[MOAB-dev] commit/MOAB: 2 new changesets
commits-noreply at bitbucket.org
Thu Nov 14 15:34:37 CST 2013
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/d7a5a2be5184/
Changeset: d7a5a2be5184
Branch: None
User: tautges
Date: 2013-11-14 22:33:51
Summary: Fix parallel_unit_test so it works for 4 procs as well as 2 (not all entities are only pairwise-shared).
Add an MPI_Finalize to scdtest in case of error.
Affected #: 2 files
diff --git a/test/parallel/parallel_unit_tests.cpp b/test/parallel/parallel_unit_tests.cpp
index 45ef1c5..85cc3b8 100644
--- a/test/parallel/parallel_unit_tests.cpp
+++ b/test/parallel/parallel_unit_tests.cpp
@@ -1447,8 +1447,10 @@ template <typename T> ErrorCode check_shared_ents(ParallelComm &pcomm, Tag tagh,
if (1 == np && shprocs[0] != (int) pcomm.proc_config().proc_rank()) np++;
if (mpi_op == MPI_SUM) {if (dum_vals[i] != fact*np) return MB_FAILURE;}
else if (mpi_op == MPI_PROD) {if (dum_vals[i] != pow(fact, np)) return MB_FAILURE;}
- else if (mpi_op == MPI_MAX) {if (dum_vals[i] != fact) return MB_FAILURE;}
- else if (mpi_op == MPI_MIN) {if (dum_vals[i] != fact) return MB_FAILURE;}
+ else if (mpi_op == MPI_MAX) {if (pcomm.rank() && std::find(&shprocs[0],&shprocs[np], 0) != &shprocs[np] &&
+ dum_vals[i] != fact) return MB_FAILURE;}
+ else if (mpi_op == MPI_MIN) {if (pcomm.rank() && std::find(&shprocs[0],&shprocs[np], 0) != &shprocs[np] &&
else return MB_FAILURE;
diff --git a/test/parallel/scdtest.cpp b/test/parallel/scdtest.cpp
index 3202621..5338b81 100644
--- a/test/parallel/scdtest.cpp
+++ b/test/parallel/scdtest.cpp
@@ -49,6 +49,7 @@ int main(int argc, char *argv[])
MPI_Comm_size(MPI_COMM_WORLD, &size);
if (size != 4 && size != 2) {
cerr << "Run this with 2 or 4 processes\n";
+ MPI_Finalize();
exit(1);
https://bitbucket.org/fathomteam/moab/commits/7c37ce441fdd/
Changeset: 7c37ce441fdd
Branch: master
User: tautges
Date: 2013-11-14 22:34:11
Summary: Merge branch 'master' of bitbucket.org:fathomteam/moab
Affected #: 8 files
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index be91ef8..ebf149c 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -10,10 +10,10 @@
#include "MBTagConventions.hpp"
#define ERRORR(rval, str) \
- if (MB_SUCCESS != rval) {_readNC->readMeshIface->report_error("%s", str); return rval;}
+ if (MB_SUCCESS != rval) {_readNC->readMeshIface->report_error("%s", str); return rval;}
#define ERRORS(err, str) \
- if (err) {_readNC->readMeshIface->report_error("%s", str); return MB_FAILURE;}
+ if (err) {_readNC->readMeshIface->report_error("%s", str); return MB_FAILURE;}
namespace moab {
@@ -315,8 +315,10 @@ ErrorCode NCHelper::read_variable_setup(std::vector<std::string>& var_names, std
for (mit = varInfo.begin(); mit != varInfo.end(); ++mit) {
ReadNC::VarData vd = (*mit).second;
- // This variable will not be read
- if (ignoredVarNames.find(vd.varName) != ignoredVarNames.end())
+ // No need to read ignored variables. Upon creation of dummy variables,
+ // tag values have already been set
+ if (ignoredVarNames.find(vd.varName) != ignoredVarNames.end() ||
+ dummyVarNames.find(vd.varName) != dummyVarNames.end())
continue;
if (vd.entLoc == ReadNC::ENTLOCSET)
@@ -331,8 +333,10 @@ ErrorCode NCHelper::read_variable_setup(std::vector<std::string>& var_names, std
