[MOAB-dev] commit/MOAB: 2 new changesets
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Fri Oct 11 17:49:57 CDT 2013
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/50b351b17830/
Changeset:   50b351b17830
Branch:      None
User:        tautges
Date:        2013-10-07 23:31:36
Summary:     DeformMeshRemap: add some of the data interpolation calls, basically filling
  out the algorithm outlined on confluence.
makefile: adding MOAB lib as a dependency, and mbcoupler lib
  to libs for DeformMeshRemap
ElemEvaluator: hardwiring the number of tuples in a few cases where we know
  coords is the field we're evaluating; also changing the name of a few params from
  tag_dim to tagged_ent_dim to be more descriptive
LinearQuad: fixed jacobian scaling so J(2,2) is 1 instead of .25 (otherwise Jacobian for
  ideal cube is wrong)
SpatialLocator: added par_locate_points function, with no definition yet; also commented more fully,
  to describe use of SpatialLocator and assumptions made, and distinguishing serial vs. parallel use
test/elem_eval_test: added test for linear quad, and corrected test for avg position to divide by elem volume
test/spatial_locator_test: corrected arg order for SpatialLocator::locate_points
tools/mbcoupler/DataCoupler: new class analagous to Coupler that takes advantage of new SpatialLocator functionality
Affected #:  12 files
diff --git a/examples/DeformMeshRemap.cpp b/examples/DeformMeshRemap.cpp
index fac83ae..500d969 100644
--- a/examples/DeformMeshRemap.cpp
+++ b/examples/DeformMeshRemap.cpp
@@ -15,6 +15,7 @@
 #include "moab/LloydSmoother.hpp"
 #include "moab/ProgOptions.hpp"
 #include "MBTagConventions.hpp"
+#include "DataCoupler.hpp"
 #include <iostream>
 #include <set>
@@ -84,7 +85,7 @@ public:
 private:
     //! apply a known deformation to the solid elements, putting the results in the xNew tag; also
     //! write current coordinates to the xNew tag for fluid elements
-  ErrorCode deform_master(Range &fluid_elems, Range &solid_elems);
+  ErrorCode deform_master(Range &fluid_elems, Range &solid_elems, const char *tag_name = NULL);
     //! read a file and establish proper ranges
   ErrorCode read_file(int m_or_s, string &fname, EntityHandle &seth);
@@ -193,20 +194,46 @@ ErrorCode DeformMeshRemap::execute()
   if (MB_SUCCESS != rval) return rval;
     // deform the master's solid mesh, put results in a new tag
-  rval = deform_master(fluidElems[MASTER], solidElems[MASTER]); RR("");
+  rval = deform_master(fluidElems[MASTER], solidElems[MASTER], "xnew"); RR("");
   if (debug) write_and_save(solidElems[MASTER], masterSet, xNew, "deformed.vtk");
-    // smooth the master mesh
-  LloydSmoother *ll = new LloydSmoother(mbImpl, NULL, fluidElems[MASTER], xNew);
-  rval = ll->perform_smooth();
-  RR("Failed in lloyd smoothing.");
-  cout << "Lloyd smoothing required " << ll->num_its() << " iterations." << endl;
-  if (debug) write_and_save(fluidElems[MASTER], masterSet, xNew, "smoothed.vtk");
+  { // to isolate the lloyd smoother & delete when done
+      // smooth the master mesh
+    LloydSmoother ll(mbImpl, NULL, fluidElems[MASTER], xNew);
+    rval = ll.perform_smooth();
+    RR("Failed in lloyd smoothing.");
+    cout << "Lloyd smoothing required " << ll.num_its() << " iterations." << endl;
     // map new locations to slave
+    // locate slave vertices in master, orig coords; do this with a data coupler, so you can
+    // later interpolate
+  Range src_elems = solidElems[MASTER];
+  src_elems.merge(fluidElems[MASTER]);
+    // initialize data coupler on source elements
+  DataCoupler dc_master(mbImpl, NULL, src_elems, 0);
-  delete ll;
+  Range tgt_verts, tmp_range = solidElems[SLAVE];
+  tmp_range.merge(fluidElems[SLAVE]);
+  rval = mbImpl->get_adjacencies(tmp_range, 0, false, tgt_verts, Interface::UNION);
+  RR("Failed to get target verts.");
+    // locate slave vertices, caching results in dc
+  rval = dc_master.locate_points(tgt_verts, 0.0, 1e-10); RR("Point location of tgt verts failed.");
+    // interpolate xNew to slave points
+  rval = dc_master.interpolate((int)DataCoupler::VOLUME, "xnew"); RR("Failed to interpolate target solution.");
+    // transfer xNew to coords, for master and slave
+  rval = write_to_coords(fluidElems[MASTER], xNew); RR("Failed writing tag to master fluid verts.");
+  rval = write_to_coords(tgt_verts, xNew); RR("Failed writing tag to slave verts.");
+  if (debug) {
+    rval = mbImpl->write_file("smoothed_master.vtk", NULL, NULL, &masterSet, 1);
+    rval = mbImpl->write_file("slave_interp.vtk", NULL, NULL, &slaveSet, 1);
   return MB_SUCCESS;
@@ -302,12 +329,12 @@ void deform_func(double *xold, double *xnew)
   xnew[1] = xold[1] + yfrac * (1.0 + xfrac) * 0.05;
-ErrorCode DeformMeshRemap::deform_master(Range &fluid_elems, Range &solid_elems)
+ErrorCode DeformMeshRemap::deform_master(Range &fluid_elems, Range &solid_elems, const char *tag_name)
     // deform elements with an analytic function
     // create the tag
-  ErrorCode rval = mbImpl->tag_get_handle("", 3, MB_TYPE_DOUBLE, xNew, MB_TAG_CREAT|MB_TAG_DENSE);
+  ErrorCode rval = mbImpl->tag_get_handle((tag_name ? tag_name : ""), 3, MB_TYPE_DOUBLE, xNew, MB_TAG_CREAT|MB_TAG_DENSE);
   RR("Failed to create xnew tag.");
     // get all the vertices and coords in the fluid, set xnew to them
diff --git a/examples/makefile b/examples/makefile
index 87c0132..773c443 100644
--- a/examples/makefile
+++ b/examples/makefile
@@ -14,43 +14,43 @@ EXOIIEXAMPLES = TestExodusII
 default: ${EXAMPLES}
-HelloMOAB : HelloMOAB.o
+HelloMOAB : HelloMOAB.o ${MOAB_LIBDIR}/libMOAB.la
 	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
-GetEntities: GetEntities.o
+GetEntities: GetEntities.o ${MOAB_LIBDIR}/libMOAB.la
-SetsNTags: SetsNTags.o
+SetsNTags: SetsNTags.o ${MOAB_LIBDIR}/libMOAB.la
-LloydRelaxation: LloydRelaxation.o
+LloydRelaxation: LloydRelaxation.o ${MOAB_LIBDIR}/libMOAB.la
-StructuredMeshSimple : StructuredMeshSimple.o
+StructuredMeshSimple : StructuredMeshSimple.o ${MOAB_LIBDIR}/libMOAB.la
-DirectAccessWithHoles: DirectAccessWithHoles.o
+DirectAccessWithHoles: DirectAccessWithHoles.o ${MOAB_LIBDIR}/libMOAB.la
-DirectAccessNoHoles: DirectAccessNoHoles.o
+DirectAccessNoHoles: DirectAccessNoHoles.o ${MOAB_LIBDIR}/libMOAB.la
-DirectAccessNoHolesF90: DirectAccessNoHolesF90.o
+DirectAccessNoHolesF90: DirectAccessNoHolesF90.o ${MOAB_LIBDIR}/libMOAB.la
 	${MOAB_CXX} -o $@ $< ${IMESH_LIBS}
-ReduceExchangeTags : ReduceExchangeTags.o
+ReduceExchangeTags : ReduceExchangeTags.o ${MOAB_LIBDIR}/libMOAB.la
-HelloParMOAB: HelloParMOAB.o
+HelloParMOAB: HelloParMOAB.o ${MOAB_LIBDIR}/libMOAB.la
-TestExodusII: TestExodusII.o
+TestExodusII: TestExodusII.o ${MOAB_LIBDIR}/libMOAB.la
-point_in_elem_search: point_in_elem_search.o
+point_in_elem_search: point_in_elem_search.o ${MOAB_LIBDIR}/libMOAB.la
-DeformMeshRemap: DeformMeshRemap.o
-	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
+DeformMeshRemap: DeformMeshRemap.o ${MOAB_LIBDIR}/libMOAB.la
+	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK} -lmbcoupler ${MOAB_LIBS_LINK}
 clean:
 	rm -rf *.o ${EXAMPLES} ${PAREXAMPLES} ${EXOIIEXAMPLES}
diff --git a/src/LocalDiscretization/ElemEvaluator.cpp b/src/LocalDiscretization/ElemEvaluator.cpp
index b132da9..4446281 100644
--- a/src/LocalDiscretization/ElemEvaluator.cpp
+++ b/src/LocalDiscretization/ElemEvaluator.cpp
@@ -30,7 +30,9 @@ namespace moab {
       CartVect new_pos;
         // evaluate that first guess to get a new position
-      ErrorCode rval = (*eval)(cvparams->array(), verts, ndim, ndim, work, new_pos.array());
+      ErrorCode rval = (*eval)(cvparams->array(), verts, ndim,
+                               3, // hardwire to num_tuples to 3 since the field is coords
+                               work, new_pos.array());
         // residual is diff between old and new pos; need to minimize that
@@ -58,7 +60,9 @@ namespace moab {
         *cvparams -= J.inverse(1.0/det) * res;
           // get the new forward-evaluated position, and its difference from the target pt
-        rval = (*eval)(params, verts, ndim, ndim, work, new_pos.array());
+        rval = (*eval)(params, verts, ndim,
         res = new_pos - *cvposn;
diff --git a/src/LocalDiscretization/LinearQuad.cpp b/src/LocalDiscretization/LinearQuad.cpp
index ddd4918..93237f9 100644
--- a/src/LocalDiscretization/LinearQuad.cpp
+++ b/src/LocalDiscretization/LinearQuad.cpp
@@ -16,23 +16,23 @@ namespace moab
     const double LinearQuad::gauss[1][2] = { {  2.0,           0.0          } };
-    ErrorCode LinearQuad::jacobianFcn(const double *params, const double *verts, const int /*nverts*/, const int ndim,
+    ErrorCode LinearQuad::jacobianFcn(const double *params, const double *verts, const int /*nverts*/, const int /*ndim*/,
                                       double *, double *result)
       Matrix3 *J = reinterpret_cast<Matrix3*>(result);
       *J = Matrix3(0.0);
       for (unsigned i = 0; i < 4; ++i) {
-        const double   params_p = 1 + params[0]*corner[i][0];
+        const double   xi_p = 1 + params[0]*corner[i][0];
         const double  eta_p = 1 + params[1]*corner[i][1];
-        const double dNi_dparams   = corner[i][0] * eta_p;
-        const double dNi_deta  = corner[i][1] *  params_p;
-        (*J)(0,0) += dNi_dparams   * verts[i*ndim+0];
-        (*J)(1,0) += dNi_dparams   * verts[i*ndim+1];
-        (*J)(0,1) += dNi_deta  * verts[i*ndim+0];
-        (*J)(1,1) += dNi_deta  * verts[i*ndim+1];
+        const double dNi_dxi   = corner[i][0] * eta_p;
+        const double dNi_deta  = corner[i][1] * xi_p;
+        (*J)(0,0) += dNi_dxi   * verts[i*3+0];
+        (*J)(1,0) += dNi_dxi   * verts[i*3+1];
+        (*J)(0,1) += dNi_deta  * verts[i*3+0];
+        (*J)(1,1) += dNi_deta  * verts[i*3+1];
-      (*J)(2,2) = 1.0; /* to make sure the Jacobian determinant is non-zero */
       (*J) *= 0.25;
+      (*J)(2,2) = 1.0; /* to make sure the Jacobian determinant is non-zero */
       return MB_SUCCESS;
     }// LinearQuad::jacobian()
@@ -62,7 +62,7 @@ namespace moab
         for(unsigned int j2 = 0; j2 < LinearQuad::gauss_count; ++j2) {
           x[1] = LinearQuad::gauss[j2][1];
           double w2 = LinearQuad::gauss[j2][0];
-          rval = evalFcn(x.array(),field, ndim, num_tuples, NULL, tmp_result);
+          rval = evalFcn(x.array(), field, ndim, num_tuples, NULL, tmp_result);
           rval = jacobianFcn(x.array(), verts, nverts, ndim, work, J[0]);
diff --git a/src/LocalDiscretization/moab/ElemEvaluator.hpp b/src/LocalDiscretization/moab/ElemEvaluator.hpp
index 48d34ac..eac008d 100644
--- a/src/LocalDiscretization/moab/ElemEvaluator.hpp
+++ b/src/LocalDiscretization/moab/ElemEvaluator.hpp
@@ -119,9 +119,9 @@ namespace moab {
          * \param impl MOAB instance
          * \param ent Entity handle to cache on the evaluator
          * \param tag Tag to cache on the evaluator
-         * \param tag_dim Tag dimension to cache on the evaluator
+         * \param tagged_ent_dim Dimension of entities to be tagged to cache on the evaluator
-      ElemEvaluator(Interface *impl, EntityHandle ent = 0, Tag tag = 0, int tag_dim = -1);
+      ElemEvaluator(Interface *impl, EntityHandle ent = 0, Tag tag = 0, int tagged_ent_dim = -1);
         /** \brief Evaluate cached tag at a given parametric location within the cached entity
          * If evaluating coordinates, call set_tag(0, 0), which indicates coords instead of a tag.
