | | | owned_entities[7], size = 871
| | | | | | | | owned_entities[1], size = 859
| | | | | | | | owned_entities[3], size = 860
| | | | | | | | owned_entities[4], size = 867
| | | | | | | | owned_entities[0], size = 866
| | | | | | | | owned_entities[2], size = 861
| | | | | | | | besides procs 0, all other report wrong number of
| | | | | | | | entities.
| | | | | | | | Code
| | | | | | | | to
| | | | | | | | compute such distribution is below (based on
| | | | | | | | example/HelloParMOAB.cpp). The mixed mesh
| | | | | | | | (2d_naca0012_mixed.h5m)
| | | | | | | | now is read (does not crash) but the distribution is
| | | | | | | | off
| | | | | | | | as
| | | | | | | | well.
| | | | | | | | With MOAB 462 the distribution is OK for homogeneous
| | | | | | | | meshes.
| | | | | | | | Moreover, with MOAB 470pre, no output is written to
| | | | | | | | disk
| | | | | | | | with
| | | | | | | | PARALLEL=WRITE_PART, regardless of the mesh type. Using
| | | | | | | | PARALLEL=NONE works, but only one part of the domain is
| | | | | | | | written,
| | | | | | | | as
| | | | | | | | expected.
| | | | | | | | I understand that this is a work in progress. If you
| | | | | | | | need
| | | | | | | | more
| | | | | | | | information, let me know.
| | | | | | | | Regards,
| | | | | | | | Carlos Breviglieri
| | | | | | | | read_options =
| | | | | | | | "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1";
| | | | | | | | moab::Interface* mb = new Core;
| | | | | | | | // Create root sets for each mesh. Then pass these
| | | | | | | | // to the load_file functions to be populated.
| | | | | | | | EntityHandle rootset, partnset;
| | | | | | | | mb->create_meshset(MESHSET_SET, rootset);
| | | | | | | | mb->create_meshset(MESHSET_SET, partnset);
| | | | | | | | // Create the parallel communicator object with the
| | | | | | | | partition
| | | | | | | | handle
| | | | | | | | associated with MOAB
| | | | | | | | ParallelComm *pcomm = ParallelComm::get_pcomm(mb,
| | | | | | | | partnset,
| | | | | | | | &myComm);
| | | | | | | | // Load the file from disk with given options
| | | | | | | | mb->load_file(meshFile.c_str(), &rootset,
| | | | | | | | read_options.c_str());
| | | | | | | | // Get all entities of dimension = dim
| | | | | | | | Range elemRange, owned_entities;
| | | | | | | | int dim = 2;
| | | | | | | | mb->get_entities_by_dimension(rootset, dim, elemRange,
| | | | | | | | false);
| | | | | | | | pcomm->filter_pstatus(elemRange, // pass entities that
| | | | | | | | we
| | | | | | | | want
| | | | | | | | to
| | | | | | | | filter
| | | | | | | | PSTATUS_NOT_OWNED, // status we are looking for
| | | | | | | | PSTATUS_NOT, // operation applied ; so it will return
| | | | | | | | owned
| | | | | | | | entities
| | | | | | | | (!not_owned = owned)
| | | | | | | | -1, // this means all processors
| | | | | | | | &owned_entities);
| | | | | | | | std::vector<int> procID(owned_entities.size(), myRank);
| | | | | | | | std::cout << "owned_entities[" << myRank << "], size =
| | | | | | | | owned_entities.size() << std::endl;
| | | | | | | | Tag procID_tag;
| | | | | | | | mb->tag_get_handle("PROC_ID", 1, MB_TYPE_INTEGER,
| | | | | | | | procID_tag,
| | | | | | | | MB_TAG_CREAT | MB_TAG_DENSE, &procID[0]);
| | | | | | | | mb->tag_set_data(procID_tag, owned_entities,
| | | | | | | | &procID[0]);
| | | | | | | | // WRITE_PART writes all partitions to a single output
| | | | | | | | file
| | | | | | | | (only
| | | | | | | | h5m
| | | | | | | | format supports parallel IO at the moment).
| | | | | | | | // One can use the mbconvert tool to convert the output
| | | | | | | | to
| | | | | | | | other
| | | | | | | | formats.
| | | | | | | | mb->write_file(outputFile.c_str(), "H5M",
| | | | | | | | "PARALLEL=WRITE_PART");
| | | | | | | | On Thu, Oct 10, 2013 at 10:37 AM, Tim Tautges <
| | | | | | | | tautges at mcs.anl.gov
| | | | | | | | wrote:
| | | | | | | | | Yeah, too complicated to backport, and latest works
| | | | | | | | | for
| | | | | | | | | Carlos
| | | | | | | | | anyway.
