[MOAB-dev] commit/MOAB: danwu: Update metadata_info documents for recently introduced read option NO_MIXED_ELEMENTS.
commits-noreply at bitbucket.org
Wed Oct 9 16:16:18 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/a8d187fb864b/
Changeset: a8d187fb864b
Branch: master
User: danwu
Date: 2013-10-09 23:16:05
Summary: Update metadata_info documents for recently introduced read option NO_MIXED_ELEMENTS.
Affected #: 3 files
diff --git a/doc/MetaData/metadata.h b/doc/MetaData/metadata.h
index d67ca27..9bca8a6 100644
--- a/doc/MetaData/metadata.h
+++ b/doc/MetaData/metadata.h
@@ -208,6 +208,12 @@ to the variable name. Multiple time step values can be specified, separated from
Create a gather set (associated with tag GATHER_SET) on one processor with the specified rank, to duplicate entities on other processors. If the rank is not specified, it will be rank 0 by default. If an invalid rank is passed, no gather set will be created. Gather set is specially used by HOMME, MPAS, and any other unstructured grid.
+<H3>no_mixed_elements </H3>
+Indicates that no mixed elements (e.g. pentagons and hexagons) should be created by the MPAS reader. If this option is used, a common parameter maxEdgesPerCell will be computed to be used across all
+processors (instead of the one reported in the MPAS file header, which is usually 10), and each cell is created with maxEdgesPerCell edges. Any cell that has less actual edges will be padded by duplicating
+the last vertex in the connectivity array. As a result, all created cells will be in one contiguous chunk.
\ref md-contents "Top"
\section meta-references References
diff --git a/doc/metadata_info.doc b/doc/metadata_info.doc
index 6e3eb34..a143f91 100644
Binary files a/doc/metadata_info.doc and b/doc/metadata_info.doc differ
diff --git a/doc/metadata_info.pdf b/doc/metadata_info.pdf
index 376aa51..d86a470 100644
Binary files a/doc/metadata_info.pdf and b/doc/metadata_info.pdf differ
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
