[MOAB-dev] commit/MOAB: iulian07: do not set unused correlation tags
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Mon Nov 11 17:31:05 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/7a5c2d51e29a/
Changeset:   7a5c2d51e29a
Branch:      master
User:        iulian07
Date:        2013-11-12 00:24:00
Summary:     do not set unused correlation tags
so right now, the departure and arrival meshes are related using
corr tag (dense, handle tag); they are also correlated using
global id;
the vertices are correlated from euler to lagrange
the cells are correlated from lagrange to euler (so the departure cells know
where they are going)
More clean up is needed for global ig; do we really need the map eh-globalid?
( std::map<int, EntityHandle> globalID_to_eh )
Affected #:  1 file
diff --git a/tools/mbcslam/diffusion.cpp b/tools/mbcslam/diffusion.cpp
index e6b3ad7..ed1d120 100644
--- a/tools/mbcslam/diffusion.cpp
+++ b/tools/mbcslam/diffusion.cpp
@@ -53,6 +53,7 @@ int case_number = 1; // 1, 2 (non-divergent) 3 divergent
 moab::Tag corrTag;
 bool noWrite = false;
 bool parallelWrite = false;
+bool velocity = false;
 int field_type = 1 ; // 1 quasi smooth, 2 - smooth, 3 non-smooth,
 #ifdef MESHDIR
 std::string TestDir( STRINGIFY(MESHDIR) );
@@ -260,13 +261,12 @@ ErrorCode compute_velocity_case1(Interface * mb, EntityHandle euler_set, Tag & t
     // increment to the next node
     ptr_velo+=3;// to next velocity
-  if (!noWrite)
-    std::stringstream velos;
-    velos<<"Tracer" << rank<<"_"<<tStep<<  ".vtk";
-    rval = mb->write_file(velos.str().c_str(), 0, 0, &euler_set, 1, &tagh, 1);
-    CHECK_ERR(rval);
+  std::stringstream velos;
+  velos<<"Tracer" << rank<<"_"<<tStep<<  ".vtk";
+  rval = mb->write_file(velos.str().c_str(), 0, 0, &euler_set, 1, &tagh, 1);
+  CHECK_ERR(rval);
   return MB_SUCCESS;
@@ -312,9 +312,11 @@ ErrorCode  create_lagr_mesh(Interface * mb, EntityHandle euler_set, EntityHandle
     rval = mb->tag_set_data(corrTag, &oldV, 1, &new_vert);
     CHECK_ERR(rval);
     // also the other side
-    rval = mb->tag_set_data(corrTag, &new_vert, 1, &oldV);
-    CHECK_ERR(rval);
-    // set the global id
+    // need to check if we really need this; the new vertex will never need the old vertex
+    // we have the global id which is the same
+    /*rval = mb->tag_set_data(corrTag, &new_vert, 1, &oldV);
+    CHECK_ERR(rval);*/
+    // set the global id on the corresponding vertex the same as the initial vertex
     rval = mb->tag_set_data(gid, &new_vert, 1, &global_id);
     CHECK_ERR(rval);
@@ -339,9 +341,9 @@ ErrorCode  create_lagr_mesh(Interface * mb, EntityHandle euler_set, EntityHandle
     EntityHandle newElement;
     rval = mb->create_element(typeElem, &new_conn[0], nnodes, newElement);
     CHECK_ERR(rval);
-    //set the corresponding tag
-    rval = mb->tag_set_data(corrTag, &q, 1, &newElement);
-    CHECK_ERR(rval);
+    //set the corresponding tag; not sure we need this one, from old to new
+    /*rval = mb->tag_set_data(corrTag, &q, 1, &newElement);
     rval = mb->tag_set_data(corrTag, &newElement, 1, &q);
     CHECK_ERR(rval);
@@ -521,6 +523,11 @@ int main(int argc, char **argv)
         noWrite = true;
+      if (!strcmp(argv[index], "-v"))
+        velocity = true;
       if (!strcmp(argv[index], "-pw"))
         parallelWrite = true;
@@ -528,15 +535,16 @@ int main(int argc, char **argv)
       if (!strcmp(argv[index], "-h"))
-        std::cout << "usage: -gtol <tol> -input <file> -O <extra_read_opts> \n   "
-        <<    "-f <field_type> -h (this help) -ns <numSteps> \n";