@@ -233,23 +233,23 @@ namespace moab {
          * To designate that vertex coordinates are the desired tag, pass in a tag handle of 0
          * and a tag dimension of 0.
          * \param tag Tag handle to cache, or 0 to cache vertex positions
-         * \param tag_dim Dimension of entities tagged with this tag
+         * \param tagged_ent_dim Dimension of entities tagged with this tag
-      inline ErrorCode set_tag_handle(Tag tag, int tag_dim = -1);
+      inline ErrorCode set_tag_handle(Tag tag, int tagged_ent_dim = -1);
         /* \brief Set the name of the tag to cache on this evaluator
          * To designate that vertex coordinates are the desired tag, pass in "COORDS" as the name
-         * \param tag Tag handle to cache, or 0 to cache vertex positions
+         * \param tag_name Tag handle to cache, or 0 to cache vertex positions
-      inline ErrorCode set_tag(const char *tag_name, int ent_dim = -1);
+      inline ErrorCode set_tag(const char *tag_name, int tagged_ent_dim = -1);
         /* \brief Get the dimension of the entities on which tag is set */
-      inline int get_tag_dim() const {return tagDim;};
+      inline int get_tagged_ent_dim() const {return taggedEntDim;};
         /* \brief Set the dimension of entities having the tag */
-      inline ErrorCode set_tag_dim(int dim);
+      inline ErrorCode set_tagged_ent_dim(int dim);
         /* \brief MOAB interface cached on this evaluator */
       inline Interface *get_moab() {return mbImpl;}
@@ -287,7 +287,7 @@ namespace moab {
       int numTuples;
         /** \brief Dimension of entities from which to grab tag */
-      int tagDim;
+      int taggedEntDim;
         /** \brief Tag space */
       std::vector<unsigned char> tagSpace;
@@ -300,13 +300,13 @@ namespace moab {
     }; // class ElemEvaluator
-    inline ElemEvaluator::ElemEvaluator(Interface *impl, EntityHandle ent, Tag tag, int tag_dim)
+    inline ElemEvaluator::ElemEvaluator(Interface *impl, EntityHandle ent, Tag tag, int tagged_ent_dim)
             : mbImpl(impl), entHandle(0), entType(MBMAXTYPE), entDim(-1), numVerts(0),
               vertHandles(NULL), tagHandle(0), tagCoords(false), numTuples(0),
-              tagDim(0), workSpace(NULL)
+              taggedEntDim(0), workSpace(NULL)
       if (ent) set_ent_handle(ent);
-      if (tag) set_tag_handle(tag, tag_dim);
+      if (tag) set_tag_handle(tag, tagged_ent_dim);
     inline ErrorCode ElemEvaluator::set_ent_handle(EntityHandle ent)
@@ -329,18 +329,17 @@ namespace moab {
         rval = set_tag_handle(tagHandle);
       if (evalSets[entType].initFcn) return (*evalSets[entType].initFcn)(vertPos[0].array(), numVerts, workSpace);
       return MB_SUCCESS;
-    inline ErrorCode ElemEvaluator::set_tag_handle(Tag tag, int tag_dim)
+    inline ErrorCode ElemEvaluator::set_tag_handle(Tag tag, int tagged_ent_dim)
       ErrorCode rval = MB_SUCCESS;
-      if (!tag && !tag_dim) {
+      if (!tag && !tagged_ent_dim) {
         tagCoords = true;
         numTuples = 3;
-        tagDim = 0;
+        taggedEntDim = 0;
         tagHandle = 0;
         return rval;
@@ -355,14 +354,14 @@ namespace moab {
         tagCoords = false;
-      tagDim = (-1 == tag_dim ? 0 : tag_dim);
+      taggedEntDim = (-1 == tagged_ent_dim ? 0 : tagged_ent_dim);
       if (entHandle) {
-        if (0 == tagDim) {
+        if (0 == taggedEntDim) {
           rval = mbImpl->tag_get_data(tagHandle, vertHandles, numVerts, &tagSpace[0]);
-        else if (tagDim == entDim) {
+        else if (taggedEntDim == entDim) {
           rval = mbImpl->tag_get_data(tagHandle, &entHandle, 1, &tagSpace[0]);
@@ -371,14 +370,14 @@ namespace moab {
       return rval;
-    inline ErrorCode ElemEvaluator::set_tag(const char *tag_name, int tag_dim)
+    inline ErrorCode ElemEvaluator::set_tag(const char *tag_name, int tagged_ent_dim)
       if (!tag_name || strlen(tag_name) == 0) return MB_FAILURE;
       Tag tag;
       if (!strcmp(tag_name, "COORDS")) {
         tagCoords = true;
-        tagDim = 0;
+        taggedEntDim = 0;
         numTuples = 3;
         tagHandle = 0;
           // can return here, because vertex coords already cached when entity handle set
@@ -399,15 +398,15 @@ namespace moab {
           tagCoords = false;
-        tagDim = (-1 == tag_dim ? entDim : tag_dim);
+        taggedEntDim = (-1 == tagged_ent_dim ? entDim : tagged_ent_dim);
       if (entHandle) {
@@ -431,16 +430,16 @@ namespace moab {
       assert(entHandle && MBMAXTYPE != entType);
       return (*evalSets[entType].evalFcn)(params,
                                           (tagCoords ? (const double*) vertPos[0].array(): (const double*)&tagSpace[0]),
-                                          entDim, (-1 == num_tuples ? numTuples : num_tuples),
-                                          workSpace, result);
+                                          entDim,
+                                          (-1 == num_tuples ? numTuples : num_tuples), workSpace, result);
     inline ErrorCode ElemEvaluator::reverse_eval(const double *posn, const double tol, double *params, bool *ins) const
       return (*evalSets[entType].reverseEvalFcn)(evalSets[entType].evalFcn, evalSets[entType].jacobianFcn, evalSets[entType].insideFcn,
-                                                 posn, vertPos[0].array(), numVerts, entDim, tol, workSpace,
-                                                 params, ins);
+                                                 posn, vertPos[0].array(), numVerts,
+                                                 entDim, tol, workSpace, params, ins);
       /** \brief Evaluate the jacobian of the cached entity at a given parametric location */
@@ -456,7 +455,7 @@ namespace moab {
       assert(entHandle && MBMAXTYPE != entType && (tagCoords || tagHandle));
       if (!tagCoords) {
-        if (0 == tagDim) rval = mbImpl->tag_get_data(tagHandle, vertHandles, numVerts, (void*)&tagSpace[0]);
+        if (0 == taggedEntDim) rval = mbImpl->tag_get_data(tagHandle, vertHandles, numVerts, (void*)&tagSpace[0]);
         else rval = mbImpl->tag_get_data(tagHandle, &entHandle, 1, (void*)&tagSpace[0]);
diff --git a/src/SpatialLocator.cpp b/src/SpatialLocator.cpp
index a543dc9..d3b521e 100644
--- a/src/SpatialLocator.cpp
+++ b/src/SpatialLocator.cpp
@@ -31,10 +31,62 @@ namespace moab
       return MB_SUCCESS;
+#ifdef USE_MPI
+    ErrorCode SpatialLocator::par_locate_points(Range &/*vertices*/,
+                                                double /*rel_tol*/, double /*abs_tol*/)
+      return MB_UNSUPPORTED_OPERATION;
+    ErrorCode SpatialLocator::par_locate_points(const double */*pos*/, int /*num_points*/,
+#endif
+    ErrorCode SpatialLocator::locate_points(Range &verts,
+                                            double rel_eps, double abs_eps)
+      assert(!verts.empty() && mbImpl->type_from_handle(*verts.rbegin()) == MBVERTEX);
+      std::vector<double> pos(3*verts.size());
+      ErrorCode rval = mbImpl->get_coords(verts, &pos[0]);
+      if (MB_SUCCESS != rval) return rval;
+      rval = locate_points(&pos[0], verts.size(), rel_eps, abs_eps);
+      return MB_SUCCESS;
+    ErrorCode SpatialLocator::locate_points(const double *pos, int num_points,
+        // initialize to tuple structure (p_ui, hs_ul, r[3]_d) (see header comments for locTable)
+      locTable.initialize(1, 0, 1, 3, num_points);
+      locTable.enableWriteAccess();
+        // pass storage directly into locate_points, since we know those arrays are contiguous
+      ErrorCode rval = locate_points(pos, num_points, locTable.vul_wr, locTable.vr_wr, NULL, rel_eps, abs_eps);
+      std::fill(locTable.vi_wr, locTable.vi_wr+num_points, 0);
+                                            EntityHandle *ents, double *params, bool *is_inside,
+      return locate_points(&pos[0], verts.size(), ents, params, is_inside, rel_eps, abs_eps);
-                                            EntityHandle *ents, double *params,
-                                            double rel_eps, double abs_eps,
-                                            bool *is_inside)
       if (rel_eps && !abs_eps) {
diff --git a/src/moab/SpatialLocator.hpp b/src/moab/SpatialLocator.hpp
index a8f694f..780c086 100644
--- a/src/moab/SpatialLocator.hpp
+++ b/src/moab/SpatialLocator.hpp
@@ -1,6 +1,30 @@
 /**\file SpatialLocator.hpp
  * \class moab::SpatialLocator
  * \brief Tool to facilitate spatial location of a point in a mesh
+ * SpatialLocator facilitates searching for points in or performing ray traces on collections of mesh entities
+ * in 2D or 3D.  This searching is facilitated by a tree-based decomposition of the mesh.  Various types
+ * of trees are implemented in MOAB and can be used by this tool, but by default it uses AdaptiveKDTree
+ * (see child classes of Tree for which others are available).  Parallel and serial searching are both
+ * supported.
+ * SpatialLocator can either cache the search results for points or pass back this information in arguments.
+ * Cached information is kept in locTable, indexed in the same order as search points passed in.  This information
+ * consists of the entity handle containing the point and the parametric coordinates inside that element.
+ * Information about the points searched, e.g. the entities from which those points are derived, can be stored
+ * in the calling application if desired.
+ * In parallel, there is a separation between the proc deciding which points to search for (the "target" proc),
+ * and the proc locating the point in its local mesh (the "source" proc).  On the source proc, location
+ * information is cached in locTable, as in the serial case.  By default, this location information (handle and
+ * parametric coords) is not returned to the target proc, since it would be of no use there.  Instead, the rank
+ * of the source proc locating the point, and the index of that location info in the source proc's locTable, is
+ * returned; this information is stored on the target proc in this class's parLocTable variable.  Again,
+ * information about the points searched should be stored in the calling application, if desired.
+ * This class uses the ElemEvaluator class for specification and evaluation of basis functions (used for computing
+ * parametric coords within an entity).  See documentation and examples for that class for usage information.
 #ifndef MOAB_SPATIALLOCATOR_HPP
@@ -9,6 +33,7 @@
 #include "moab/Types.hpp"
 #include "moab/Tree.hpp"
 #include "moab/Range.hpp"
+#include "moab/TupleList.hpp"
 #include <string>
 #include <vector>
@@ -34,23 +59,83 @@ namespace moab {
         /* get bounding box of this locator */
       ErrorCode get_bounding_box(BoundBox &box);
+        /* locate a set of vertices, Range variant */
+      ErrorCode locate_points(Range &vertices,
+                              EntityHandle *ents, double *params, bool *is_inside = NULL,
+                              double rel_tol = 0.0, double abs_tol = 0.0);
         /* locate a set of points */
       ErrorCode locate_points(const double *pos, int num_points,
-                              double rel_tol = 0.0, double abs_tol = 0.0,
-                              bool *is_inside = NULL);
-        /* locate a point */
-      ErrorCode locate_point(const double *pos,
-                             EntityHandle &ent, double *params,
+        /* locate a set of vertices or entity centroids, storing results on TupleList in this class
+         * Locate a set of vertices or entity centroids, storing the detailed results in member
+         * variable (TupleList) locTable (see comments on locTable for structure of that tuple).
+      ErrorCode locate_points(Range &ents,
+        /* locate a set of points, storing results on TupleList in this class
+         * Locate a set of points, storing the detailed results in member variable (TupleList) locTable
+         * (see comments on locTable for structure of that tuple).
+      ErrorCode locate_points(const double *pos, int num_points,
+#ifdef USE_MPI
+         * variables (TupleList) locTable and parLocTable (see comments on locTable and parLocTable for
+         * structure of those tuples).
