[MOAB-dev] MOAB Build with Open MPI
    Saumil Patel
    saumil.patel134 at gmail.com
    Tue Sep 24 16:55:04 CDT 2013
I am trying to use CUBIT to generate my meshes (to be later used with the
nek5000 code) - will I need to build and install iMesh
On Tue, Sep 24, 2013 at 5:52 PM, Tim Tautges <tautges at mcs.anl.gov> wrote:
> Yep, that's what I use.  You get some warnings from the MPI libs, but the
> auto tests should all work correctly.
> - tim
> On 09/24/2013 04:47 PM, Saumil Patel wrote:
>> Tim,
>> Can MOAB be built with Open MPI?
>> Best,
>> Saumil Patel
>> Ph.D. Candidate
>> The City College of New York
>> Mechanical Engineering Department
> "You will keep in perfect peace him whose mind is
>   steadfast, because he trusts in you."               Isaiah 26:3
>              Tim Tautges            Argonne National Laboratory
>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130924/7bcedf51/attachment.html>