if (mit != varInfo.end()) {
continue;
@@ -382,7 +386,6 @@ ErrorCode NCHelper::read_variable_setup(std::vector<std::string>& var_names, std
ErrorCode NCHelper::read_variable_to_set(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
- std::set<std::string>& dummyVarNames = _readNC->dummyVarNames;
Interface*& mbImpl = _readNC->mbImpl;
DebugOutput& dbgOut = _readNC->dbgOut;
@@ -392,11 +395,6 @@ ErrorCode NCHelper::read_variable_to_set(std::vector<ReadNC::VarData>& vdatas, s
// Finally, read into that space
int success;
for (unsigned int i = 0; i < vdatas.size(); i++) {
- // This is a dummy variable for a dimension with no corresponding coordinate variable
- // No need to set its tag data
- if (dummyVarNames.find(vdatas[i].varName) != dummyVarNames.end())
- continue;
for (unsigned int t = 0; t < tstep_nums.size(); t++) {
void* data = vdatas[i].varDatas[t];
@@ -719,56 +717,63 @@ ErrorCode NCHelper::create_attrib_string(const std::map<std::string, ReadNC::Att
return MB_SUCCESS;
-void NCHelper::init_dims_with_no_coord_vars_info()
+ErrorCode NCHelper::create_dummy_variables()
+ Interface*& mbImpl = _readNC->mbImpl;
std::vector<std::string>& dimNames = _readNC->dimNames;
+ std::vector<int>& dimLens = _readNC->dimLens;
std::map<std::string, ReadNC::VarData>& varInfo = _readNC->varInfo;
// Hack: look at all dimensions, and see if we have one that does not appear in the list of varInfo names
- // Right now, candidates are from unstructured meshes, such as ncol(HOMME) and nCells(MPAS)
- // For them, create dummy tags
+ // Right now, candidates are from unstructured meshes, such as ncol (HOMME) and nCells (MPAS)
+ // For each of them, create a dummy variable with a sparse tag to store the dimension length
for (unsigned int i = 0; i < dimNames.size(); i++) {
- // If there is a variable with this dimension name, skip, we are fine; if not, create a dummy varInfo
+ // If there is a variable with this dimension name, skip
if (varInfo.find(dimNames[i]) != varInfo.end())
continue;
+ // Create a dummy variable
int sizeTotalVar = varInfo.size();
std::string var_name(dimNames[i]);
ReadNC::VarData& data = varInfo[var_name];
data.varName = std::string(var_name);
data.varId = sizeTotalVar;
data.varTags.resize(1, 0);
- data.varDataType = NC_DOUBLE; // Could be int, actually, but we do not really need the type
+ data.varDataType = NC_INT;
data.varDims.resize(1);
data.varDims[0] = (int)i;
data.numAtts = 0;
data.entLoc = ReadNC::ENTLOCSET;
- dbgOut.tprintf(2, "Dummy varInfo created for dimension %s\n", dimNames[i].c_str());
dummyVarNames.insert(dimNames[i]);
+ dbgOut.tprintf(2, "Dummy variable created for dimension %s\n", dimNames[i].c_str());
+ // Create a sparse tag to store the dimension length
+ Tag tagh;
+ ErrorCode rval = mbImpl->tag_get_handle(dimNames[i].c_str(), 1, MB_TYPE_INTEGER, tagh,
+ MB_TAG_SPARSE | MB_TAG_CREAT | MB_TAG_EXCL);
+ // If the tag already exists, skip
+ if (MB_ALREADY_ALLOCATED == rval)
+ continue;
+ ERRORR(rval, "Failed to create dimension tag.");
+ rval = mbImpl->tag_set_data(tagh, &_fileSet, 1, &dimLens[i]);
+ ERRORR(rval, "Failed to set data for dimension tag.");
+ dbgOut.tprintf(2, "Sparse tag created for dimension %s\n", dimNames[i].c_str());
+ return MB_SUCCESS;
