[MOAB-dev] MOAB Build with Open MPI
    Saumil Patel
    saumil.patel134 at gmail.com
    Sat Sep 28 14:20:26 CDT 2013
Hi Tim,
I am trying to compile moab with a 'NEK'-based program called NEKLBM using
the gnu compilers.  Below are some errors that I am getting when I try to
compile and link all the libraries....do know what the errors might be a
result of?
 /home/saumilp/fathom/moab/trunk/lib/libiMesh.a(iMesh_MOAB.o): In function
`imesh_newmesh_':
iMesh_MOAB.cpp:(.text+0x7df): undefined reference to
`std::basic_string<char, std::char_traits<char>, std::allocator<char>
>::c_str() const'
iMesh_MOAB.cpp:(.text+0x873): undefined reference to `operator new(unsigned
long)'
iMesh_MOAB.cpp:(.text+0x89c): undefined reference to `operator new(unsigned
long)'
`MPI::Intracomm::Intracomm(ompi_communicator_t*)':
iMesh_MOAB.cpp:(.text._ZN3MPI9IntracommC2EP19ompi_communicator_t[_ZN3MPI9IntracommC5EP19ompi_communicator_t]+0x19):
undefined reference to `MPI::Comm::Comm()'
Thanks for your help,
Saumil
On Tue, Sep 24, 2013 at 6:02 PM, Tim Tautges <tautges at mcs.anl.gov> wrote:
> Yes, but should be built by default in MOAB (but you do need to define a
> fortran compiler, if it can't be found automatically).
> - tim
> On 09/24/2013 04:55 PM, Saumil Patel wrote:
>> I am trying to use CUBIT to generate my meshes (to be later used with the
>> nek5000 code) - will I need to build and
>> install iMesh
>> On Tue, Sep 24, 2013 at 5:52 PM, Tim Tautges <tautges at mcs.anl.gov<mailto:
>> tautges at mcs.anl.gov>> wrote:
>>     Yep, that's what I use.  You get some warnings from the MPI libs, but
>> the auto tests should all work correctly.
>>     - tim
>>     On 09/24/2013 04:47 PM, Saumil Patel wrote:
>>         Tim,
>>         Can MOAB be built with Open MPI?
>>         Best,
>>         Saumil Patel
>>         Ph.D. Candidate
>>         The City College of New York
>>         Mechanical Engineering Department
>>     ==============================**__============================**
>> ==__====
>>     "You will keep in perfect peace him whose mind is
>>        steadfast, because he trusts in you."               Isaiah 26:3
>>                   Tim Tautges            Argonne National Laboratory
>>               (tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>)
>>  (telecommuting from UW-Madison)
>>       phone (gvoice): (608) 354-1459 <tel:%28608%29%20354-1459>
>>  1500 Engineering Dr.
>>                  fax: (608) 263-4499 <tel:%28608%29%20263-4499>
>>  Madison, WI 53706
>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130928/547addb1/attachment.html>