+      ErrorCode par_locate_points(Range &vertices,
+      ErrorCode par_locate_points(const double *pos, int num_points,
+#endif
         /* return the tree */
       Tree *get_tree() {return myTree;}
+        /* get the locTable
+      TupleList &loc_table() {return locTable;}
+      const TupleList &loc_table() const {return locTable;}
+        /* get the parLocTable
+      TupleList &par_loc_table() {return parLocTable;}
+      const TupleList &par_loc_table() const {return parLocTable;}
+        /* get elemEval */
+      ElemEvaluator *elem_eval() {return elemEval;}
+      const ElemEvaluator *elem_eval() const {return elemEval;}
+        /* set elemEval */
+      void elem_eval(ElemEvaluator *eval) {elemEval = eval;}
   private:
+        /* locate a point */
+      ErrorCode locate_point(const double *pos,
+                             EntityHandle &ent, double *params, bool *is_inside = NULL,
         /* MOAB instance */
       Interface* mbImpl;
@@ -68,6 +153,29 @@ namespace moab {
         /* whether I created the tree or not (determines whether to delete it or not on destruction) */
       bool iCreatedTree;
+        /* \brief local locations table
+         * This table stores detailed local location data results from locate_points, that is, location data
+         * for points located on the local mesh.  Data is stored
+         * in a TupleList, where each tuple consists of (p_i, hs_ul, r[3]_d), where
+         *   p_i = (int) proc from which request for this point was made (0 if serial)
+         *   hs_ul = (unsigned long) source entity containing the point
+         *   r[3]_d = (double) parametric coordinates of the point in hs
+      TupleList locTable;
+        /* \brief parallel locations table
+         * This table stores information about points located on a local or remote processor.  For
+         * points located on this processor's local mesh, detailed location data is stored in locTable.
+         * For points located on remote processors, more communication is required to retrieve specific
+         * location data (usually that information isn't useful on this processor).
+         * The tuple structure of this TupleList is (p_i, ri_i), where:
+         *   p_i = (int) processor rank containing this point
+         *   ri_i = (int) index into locTable on remote proc containing this point's location information
+         * The indexing of parLocTable corresponds to that of the points/entities passed in.
+      TupleList parLocTable;
     inline SpatialLocator::~SpatialLocator()
@@ -76,11 +184,10 @@ namespace moab {
     inline ErrorCode SpatialLocator::locate_point(const double *pos,
-                                                  double rel_tol, double abs_tol,
-                                                  bool *is_inside)
+                                                  EntityHandle &ent, double *params, bool *is_inside,
+                                                  double rel_tol, double abs_tol)
-      return locate_points(pos, 1, &ent, params, rel_tol, abs_tol, is_inside);
+      return locate_points(pos, 1, &ent, params, is_inside, rel_tol, abs_tol);
     inline ErrorCode SpatialLocator::get_bounding_box(BoundBox &box)
diff --git a/test/elem_eval_test.cpp b/test/elem_eval_test.cpp
index a5907fd..6f07d7a 100644
--- a/test/elem_eval_test.cpp
+++ b/test/elem_eval_test.cpp
@@ -7,6 +7,7 @@
 #include "moab/Core.hpp"
 #include "moab/ReadUtilIface.hpp"
 #include "moab/ElemEvaluator.hpp"
+#include "moab/LinearQuad.hpp"
 #include "moab/LinearHex.hpp"
 #include "moab/LinearTet.hpp"
 #include "moab/QuadraticHex.hpp"
@@ -21,6 +22,7 @@ std::string TestDir(".");
 using namespace moab;
+void test_linear_quad();
 void test_linear_hex();
 void test_linear_tet();
 void test_quadratic_hex();
@@ -49,6 +51,7 @@ void test_eval(ElemEvaluator &ee, bool test_integrate)
   bool is_inside;
   Matrix3 jacob;
   ErrorCode rval;
+  int ent_dim = ee.get_moab()->dimension_from_handle(ee.get_ent_handle());
   for (params[0] = -1; params[0] <= 1; params[0] += 0.2) {
     for (params[1] = -1; params[1] <= 1; params[1] += 0.2) {
@@ -59,9 +62,11 @@ void test_eval(ElemEvaluator &ee, bool test_integrate)
         rval = ee.eval(params.array(), posn.array()); CHECK_ERR(rval);
         rval = ee.reverse_eval(posn.array(), EPS1, params2.array(), &is_inside); CHECK_ERR(rval);
-        if ((params - params2).length() > 3*EPS1)
-          std::cerr << params << std::endl;
-        CHECK_REAL_EQUAL(0.0, (params - params2).length(), 3*EPS1);
+        CHECK_REAL_EQUAL(0.0, params[0] - params2[0], 3*EPS1);
+        if (ent_dim > 1)
+          CHECK_REAL_EQUAL(0.0, params[1] - params2[1], 3*EPS1);
+        if (ent_dim > 2)
+          CHECK_REAL_EQUAL(0.0, params[2] - params2[2], 3*EPS1);
           // jacobian should be >= 0
         rval = ee.jacobian(params.array(), jacob.array()); CHECK_ERR(rval);
@@ -81,8 +86,21 @@ void test_eval(ElemEvaluator &ee, bool test_integrate)
     // set that temporary tag on the evaluator so that's what gets integrated
   rval = ee.set_tag_handle(tag, 0); CHECK_ERR(rval);
-  CartVect integral, avg(0.0);
+  CartVect integral, avg;
   rval = ee.integrate(integral.array()); CHECK_ERR(rval);
+    // now integrate a const 1-valued function, using direct call to the integrate function
+  std::vector<double> one(ee.get_num_verts(), 1.0);
+  double measure;
+  EvalSet es;
+  EntityHandle eh = ee.get_ent_handle();
+  rval = EvalSet::get_eval_set(ee.get_moab(), eh, es); CHECK_ERR(rval);
+  rval = (*es.integrateFcn)(&one[0], hex_verts[0].array(), ee.get_num_verts(), ee.get_moab()->dimension_from_handle(eh),
+                            1, NULL, &measure); CHECK_ERR(rval);
+  if (measure) integral /= measure;
+    // check against avg of entity's vertices' positions
+  rval = ee.get_moab()->get_coords(&eh, 1, avg.array()); CHECK_ERR(rval);
   CHECK_REAL_EQUAL(0.0, (avg - integral).length(), EPS1);
     // delete the temporary tag
@@ -118,6 +136,7 @@ int main()
   int failures = 0;
+  failures += RUN_TEST(test_linear_quad);
   failures += RUN_TEST(test_linear_hex);
   failures += RUN_TEST(test_quadratic_hex);
   failures += RUN_TEST(test_linear_tet);
@@ -125,6 +144,23 @@ int main()
   return failures;
+  Core mb;
+  Range verts;
+  ErrorCode rval = mb.create_vertices((double*)hex_verts, 4, verts); CHECK_ERR(rval);
+  EntityHandle quad;
+  std::vector<EntityHandle> connect;
+  std::copy(verts.begin(), verts.end(), std::back_inserter(connect));
+  rval = mb.create_element(MBQUAD, &connect[0], 4, quad); CHECK_ERR(rval);
+  ElemEvaluator ee(&mb, quad, 0);
+  ee.set_tag_handle(0, 0);
+  ee.set_eval_set(MBQUAD, LinearQuad::eval_set());
+  test_eval(ee, true);
   Core mb;
diff --git a/test/spatial_locator_test.cpp b/test/spatial_locator_test.cpp
index 31bf08a..6ffa109 100644
--- a/test/spatial_locator_test.cpp
+++ b/test/spatial_locator_test.cpp
@@ -116,7 +116,7 @@ void test_locator(SpatialLocator *sl)
     test_pt = box.bMin + CartVect(rx*box_del[0], ry*box_del[1], rz*box_del[2]);
     // call spatial locator to locate points
-    rval = sl->locate_points(test_pt.array(), 1, &ent, test_res.array(), 0.0, 0.0, &is_in); CHECK_ERR(rval);
+    rval = sl->locate_points(test_pt.array(), 1, &ent, test_res.array(), &is_in); CHECK_ERR(rval);
     // verify that the point was found
     CHECK_EQUAL(is_in, true);
diff --git a/tools/mbcoupler/DataCoupler.cpp b/tools/mbcoupler/DataCoupler.cpp
new file mode 100644
index 0000000..71f3497
--- /dev/null
+++ b/tools/mbcoupler/DataCoupler.cpp
@@ -0,0 +1,225 @@
+#include "moab/ParallelComm.hpp"
+#include "moab/Tree.hpp"
+#include "moab/SpatialLocator.hpp"
+#include "moab/ElemEvaluator.hpp"
+#include "moab/Error.hpp"
+#include "iostream"
+#include <stdio.h>
+#include <algorithm>
+#include <sstream>
+#include "assert.h"
+namespace moab {
+bool debug = false;
+DataCoupler::DataCoupler(Interface *impl,
+                         ParallelComm *pc,
+                         Range &source_ents,
+                         int coupler_id,
+                         bool init_locator,
+                         int dim)
+        : mbImpl(impl), myPcomm(pc), myId(coupler_id), myDim(dim)
+  assert(NULL != mbImpl && (myPcomm || !source_ents.empty()));
+    // now initialize the tree
+  if (init_locator) {
+    myLocator = new SpatialLocator(mbImpl, source_ents);
+    myLocator->elem_eval(new ElemEvaluator(mbImpl));
+      // initialize element evaluator with the default for the entity types in source_ents;
+      // can be replaced later by application if desired
+    if (!source_ents.empty()) {
+      Range::pair_iterator pit = source_ents.pair_begin();
+      EntityType last_type = MBMAXTYPE;
+      for (; pit != source_ents.pair_end(); pit++) {
+        EntityType this_type = mbImpl->type_from_handle(pit->first);
+        if (last_type == this_type) continue;
+        myLocator->elem_eval()->set_eval_set(pit->first);
+        last_type = this_type;
+  if (-1 == dim && !source_ents.empty())
+    dim = mbImpl->dimension_from_handle(*source_ents.rbegin());
+  ErrorCode rval = impl->query_interface(mError);
+  if (MB_SUCCESS != rval) throw(rval);
+  /* destructor
+DataCoupler::~DataCoupler()
+  delete myLocator;
+ErrorCode DataCoupler::locate_points(Range &targ_ents,
+                                     double rel_eps,
+                                     double abs_eps)
+  targetEnts = targ_ents;
+  return myLocator->locate_points(targ_ents, rel_eps, abs_eps);
+ErrorCode DataCoupler::locate_points(double *xyz, int num_points,
+                                 double rel_eps,
+                                 double abs_eps)
+  return myLocator->locate_points(xyz, num_points, rel_eps, abs_eps);
+ErrorCode DataCoupler::interpolate(/*DataCoupler::Method*/ int method,
+                                   const std::string &interp_tag,
+                                   double *interp_vals,
+                                   std::vector<int> *point_indices,
+                                   bool normalize)
+    // tag name input, translate to tag handle and pass down the chain
+    // not inlined because of call to set_last_error, class Error isn't in public interface
+  Tag tag;
+  ErrorCode result = mbImpl->tag_get_handle(interp_tag.c_str(), tag);
+  if (MB_SUCCESS != result) {
+    std::ostringstream str;
+    str << "Failed to get handle for interpolation tag \"" << interp_tag << "\"";
+    mError->set_last_error(str.str());
+    return result;
+  return interpolate(method, tag, interp_vals, point_indices, normalize);
+ErrorCode DataCoupler::interpolate(/*DataCoupler::Method*/ int *methods,
+                                   Tag *tags,
+                                   int *points_per_method,
+                                   int num_methods,
+                                   bool /*normalize*/)
+    // lowest-level interpolate function, does actual interpolation using calls to ElemEvaluator
+  ErrorCode result = MB_SUCCESS;
+  unsigned int pts_total = 0;
+  for (int i = 0; i < num_methods; i++) pts_total += (points_per_method ? points_per_method[i] : targetEnts.size());
+  unsigned int num_indices = (point_indices ? point_indices->size() : targetEnts.size());
+  int max_tsize = -1;
+  for (int i = 0; i < num_methods; i++) {
+    int tmp_tsize;
+    result = mbImpl->tag_get_length(tags[i], tmp_tsize);
+    if (MB_SUCCESS != result) return MB_FAILURE;
+    max_tsize = std::max(max_tsize, tmp_tsize);
+    // if tl was passed in non-NULL, just have those points, otherwise have targetPts plus
+    // locally mapped pts
+  if (pts_total != num_indices)
+    return MB_FAILURE;
+  if (myPcomm) {
+      // TL to send interpolation indices to target procs
+      // Tuple structure: (pto_i, ridx_i, lidx_i, meth_i, tagidx_i, interp_val[max_tsize]_d)
+    TupleList tinterp;
+    tinterp.initialize(5, 0, 0, max_tsize, num_indices);
+    int t = 0;
+    tinterp.enableWriteAccess();
+      int num_points = (points_per_method ? points_per_method[i] : targetEnts.size());
+      for (int j = 0; j < num_points; j++) {
+        int idx = (point_indices ? (*point_indices)[j] : j);
+          // remote proc/idx from myLocator->parLocTable
+        tinterp.vi_wr[5*t]   = myLocator->par_loc_table().vi_rd[2*idx]; // proc
+        tinterp.vi_wr[5*t+1] = myLocator->par_loc_table().vi_rd[2*idx+1]; // remote idx
+          // local entity index, tag/method index from my data
+        tinterp.vi_wr[5*t+2] = idx;
+        tinterp.vi_wr[5*t+3] = methods[i];
+        tinterp.vi_wr[5*t+4] = i;
+        tinterp.inc_n();
+        t++;
+      // scatter/gather interpolation points
+    myPcomm->proc_config().crystal_router()->gs_transfer(1, tinterp, 0);
+      // perform interpolation on local source mesh; put results into
+      // tinterp.vr_wr
+    for (unsigned int i = 0; i < tinterp.get_n(); i++) {
+      int lidx = tinterp.vi_rd[5*i+1];
+//    /*Method*/ int method = (/*Method*/ int)tinterp.vi_rd[5*i+3];
+      Tag tag = tags[tinterp.vi_rd[5*i+4]];
+      myLocator->elem_eval()->set_tag_handle(tag);
+      myLocator->elem_eval()->set_ent_handle(myLocator->loc_table().vul_rd[lidx]);
+      result = myLocator->elem_eval()->eval(myLocator->loc_table().vr_rd+3*lidx, tinterp.vr_rd+i*max_tsize);
+      if (MB_SUCCESS != result) return result;
+      // scatter/gather interpolation data
+      // copy the interpolated field as a unit
+    std::copy(tinterp.vr_rd, tinterp.vr_rd+tinterp.get_n()*max_tsize, interp_vals);
+  else {
+    std::vector<double> tmp_vals;
+    std::vector<EntityHandle> tmp_ents;
+    double *tmp_dbl = interp_vals;
+        // interpolated data is tsize long, which is either max size (if data passed back to caller in tinterp)
+        // or tag size (if data will be set on entities, in which case it shouldn't have padding)
+      int tsize = max_tsize, tsize_bytes = 0;
+      if (!interp_vals) {
+        tmp_vals.resize(num_points*max_tsize);
+        tmp_dbl = &tmp_vals[0];
+        tmp_ents.resize(num_points);
+        result = mbImpl->tag_get_length(tags[i], tsize);
+        result = mbImpl->tag_get_bytes(tags[i], tsize_bytes);
+        int lidx;
+        if (point_indices) {
+          lidx = (*point_indices)[j];
+        else {
+          lidx = j;
+        myLocator->elem_eval()->set_tag_handle(tags[i]);
+        if (!interp_vals) tmp_ents[j] = targetEnts[lidx]; // could be performance-sensitive, thus the if test
+        result = myLocator->elem_eval()->eval(myLocator->loc_table().vr_rd+3*lidx, tmp_dbl);
+        tmp_dbl += tsize;
+      } // for j
+          // set tags on tmp_ents; data is already w/o padding, due to tsize setting above
+        result = mbImpl->tag_set_data(tags[i], &tmp_ents[0], tmp_ents.size(), &tmp_vals[0]);
+    } // for i
+  } // if myPcomm
+      // done
+} // namespace_moab
diff --git a/tools/mbcoupler/DataCoupler.hpp b/tools/mbcoupler/DataCoupler.hpp
index 0000000..3ad1d74
--- /dev/null
+++ b/tools/mbcoupler/DataCoupler.hpp
@@ -0,0 +1,255 @@
+ * \class moab::DataCoupler
+ * \brief This class couples data between meshes.