+        std::cout << "usage: -gtol <tol> -input <file> -O <extra_read_opts> -v (output velocities) \n   "
+        <<    "-f <field_type> -h (this help) -ns <numSteps> -pw (parallel write) -nw (no dbg write) \n";
         std::cout << " field type: 1: quasi-smooth; 2: smooth; 3: slotted cylinders (non-smooth)\n";
         return 0;
       index++;
-  // start copy
+  // read in parallel, in the "euler_set", the initial mesh
   std::string opts = std::string("PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION")+
             std::string(";PARALLEL_RESOLVE_SHARED_ENTS")+extra_read_opts;
   Core moab;
@@ -553,24 +561,33 @@ int main(int argc, char **argv)
   rval = pcomm->check_all_shared_handles();
   CHECK_ERR(rval);
-  // end copy
   int rank = pcomm->proc_config().proc_rank();
   if (0==rank)
     std::cout << " case 1: use -gtol " << gtol <<
         " -R " << radius << " -input " << filename_mesh1 <<  " -f " << field_type <<
         " numSteps: " << numSteps << "\n";
+    std::cout<<" write debug results: " << (noWrite ? "no" : "yes") << "\n";
+    std::cout<< " write tracer in parallel: " << ( parallelWrite ? "yes" : "no") << "\n";
+    std::cout <<" output velocity: " << (velocity? "yes" : "no") << "\n";
+  // tagTracer is the value at nodes
   Tag tagTracer = 0;
   std::string tag_name("Tracer");
   rval = mb.tag_get_handle(tag_name.c_str(), 1, MB_TYPE_DOUBLE, tagTracer, MB_TAG_DENSE | MB_TAG_CREAT);
   CHECK_ERR(rval);
+  // tagElem is the average computed at each element, from nodal values
   Tag tagElem = 0;
   std::string tag_name2("TracerAverage");
   rval = mb.tag_get_handle(tag_name2.c_str(), 1, MB_TYPE_DOUBLE, tagElem, MB_TAG_DENSE | MB_TAG_CREAT);
   CHECK_ERR(rval);
+  // area of the euler element is fixed, store it; it is used to recompute the averages at each
+  // time step
   Tag tagArea = 0;
   std::string tag_name4("Area");
   rval = mb.tag_get_handle(tag_name4.c_str(), 1, MB_TYPE_DOUBLE, tagArea, MB_TAG_DENSE | MB_TAG_CREAT);
@@ -580,6 +597,7 @@ int main(int argc, char **argv)
   rval = add_field_value(&mb, euler_set, rank, tagTracer, tagElem, tagArea);
   CHECK_ERR(rval);
+  // iniVals are used for 1-norm error computation
   Range redEls;
   rval = mb.get_entities_by_dimension(euler_set, 2, redEls);
   CHECK_ERR(rval);
@@ -619,10 +637,14 @@ int main(int argc, char **argv)
     // time depends on i; t = i*T/numSteps: ( 0, T/numSteps, 2*T/numSteps, ..., T )
     // this is really just to create some plots; it is not really needed to proceed
     // the compute_tracer_case1 method actually computes the departure point position
-    rval = compute_velocity_case1(&mb, euler_set, tagh, rank, i);
-    CHECK_ERR(rval);
+    if (velocity)
+      rval = compute_velocity_case1(&mb, euler_set, tagh, rank, i);
+      CHECK_ERR(rval);
-    // this is to actually compute concentrations, using the current concentrations
+    // this is to actually compute concentrations at time step i, using the
+    //  current concentrations
     rval = compute_tracer_case1(&mb, worker, euler_set, lagr_set, out_set,
         tagElem, tagArea, rank, i, local_verts);
@@ -656,7 +678,7 @@ int main(int argc, char **argv)
   int mpi_err = MPI_Reduce(&norm1, &total_norm1, 1, MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD);
   if (MPI_SUCCESS != mpi_err) return 1;
   if (0==rank)
-    std::cout << " numSteps:" << numSteps << " 1-norm:" << norm1 << "\n";
+    std::cout << " numSteps:" << numSteps << " 1-norm:" << total_norm1 << "\n";
   MPI_Finalize();
   return 0;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