ErrorCode NCHelper::read_variable_to_set_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
ErrorCode rval = MB_SUCCESS;
- // No need to allocate memory to read it
- if (dummyVarNames.find(vdatas[i].varName) != dummyVarNames.end()) {
- if (!vdatas[i].varTags[0]) {
- rval = get_tag_to_set(vdatas[i], 0, vdatas[i].varTags[0]);
- ERRORR(rval, "Trouble getting dummy tag.");
- continue;
if ((std::find(vdatas[i].varDims.begin(), vdatas[i].varDims.end(), tDim) != vdatas[i].varDims.end()))
vdatas[i].has_t = true;
@@ -893,7 +898,7 @@ ErrorCode ScdNCHelper::create_mesh(Range& faces)
ScdParData& parData = _readNC->parData;
Range tmp_range;
- ScdBox *scd_box;
+ ScdBox* scd_box;
ErrorCode rval = scdi->construct_box(HomCoord(lDims[0], lDims[1], lDims[2], 1), HomCoord(lDims[3], lDims[4], lDims[5], 1),
NULL, 0, scd_box, locallyPeriodic, &parData, true);
@@ -1050,8 +1055,6 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset_allocate(std::vector<ReadNC::
#endif
- vdatas[i].numLev = nLevels;
dbgOut.tprintf(2, "Reading variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t]);
@@ -1074,17 +1077,14 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset_allocate(std::vector<ReadNC::
vdatas[i].readStarts[t].push_back(tstep_nums[t]);
vdatas[i].readCounts[t].push_back(1);
- // Next: numLev
- if (vdatas[i].numLev != 1) {
- vdatas[i].readStarts[t].push_back(0);
- vdatas[i].readCounts[t].push_back(vdatas[i].numLev);
+ // Next: numLev, even if it is 1
+ vdatas[i].readStarts[t].push_back(0);
+ vdatas[i].readCounts[t].push_back(vdatas[i].numLev);
// Finally: y and x
switch (vdatas[i].entLoc) {
case ReadNC::ENTLOCVERT:
// Vertices
- // Only structured mesh has j parameter that multiplies i to get total # vertices
vdatas[i].readStarts[t].push_back(lDims[1]);
vdatas[i].readCounts[t].push_back(lDims[4] - lDims[1] + 1);
vdatas[i].readStarts[t].push_back(lDims[0]);
@@ -1101,8 +1101,8 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset_allocate(std::vector<ReadNC::
case ReadNC::ENTLOCFACE:
// Faces
vdatas[i].readStarts[t].push_back(lCDims[1]);
- vdatas[i].readStarts[t].push_back(lCDims[0]);
vdatas[i].readCounts[t].push_back(lCDims[4] - lCDims[1] + 1);
+ vdatas[i].readStarts[t].push_back(lCDims[0]);
vdatas[i].readCounts[t].push_back(lCDims[3] - lCDims[0] + 1);
assert(vdatas[i].readStarts[t].size() == vdatas[i].varDims.size());
#ifdef USE_MPI
@@ -1245,6 +1245,7 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset(std::vector<ReadNC::VarData>&
rval = tmp_rval;
// Debug output, if requested
if (1 == dbgOut.get_verbosity()) {
dbgOut.printf(1, "Read variables: %s", vdatas.begin()->varName.c_str());
diff --git a/src/io/NCHelper.hpp b/src/io/NCHelper.hpp
index dcb006e..817257c 100644
--- a/src/io/NCHelper.hpp
+++ b/src/io/NCHelper.hpp
@@ -55,18 +55,18 @@ protected:
ErrorCode get_tag_to_nonset(ReadNC::VarData& var_data, int tstep_num, Tag& tagh, int num_lev);
- //! Create a character string attString of attMap. with '\0'
+ //! Create a character string attString of attMap. with '\0'
//! terminating each attribute name, ';' separating the data type
//! and value, and ';' separating one name/data type/value from
- //! the next'. attLen stores the end position for each name/data
+ //! the next'. attLen stores the end position for each name/data
//! type/ value.
