[MOAB-dev] commit/MOAB: 2 new changesets
commits-noreply at bitbucket.org
Wed Nov 6 15:02:23 CST 2013
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/74c3fbab733c/
Changeset: 74c3fbab733c
Branch: None
User: iulian07
Date: 2013-11-06 21:58:20
Summary: fix ticket 285
when cleaning up memory for adjacency lists, do not stop at mesh sets.
clean for mesh sets too, as they could be adjacent to other mesh sets, if they
are added to a tracked mesh set
Thanks to Lukasz for pointing it out.
Affected #: 1 file
diff --git a/src/AEntityFactory.cpp b/src/AEntityFactory.cpp
index 08ddb00..e29df97 100644
--- a/src/AEntityFactory.cpp
+++ b/src/AEntityFactory.cpp
@@ -65,7 +65,7 @@ AEntityFactory::~AEntityFactory()
EntityType ent_type;
// iterate through each element type
- for (ent_type = MBVERTEX; ent_type != MBENTITYSET; ent_type++) {
+ for (ent_type = MBVERTEX; ent_type <= MBENTITYSET; ent_type++) {
TypeSequenceManager::iterator i;
TypeSequenceManager& seqman = thisMB->sequence_manager()->entity_map( ent_type );
for (i = seqman.begin(); i != seqman.end(); ++i) {
https://bitbucket.org/fathomteam/moab/commits/bee2e77e4169/
Changeset: bee2e77e4169
Branch: master
User: iulian07
Date: 2013-11-06 22:01:08
Summary: Merge branch 'master' of https://bitbucket.org/fathomteam/moab
Affected #: 1 file
diff --git a/test/io/read_mpas_nc.cpp b/test/io/read_mpas_nc.cpp
index 5ceb994..d6e886f 100644
--- a/test/io/read_mpas_nc.cpp
+++ b/test/io/read_mpas_nc.cpp
@@ -1,6 +1,7 @@
#include "TestUtil.hpp"
#include "moab/Core.hpp"
#include "moab/ReadUtilIface.hpp"
+#include "MBTagConventions.hpp"
using namespace moab;
@@ -20,7 +21,9 @@ void test_read_onevar();
void test_read_onetimestep();
void test_read_nomesh();
void test_read_novars();
-void test_read_no_mixed_elements();
+void test_read_no_mixed_elements(); // Test read option NO_MIXED_ELEMENTS
+void test_read_no_edges(); // Test read option NO_EDGES
+void test_gather_onevar(); // Test gather set with one variable
ErrorCode get_options(std::string& opts);
@@ -41,8 +44,9 @@ int main(int argc, char* argv[])
result += RUN_TEST(test_read_onetimestep);
result += RUN_TEST(test_read_nomesh);
result += RUN_TEST(test_read_novars);
- // Test read option NO_MIXED_ELEMENTS
result += RUN_TEST(test_read_no_mixed_elements);
+ result += RUN_TEST(test_read_no_edges);
+ result += RUN_TEST(test_gather_onevar);
#ifdef USE_MPI
fail = MPI_Finalize();
@@ -163,8 +167,6 @@ void test_read_onevar()
CHECK_ERR(rval);
opts += std::string(";VARIABLE=ke");
- // Create gather set
- opts += std::string(";GATHER_SET=");
rval = mb.load_file(example, NULL, opts.c_str());
CHECK_ERR(rval);
@@ -187,38 +189,15 @@ void test_read_onevar()
Range cells;
rval = mb.get_entities_by_type(0, MBPOLYGON, cells);
assert(rval == MB_SUCCESS);
- CHECK_EQUAL((size_t)1284, cells.size()); // Gather set cells included
-#ifdef USE_MPI
- // If MOAB is compiled parallel, sequence size requested are increased
- // by a factor of 1.5, to allow for ghosts. This will introduce a gap
- // between the two face sequences.