| | | | | | | | | - tim
| | | | | | | | | On 10/09/2013 09:41 PM, Iulian Grindeanu wrote:
| | | | | | | | | | Both worked for me, with the current code
| | | | | | | | | | (4.7.0pre)
| | | | | | | | | | I don't get your error :(
| | | | | | | | | | What version are you using? I will try 4.6.2, but
| | | | | | | | | | it
| | | | | | | | | | should
| | | | | | | | | | be
| | | | | | | | | | fine
| | | | | | | | | | there too :(
| | | | | | | | | | OK, I got an error with more quads, on 4.6.2 maybe
| | | | | | | | | | I
| | | | | | | | | | mixed
| | | | | | | | | | them
| | | | | | | | | | up
| | | | | | | | | | when I saved :(
| | | | | | | | | | mpiexec -np 2 /home/iulian/source/MOAB46/
| | | | | | | | | | tools/mbconvert
| | | | | | | | | | -O
| | | | | | | | | | PARALLEL=READ_PART -O PARTITION=PARALLEL_PARTITION
| | | | | | | | | | -O
| | | | | | | | | | PARALLEL_RESOLVE_SHARED_ENTS -O
| | | | | | | | | | -o
| | | | | | | | | | PARALLEL=WRITE_PART
| | | | | | | | | | /home/iulian/tmp/2d_naca0012_ mixed2.h5m 2.h5m
| | | | | | | | | | Leaked HDF5 object handle in function at
| | | | | | | | | | ../../../moab46source/src/io/ ReadHDF5.cpp:1523
| | | | | | | | | | Open at entrance: 1
| | | | | | | | | | Open at exit: 2
| | | | | | | | | | ../../../moab46source/src/io/ ReadHDF5.cpp:827
| | | | | | | | | | Open at entrance: 1
| | | | | | | | | | Open at exit: 2
| | | | | | | | | | Failed to load "/home/iulian/tmp/2d_naca0012_
| | | | | | | | | | mixed2.h5m".
| | | | | | | | | | Error code: MB_INDEX_OUT_OF_RANGE (1)
| | | | | | | | | | Error message: Failed in step PARALLEL READ PART
| | | | | | | | | | Cannot close file with open handles: 0 file, 1
| | | | | | | | | | data,
| | | | | | | | | | 0
| | | | | | | | | | group,
| | | | | | | | | | 0
| | | | | | | | | | type,
| | | | | | | | | | 0 attr
| | | | | | | | | | I will look into it.
| | | | | | | | | | Hi Carlos,
| | | | | | | | | | It looks like it is a bug in 4.6.2.
| | | | | | | | | | I don't know if it will be fixed, there are some
| | | | | | | | | | important
| | | | | | | | | | changes
| | | | | | | | | | in
| | | | | | | | | | ghosting in current version.
| | | | | | | | | | So for Version4.6 branch, the model with 17 quads
| | | | | | | | | | works
| | | | | | | | | | fine
| | | | | | | | | | if
| | | | | | | | | | you
| | | | | | | | | | don't do ghosting:
| | | | | | | | | | iulian at T520-iuli:~/source/ MOAB46$ mpiexec -np 2
| | | | | | | | | | /home/iulian/source/MOAB46/ tools/mbconvert -O
| | | | | | | | | | PARALLEL=READ_PART
| | | | | | | | | | -O
| | | | | | | | | | PARTITION=PARALLEL_PARTITION -O
| | | | | | | | | | -o
| | | | | | | | | | PARALLEL=WRITE_PART
| | | | | | | | | | /home/iulian/tmp/2d_naca0012_ mixed_invert.h5m
| | | | | | | | | | 2.h5m
| | | | | | | | | | Read "/home/iulian/tmp/2d_naca0012_
| | | | | | | | | | mixed_invert.h5m"
| | | | | | | | | | Wrote "2.h5m"
| | | | | | | | | | I would recommend upgrading to current version.
| | | | | | | | | | That code is pretty complicated, and I am not sure
| | | | | | | | | | if
| | | | | | | | | | we
| | | | | | | | | | will
| | | | | | | | | | backport changes to Version4.6 branch.
| | | | | | | | | | Tim, what do you suggest? Should I try to backport
| | | | | | | | | | some
| | | | | | | | | | changes
| | | | | | | | | | in
| | | | | | | | | | ParallelComm? I know you are working on that code.
| | | | | | | | | | Thanks,
| | | | | | | | | | Iulian
| | | | | | | | | "You will keep in perfect peace him whose mind is
| | | | | | | | | steadfast, because he trusts in you." Isaiah 26:3
| | | | | | | | | Tim Tautges Argonne National Laboratory
| | | | | | | | | ( tautges at mcs.anl.gov ) (telecommuting from
| | | | | | | | | UW-Madison)
| | | | | | | | | phone (gvoice): (608) 354-1459 1500 Engineering Dr.
| | | | | | | | | fax: (608) 263-4499 Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131119/e7cc243c/attachment-0001.html>