ErrorCode create_attrib_string(const std::map<std::string, ReadNC::AttData>& attMap,
std::string& attString,
std::vector<int>& attLen);
- //! Initialize information for dimensions that don't have corresponding
- //! coordinate variables - this information is used for creating dummy tags
- void init_dims_with_no_coord_vars_info();
+ //! For a dimension that does not have a corresponding coordinate variable (e.g. ncol for HOMME),
+ //! create a dummy variable with a sparse tag to store the dimension length
+ ErrorCode create_dummy_variables();
private:
//! Used by read_variable_to_set()
@@ -90,8 +90,11 @@ protected:
//! Dimension numbers for time and level
int tDim, levDim;
- //! Skip unexpected variables
+ //! Ignored variables
std::set<std::string> ignoredVarNames;
+ //! Dummy variables
+ std::set<std::string> dummyVarNames;
//! Child helper class for scd mesh, e.g. CAM_EL or CAM_FV
diff --git a/src/io/NCHelperEuler.cpp b/src/io/NCHelperEuler.cpp
index 48056c6..b117921 100644
--- a/src/io/NCHelperEuler.cpp
+++ b/src/io/NCHelperEuler.cpp
@@ -6,10 +6,10 @@
#include <sstream>
namespace moab {
@@ -319,13 +319,21 @@ ErrorCode NCHelperEuler::init_mesh_vals()
dbgOut.tprintf(1, "%d elements, %d vertices\n", (lDims[3] - lDims[0]) * (lDims[4] - lDims[1]), (lDims[3] - lDims[0] + 1)
* (lDims[4] - lDims[1] + 1));
- // Determine the entity location type of a variable
+ // For each variable, determine the entity location type and number of levels
std::map<std::string, ReadNC::VarData>::iterator mit;
ReadNC::VarData& vd = (*mit).second;
- if ((std::find(vd.varDims.begin(), vd.varDims.end(), iCDim) != vd.varDims.end()) && (std::find(vd.varDims.begin(),
- vd.varDims.end(), jCDim) != vd.varDims.end()))
- vd.entLoc = ReadNC::ENTLOCFACE;
+ vd.entLoc = ReadNC::ENTLOCSET;
+ if (std::find(vd.varDims.begin(), vd.varDims.end(), tDim) != vd.varDims.end()) {
+ if ((std::find(vd.varDims.begin(), vd.varDims.end(), iCDim) != vd.varDims.end()) &&
+ (std::find(vd.varDims.begin(), vd.varDims.end(), jCDim) != vd.varDims.end()))
+ vd.entLoc = ReadNC::ENTLOCFACE;
+ vd.numLev = 1;
+ if (std::find(vd.varDims.begin(), vd.varDims.end(), levDim) != vd.varDims.end())
+ vd.numLev = nLevels;
// For Eul models, slon and slat are "virtual" dimensions (not defined in the file header)
@@ -451,8 +459,9 @@ ErrorCode NCHelperEuler::init_mesh_vals()
dbgOut.tprintf(2, "Tag created for variable %s\n", tag_name.c_str());
- // Hack: create dummy tags, if needed, for dimensions with no corresponding coordinate variables
- init_dims_with_no_coord_vars_info();
+ // Hack: create dummy variables, if needed, for dimensions with no corresponding coordinate variables
+ rval = create_dummy_variables();
+ ERRORR(rval, "Failed to create dummy variables.");
return MB_SUCCESS;
diff --git a/src/io/NCHelperFV.cpp b/src/io/NCHelperFV.cpp
index 253d598..7725b55 100644
--- a/src/io/NCHelperFV.cpp
+++ b/src/io/NCHelperFV.cpp
@@ -6,7 +6,7 @@
#include <sstream>
namespace moab {
@@ -315,19 +315,27 @@ ErrorCode NCHelperFV::init_mesh_vals()
- else if ((std::find(vd.varDims.begin(), vd.varDims.end(), jDim) != vd.varDims.end()) && (std::find(vd.varDims.begin(),
- vd.varDims.end(), iCDim) != vd.varDims.end()))
- vd.entLoc = ReadNC::ENTLOCNSEDGE;