+ * The coupler interpolates solution data at a set of points.  Data being interpolated resides on a "source"
+ * mesh, in a tag or in vertex coords.  Applications calling this coupler send in entities, and receive back
+ * data interpolated at those points.  Entities in the source mesh containing those points do not have to reside
+ * on the same processor.
+ * To use, an application should:
+ * - instantiate this DataCoupler by calling the constructor collectively on all processors in the communicator
+ * - call locate_points, which locates the points to be interpolated and (optionally) caches the results in
+ *   this class and SpatialLocator
+ * - call interpolate, which does the interpolation
+ * Multiple interpolations (of multiple tags, or element-average vs. true interpolation) can be done after
+ * locating the points.
+ * SpatialLocator is used for the spatial location portion of this work.
+ * This class is a next-generation implementation of Coupler.
+#ifndef DATACOUPLER_HPP
+#define DATACOUPLER_HPP
+#include "moab/Range.hpp"
+#include "moab/Interface.hpp"
+#include <sstream>
+namespace moab {
+class ParallelComm;
+class SpatialLocator;
+class Error;
+class DataCoupler
+public:
+  enum IntegType {VOLUME};
+    /* constructor
+     * Constructor, which also optionally initializes the coupler
+     * \param pc ParallelComm object to be used with this coupler, representing the union
+     *    of processors containing source and target meshes
+     * \param source_elems Elements in the source mesh
+     * \param coupler_id Id of this coupler, should be the same over all procs
+     * \param init_locator If true, initializes a spatial locator inside the constructor
+     * \param dim Dimension of entities to be coupled; if -1, get from source_elems
+  DataCoupler(Interface *impl,
+              ParallelComm *pc,
+              int coupler_id,
+              bool init_locator = true,
+              int dim = -1);
+    /* destructor
+  virtual ~DataCoupler();
+    /* \brief Locate points on the source mesh
+     * This is a pass-through function to SpatialLocator::locate_points
+     * \param xyz Point locations (interleaved) being located
+     * \param num_points Number of points in xyz
+     * \param rel_eps Relative tolerance for the non-linear iteration inside a given element
+     * \param abs_eps Absolute tolerance for the non-linear iteration inside a given element
+     * \param loc_results Tuple list containing the results; two types of results are possible,
+     *      controlled by value of store_local parameter:
+     *      store_local = true: each tuple T[j] consists of (p, i), p = proc with src element containing
+     *        point j (or 0 if serial), i = index in stored list (in SpatialLocator) on src proc
+     *      store_local = false: each tuple T[j] consists of (p, ht, hs, pr[3]), where ht = target mesh entity
+     *        handle, hs = source mesh entity containing point (0 if not found), pr = parameters in hs
+     * \param store_local If true, stores the located points on SpatialLocator
+  ErrorCode locate_points(double *xyz, int num_points,
+                          double rel_eps = 0.0, double abs_eps = 0.0);
+     * \param ents Target entities being located
+                          double abs_eps = 0.0);
+    /* \brief Interpolate data from the source mesh onto points
+     * All entities/points or, if tuple_list is input, only those points
+     * are interpolated from the source mesh.  Application should
+     * allocate enough memory in interp_vals to hold interpolation results.
+     * If normalization is requested, technique used depends on the coupling
+     * method.
+     * \param method Interpolation/normalization method
+     * \param tag Tag on source mesh holding data to be interpolated
+     * \param interp_vals Memory holding interpolated data; if NULL, data is written to same tag on target ents
+     * \param point_indices If non-NULL, a set of indices of points input to
+     *        locate_points at which to interpolate; if NULL, interpolates at all points
+     *        input to locate_points
+     * \param normalize If true, normalization is done according to method
+  ErrorCode interpolate(/*DataCoupler::Method*/ int method,
+                        Tag tag,
+                        double *interp_vals = NULL,
+                        std::vector<int> *point_indices = NULL,
+                        bool normalize = true);
+     * method.
+     * \param tag_name Tag name on source mesh holding data to be interpolated
+                        const std::string &tag_name,
+    /* \brief Interpolate data from multiple tags
+     * In this variant, multiple tags, possibly with multiple interpolation
+     * methods, are specified.  Sum of values in points_per_method should be
+     * the number of points in tl or, if NULL, targetPts.
+     * method.
+     * \param methods Vector of Interpolation/normalization methods
+     * \param tag_names Names of tag being interpolated for each method
+     * \param points_per_method Number of points for each method
+     * \param num_methods Length of vectors in previous 3 arguments
+  ErrorCode interpolate(/*DataCoupler::Method*/ int *methods,
+                        const std::string *tag_names,
+                        int num_methods,
+     * method.
+                        Tag *tag_names,
+                        int num_methods,
+    /* Get functions */
+  inline SpatialLocator *spatial_locator() {return myLocator;}
+  inline int my_id() const {return myId;}
+  inline const Range &target_ents() const {return targetEnts;}
+  inline Range &target_ents() {return targetEnts;}
+  inline int get_dim() const {return myDim;}
+private:
+    /* \brief MOAB instance
+  Interface *mbImpl;
+    /* \brief ParallelComm object for this coupler
+  ParallelComm *myPcomm;
+    /* \brief SpatialLocator for local mesh
+  SpatialLocator *myLocator;
+    /* \brief error object used to set last error on interface
+  Error *mError;
+    /* \brief Id of this coupler
+  int myId;
+    /* \brief Range of target entities
+  Range targetEnts;
+  // entity dimension
+  int myDim;
+    inline ErrorCode DataCoupler::interpolate(/*DataCoupler::Method*/ int method,
+                                          Tag tag,
+                                          bool normalize)
+    // no point indices input,
+  int num_pts = (point_indices ? point_indices->size() : targetEnts.size());
+  return interpolate(&method, &tag, &num_pts, 1,
+                     interp_vals, point_indices, normalize);
+} // namespace moab
+#endif
diff --git a/tools/mbcoupler/Makefile.am b/tools/mbcoupler/Makefile.am
index 25a58c2..ea32ff9 100644
--- a/tools/mbcoupler/Makefile.am
+++ b/tools/mbcoupler/Makefile.am
@@ -9,6 +9,7 @@ AM_CPPFLAGS += -DSRCDIR=$(srcdir) \
                -I$(top_srcdir)/src \
                -I$(top_builddir)/src \
                -I$(top_srcdir)/src/parallel \
+               -I$(top_srcdir)/src/LocalDiscretization \
                -I$(top_srcdir)/src/moab/point_locater/lotte \
                -I$(top_srcdir)/test \
                -I$(top_srcdir)/itaps \
@@ -23,10 +24,12 @@ LDADD = libmbcoupler.la $(top_builddir)/src/libMOAB.la $(top_builddir)/itaps/ime
 libmbcoupler_la_SOURCES = \
    Coupler.cpp \
+   DataCoupler.cpp \
    ElemUtil.cpp
 libmbcoupler_la_include_HEADERS = \
    Coupler.hpp \
+   DataCoupler.hpp \
    ElemUtil.hpp
 libmbcoupler_la_includedir = $(includedir)
https://bitbucket.org/fathomteam/moab/commits/97620d2ef9c1/
Changeset:   97620d2ef9c1
Branch:      deformed-mesh-remap
User:        tautges
Date:        2013-10-12 00:49:43
Summary:     General debugging and small feature additions.
DeformMeshRemap: moving location in source mesh of slave mesh to before lloyd smoothing.
  Adding bounding box calculation for use in relative displacement calculation, using displacements
  of about 1% based on communication with LLNL.
SpatialLocator: adding local_num_located and remote_num_located functions, which evaluate contents of locTable and parLocTable for this info.
  Also, when eval_set is set, pass it down to the tree too.
elem_eval_test.cpp: adding (commented out for now) test for LinearTri.
Tree, AdaptiveKDTree, BVHTree, various element types: changing tolerance model to using both iteration tolerance, for non-linear
  point in element iteration, and inside tolerance, for determining whether parameters are inside.
ElemEvaluator: instead of just asserting on negative jacobian, only do so if we're inside the element.
  Also using new tolerance model from above, and incorporating linear tri.
Adding a LinearTri class.
