[MOAB-dev] commit/MOAB: danwu: Compare the number of elements with correct expected result in ScdNCHelper::check_existing_mesh().
commits-noreply at bitbucket.org
Mon Nov 11 11:33:37 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/ac80582d4fc3/
Changeset: ac80582d4fc3
Branch: master
User: danwu
Date: 2013-11-11 18:33:23
Summary: Compare the number of elements with correct expected result in ScdNCHelper::check_existing_mesh().
Affected #: 1 file
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index bc8da0f..1465db2 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -793,16 +793,13 @@ ErrorCode ScdNCHelper::check_existing_mesh() {
rval = mbImpl->get_number_entities_by_dimension(_fileSet, (-1 == lDims[2] ? 2 : 3), num_elems);
ERRORR(rval, "Trouble getting number of elements.");
// Check against parameters
- // The expected number of elements calculated below is incorrect (to be updated later)
if (num_elems > 0) {
- int expected_elems = (lDims[3] - lDims[0]) * (lDims[4] - lDims[1]) * (-1 == lDims[2] ? 1 : lDims[5] - lDims[2]);
+ int expected_elems = (lCDims[3] - lCDims[0] + 1) * (lCDims[4] - lCDims[1] + 1) * (-1 == lCDims[2] ? 1 : (lCDims[5] - lCDims[2] + 1));
if (num_elems != expected_elems) {
ERRORR(MB_FAILURE, "Number of elements doesn't match.");
return MB_SUCCESS;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