- else if ((std::find(vd.varDims.begin(), vd.varDims.end(), jCDim) != vd.varDims.end()) && (std::find(vd.varDims.begin(),
- vd.varDims.end(), iDim) != vd.varDims.end()))
- vd.entLoc = ReadNC::ENTLOCEWEDGE;
+ else if ((std::find(vd.varDims.begin(), vd.varDims.end(), jDim) != vd.varDims.end()) &&
+ (std::find(vd.varDims.begin(), vd.varDims.end(), iCDim) != vd.varDims.end()))
+ vd.entLoc = ReadNC::ENTLOCNSEDGE;
+ else if ((std::find(vd.varDims.begin(), vd.varDims.end(), jCDim) != vd.varDims.end()) &&
+ (std::find(vd.varDims.begin(), vd.varDims.end(), iDim) != vd.varDims.end()))
+ vd.entLoc = ReadNC::ENTLOCEWEDGE;
+ vd.numLev = 1;
std::vector<std::string> ijdimNames(4);
@@ -452,8 +460,9 @@ ErrorCode NCHelperFV::init_mesh_vals()
return MB_SUCCESS;
diff --git a/src/io/NCHelperHOMME.cpp b/src/io/NCHelperHOMME.cpp
index be4d93f..25c4441 100644
--- a/src/io/NCHelperHOMME.cpp
+++ b/src/io/NCHelperHOMME.cpp
@@ -151,17 +151,25 @@ ErrorCode NCHelperHOMME::init_mesh_vals()
tVals.push_back((double)t);
- if ((std::find(vd.varDims.begin(), vd.varDims.end(), vDim) != vd.varDims.end()) && (std::find(vd.varDims.begin(),
- vd.varDims.end(), levDim) != vd.varDims.end()))
- vd.entLoc = ReadNC::ENTLOCVERT;
+ if (std::find(vd.varDims.begin(), vd.varDims.end(), vDim) != vd.varDims.end())
+ vd.entLoc = ReadNC::ENTLOCVERT;
+ vd.numLev = 1;
- // Hack: create dummy tags for dimensions (like ncol) with no corresponding coordinate variables
+ // Hack: create dummy variables for dimensions (like ncol) with no corresponding coordinate variables
return MB_SUCCESS;
@@ -540,11 +548,9 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC
- // Next: numLev
// Finally: nVertices
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index a326e52..c803bf3 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -26,8 +26,22 @@ NCHelperMPAS::NCHelperMPAS(ReadNC* readNC, int fileId, const FileOptions& opts,
, numCellGroups(0)
, createGatherSet(false)
- // Hack: ignore 4D variable tracers(Time, nCells, nVertLevels, nTracers)
- ignoredVarNames.insert("tracers");
+ // Ignore variables containing topological information
+ ignoredVarNames.insert("nEdgesOnEdge");
+ ignoredVarNames.insert("nEdgesOnCell");
+ ignoredVarNames.insert("edgesOnVertex");
+ ignoredVarNames.insert("cellsOnVertex");
+ ignoredVarNames.insert("verticesOnEdge");
+ ignoredVarNames.insert("edgesOnEdge");
+ ignoredVarNames.insert("cellsOnEdge");
+ ignoredVarNames.insert("verticesOnCell");
+ ignoredVarNames.insert("edgesOnCell");
+ ignoredVarNames.insert("cellsOnCell");
+ // Ignore variables for index conversion
+ ignoredVarNames.insert("indexToVertexID");
+ ignoredVarNames.insert("indexToEdgeID");
+ ignoredVarNames.insert("indexToCellID");
bool NCHelperMPAS::can_read_file(ReadNC* readNC)
@@ -144,42 +158,41 @@ ErrorCode NCHelperMPAS::init_mesh_vals()
for (vmit = varInfo.begin(); vmit != varInfo.end(); ++vmit) {
ReadNC::VarData& vd = (*vmit).second;
- vd.entLoc = ReadNC::ENTLOCSET;
- if ((std::find(vd.varDims.begin(), vd.varDims.end(), tDim) != vd.varDims.end()) &&
- (std::find(vd.varDims.begin(), vd.varDims.end(), vDim) != vd.varDims.end()))
- else if ((std::find(vd.varDims.begin(), vd.varDims.end(), tDim) != vd.varDims.end()) &&
- (std::find(vd.varDims.begin(), vd.varDims.end(), eDim) != vd.varDims.end()))