Affected #:  31 files
index 500d969..7614934 100644
@@ -14,6 +14,8 @@
+#include "moab/BoundBox.hpp"
@@ -30,7 +32,7 @@ using namespace std;
 ErrorCode read_file(string &fname, EntityHandle &seth,
                     Range &solids, Range &solid_elems, Range &fluids, Range &fluid_elems);
-void deform_func(double *xold, double *xnew);
+void deform_func(const BoundBox &bbox, double *xold, double *xnew);
 ErrorCode deform_master(Range &fluid_elems, Range &solid_elems, Tag &xnew);
 ErrorCode smooth_master(int dim, Tag xnew, EntityHandle &master, Range &fluids);
 ErrorCode write_to_coords(Range &elems, Tag tagh);
@@ -193,9 +195,30 @@ ErrorCode DeformMeshRemap::execute()
   rval = read_file(SLAVE, slaveFileName, slaveSet);
+  rval = dc_master.locate_points(tgt_verts); RR("Point location of tgt verts failed.");
+  int num_located = dc_master.spatial_locator()->local_num_located();
+  if (num_located != (int)tgt_verts.size()) {
+    rval = MB_FAILURE;
+    std::cout << "Only " << num_located << " out of " << tgt_verts.size() << " target points successfully located." << std::endl;
+    return rval;
-  if (debug) write_and_save(solidElems[MASTER], masterSet, xNew, "deformed.vtk");
@@ -207,22 +230,6 @@ ErrorCode DeformMeshRemap::execute()
-    // locate slave vertices in master, orig coords; do this with a data coupler, so you can
-    // later interpolate
-  Range src_elems = solidElems[MASTER];
-  src_elems.merge(fluidElems[MASTER]);
-    // initialize data coupler on source elements
-  DataCoupler dc_master(mbImpl, NULL, src_elems, 0);
-  Range tgt_verts, tmp_range = solidElems[SLAVE];
-  tmp_range.merge(fluidElems[SLAVE]);
-  rval = mbImpl->get_adjacencies(tmp_range, 0, false, tgt_verts, Interface::UNION);
-  RR("Failed to get target verts.");
-    // locate slave vertices, caching results in dc
-  rval = dc_master.locate_points(tgt_verts, 0.0, 1e-10); RR("Point location of tgt verts failed.");
@@ -317,9 +324,10 @@ ErrorCode DeformMeshRemap::write_to_coords(Range &elems, Tag tagh)
   return MB_SUCCESS;
-  const double RODWIDTH = 0.2, RODHEIGHT = 0.5;
+/*  Deformation function based on max delx and dely at top of rod
+    const double RODWIDTH = 0.2, RODHEIGHT = 0.5;
     // function: origin is at middle base of rod, and is .5 high
     // top of rod is (0,.55) on left and (.2,.6) on right
   double delx = 0.5*RODWIDTH;
@@ -327,6 +335,13 @@ void deform_func(double *xold, double *xnew)
   double xfrac = (xold[0] + .5*RODWIDTH)/RODWIDTH, yfrac = xold[1]/RODHEIGHT;
   xnew[0] = xold[0] + yfrac * delx;
+/* Deformation function based on fraction of bounding box dimension in each direction */
+  double frac = 0.01; // taken from approximate relative deformation from LLNL Diablo of XX09 assys
+  CartVect *xo = reinterpret_cast<CartVect*>(xold), *xn = reinterpret_cast<CartVect*>(xnew);
+  CartVect disp = frac * (*xo - bbox.bMin);
+  *xn = *xo + disp;
@@ -346,6 +361,10 @@ ErrorCode DeformMeshRemap::deform_master(Range &fluid_elems, Range &solid_elems,
   RR("Failed to get vertex coords.");
   rval = mbImpl->tag_set_data(xNew, verts, &coords[0]);
   RR("Failed to set xnew tag on fluid verts.");
+    // get the bounding box of the solid mesh
+  BoundBox bbox;
+  bbox.update(*mbImpl, solid_elems);
     // get all the vertices and coords in the solid
   verts.clear();
@@ -356,7 +375,7 @@ ErrorCode DeformMeshRemap::deform_master(Range &fluid_elems, Range &solid_elems,
   unsigned int num_verts = verts.size();
   for (unsigned int i = 0; i < num_verts; i++)
-    deform_func(&coords[3*i], &coords[3*i]);
+    deform_func(bbox, &coords[3*i], &coords[3*i]);
     // set the new tag to those coords
diff --git a/src/AdaptiveKDTree.cpp b/src/AdaptiveKDTree.cpp
index f66acbc..1324c30 100644
--- a/src/AdaptiveKDTree.cpp
+++ b/src/AdaptiveKDTree.cpp
@@ -1303,7 +1303,8 @@ namespace moab {
     ErrorCode AdaptiveKDTree::point_search(const double *point,
                                            EntityHandle& leaf_out,
-                                           double tol,
+                                           const double iter_tol,
+                                           const double inside_tol,
                                            bool *multiple_leaves,
                                            EntityHandle *start_node,
                                            CartVect *params)
@@ -1322,7 +1323,7 @@ namespace moab {
       treeStats.nodesVisited++;
       ErrorCode rval = get_bounding_box(box, &node);
-      if (!box.contains_point(point, tol)) return MB_SUCCESS;
+      if (!box.contains_point(point, iter_tol)) return MB_SUCCESS;
       rval = moab()->get_child_meshsets( node, children );
@@ -1346,7 +1347,7 @@ namespace moab {
       treeStats.leavesVisited++;
       if (myEval && params) {
-        rval = myEval->find_containing_entity(node, point, tol,
+        rval = myEval->find_containing_entity(node, point, iter_tol, inside_tol,
                                               leaf_out, params->array(), &treeStats.leafObjectTests);
@@ -1358,7 +1359,8 @@ namespace moab {
                                            AdaptiveKDTreeIter& leaf_it,
-                                           double tol,
+                                           const double /*inside_tol*/,
                                            EntityHandle *start_node)
@@ -1372,7 +1374,7 @@ namespace moab {
       leaf_it.mBox[1] = boundBox.bMax;
         // test that point is inside tree
-      if (!boundBox.contains_point(point, tol)) {
+      if (!boundBox.contains_point(point, iter_tol)) {
         return MB_ENTITY_NOT_FOUND;
@@ -1423,7 +1425,8 @@ namespace moab {
     ErrorCode AdaptiveKDTree::distance_search(const double from_point[3],
                                               const double distance,
                                               std::vector<EntityHandle>& result_list,
-                                              double tol,
                                               std::vector<double> *result_dists,
                                               std::vector<CartVect> *result_params,
                                               EntityHandle *tree_root)
@@ -1445,7 +1448,7 @@ namespace moab {
         // (zero if inside box)
       BoundBox box;
       rval = get_bounding_box(box);
-      if (MB_SUCCESS == rval && !box.contains_point(from_point, tol)) {
+      if (MB_SUCCESS == rval && !box.contains_point(from_point, iter_tol)) {
         return MB_SUCCESS;
@@ -1484,7 +1487,7 @@ namespace moab {
           if (myEval && result_params) {
             EntityHandle ent;
             CartVect params;
-            rval = myEval->find_containing_entity(node.handle, from_point, tol,
+            rval = myEval->find_containing_entity(node.handle, from_point, iter_tol, inside_tol,
                                                   ent, params.array(), &treeStats.leafObjectTests);
             else if (ent) {
@@ -1802,7 +1805,7 @@ namespace moab {
         // the same distance from the input point as the current closest
         // point is.
       CartVect diff = closest_pt - from;
-      rval = distance_search(from_coords, sqrt(diff%diff), leaves, 0.0, NULL, NULL, &tree_root);
+      rval = distance_search(from_coords, sqrt(diff%diff), leaves, 1.0e-10, 1.0e-6, NULL, NULL, &tree_root);
         // Check any close leaves to see if they contain triangles that
@@ -1834,7 +1837,7 @@ namespace moab {
         // get leaves of tree that intersect sphere
       assert(tree_root);
-      rval = distance_search(center, radius, leaves, 0.0, NULL, NULL, &tree_root);
+      rval = distance_search(center, radius, leaves, 1.0e-10, 1.0e-6, NULL, NULL, &tree_root);
         // search each leaf for triangles intersecting sphere
diff --git a/src/BVHTree.cpp b/src/BVHTree.cpp
index 8903070..b65eae4 100644
--- a/src/BVHTree.cpp
+++ b/src/BVHTree.cpp
@@ -435,7 +435,8 @@ namespace moab
     ErrorCode BVHTree::find_point(const std::vector<double> &point,
                                   const unsigned int &index,
-                                  const double tol,
                                   std::pair<EntityHandle, CartVect> &result)
       if (index == 0) treeStats.numTraversals++;
@@ -453,7 +454,7 @@ namespace moab
         for(Range::iterator i = entities.begin(); i != entities.end(); i++) {
           treeStats.leafObjectTests++;
           myEval->set_ent_handle(*i);
-          myEval->reverse_eval(&point[0], tol, params.array(), &is_inside);
+          myEval->reverse_eval(&point[0], iter_tol, inside_tol, params.array(), &is_inside);
           if (is_inside) {
             result.first = *i;
             result.second = params;
@@ -469,11 +470,11 @@ namespace moab
       rval = mbImpl->get_child_meshsets(startSetHandle+index, children);
       if (MB_SUCCESS != rval || children.size() != 2) return rval;
-      if((node.Lmax+tol) < (node.Rmin-tol)){
-        if(point[node.dim] <= (node.Lmax + tol))
-          return find_point(point, children[0]-startSetHandle, tol, result);
-        else if(point[ node.dim] >= (node.Rmin - tol))
-          return find_point(point, children[1]-startSetHandle, tol, result);
+      if((node.Lmax+iter_tol) < (node.Rmin-iter_tol)){
+        if(point[node.dim] <= (node.Lmax + iter_tol))
+          return find_point(point, children[0]-startSetHandle, iter_tol, inside_tol, result);
+        else if(point[ node.dim] >= (node.Rmin - iter_tol))
+          return find_point(point, children[1]-startSetHandle, iter_tol, inside_tol, result);
         result = std::make_pair(0, CartVect(&point[0])); //point lies in empty space.
         return MB_SUCCESS;
@@ -482,11 +483,11 @@ namespace moab
         //left of Rmin, you must be on the left
         //we can't be sure about the boundaries since the boxes overlap
         //this was a typo in the paper which caused pain.
-      if(point[node.dim] < (node.Rmin - tol))
+      if(point[node.dim] < (node.Rmin - iter_tol))
         //if you are on the right Lmax, you must be on the right
-      else if(point[ node.dim] > (node.Lmax+tol))
+      else if(point[ node.dim] > (node.Lmax+iter_tol))
         /* pg5 of paper
          * However, instead of always traversing either subtree
@@ -501,22 +502,22 @@ namespace moab
         //branch predicted..
         //bool dir = (point[ node.dim] - node.Rmin) <=
         //				(node.Lmax - point[ node.dim]);
-      find_point(point, children[0]-startSetHandle, tol, result);
+      find_point(point, children[0]-startSetHandle, iter_tol, inside_tol, result);
       if(result.first == 0){
       return MB_SUCCESS;
-    EntityHandle BVHTree::bruteforce_find(const double *point, const double tol) {
+    EntityHandle BVHTree::bruteforce_find(const double *point, const double iter_tol, const double inside_tol) {
       CartVect params;
       for(unsigned int i = 0; i < myTree.size(); i++) {
-        if(myTree[i].dim != 3 || !myTree[i].box.contains_point(point, tol)) continue;
+        if(myTree[i].dim != 3 || !myTree[i].box.contains_point(point, iter_tol)) continue;
         if (myEval) {
           EntityHandle entity = 0;
-          ErrorCode rval = myEval->find_containing_entity(startSetHandle+i, point, tol,
+          ErrorCode rval = myEval->find_containing_entity(startSetHandle+i, point, iter_tol, inside_tol,
                                                           entity, params.array(), &treeStats.leafObjectTests);
           if (entity) return entity;
           else if (MB_SUCCESS != rval) return 0;
@@ -542,7 +543,8 @@ namespace moab
     ErrorCode BVHTree::point_search(const double *point,
-                                    double tol,
                                     CartVect *params)
@@ -572,7 +574,7 @@ namespace moab
           // test box of this node
         ErrorCode rval = get_bounding_box(box, &this_set);
-        if (!box.contains_point(point, tol)) continue;
+        if (!box.contains_point(point, iter_tol)) continue;
           // else if not a leaf, test children & put on list
         else if (myTree[ind].dim != 3) {
@@ -581,7 +583,7 @@ namespace moab
           continue;
         else if (myTree[ind].dim == 3 && myEval && params) {
-          rval = myEval->find_containing_entity(startSetHandle+ind, point, tol,
+          rval = myEval->find_containing_entity(startSetHandle+ind, point, iter_tol, inside_tol,
           if (leaf_out || MB_SUCCESS != rval) return rval;
@@ -599,7 +601,8 @@ namespace moab
     ErrorCode BVHTree::distance_search(const double from_point[3],
-                                       double params_tol,
@@ -653,7 +656,7 @@ namespace moab
           EntityHandle ent;
           CartVect params;
-          rval = myEval->find_containing_entity(startSetHandle+ind, from_point, params_tol,
+          rval = myEval->find_containing_entity(startSetHandle+ind, from_point, iter_tol, inside_tol,
           else if (ent) {
index 4446281..4ca3943 100644
@@ -6,6 +6,7 @@
 // need to include eval set types here to support get_eval_set; alternative would be to have some
 // type of registration, but we'd still need static registration for the built-in types
+#include "moab/LinearTri.hpp"
@@ -16,12 +17,12 @@
 namespace moab {
     ErrorCode EvalSet::evaluate_reverse(EvalFcn eval, JacobianFcn jacob, InsideFcn inside_f,
                                         const double *posn, const double *verts, const int nverts,
-                                        const int ndim, const double tol, double *work,
-                                        double *params, bool *inside) {
+                                        const int ndim, const double iter_tol, const double inside_tol,
+                                        double *work, double *params, bool *inside) {
         // TODO: should differentiate between epsilons used for
         // Newton Raphson iteration, and epsilons used for curved boundary geometry errors
         // right now, fix the tolerance used for NR
-      const double error_tol_sqr = tol*tol;
+      const double error_tol_sqr = iter_tol*iter_tol;
       CartVect *cvparams = reinterpret_cast<CartVect*>(params);
       const CartVect *cvposn = reinterpret_cast<const CartVect*>(posn);
@@ -38,23 +39,26 @@ namespace moab {
       CartVect res = new_pos - *cvposn;
       Matrix3 J;
+      bool dum, *tmp_inside = (inside ? inside : &dum);