- CHECK_EQUAL((size_t)4, cells.psize()); // Gather set cells included
-#else
- CHECK_EQUAL((size_t)1, cells.psize()); // Gather set cells included
-#endif
- // Get gather set
- EntityHandle gather_set;
- ReadUtilIface* readUtilIface;
- mb.query_interface(readUtilIface);
- rval = readUtilIface->get_gather_set(gather_set);
- CHECK_ERR(rval);
- // Get gather set entities
- Range gather_ents;
- rval = mb.get_entities_by_handle(gather_set, gather_ents);
- CHECK_ERR(rval);
+ CHECK_EQUAL((size_t)642, cells.size());
- // Remove gather set cells
- cells = subtract(cells, gather_ents);
- CHECK_EQUAL((size_t)642, cells.size()); // Gather set cells excluded
#ifdef USE_MPI
- CHECK_EQUAL((size_t)2, cells.psize()); // Gather set cells excluded
+ CHECK_EQUAL((size_t)2, cells.psize());
#else
- CHECK_EQUAL((size_t)1, cells.psize()); // Gather set cells excluded
+ CHECK_EQUAL((size_t)1, cells.psize());
#endif
// Check ke tag values on first pentagon and first hexagon
@@ -368,7 +347,8 @@ void test_read_no_mixed_elements()
- // Only one group of cells (each cell is actually represented by a 10-vertex polygon)
+ // Only one group of cells (pentagons are padded to hexagons,
+ // e.g. connectivity [1 2 3 4 5] => [1 2 3 4 5 5])
const double eps = 1e-20;
@@ -385,7 +365,104 @@ void test_read_no_mixed_elements()
-ErrorCode get_options(std::string &opts)
+ Core moab;
+ Interface& mb = moab;
+ std::string opts;
+ ErrorCode rval = get_options(opts);
+ CHECK_ERR(rval);
+ opts += std::string(";NO_EDGES;VARIABLE=");
+ rval = mb.load_file(example, NULL, opts.c_str());
+ CHECK_ERR(rval);
+ int procs = 1;
+#ifdef USE_MPI
+ ParallelComm* pcomm = ParallelComm::get_pcomm(&mb, 0);
+ procs = pcomm->proc_config().proc_size();
+#endif
+ // Make check runs this test in one processor
+ if (1 == procs) {
+ // Get edges
+ Range edges;
+ rval = mb.get_entities_by_type(0, MBEDGE, edges);
+ assert(rval == MB_SUCCESS);
+ CHECK_EQUAL((size_t)0, edges.size());
+ Core moab;
+ std::string opts;
+ CHECK_ERR(rval);
+ EntityHandle file_set;
+ rval = mb.create_meshset(MESHSET_SET, file_set);
+ CHECK_ERR(rval);
+ // Get cell variable ke
+ opts += std::string(";VARIABLE=ke;");
+ // Create gather set
+ opts += std::string(";GATHER_SET=0;");
+ rval = mb.load_file(example, &file_set, opts.c_str());
+ CHECK_ERR(rval);
+#ifdef USE_MPI
+ int procs = pcomm->proc_config().proc_size();
+ if (1 == procs) {
+ Range cells, cells_owned;
+ rval = mb.get_entities_by_type(file_set, MBPOLYGON, cells);
+ CHECK_ERR(rval);
+ // Get locally owned cells
+ rval = pcomm->filter_pstatus(cells, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &cells_owned);
+ CHECK_ERR(rval);
+ CHECK_EQUAL((size_t)642, cells_owned.size());
+ CHECK_EQUAL((size_t)2, cells_owned.psize());
+ // Get gather set
+ EntityHandle gather_set;
+ ReadUtilIface* readUtilIface;
+ mb.query_interface(readUtilIface);
+ rval = readUtilIface->get_gather_set(gather_set);
+ CHECK_ERR(rval);
+ Tag ke_tag0, gid_tag;
+ rval = mb.tag_get_handle("ke0", 1, MB_TYPE_DOUBLE, ke_tag0, MB_TAG_DENSE);
+ CHECK_ERR(rval);
+ rval = mb.tag_get_handle(GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, gid_tag, MB_TAG_DENSE);
+ CHECK_ERR(rval);
+ pcomm->gather_data(cells_owned, ke_tag0, gid_tag, gather_set);
+ // Get gather set cells
+ Range gather_set_cells;
+ rval = mb.get_entities_by_type(gather_set, MBPOLYGON, gather_set_cells);
+ CHECK_EQUAL((size_t)642, gather_set_cells.size());
+ CHECK_EQUAL((size_t)2, gather_set_cells.psize());
+ const double eps = 1e-20;
+ double val[2];
+ // Check ke0 tag values on first pentagon and first hexagon of the gather set cells
+ EntityHandle cell_ents[] = {gather_set_cells[0], gather_set_cells[12]};
+ rval = mb.tag_get_data(ke_tag0, &cell_ents[0], 2, val);
+ CHECK_REAL_EQUAL(15.001, val[0], eps);
+ CHECK_REAL_EQUAL(16.013, val[1], eps);
+#endif
+ErrorCode get_options(std::string& opts)
#ifdef USE_MPI
// Use parallel options
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
