[MOAB-dev] buildbot failure in moab-cub-par-tru: failed shell test install
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Tue Sep 17 08:07:30 CDT 2013
Yes, I should have removed from buildbot builds this configure option. I will do it today
----- Original Message -----
| If no one is using pointsearch anymore, I vote we scratch this tool
| and its dependencies. They break a lot of tests, have compiler
| warnings, are not a useful API anymore and trigger faults with
| --enable-tools anyway. Now that the new Coupler design is somewhat
| mature, any functionality that this tool provided should be
| alternately available in the new interface.
| Thoughts ?
| Vijay
| On Tue, Sep 17, 2013 at 2:59 AM, < moab-dev at mcs.anl.gov > wrote:
| | Fathom : moab-cub-par-tru build #221
| | Results: 	failed shell test install
| | Buildslave: 	gnep
| | Revision: 	None Log Excerpt
| | /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:384:
| | warning: unused parameter ‘oldtype’
| | warning: unused parameter ‘keyval’
| | warning: unused parameter ‘ex’
| | warning: unused parameter ‘attr_in’
| | warning: unused parameter ‘attr_out’
| | /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:386:
| | warning: unused parameter ‘type’
| | warning: unused parameter ‘attr’
| | /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:388:
| | /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1451:
| | warning: unused parameter ‘oldcomm’
| | /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1453:
| | warning: unused parameter ‘comm’
| | /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1455:
| | /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1884:
| | warning: unused parameter ‘oldwin’
| | /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1886:
| | warning: unused parameter ‘win’
| | /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1888:
| | In file included from point_search.cpp:25:
| | ../src/moab/point_locater/tree/bvh_tree.hpp: In member function
| | ‘typename _Entity_handles::value_type
| | moab::Bvh_tree<_Entity_handles, _Box, _Moab,
| | _Parametrizer>::bruteforce_find(const Vector&, double) const [with
| | Vector = std::vector >, _Entity_handles = moab::Range, _Box =
| | moab::common_tree::Box , _Moab = moab::Core, _Parametrizer =
| | moab::element_utility::Parametrizer]’:
| | ../src/moab/point_locater/point_locater.hpp:139:   instantiated
| | from
| | ‘int moab::Point_search<_Tree,
| | _Boxes>::bruteforce_locate_points(const Points&, Entities&, double)
| | const [with Points = std::vector >, std::allocator > > >, Entities
| | std::vector > >, std::allocator > > > >, _Tree = moab::Bvh_tree ,
| | moab::Core, moab::element_utility::Parametrizer>, _Boxes =
| | std::vector , std::allocator > >]’
| | point_search.cpp:204:   instantiated from here
| | ../src/moab/point_locater/tree/bvh_tree.hpp:728: warning:
| | declaration
| | of ‘Node’ shadows a member of 'this'
| | In file included from point_search.cpp:26:
| | ../src/moab/point_locater/parametrizer.hpp: In member function
| | ‘std::pair moab::element_utility::Parametrizer::operator()(Moab&,
| | const Entity_handle&, const Point&) [with Moab = moab::Core,
| | Entity_handle = long unsigned int, Point = std::vector >]’:
| | ../src/moab/point_locater/tree/bvh_tree.hpp:739:   instantiated
| | from
| | from
| | ../src/moab/point_locater/parametrizer.hpp:76: error: ‘hex_map’ was
| | not declared in this scope
| | ../src/moab/point_locater/parametrizer.hpp:79: error: ‘tet_map’ was
| | ../src/moab/point_locater/parametrizer.hpp:84: error:
| | ‘quadratic_hex_map’ was not declared in this scope
| | ../src/moab/point_locater/parametrizer.hpp:87: error:
| | ‘spectral_hex_map’ was not declared in this scope
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130917/aa6ecbe5/attachment-0001.html>