       int iters=0;
         // while |res| larger than tol
       while (res % res > error_tol_sqr) {
         if(++iters>10) {
-          if (inside) {
-              // if we haven't converged but we're outside, that's defined as success
-            *inside = (*inside_f)(params, ndim, tol);
-            if (!(*inside)) return MB_SUCCESS;
-          return MB_FAILURE;
+            // if we haven't converged but we're outside, that's defined as success
+          *tmp_inside = (*inside_f)(params, ndim, inside_tol);
+          if (!(*tmp_inside)) return MB_SUCCESS;
+          else return MB_FAILURE;
           // get jacobian at current params
         rval = (*jacob)(cvparams->array(), verts, nverts, ndim, work, J[0]);
         double det = J.determinant();
-        assert(det > std::numeric_limits<double>::epsilon());
+        if (det < std::numeric_limits<double>::epsilon()) {
           // new params tries to eliminate residual
@@ -68,7 +72,7 @@ namespace moab {
       if (inside)
+        *inside = (*inside_f)(params, ndim, inside_tol);
       return MB_SUCCESS;
     }// Map::evaluate_reverse()
@@ -89,6 +93,7 @@ namespace moab {
         case MBEDGE:
             break;
         case MBTRI:
+            if (LinearTri::compatible(tp, num_vertices, eval_set)) return MB_SUCCESS;
             break;
         case MBQUAD:
             if (LinearQuad::compatible(tp, num_vertices, eval_set)) return MB_SUCCESS;
@@ -109,9 +114,9 @@ namespace moab {
       return MB_NOT_IMPLEMENTED;
-    ErrorCode ElemEvaluator::find_containing_entity(Range &entities, const double *point, double tol,
-                                                    EntityHandle &containing_ent, double *params,
-                                                    unsigned int *num_evals)
+    ErrorCode ElemEvaluator::find_containing_entity(Range &entities, const double *point, const double iter_tol,
+                                                    const double inside_tol, EntityHandle &containing_ent,
+                                                    double *params, unsigned int *num_evals)
       bool is_inside;
@@ -120,7 +125,7 @@ namespace moab {
       for(i = entities.begin(); i != entities.end(); i++) {
         nevals++;
         set_ent_handle(*i);
-        rval = reverse_eval(point, tol, params, &is_inside);
+        rval = reverse_eval(point, iter_tol, inside_tol, params, &is_inside);
         if (is_inside) break;
diff --git a/src/LocalDiscretization/LinearHex.cpp b/src/LocalDiscretization/LinearHex.cpp
index 14de2d9..5e730af 100644
--- a/src/LocalDiscretization/LinearHex.cpp
+++ b/src/LocalDiscretization/LinearHex.cpp
@@ -96,10 +96,12 @@ namespace moab
     ErrorCode LinearHex::reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
                                         const double *posn, const double *verts, const int nverts, const int ndim,
-                                        const double tol, double *work, double *params, bool *is_inside)
+                                        const double iter_tol, const double inside_tol, double *work,
+                                        double *params, bool *is_inside)
       assert(posn && verts);
-      return EvalSet::evaluate_reverse(eval, jacob, ins, posn, verts, nverts, ndim, tol, work, params, is_inside);
+      return EvalSet::evaluate_reverse(eval, jacob, ins, posn, verts, nverts, ndim, iter_tol, inside_tol, work,
+                                       params, is_inside);
     bool LinearHex::insideFcn(const double *params, const int ndim, const double tol)
index 93237f9..63c9959 100644
@@ -75,9 +75,11 @@ namespace moab
     ErrorCode LinearQuad::reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
     bool LinearQuad::insideFcn(const double *params, const int ndim, const double tol)
diff --git a/src/LocalDiscretization/LinearTet.cpp b/src/LocalDiscretization/LinearTet.cpp
index 705dbee..4965cfc 100644
--- a/src/LocalDiscretization/LinearTet.cpp
+++ b/src/LocalDiscretization/LinearTet.cpp
@@ -74,27 +74,29 @@ namespace moab
     ErrorCode LinearTet::reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
-      return evaluate_reverse(eval, jacob, ins, posn, verts, nverts, ndim, tol, work, params, is_inside);
+      return evaluate_reverse(eval, jacob, ins, posn, verts, nverts, ndim, iter_tol, inside_tol,
+                              work, params, is_inside);
     bool LinearTet::insideFcn(const double *params, const int , const double tol)
       return (params[0] >= -1.0-tol && params[1] >= -1.0-tol && params[2] >= -1.0-tol &&
-              params[0] + params[1] + params[2] <= -1.0+tol);
+              params[0] + params[1] + params[2] <= 1.0+tol);
     ErrorCode LinearTet::evaluate_reverse(EvalFcn eval, JacobianFcn jacob, InsideFcn inside_f,
@@ -138,7 +140,7 @@ namespace moab
       if (inside)
       return MB_SUCCESS;
diff --git a/src/LocalDiscretization/LinearTri.cpp b/src/LocalDiscretization/LinearTri.cpp
index 0000000..8fe9d23
--- /dev/null
+++ b/src/LocalDiscretization/LinearTri.cpp
@@ -0,0 +1,145 @@
+#include "moab/Forward.hpp"
+namespace moab
+    const double LinearTri::corner[3][2] = { {0,0},
+                                             {1,0},
+                                             {0,1}};
+    ErrorCode LinearTri::initFcn(const double *verts, const int /*nverts*/, double *&work) {
+        // allocate work array as:
+        // work[0..8] = T
+        // work[9..17] = Tinv
+        // work[18] = detT
+        // work[19] = detTinv
+      assert(!work && verts);
+      work = new double[20];
+      Matrix3 *T = reinterpret_cast<Matrix3*>(work),
+          *Tinv = reinterpret_cast<Matrix3*>(work+9);
+      double *detT = work+18, *detTinv = work+19;
+      *T = Matrix3(verts[1*3+0]-verts[0*3+0],verts[2*3+0]-verts[0*3+0],0.0,
+                   verts[1*3+1]-verts[0*3+1],verts[2*3+1]-verts[0*3+1],0.0,
+                   verts[1*3+2]-verts[0*3+2],verts[2*3+2]-verts[0*3+2],1.0);
+      *T *= 0.5;
+      (*T)(2,2) = 1.0;
+      *Tinv = T->inverse();
+      *detT = T->determinant();
+      *detTinv = (0.0 == *detT ? HUGE : 1.0 / *detT);
+    ErrorCode LinearTri::evalFcn(const double *params, const double *field, const int /*ndim*/, const int num_tuples,
+                                 double */*work*/, double *result) {
+      assert(params && field && num_tuples > 0);
+        // convert to [0,1]
+      double p1 = 0.5 * (1.0 + params[0]),
+          p2 = 0.5 * (1.0 + params[1]),
+          p0 = 1.0 - p1 - p2;
+      for (int j = 0; j < num_tuples; j++)
+        result[j] = p0 * field[0*num_tuples+j] + p1 * field[1*num_tuples+j] + p2 * field[2*num_tuples+j];
+    ErrorCode LinearTri::integrateFcn(const double *field, const double */*verts*/, const int /*nverts*/, const int /*ndim*/, const int num_tuples,
+                                      double *work, double *result)
+      assert(field && num_tuples > 0);
+      double tmp = work[18];
+      for (int i = 0; i < num_tuples; i++)
+        result[i] = tmp * (field[num_tuples+i] + field[2*num_tuples+i]);
+    ErrorCode LinearTri::jacobianFcn(const double *, const double *, const int, const int ,
+        // jacobian is cached in work array
+      assert(work);
+      std::copy(work, work+9, result);
+    ErrorCode LinearTri::reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
+                                        const double *posn, const double *verts, const int nverts, const int ndim,
+      assert(posn && verts);
+      return evaluate_reverse(eval, jacob, ins, posn, verts, nverts, ndim, iter_tol, inside_tol, work,
+    bool LinearTri::insideFcn(const double *params, const int , const double tol)
+      return (params[0] >= -1.0-tol && params[1] >= -1.0-tol &&
+              params[0] + params[1] <= 1.0+tol);
+    ErrorCode LinearTri::evaluate_reverse(EvalFcn eval, JacobianFcn jacob, InsideFcn inside_f,
+        // TODO: should differentiate between epsilons used for
+        // Newton Raphson iteration, and epsilons used for curved boundary geometry errors
+        // right now, fix the tolerance used for NR
+      CartVect *cvparams = reinterpret_cast<CartVect*>(params);
+      const CartVect *cvposn = reinterpret_cast<const CartVect*>(posn);
+        // find best initial guess to improve convergence
+      CartVect tmp_params[] = {CartVect(-1,-1,-1), CartVect(1,-1,-1), CartVect(-1,1,-1)};
+      double resl = HUGE;
+      CartVect new_pos, tmp_pos;
+      ErrorCode rval;
+      for (unsigned int i = 0; i < 3; i++) {
+        rval = (*eval)(tmp_params[i].array(), verts, ndim, 3, work, tmp_pos.array());
+        double tmp_resl = (tmp_pos-*cvposn).length_squared();
+        if (tmp_resl < resl) {
+          *cvparams = tmp_params[i];
+          new_pos = tmp_pos;
+          resl = tmp_resl;
+        // residual is diff between old and new pos; need to minimize that
+      CartVect res = new_pos - *cvposn;
+      Matrix3 J;
+      rval = (*jacob)(cvparams->array(), verts, nverts, ndim, work, J[0]);
+      double det = J.determinant();
+      assert(det > std::numeric_limits<double>::epsilon());
+      Matrix3 Ji = J.inverse(1.0/det);
+      int iters=0;
+        // while |res| larger than tol
+      while (res % res > error_tol_sqr) {
+        if(++iters>25)
+          // new params tries to eliminate residual
+        *cvparams -= Ji * res;
+          // get the new forward-evaluated position, and its difference from the target pt
+        rval = (*eval)(params, verts, ndim, 3, work, new_pos.array());
+        res = new_pos - *cvposn;
+      if (inside)
+    }// Map::evaluate_reverse()
diff --git a/src/LocalDiscretization/Makefile.am b/src/LocalDiscretization/Makefile.am
index 7309aef..cb34071 100644
--- a/src/LocalDiscretization/Makefile.am
+++ b/src/LocalDiscretization/Makefile.am
@@ -17,6 +17,7 @@ MOAB_LOCALDISCR_SRCS = \
 	LinearHex.cpp \
 	LinearQuad.cpp \
 	LinearTet.cpp \
+	LinearTri.cpp \
 	QuadraticHex.cpp
 MOAB_LOCALDISCR_HDRS = \
@@ -24,6 +25,7 @@ MOAB_LOCALDISCR_HDRS = \
 	moab/LinearHex.hpp \
 	moab/LinearQuad.hpp \
 	moab/LinearTet.hpp \
+	moab/LinearTri.hpp \
 # The list of source files, and any header files that do not need to be installed
diff --git a/src/LocalDiscretization/QuadraticHex.cpp b/src/LocalDiscretization/QuadraticHex.cpp
index ca4758b..5c621f6 100644
--- a/src/LocalDiscretization/QuadraticHex.cpp
+++ b/src/LocalDiscretization/QuadraticHex.cpp
@@ -107,10 +107,12 @@ namespace moab
     ErrorCode QuadraticHex::reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
     bool QuadraticHex::insideFcn(const double *params, const int ndim, const double tol)
diff --git a/src/LocalDiscretization/SpectralHex.cpp b/src/LocalDiscretization/SpectralHex.cpp
index 0e40eba..31f5391 100644
--- a/src/LocalDiscretization/SpectralHex.cpp
+++ b/src/LocalDiscretization/SpectralHex.cpp
@@ -73,7 +73,8 @@ CartVect SpectralHex::evaluate( const CartVect& params ) const
   return result;
   // replicate the functionality of hex_findpt
-bool SpectralHex::evaluate_reverse(CartVect const & xyz, CartVect &params, double tol, const CartVect &init) const
+    bool SpectralHex::evaluate_reverse(CartVect const & xyz, CartVect &params, double iter_tol, const double inside_tol,
+                                       const CartVect &init) const
   params = init;
@@ -92,7 +93,7 @@ bool SpectralHex::evaluate_reverse(CartVect const & xyz, CartVect &params, doubl
     //copy parametric coords back
   params = r;
-  return is_inside(params, tol);
+  return is_inside(params, inside_tol);
 Matrix3  SpectralHex::jacobian(const CartVect& params) const
diff --git a/src/LocalDiscretization/SpectralQuad.cpp b/src/LocalDiscretization/SpectralQuad.cpp
index cbd1251..5c11d13 100644
--- a/src/LocalDiscretization/SpectralQuad.cpp
+++ b/src/LocalDiscretization/SpectralQuad.cpp
@@ -95,7 +95,8 @@ CartVect SpectralQuad::evalFcn(const double *params, const double *field, const
 bool SpectralQuad::reverseEvalFcn(const double *posn, const double *verts, const int nverts, const int ndim,
   params = init;
@@ -114,7 +115,7 @@ bool SpectralQuad::reverseEvalFcn(const double *posn, const double *verts, const
   params = r;
-  return insideFcn(params, 2, tol);
+  return insideFcn(params, 2, inside_tol);
index eac008d..29d1051 100644
@@ -25,7 +25,8 @@ namespace moab {
     typedef ErrorCode (*ReverseEvalFcn)(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
-                                        const double tol, double *work, double *params, bool *is_inside);
+                                        double *work, double *params, bool *is_inside);
     class EvalSet
@@ -76,8 +77,8 @@ namespace moab {
         /** \brief Common function to do reverse evaluation based on evaluation and jacobian functions */
       static ErrorCode evaluate_reverse(EvalFcn eval, JacobianFcn jacob, InsideFcn inside_f,
-                                        const int ndim, const double tol, double *work, double *params,
-                                        bool *inside);
+                                        double *work, double *params, bool *inside);
         /** \brief Common function that returns true if params is in [-1,1]^ndims */
       static bool inside_function(const double *params, const int ndims, const double tol);
@@ -133,12 +134,14 @@ namespace moab {
         /** \brief Reverse-evaluate the cached entity at a given physical position
          * \param posn Position at which to evaluate parameters
-         * \param tol Tolerance of reverse evaluation, usually 10^-6 or so
+         * \param iter_tol Tolerance of reverse evaluation non-linear iteration, usually 10^-10 or so
+         * \param inside_tol Tolerance of is_inside evaluation, usually 10^-6 or so
          * \param params Result of evaluation
          * \param is_inside If non-NULL, returns true of resulting parameters place the point inside the element
          *                  (in most cases, within [-1]*(dim)
-      ErrorCode reverse_eval(const double *posn, double tol, double *params, bool *is_inside = NULL) const;
+      ErrorCode reverse_eval(const double *posn, double iter_tol, double inside_tol, double *params,
+                             bool *is_inside = NULL) const;
          * \param params Parameters at which to evaluate jacobian
@@ -166,14 +169,16 @@ namespace moab {
          * object is changed.