- vd.entLoc = ReadNC::ENTLOCEDGE;
- (std::find(vd.varDims.begin(), vd.varDims.end(), cDim) != vd.varDims.end()))
+ else if (std::find(vd.varDims.begin(), vd.varDims.end(), eDim) != vd.varDims.end())
+ vd.entLoc = ReadNC::ENTLOCEDGE;
+ else if (std::find(vd.varDims.begin(), vd.varDims.end(), cDim) != vd.varDims.end())
- // Determine number of levels of a variable
- for (vmit = varInfo.begin(); vmit != varInfo.end(); ++vmit) {
- ReadNC::VarData& vd = (*vmit).second;
vd.numLev = 1;
- if (std::find(vd.varDims.begin(), vd.varDims.end(), levDim) != vd.varDims.end()) {
- continue;
- for (unsigned int i = 0; i < opt_lev_dims.size(); i++) {
- if (std::find(vd.varDims.begin(), vd.varDims.end(), opt_lev_dims[i]) != vd.varDims.end()) {
- vd.numLev = dimLens[opt_lev_dims[i]];
- break;
+ else {
+ // If nVertLevels dimension is not found, try other optional levels such as nVertLevelsP1
+ for (unsigned int i = 0; i < opt_lev_dims.size(); i++) {
+ if (std::find(vd.varDims.begin(), vd.varDims.end(), opt_lev_dims[i]) != vd.varDims.end()) {
+ vd.numLev = dimLens[opt_lev_dims[i]];
+ break;
+ // Hack: ignore variables with more than 3 dimensions, e.g. tracers(Time, nCells, nVertLevels, nTracers)
+ if (vd.varDims.size() > 3)
+ ignoredVarNames.insert(vd.varName);
- // Hack: create dummy tags for dimensions (like nCells) with no corresponding coordinate variables
+ // Hack: create dummy variables for dimensions (like nCells) with no corresponding coordinate variables
return MB_SUCCESS;
diff --git a/src/io/ReadNC.cpp b/src/io/ReadNC.cpp
index e930930..a0e02b4 100644
--- a/src/io/ReadNC.cpp
+++ b/src/io/ReadNC.cpp
@@ -132,16 +132,16 @@ ErrorCode ReadNC::load_file(const char* file_name, const EntityHandle* file_set,
return rval;
else {
- // Read dimension variable by default, the ones that are also variables
- std::vector<std::string> filteredDimNames;
+ // Read dimension variables by default (the dimensions that are also variables)
+ std::vector<std::string> dim_var_names;
std::map<std::string, VarData>::iterator mit = varInfo.find(dimNames[i]);
- filteredDimNames.push_back(dimNames[i]);
+ dim_var_names.push_back(dimNames[i]);
- if (!filteredDimNames.empty()) {
- rval = myHelper->read_variables(filteredDimNames, tstep_nums);
+ if (!dim_var_names.empty()) {
+ rval = myHelper->read_variables(dim_var_names, tstep_nums);
if (MB_FAILURE == rval)
return rval;
@@ -302,7 +302,7 @@ ErrorCode ReadNC::read_header()
ERRORR(result, "Getting attributes.");
dbgOut.tprintf(1, "Read %u attributes\n", (unsigned int) globalAtts.size());
- // Read in dimensions into dimVals
+ // Read in dimensions into dimNames and dimLens
result = get_dimensions(fileId, dimNames, dimLens);
ERRORR(result, "Getting dimensions.");
dbgOut.tprintf(1, "Read %u dimensions\n", (unsigned int) dimNames.size());
diff --git a/src/io/ReadNC.hpp b/src/io/ReadNC.hpp
index fc75140..c452716 100644
--- a/src/io/ReadNC.hpp
+++ b/src/io/ReadNC.hpp
@@ -165,9 +165,6 @@ private:
//! Dimension lengths
std::vector<int> dimLens;
- //! These should be taken out when we fix the dummy var info things
- std::set<std::string> dummyVarNames;
//! Global attribs
std::map<std::string, AttData> globalAtts;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
