[MOAB-dev] commit/MOAB: danwu: Besides nVertLevels, should support other optional levels (e.g. nVertLevelsP1) for MPAS reader, in progress.
commits-noreply at bitbucket.org
Mon Nov 11 17:09:22 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/c79a9de34e28/
Changeset: c79a9de34e28
Branch: master
User: danwu
Date: 2013-11-12 00:08:35
Summary: Besides nVertLevels, should support other optional levels (e.g. nVertLevelsP1) for MPAS reader, in progress.
Affected #: 1 file
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index 54ba598..6c728aa 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -97,7 +97,7 @@ ErrorCode NCHelperMPAS::init_mesh_vals()
vDim = idx;
nVertices = dimLens[idx];
- // Get number of levels
+ // Get number of vertex levels
if ((vit = std::find(dimNames.begin(), dimNames.end(), "nVertLevels")) != dimNames.end())
idx = vit - dimNames.begin();
else {
@@ -106,6 +106,27 @@ ErrorCode NCHelperMPAS::init_mesh_vals()
levDim = idx;
nLevels = dimLens[idx];
+ // Dimension numbers for other optional levels
+ std::vector<unsigned int> opt_lev_dims;
+ // Get number of vertex levels P1
+ if ((vit = std::find(dimNames.begin(), dimNames.end(), "nVertLevelsP1")) != dimNames.end()) {
+ idx = vit - dimNames.begin();
+ opt_lev_dims.push_back(idx);
+ // Get number of vertex levels P2
+ if ((vit = std::find(dimNames.begin(), dimNames.end(), "nVertLevelsP2")) != dimNames.end()) {
+ // Get number of soil levels
+ if ((vit = std::find(dimNames.begin(), dimNames.end(), "nSoilLevels")) != dimNames.end()) {
std::map<std::string, ReadNC::VarData>::iterator vmit;
// Store time coordinate values in tVals
@@ -124,17 +145,37 @@ ErrorCode NCHelperMPAS::init_mesh_vals()
// Determine the entity location type of a variable
for (vmit = varInfo.begin(); vmit != varInfo.end(); ++vmit) {
ReadNC::VarData& vd = (*vmit).second;
- if ((std::find(vd.varDims.begin(), vd.varDims.end(), vDim) != vd.varDims.end()) &&
- (std::find(vd.varDims.begin(), vd.varDims.end(), levDim) != vd.varDims.end()))
+ vd.entLoc = ReadNC::ENTLOCSET;
+ if ((std::find(vd.varDims.begin(), vd.varDims.end(), tDim) != vd.varDims.end()) &&
+ (std::find(vd.varDims.begin(), vd.varDims.end(), vDim) != vd.varDims.end()))
vd.entLoc = ReadNC::ENTLOCVERT;
- else if ((std::find(vd.varDims.begin(), vd.varDims.end(), eDim) != vd.varDims.end()) &&
+ else if ((std::find(vd.varDims.begin(), vd.varDims.end(), tDim) != vd.varDims.end()) &&
+ (std::find(vd.varDims.begin(), vd.varDims.end(), eDim) != vd.varDims.end()))
vd.entLoc = ReadNC::ENTLOCEDGE;
- else if ((std::find(vd.varDims.begin(), vd.varDims.end(), cDim) != vd.varDims.end()) &&
+ (std::find(vd.varDims.begin(), vd.varDims.end(), cDim) != vd.varDims.end()))
vd.entLoc = ReadNC::ENTLOCFACE;
+ // Determine number of levels of a variable
+ for (vmit = varInfo.begin(); vmit != varInfo.end(); ++vmit) {
+ ReadNC::VarData& vd = (*vmit).second;
+ vd.numLev = 1;
+ if (std::find(vd.varDims.begin(), vd.varDims.end(), levDim) != vd.varDims.end()) {
+ vd.numLev = nLevels;
+ continue;
+ for (unsigned int i = 0; i < opt_lev_dims.size(); i++) {
+ if (std::find(vd.varDims.begin(), vd.varDims.end(), opt_lev_dims[i]) != vd.varDims.end()) {
+ vd.numLev = dimLens[opt_lev_dims[i]];
+ break;
// Hack: create dummy tags for dimensions (like nCells) with no corresponding coordinate variables
init_dims_with_no_coord_vars_info();
@@ -585,8 +626,6 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC:
if (noEdges && vdatas[i].entLoc == ReadNC::ENTLOCEDGE)
continue;
- vdatas[i].numLev = nLevels;
for (unsigned int t = 0; t < tstep_nums.size(); t++) {
dbgOut.tprintf(2, "Reading variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t]);
// Get the tag to read into
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