          * \param entities Entities tested
          * \param point Point tested, must have 3 dimensions, even for edge and face entities
-         * \param tol Tolerance for is_inside test
+         * \param iter_tol Tolerance for non-linear reverse evaluation
+         * \param inside_tol Tolerance for is_inside test
          * \param containing_ent Entity containing the point, returned 0 if no entity
          * \param params Parameters of point in containing entity, unchanged if no containing entity
          * \param num_evals If non-NULL, incremented each time reverse_eval is called
          * \return Returns non-success only if evaulation failed for some reason (point not in element is NOT a
          * reason for failure)
-      ErrorCode find_containing_entity(Range &entities, const double *point, double tol,
+      ErrorCode find_containing_entity(Range &entities, const double *point,
                                        unsigned int *num_evals = NULL);
@@ -186,14 +191,16 @@ namespace moab {
          * \param ent_set Entity set containing the entities to be tested
-      ErrorCode find_containing_entity(EntityHandle ent_set, const double *point, double tol,
+      ErrorCode find_containing_entity(EntityHandle ent_set, const double *point,
@@ -218,8 +225,12 @@ namespace moab {
       inline ErrorCode set_ent_handle(EntityHandle ent);
         /** \brief Get entity handle for this ElemEval */
-      inline EntityHandle get_ent_handle() const {return entHandle;};
+      inline EntityHandle get_ent_handle() const {return entHandle;}
+        /* \brief Get vertex positions cached on this EE
+      inline double *get_vert_pos() {return vertPos[0].array();}
         /* \brief Get the vertex handles cached here */
       inline const EntityHandle *get_vert_handles() const {return vertHandles;}
@@ -251,6 +262,11 @@ namespace moab {
+        /* \brief Get work space, sometimes this is useful for evaluating data you don't want to set as tags on entities
+         * Can't be const because most of the functions (evaluate, integrate, etc.) take non-const work space *'s
+      inline double *get_work_space() {return workSpace;}
@@ -434,12 +450,13 @@ namespace moab {
-    inline ErrorCode ElemEvaluator::reverse_eval(const double *posn, const double tol, double *params, bool *ins) const
+    inline ErrorCode ElemEvaluator::reverse_eval(const double *posn, const double iter_tol, const double inside_tol,
+                                                 double *params, bool *ins) const
-                                                 entDim, tol, workSpace, params, ins);
+                                                 entDim, iter_tol, inside_tol, workSpace, params, ins);
@@ -464,7 +481,8 @@ namespace moab {
                                                workSpace, result);
-    inline ErrorCode ElemEvaluator::find_containing_entity(EntityHandle ent_set, const double *point, double tol,
+    inline ErrorCode ElemEvaluator::find_containing_entity(EntityHandle ent_set, const double *point,
@@ -472,7 +490,7 @@ namespace moab {
       Range entities;
       ErrorCode rval = mbImpl->get_entities_by_handle(ent_set, entities);
-      else return find_containing_entity(entities, point, tol, containing_ent, params, num_evals);
+      else return find_containing_entity(entities, point, iter_tol, inside_tol, containing_ent, params, num_evals);
     inline bool ElemEvaluator::inside(const double *params, const double tol) const
diff --git a/src/LocalDiscretization/moab/LinearHex.hpp b/src/LocalDiscretization/moab/LinearHex.hpp
index e7ca3f4..03ed33f 100644
--- a/src/LocalDiscretization/moab/LinearHex.hpp
+++ b/src/LocalDiscretization/moab/LinearHex.hpp
@@ -17,7 +17,8 @@ public:
     /** \brief Reverse-evaluation of parametric coordinates at physical space position */
   static ErrorCode reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
+                                  double *params, bool *is_inside);
     /** \brief Evaluate the jacobian at a specified parametric position */
   static ErrorCode jacobianFcn(const double *params, const double *verts, const int nverts, const int ndim,
diff --git a/src/LocalDiscretization/moab/LinearQuad.hpp b/src/LocalDiscretization/moab/LinearQuad.hpp
index 26882a1..2eb3027 100644
--- a/src/LocalDiscretization/moab/LinearQuad.hpp
+++ b/src/LocalDiscretization/moab/LinearQuad.hpp
diff --git a/src/LocalDiscretization/moab/LinearTet.hpp b/src/LocalDiscretization/moab/LinearTet.hpp
index 464b1f6..f621b2f 100644
--- a/src/LocalDiscretization/moab/LinearTet.hpp
+++ b/src/LocalDiscretization/moab/LinearTet.hpp
@@ -35,7 +36,7 @@ public:
+                                    const int ndim, const double iter_tol, const double inside_tol, double *work,
   static EvalSet eval_set()
@@ -45,7 +46,7 @@ public:
   static bool compatible(EntityType tp, int numv, EvalSet &eset)
-        if (tp == MBTET && numv == 4) {
+        if (tp == MBTET && numv >= 4) {
           eset = eval_set();
           return true;
diff --git a/src/LocalDiscretization/moab/LinearTri.hpp b/src/LocalDiscretization/moab/LinearTri.hpp
index 0000000..93820a7
--- /dev/null
+++ b/src/LocalDiscretization/moab/LinearTri.hpp
@@ -0,0 +1,63 @@
+#ifndef LINEAR_TRI_HPP
+#define LINEAR_TRI_HPP
+  /**\brief Shape function space for trilinear tetrahedron, obtained by a pushforward of the canonical linear (affine) functions. */
+namespace moab
+class LinearTri
+public:
+    /** \brief Forward-evaluation of field at parametric coordinates */
+  static ErrorCode evalFcn(const double *params, const double *field, const int ndim, const int num_tuples,
+                           double *work, double *result);
+    /** \brief Reverse-evaluation of parametric coordinates at physical space position */
+  static ErrorCode reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
+    /** \brief Evaluate the jacobian at a specified parametric position */
+  static ErrorCode jacobianFcn(const double *params, const double *verts, const int nverts, const int ndim,
+  static ErrorCode integrateFcn(const double *field, const double *verts, const int nverts, const int ndim, const int num_tuples,
+    /** \brief Initialize this EvalSet */
+  static ErrorCode initFcn(const double *verts, const int nverts, double *&work);
+        /** \brief Function that returns whether or not the parameters are inside the natural space of the element */
+  static bool insideFcn(const double *params, const int ndim, const double tol);
+  static ErrorCode evaluate_reverse(EvalFcn eval, JacobianFcn jacob, InsideFcn inside_f,
+                                    double *params, bool *inside);
+  static EvalSet eval_set()
+        return EvalSet(evalFcn, reverseEvalFcn, jacobianFcn, integrateFcn, initFcn, insideFcn);
+  static bool compatible(EntityType tp, int numv, EvalSet &eset)
+        if (tp == MBTRI && numv >= 3) {
+          eset = eval_set();
+          return true;
+        else return false;
+protected:
+  static const double corner[3][2];
+};// class LinearTri
+#endif
diff --git a/src/LocalDiscretization/moab/QuadraticHex.hpp b/src/LocalDiscretization/moab/QuadraticHex.hpp
index 0801ad7..0e5cfb8 100644
--- a/src/LocalDiscretization/moab/QuadraticHex.hpp
+++ b/src/LocalDiscretization/moab/QuadraticHex.hpp
diff --git a/src/LocalDiscretization/moab/SpectralHex.hpp b/src/LocalDiscretization/moab/SpectralHex.hpp
index e6464c3..648cc70 100644
--- a/src/LocalDiscretization/moab/SpectralHex.hpp
+++ b/src/LocalDiscretization/moab/SpectralHex.hpp
@@ -19,7 +19,8 @@ public:
diff --git a/src/LocalDiscretization/moab/SpectralQuad.hpp b/src/LocalDiscretization/moab/SpectralQuad.hpp
index 8716a43..a72f9b4 100644
--- a/src/LocalDiscretization/moab/SpectralQuad.hpp
+++ b/src/LocalDiscretization/moab/SpectralQuad.hpp
diff --git a/src/MergeMesh.cpp b/src/MergeMesh.cpp
index 4cc8158..72c4f66 100644
--- a/src/MergeMesh.cpp
+++ b/src/MergeMesh.cpp
@@ -171,7 +171,7 @@ moab::ErrorCode MergeMesh::find_merged_to(moab::EntityHandle &tree_root,
       // check close-by leaves too
       leaves_out.clear();
       result = tree.distance_search(from.array(), mergeTol,
-                                    leaves_out, 0.0, NULL, NULL, &tree_root);
+                                    leaves_out, mergeTol, 1.0e-6, NULL, NULL, &tree_root);
       leaf_range2.clear();
       for (std::vector<moab::EntityHandle>::iterator vit = leaves_out.begin();
            vit != leaves_out.end(); vit++) {
index d3b521e..f765ab9 100644
@@ -3,6 +3,8 @@
 #include "moab/AdaptiveKDTree.hpp"
+bool debug = true;
 namespace moab
@@ -33,41 +35,47 @@ namespace moab
 #ifdef USE_MPI
-                                                double /*rel_tol*/, double /*abs_tol*/)
+                                                const double /*rel_iter_tol*/, const double /*abs_iter_tol*/,
+                                                const double /*inside_tol*/)
 #endif
-                                            double rel_eps, double abs_eps)
+                                            const double rel_iter_tol, const double abs_iter_tol,
+                                            const double inside_tol)
-      rval = locate_points(&pos[0], verts.size(), rel_eps, abs_eps);
+      rval = locate_points(&pos[0], verts.size(), rel_iter_tol, abs_iter_tol, inside_tol);
       return MB_SUCCESS;
-      ErrorCode rval = locate_points(pos, num_points, locTable.vul_wr, locTable.vr_wr, NULL, rel_eps, abs_eps);
+      ErrorCode rval = locate_points(pos, num_points, locTable.vul_wr, locTable.vr_wr, NULL, rel_iter_tol, abs_iter_tol,
+                                     inside_tol);
+      locTable.set_n(num_points);
       return MB_SUCCESS;
@@ -75,25 +83,27 @@ namespace moab
-      return locate_points(&pos[0], verts.size(), ents, params, is_inside, rel_eps, abs_eps);
+      return locate_points(&pos[0], verts.size(), ents, params, is_inside, rel_iter_tol, abs_iter_tol, inside_tol);
-      if (rel_eps && !abs_eps) {
+      double tmp_abs_iter_tol = abs_iter_tol;
+      if (rel_iter_tol && !tmp_abs_iter_tol) {
           // relative epsilon given, translate to absolute epsilon using box dimensions
         BoundBox box;
         myTree->get_bounding_box(box);
-        abs_eps = rel_eps * box.diagonal_length();
+        tmp_abs_iter_tol = rel_iter_tol * box.diagonal_length();
       EntityHandle closest_leaf;
@@ -104,8 +114,8 @@ namespace moab
       for (int i = 0; i < num_points; i++) {
         int i3 = 3*i;
         ents[i] = 0;
-        if (abs_eps) {
-          rval = myTree->distance_search(pos+i3, abs_eps, leaves, abs_eps, &dists);
+        if (tmp_abs_iter_tol) {
+          rval = myTree->distance_search(pos+i3, tmp_abs_iter_tol, leaves, tmp_abs_iter_tol, inside_tol, &dists);
           if (!leaves.empty()) {
               // get closest leaf
@@ -145,22 +155,71 @@ namespace moab
           // loop over the range_leaf
         bool tmp_inside;
+        bool *is_ptr = (is_inside ? is_inside+i : &tmp_inside);
+        *is_ptr = false;
+        EntityHandle ent = 0;
         for(Range::iterator rit = range_leaf.begin(); rit != range_leaf.end(); rit++)
-          bool *is_ptr = (is_inside ? is_inside+i : &tmp_inside);
           rval = elemEval->set_ent_handle(*rit);
-          rval = elemEval->reverse_eval(pos+i3, abs_eps, params+i3, is_ptr);
+          rval = elemEval->reverse_eval(pos+i3, tmp_abs_iter_tol, inside_tol, params+i3, is_ptr);
           if (*is_ptr) {
-            ents[i] = *rit;
+            ent = *rit;
             break;
+        if (debug && !ent) {
+          std::cout << "Point " << i << " not found; point: ("
+                    << pos[i3] << "," << pos[i3+1] << "," << pos[i3+2] << ")" << std::endl;
+          std::cout << "Source element candidates: " << std::endl;
+          range_leaf.print("   ");
+          for(Range::iterator rit = range_leaf.begin(); rit != range_leaf.end(); rit++)
+            std::cout << "Candidate " << CN::EntityTypeName(mbImpl->type_from_handle(*rit)) << " " << mbImpl->id_from_handle(*rit) << ": ";
+            rval = elemEval->set_ent_handle(*rit);
+            if (MB_SUCCESS != rval) return rval;
+            std::cout << "Parameters: (" << params[i3] << "," << params[i3+1] << "," << params[i3+2] << ")"
+                      << " inside = " << *is_ptr << std::endl;
+        ents[i] = ent;
       return MB_SUCCESS;
+        /* Count the number of located points in locTable
+         * Return the number of entries in locTable that have non-zero entity handles, which
+         * represents the number of points in targetEnts that were inside one element in sourceEnts
+    int SpatialLocator::local_num_located()
+      int num_located = locTable.get_n() - std::count(locTable.vul_rd, locTable.vul_rd+locTable.get_n(), 0);
+      if (num_located != (int)locTable.get_n()) {
+        unsigned long *nl = std::find(locTable.vul_rd, locTable.vul_rd+locTable.get_n(), 0);
+        if (nl) {
+          int idx = nl - locTable.vul_rd;
+          if (idx) {}
+      return num_located;
+        /* Count the number of located points in parLocTable
+         * Return the number of entries in parLocTable that have a non-negative index in on a remote
+         * proc in parLocTable, which gives the number of points located in at least one element in a
+         * remote proc's sourceEnts.
