[MOAB-dev] MOAB Build with Open MPI
Tim Tautges tautges at mcs.anl.gov
Tue Sep 24 17:02:02 CDT 2013
Yes, but should be built by default in MOAB (but you do need to define a fortran compiler, if it can't be found
automatically).
- tim
On 09/24/2013 04:55 PM, Saumil Patel wrote:
> I am trying to use CUBIT to generate my meshes (to be later used with the nek5000 code) - will I need to build and
> install iMesh
> On Tue, Sep 24, 2013 at 5:52 PM, Tim Tautges <tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>> wrote:
>     Yep, that's what I use.  You get some warnings from the MPI libs, but the auto tests should all work correctly.
>     - tim
>     On 09/24/2013 04:47 PM, Saumil Patel wrote:
>         Tim,
>         Can MOAB be built with Open MPI?
>         Best,
>         Saumil Patel
>         Ph.D. Candidate
>         The City College of New York
>         Mechanical Engineering Department
>     ==============================__==============================__====
>     "You will keep in perfect peace him whose mind is
>        steadfast, because he trusts in you."               Isaiah 26:3
>                   Tim Tautges            Argonne National Laboratory
>               (tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>)      (telecommuting from UW-Madison)
>       phone (gvoice): (608) 354-1459 <tel:%28608%29%20354-1459>      1500 Engineering Dr.
>                  fax: (608) 263-4499 <tel:%28608%29%20263-4499>      Madison, WI 53706
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