+    int SpatialLocator::remote_num_located()
+      int located = 0;
+      for (unsigned int i = 0; i < parLocTable.get_n(); i++)
+        if (parLocTable.vi_rd[2*i] != -1) located++;
+      return located;
 } // namespace moab
diff --git a/src/moab/AdaptiveKDTree.hpp b/src/moab/AdaptiveKDTree.hpp
index 4a5ce1b..54d48e5 100644
--- a/src/moab/AdaptiveKDTree.hpp
+++ b/src/moab/AdaptiveKDTree.hpp
@@ -68,7 +68,8 @@ namespace moab {
          * containing the point in that case.
          * \param point Point to be located in tree
          * \param leaf_out Leaf containing point
-         * \param tol Tolerance below which a point is "in"
+         * \param iter_tol Tolerance for convergence of point search
+         * \param inside_tol Tolerance for inside element calculation
          * \param multiple_leaves Some tree types can have multiple leaves containing a point;
          *          if non-NULL, this parameter is returned true if multiple leaves contain
          *          the input point
@@ -77,7 +78,8 @@ namespace moab {
       virtual ErrorCode point_search(const double *point,
-                                     double tol = 0.0,
+                                     const double iter_tol = 1.0e-10,
+                                     const double inside_tol = 1.0e-6,
                                      bool *multiple_leaves = NULL,
                                      EntityHandle *start_node = NULL,
                                      CartVect *params = NULL);
@@ -92,7 +94,8 @@ namespace moab {
          * \param leaf_it Iterator to leaf containing point
          *          the input point
@@ -101,7 +104,8 @@ namespace moab {
-                             double tol = 0.0,
                              EntityHandle *start_node = NULL);
@@ -114,7 +118,8 @@ namespace moab {
          * \param distance Distance within which to query
          * \param leaves_out Leaves within distance or containing point
          * \param dists_out If non-NULL, will contain distsances to leaves
          * \param params_out If non-NULL, will contain parameters of the point in the ents in leaves_out
          * \param start_node Start from this tree node (non-NULL) instead of tree root (NULL)
@@ -122,7 +127,8 @@ namespace moab {
       virtual ErrorCode distance_search(const double *point,
                                         std::vector<EntityHandle>& leaves_out,
-                                        double tol = 0.0,
                                         std::vector<double> *dists_out = NULL,
                                         std::vector<CartVect> *params_out = NULL,
diff --git a/src/moab/BVHTree.hpp b/src/moab/BVHTree.hpp
index 7f0c7ec..d435ebf 100644
--- a/src/moab/BVHTree.hpp
+++ b/src/moab/BVHTree.hpp
@@ -74,7 +74,8 @@ namespace moab {
          *          the input point
@@ -83,7 +84,8 @@ namespace moab {
-                                     double tol = 0.0,
@@ -97,7 +99,8 @@ namespace moab {
          * \param from_point Point to be located in tree
          * \param result_list Leaves within distance or containing point
          * \param result_dists If non-NULL, will contain distsances to leaves
          * \param result_params If non-NULL, will contain parameters of the point in the ents in leaves_out
          * \param tree_root Start from this tree node (non-NULL) instead of tree root (NULL)
@@ -105,7 +108,8 @@ namespace moab {
       virtual ErrorCode distance_search(const double from_point[3],
-                                        double tol = 0.0,
                                         std::vector<double> *result_dists = NULL,
                                         std::vector<CartVect> *result_params = NULL,
                                         EntityHandle *tree_root = NULL);
@@ -242,10 +246,13 @@ namespace moab {
       ErrorCode find_point(const std::vector<double> &point,
-                           const double tol,
                            std::pair<EntityHandle, CartVect> &result);
-      EntityHandle bruteforce_find(const double *point, const double tol);
+      EntityHandle bruteforce_find(const double *point,
+                                   const double inside_tol = 1.0e-6);
       int local_build_tree(std::vector<Node> &tree_nodes,
                            HandleDataVec::iterator begin,
diff --git a/src/moab/SpatialLocator.hpp b/src/moab/SpatialLocator.hpp
index 780c086..bb639d0 100644
--- a/src/moab/SpatialLocator.hpp
+++ b/src/moab/SpatialLocator.hpp
@@ -62,26 +62,44 @@ namespace moab {
         /* locate a set of vertices, Range variant */
       ErrorCode locate_points(Range &vertices,
                               EntityHandle *ents, double *params, bool *is_inside = NULL,
-                              double rel_tol = 0.0, double abs_tol = 0.0);
+                              const double rel_iter_tol = 1.0e-10, const double abs_iter_tol = 1.0e-10,
         /* locate a set of points */
       ErrorCode locate_points(const double *pos, int num_points,
         /* locate a set of vertices or entity centroids, storing results on TupleList in this class
          * Locate a set of vertices or entity centroids, storing the detailed results in member
          * variable (TupleList) locTable (see comments on locTable for structure of that tuple).
       ErrorCode locate_points(Range &ents,
         /* locate a set of points, storing results on TupleList in this class
          * Locate a set of points, storing the detailed results in member variable (TupleList) locTable
          * (see comments on locTable for structure of that tuple).
+      int local_num_located();
+      int remote_num_located();
 #ifdef USE_MPI
@@ -90,7 +108,8 @@ namespace moab {
          * structure of those tuples).
       ErrorCode par_locate_points(Range &vertices,
@@ -98,7 +117,8 @@ namespace moab {
       ErrorCode par_locate_points(const double *pos, int num_points,
 #endif
         /* return the tree */
@@ -127,14 +147,15 @@ namespace moab {
       const ElemEvaluator *elem_eval() const {return elemEval;}
         /* set elemEval */
-      void elem_eval(ElemEvaluator *eval) {elemEval = eval;}
+      void elem_eval(ElemEvaluator *eval) {elemEval = eval; if (myTree) myTree->set_eval(eval);}
   private:
         /* locate a point */
       ErrorCode locate_point(const double *pos,
                              EntityHandle &ent, double *params, bool *is_inside = NULL,
         /* MOAB instance */
       Interface* mbImpl;
@@ -185,9 +206,10 @@ namespace moab {
-                                                  double rel_tol, double abs_tol)
-      return locate_points(pos, 1, &ent, params, is_inside, rel_tol, abs_tol);
+      return locate_points(pos, 1, &ent, params, is_inside, rel_iter_tol, abs_iter_tol, inside_tol);
diff --git a/src/moab/Tree.hpp b/src/moab/Tree.hpp
index c2a117c..4d2694a 100644
--- a/src/moab/Tree.hpp
+++ b/src/moab/Tree.hpp
@@ -100,7 +100,8 @@ namespace moab {
          *          the input point
@@ -109,7 +110,8 @@ namespace moab {
-                                     double tol = 0.0,
                                      CartVect *params = NULL) = 0;
@@ -123,7 +125,8 @@ namespace moab {
@@ -131,7 +134,8 @@ namespace moab {
-                                        double params_tol = 0.0,
                                         EntityHandle *start_node = NULL) = 0;
diff --git a/test/elem_eval_test.cpp b/test/elem_eval_test.cpp
index 6f07d7a..1e669c3 100644
--- a/test/elem_eval_test.cpp
+++ b/test/elem_eval_test.cpp
@@ -7,6 +7,7 @@
 #include "moab/Core.hpp"
 #include "moab/ReadUtilIface.hpp"
@@ -22,6 +23,7 @@ std::string TestDir(".");
+void test_linear_tri();
@@ -78,11 +80,11 @@ void test_eval(ElemEvaluator &ee, bool test_integrate)
   if (!test_integrate) return;
-    // tag equal to coordinates should integrate to avg position, since volume is 1
+    // tag equal to coordinates should integrate to avg position, test that
   Tag tag;
     // make a temporary tag and set it on vertices to the vertex positions
   rval = ee.get_moab()->tag_get_handle(NULL, 3, MB_TYPE_DOUBLE, tag, MB_TAG_DENSE | MB_TAG_CREAT); CHECK_ERR(rval);
-  rval = ee.get_moab()->tag_set_data(tag, ee.get_vert_handles(), ee.get_num_verts(), hex_verts[0].array()); CHECK_ERR(rval);
+  rval = ee.get_moab()->tag_set_data(tag, ee.get_vert_handles(), ee.get_num_verts(), ee.get_vert_pos()); CHECK_ERR(rval);
@@ -95,8 +97,8 @@ void test_eval(ElemEvaluator &ee, bool test_integrate)
   EvalSet es;
-  rval = (*es.integrateFcn)(&one[0], hex_verts[0].array(), ee.get_num_verts(), ee.get_moab()->dimension_from_handle(eh),
-                            1, NULL, &measure); CHECK_ERR(rval);
+  rval = (*es.integrateFcn)(&one[0], ee.get_vert_pos(), ee.get_num_verts(), ee.get_moab()->dimension_from_handle(eh),
+                            1, ee.get_work_space(), &measure); CHECK_ERR(rval);
@@ -136,6 +138,7 @@ int main()
   int failures = 0;
+//  failures += RUN_TEST(test_linear_tri); currently failing linear tri, bad formulation, working on it...
@@ -144,6 +147,28 @@ int main()
   return failures;
+  Core mb;
+  Range verts;
+  double tri_verts[] = {-1.0, -1.0, -1.0,
+                         1.0, -1.0, -1.0,
+                        -1.0,  1.0, -1.0};
+  ErrorCode rval = mb.create_vertices(tri_verts, 3, verts); CHECK_ERR(rval);
+  EntityHandle tri;
+  rval = mb.create_element(MBTRI, &connect[0], 3, tri); CHECK_ERR(rval);
+  ElemEvaluator ee(&mb, tri, 0);
+  ee.set_eval_set(MBTRI, LinearTri::eval_set());
 void test_linear_quad()
   Core mb;
diff --git a/tools/mbcoupler/Coupler.cpp b/tools/mbcoupler/Coupler.cpp
index 71231b8..0a10d14 100644
--- a/tools/mbcoupler/Coupler.cpp
+++ b/tools/mbcoupler/Coupler.cpp
@@ -614,7 +614,7 @@ ErrorCode Coupler::nat_param(double xyz[3],
   if (epsilon) {
     std::vector<double> dists;
     std::vector<EntityHandle> leaves;
-    result = myTree->distance_search(xyz, epsilon, leaves, 0.0, &dists, NULL, &localRoot);
+    result = myTree->distance_search(xyz, epsilon, leaves, 1.0e-10, 1.0e-6, &dists, NULL, &localRoot);
     if (leaves.empty())
       // not found returns success here, with empty list, just like case with no epsilon
       return MB_SUCCESS;
@@ -631,7 +631,7 @@ ErrorCode Coupler::nat_param(double xyz[3],
   else {
-    result = myTree->point_search(xyz, treeiter, 0.0, NULL, &localRoot);
+    result = myTree->point_search(xyz, treeiter, 1.0e-10, 1.0e-6, NULL, &localRoot);
     if(MB_ENTITY_NOT_FOUND==result) //point is outside of myTree's bounding box
       return MB_SUCCESS;
     else if (MB_SUCCESS != result) {
index 71f3497..421f45c 100644
--- a/tools/mbcoupler/DataCoupler.cpp
@@ -40,7 +40,8 @@ DataCoupler::DataCoupler(Interface *impl,
-        myLocator->elem_eval()->set_eval_set(pit->first);
+        ErrorCode rval = myLocator->elem_eval()->set_eval_set(pit->first);
@@ -61,19 +62,19 @@ DataCoupler::~DataCoupler()
-                                     double rel_eps,
-                                     double abs_eps)
-  return myLocator->locate_points(targ_ents, rel_eps, abs_eps);
+  return myLocator->locate_points(targ_ents, rel_iter_tol, abs_iter_tol, inside_tol);
-                                 double rel_eps,
-                                 double abs_eps)
-  return myLocator->locate_points(xyz, num_points, rel_eps, abs_eps);
+  return myLocator->locate_points(xyz, num_points, rel_iter_tol, abs_iter_tol, inside_tol);
index 3ad1d74..bfe2ba5 100644
--- a/tools/mbcoupler/DataCoupler.hpp
@@ -65,8 +65,9 @@ public:
-     * \param rel_eps Relative tolerance for the non-linear iteration inside a given element
-     * \param abs_eps Absolute tolerance for the non-linear iteration inside a given element
+     * \param rel_iter_tol Relative tolerance for non-linear iteration
+     * \param abs_iter_tol Relative tolerance for non-linear iteration, usually 10^-10 or so
@@ -76,13 +77,15 @@ public:
-                          double rel_eps = 0.0, double abs_eps = 0.0);
@@ -92,8 +95,8 @@ public:
-                          double abs_eps = 0.0);
diff --git a/tools/skin.cpp b/tools/skin.cpp
index 761f7d2..25caa43 100644
--- a/tools/skin.cpp
+++ b/tools/skin.cpp
@@ -525,7 +525,7 @@ ErrorCode merge_duplicate_vertices( Interface& moab, const double epsilon )
     leaves.clear();;
-    rval = tree.distance_search(coords, epsilon, leaves, epsilon);
+    rval = tree.distance_search(coords, epsilon, leaves, epsilon, epsilon);
     Range near;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
